Add DNs using CUCM 11.x BAT
pobrien
I'm looking for a way to add DNs, and DNs only, using the BAT in CUCM 11.x. I have about 100 I need to Forward All and I think BAT would help save some time.
I have a CSV of phone exports, and I've grabbed the headers for the DN, Partition, Description, Alerting Name, etc. however when I import using BAT > Phones > Add/Update Lines > Add Lines, and import my CSV, I get a failure on PARTITION is not a supported field.
So I'm not doing something right. Can anyone suggest how to add DNs (and DNs only - no phone associated with it) with a FORWARD ALL DESTINATION 1 CUCM 11?
Thanks!
Thanks. I ended up importing CTI RP's for this CF task.
Dennis Mink
I checked BAT and there is no way to add only DN. i.e. not tied to a MAC or UDP
Please remember to rate useful posts, by clicking on the stars below.
Jaime Valencia
If all you need is to CFA from a DN you can do that with a TP
java
if this helps, please rate
