adding, resetting a sip trunk
iptuser55
Level 6
Level 6
I would like to add a new sip trunk - "test" to an existing SIP GW for testing. The GW already has some production SIP Trunks connected but I need to create a new one to testing some settings which would involve resetting it
The existing SIP trunks are already in their own RL, RG and so this new one would be in a dedicated RL,RG by itself with dedicated Route points relating to it
Question If I reset the "test" sip trunk which is on it`s own  RL,RG which Ive just created, would it reset the production ones since they all point to the new same GW?  or be ok ?
thanks
Ayodeji Okanlawon
First of all, to add a new sip trunk to an existing gateway (already using sip trunk) you will either need to use a different port number for SIP or use a different IP address on the gateway.
Secondly, No it will not reset the existing sip trunk. They are different from the application point
Please rate all useful posts
Thanks, Can the port be any number bearing in mind any firewall issues? ?- Any special configuration on the GW if I use a different port other then 5060?
I would say use next 5061 as non secure as this is commonly used and i have one set up in my lab .
5060- unsecure; 5061- with TLS is the default.
Generally you wouldn't steer away from standards.
As per Deepak's comment, CUCM will then use 5061 to CUBE/GW. In order to achieve similar behaviour from CUBE to CUCM, I believe on dial-peers pointing to CUCM you define port 5061 along with IP address & change SIP trunk security profile to accept messages on 5061.
