04-30-2015 02:24 AM - edited 03-17-2019 02:51 AM
Dears,
I have CUCM 9.1.2 I deleted phone and when I tried to add the same phone I got this message (Add failed. Already exist in the data base).
Any suggestions please
04-30-2015 03:12 AM
You probably have auto-registration enabled; it will have re-added itself to CUCM when it attempts to register in between you deleting the phone, and re-adding it.
I would either:
- Disable auto-reg (on your System/Cisco Unified CM) page
- Find and edit the auto-registered device rather that adding a new one
Aaron
05-01-2015 01:14 AM
The issue that I can't find the device itself in the CUCM.
By the way my device is a third party so when I'm trying to add it I got the mentioned message.
05-01-2015 01:23 AM
Hi Ali,
Can u go through this DOC and run SQL query if it helps for 3rd party phones.
regds,
aman
