08-12-2014 09:52 PM - edited 03-16-2019 11:43 PM
As per a customer request he want to add a new Site to the existing cluster replacing the existing avaya Pbx will be having new did what all changes we have to make in call manager and new gateway customer is having all the proper license with him.
1.Call manager add new phones around 50
2.Adding new gateway
3.Creating a new dialplan in call manager
4.Gateway should be h323 and it should have cme-srst
Correct me if anything more required
08-12-2014 11:13 PM
To add to the above:
Add Route Group, Route list, Route patterns on CUCM.
Add incoming / outgoing dial-peers on gateway and other h323 config like srcaddr
Depending on how many digits you recieve in the called number field on the gateway from PSTN, you may need to change the significant digits field on the gateway page on cucm or do it on the gateway itself.
Manish
08-12-2014 11:38 PM
In addition to what Mansih[+5] has said,u can refer the links for H.323 configs
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/13934-config-h323-ccm.html
https://supportforums.cisco.com/document/99806/adding-h323-gateway
regds,
aman
