Adding Line Group using Bulk Admin Tool
mightyking
Level 6
Level 6
Hello Experts,
I am trying to add some line groupes using Bulk admin tool. This is what I do:
1) I export the line groupe and all dependencies using import/export tool.
2) I untar the tar file and use the linegroup csv file
3) I add line groupe in the csv file and uploade to Bulk admin adn select Importer/Exporter as the target.
4) I do a validation before importing the file and receive the follwoing error message.
Validate Configuration Items
Begin Time : 12/05/2024 09:50:55
Failure Details :
FileName Error Code Error Description
Record Number 1 Record does not match the fileformat selected
Result Summary :
VALIDATE for 0 Records passed.
VALIDATE for 1 Records failed.
End Time : 12/05/2024 09:50:55
Am I doing anything wrong?
MK
28 Replies 28
The last shared csv file comes from an export of the line groupe from CUCM 12.5 and includes all the modifications provided by you guys.
MK
Try with this.
You had the line wrongly formatted. There is a semi-colon after "Try next member" and before the "next".
10,LG_PDC_CIGC_GAT,Broadcast,"Try next member; then, try next group in Hunt List","Try next member; then, try next group in Hunt List","Try next member; then, try next group in Hunt List",f,14,56049,ptInternal,25,56060,ptInternal,20,56055,ptInternal,10,56045,ptInternal,6,56041,ptInternal,13,56048,ptInternal,22,56057,ptInternal,17,56052,ptInternal,0,56031,ptInternal,23,56058,ptInternal,3,56034,ptInternal,19,56054,ptInternal,7,56042,ptInternal,1,56032,ptInternal,9,56044,ptInternal,15,56050,ptInternal,2,56033,ptInternal,12,56047,ptInternal,8,56043,ptInternal,5,56040,ptInternal,18,56053,ptInternal,11,56046,ptInternal,16,56051,ptInternal,24,56059,ptInternal,4,56035,ptInternal,21,56056,ptInternal
Response Signature
Thank you Roger for your help. The import seems to be successful, but the final result is an error. I am attaching the file I am using with the corrections you indicated.
As you can see the semi colon (;) is included in the CUCM config page.
The file does not seem to have the semi-colon in the 3 fields where it should be.
Response Signature
Sorry sent you the wrong csv file. This is the one I used and received the below error message.
There are errors in the file. Look at it from position 19 and forward.
Response Signature
Those 3 fields should be "Try next member; then, try next group in Hunt List", with the double quotes and semi-colon between member and then.
Response Signature
This is file I just used and below is the error message I receive.
Remove the empty columns from position 25.
Response Signature
Thank you Roger, It worked.
You are the best!
MK
Glad it worked for you. Please consider giving Helpful votes to answers you feel merit this as that's how we're measured in the Community standings.
Response Signature
I did accept your replies as solution and clicked on Helpful. Is that enough?
You gave helpful vote to one of my many responses and I thank you for that, but IMHO you could have given that to more than just one. It’s not a necessity, but a nice way of showing appreciation for the work people do in the community on their own time.
Response Signature
