Add new subscriber server
islam.irshaid
Dear Experts,
We have One CCM (7825I2) Server is working as a publisher , the software version is 5.1.1.3000-5 , now we need to add new subscriber server but when I tried to add it, I faced a problem that there is no connectivity between it and with the first node.
But I am sure that ,the connectivity is up and no problem belong to the connectivity issue.
Is there any problem, If the software version is different between the first node and the new server ,since we have a diff ver on sub server?
Brandon Buffin
Did you define the new server on the first node by going to System > Server > Add New?
Brandon
Dear Brandon,
Yes i added the new server on the first name ,IP and mac address
are you plugging all to the primary NIC of the server?
is the default GW reachable?
are you assigning static IP parameters?
javalenc
if this helps, please rate
java
just read the last part of your post:
"Is there any problem, If the software version is different between the first node and the new server ,since we have a diff ver on sub server? "
YES THERE IS, they need to be the same version for this to work. during the install you get the option to install an SR or en ES, during this phase you need to apply the proper patch for both servers to have the same version
javalenc
java
