adding 2nd PRI in the H323 gateway - help..
shabeebmohammed
Dear All,
This is my scenario,
We have CUCM 6 installed and running smoothly since last 3 years or so. They have 1 PRI line (100 number block) in the range YYYYY1XX. (everything is working perfectly).. Now they add another 2nd PRI line (100 number block) to this setup, YYYYY6XX.
The configurations is as below -
CUCM
RP, RL, RG, Partition and CSS all configured properly pointing to the H323 Gateway.
H323 VGW
dial-peer voice 20 pots              ----------------------------> 1st PRI dial-peer
destination-pattern [0-9]T
fax rate disable
direct-inward-dial
port 0/0/0:15
forward-digits all
dial-peer voice 30 pots               ----------------------------> 2nd PRI dial-peer
preference 1
fax rate disable
direct-inward-dial
port 0/1/0:15
forward-digits all
dial-peer voice 50 voip
destination-pattern [16]..
modem passthrough nse codec g711ulaw
session target ipv4:10.10.10.10
incoming called-number .
dtmf-relay h245-alphanumeric
codec g711ulaw
fax rate disable
no vad
The Problem:
I have configured 2 phones (testing purposes) - numbers are 150 & 650 -
Incoming Call to 150 - OK
Incoming Call to 650 - OK
Outgoing Call from 150 - the destination phone displays sometimes YYYYY150 and the other times YYYYY600 (pilot number of 2nd PRI)
Outgoing Call from 650 - the destination phone displays sometimes  YYYYY650 and the other times YYYYY100 (pilot number of 1st PRI)
This means that if the first dial-peer is busy, it goes through the second dial-peer.. (thats how i have configured it rite now)
What has to be done so that the respective calls go through the respective PRI lines, and eventually the destination phone displays the correct calling number all the time??
Waiting for your responses.
Thanks a lot
Shabeeb Mohammed
5 Replies 5
venparaj
Is both the lines are connected to the same office or in any branch offices? If both of them are connected to the same office, ask them to bundle the new pri line to the existing number group itself. so no caller id problem will not be there. otherwise as for my understanding the TSP will send the pilot number as a caller id if the calling number is not in the same number group range.
Venkatesan A.
The line are connected in the same office. and its in  the same VGW, just 2 different ports.. Im pushing the client to talk to  the TSP and bundeling the blocks. I wanted to know a workaround for this  scenario without talking to the TSP.
Please let me know if its possible..
Shabeeb Mohammed
Arun Thomas
Use translation rules on the voice port
voice translation-rule 1
rule 1 /^YYYYY6\(..$\)/ /1\1/ -- on the fisrt PRI voice port (Where DID is YYYYY100)
rule 1 /^YYYYY1\(..$\)/ /6\1/ -- on the second PRI voice port (Where DID is YYYYY600)
assuming you're supposed to send last 3 digits to telco for the callerID
Also its possible to match the calling number using an answer-address on dial peer and apply translation rule
to select specific PRI
Sharon Tom
recive the call on specific incoming dial-peer using answer address
eg
dial-peer voice 1 voip
answer address .....1..
dial-peer voice 2 voip
answer address .....6..
and then apply cor on the dial-peers to select the outgoing dial-peer
fax rate disable
direct-inward-dial
port 0/0/0:15
forward-digits all
preference 1
fax rate disable
direct-inward-dial
port 0/1/0:15
forward-digits all
Arun Thomas
If both the PRI's are from the same Telco, you may need to request them to allow DID sharing over the 2 PRI's
If not, then i think its better to route the calls via pecific PRI. Configs as follows
dial peer voice 100 voip
answer−address 1XX -- should match the DN configured on Ipphone
translation−profile incoming PRI1
dial peer voice 200 voip
answer−address 6XX
translation−profile incoming PRI2
voice translation−rule 1
rule 1 /^9/ /19/               < ------- assuming the PTSN access code is 9, if you're using discard digits on CCM - change it to none
voice translation−rule 2
rule 1 /^9/ /29/
voice translation−profile PRI1
translate called 1
voice translation−profile PRI2
translate called 2
Change the destination-pattern on outgoing dial peer
to 19T & 29T
