Adding directory numbers from Active Directory users doesn't work
Kai Onken
When I press "Full Sync" at LDAP Directory all user including  firstname, givenname, telephone number, will be added correctly to the  "End users", but the
telephone number is not added to the "Directory numbers".
Has anybody an idea why?
Kind regades
Kai
10 Replies 10
Chris Deren
In your directory synchronization which attribute are you using for telephone number, you can either use telephoneNumber ot ipPhone attribute, make sure you are using the one you desire.
HTH,
Chris
avinsrid
Telephonenumber field is not added as a directory number. It will appear on the telephone number field of imported end user.
Regards, Avinash
currently I use telephoneNumber, but I haven't tried ipphone yet. So, will the number be added when I use ipphone?
Kind regards
Kai
Which field is populated in AD with the actaul phone number?
Which one do you want to use?
Which one is selected on the integration?
Chris
Hello Chris,
currently is this configured:
--> telephoneNumber
--> I want to use the telephoneNumber filed
--> telephoneNumber = telephoneNumber
But I doen't work...And I've no idea why...
Kind regards
Kai
Kai,
Whatever you do, when we import the field from AD, I believe this will never get associated automatically with a phone's DN.
Regards, Avinash
Hello Avinash,
thank for your replay, but I can't belive, that I've to add e.g. for our company 10000 DN's by hand.
Kind regards
Kai
Sure the telephoneNumber is suppose to be pulled from AD, you should not be doing anything manually, in fact you cannot as the fileld is read only.  You need to look at your Dirsync logs for clues. I have done the exact same integrations many times and never ran into and issue, perhaps you can post your integration details, sample user config in AD and how the user is defined as end user.
HTH,
Chris
Hello Chris,
I checked everything an I wasn't able to find anything. I've setup a second CUCM and a second AD in a lab enviroment and there I've excatly the same problem... I don't know why. When I've a look at my sync End User I can see the DN, which I've assigned at the AD, but I can't find it in Directory Numbers....
That's so confusing....
Kind regards
Kai
Kai,
Cisco provides BAT tool to implement this functionality with ease
Avinash
Regards, Avinash
