01-16-2015 01:35 AM - edited 03-17-2019 01:36 AM
I have just connected a 2nd wic card in our 2821 for an additional 5 isdn 30 channels. I have gone through the config in the router and I am trying to work out the commands required to use the additional lines.
Solved! Go to Solution.
01-16-2015 03:41 AM
In addition to what is said by AOK[+5], you need to configure
a. card type e1 0 0 [check the slot]
b. framing under controller E1 0/0/0[check in your case]
c. pri-group timeslots 1-31
d. no shutdown
regds,
aman
01-16-2015 04:27 AM
And probably network-clock-participate & network-clock-select commands too.
The exact details will vary depending on the gateway protocol you're using (MGCP, H323, SIP, etc)
GTG
01-16-2015 03:03 AM
That depends on what type of vwic card it is. If its a mft-e1-t1 card, you will need to first of all specify the card type before you can even begin to configure it
01-16-2015 03:41 AM
d. no shutdown
regds,
aman
01-16-2015 04:27 AM
GTG
01-16-2015 04:28 AM
Ooh, watch out. The original poster said they wanted to use 5 channels...
GTG
01-16-2015 04:30 AM
my mistake..
thanks for correcting me.
regds,
aman
