Activation code or service domain CP-8841
Felo-WF
After resetting the phone, it asks for an activation code or service domain.
From what I found out, I need a cfg.xml file but unfortunately I don't have anything like that. The phone is connected directly to the cisco switch. Where can I find such a sample cfg file or some standard one?
And I just wanted to update the software
Thank you for your help
10 Replies 10
b.winter
If you wanna register them to CUCM, then search the forum for old post.
This topic has been asked so many times here.
Felo-WF
I've already read that, but I don't have CUCM.
But you added a tag "CUCM" ^^
Which PBX do you have?
Felo-WF
I don't have any PBX.
I would like to upload configuration files via tFTP
Sorry for the incorrect tag
What you mean, you don't have any PBX?
Without a PBX, the phone is useless ...
If you don’t have any PBX, let’s explore what you intend to do with this phone. Here are some considerations based on the context:
  1. Call Control Platform:
    • Your phone needs to be registered with a call control platform. This could be either:
      • On-premises: Such as Cisco Unified Communications Manager (CUCM).
      • Cloud-based: Like Cisco Webex Calling.
      • Third-party: If you’re using a non-Cisco solution.
  2. MPP Model:
    • If you plan to use it with a third-party call control platform, you’ll need an MPP (Multiplatform Phone) model.
    • Alternatively, if you have an enterprise phone model, you can convert its firmware to MPP.
  3. Share Details:
    • To assist you further, please provide more details about your specific use case or requirements for this device.
Response Signature
Felo-WF
I wanted to configure the phone for VoIP (SIP) calls
And how do you want to make VoIP calls without a PBX?! --> I'll answer it for you: it doesn't
Maybe you should first learn, how VoIP works ...
Pretty harsh.  Your replies do not add value.
Felo-WF
Of course you're right But my status is "Beginner"
My internet service provider has a virtual PBX.
Currently, I am stuck with updating the software due to lack of activation, hence my questions.
Thanks a lot for your help
