Adding Line Group using Bulk Admin Tool
mightyking
Level 6
Level 6
Hello Experts,
I am trying to add some line groupes using Bulk admin tool. This is what I do:
1) I export the line groupe and all dependencies using import/export tool.
2) I untar the tar file and use the linegroup csv file
3) I add line groupe in the csv file and uploade to Bulk admin adn select Importer/Exporter as the target.
4) I do a validation before importing the file and receive the follwoing error message.
Validate Configuration Items
Begin Time : 12/05/2024 09:50:55
Failure Details :
FileName Error Code Error Description
Record Number 1 Record does not match the fileformat selected
Result Summary :
VALIDATE for 0 Records passed.
VALIDATE for 1 Records failed.
End Time : 12/05/2024 09:50:55
Am I doing anything wrong?
MK
Remove the empty columns from position 25.
Response Signature
28 Replies 28
It’s easier for us to help you if you post your update file.
Response Signature
Hi Roger,
Here's a test file I am trying to use in order to add line groupes.
MK
In the first file I sent I inter changed the name and RNA REVERSION TIMEOUT to see if that could make a diffrence but the reslut was the same.  The attached file is the one I downloaded using the export tool to export line groupes.
MK
Il looks like the export from 11.5 would work with 12.5. I would appreciate If someone could provide me with an export of line group from version 11.5.
MK
Based on experience from other imports I believe that this could be caused by that there are empty "columns" in  the CSV file.
Try with this file where only columns where you have data is left in.
Response Signature
Hi Roger,
Thank you for taking the time and replying.
The validation pass
But the import fails. I am using CUCM System version: 12.5.1.18901-1
Import Configuration
Begin Time : 12/05/2024 08:24:27
Query :
IMPORT LINEGROUP IN linegroup.csv
Failure Details :
linegroup Error Code Error Description
LG_PDC_CIGC_GAT java.sql.SQLException
Result Summary :
IMPORT for 0 Line Group passed.
IMPORT for 1 Line Group failed.
End Time : 12/05/2024 08:24:27
MK
Now I am receving the following error message:
rna reversion timeout is not a supported field.
but the Job Scheduler shows the following:
Upon verifying your files, I see that you haven't provided the correct information. For line selection 1, you have selected "then" DN partitions. Please try the next group, etc.
The CSV file  below is exported from the lab compare it.
Response Signature
HI Nithin,
I am not seeing any csv file attached to your reply.
MK
I modified the csv file as you suggested but receiving the following error message:
Begin Time : 12/09/2024 10:14:25
Query :
Failure Details :
The attached is the new csv file I used
MK
This is the error message I receive:
And this is the csv file I am using.
Please note that I am using the exact same export file from CUCM.
Do you guys have CUCM version 12.5? If so, could you please try to insert a line group and send me the working csv file.
MK
I don’t, we’re on version 15. Have you shared an untouched file with us? If so we can help you, but not if you try to adopt the file to fix any errors you encounter before sharing the file with us.
Response Signature
