alerting name
kp-tkr2014
I have sip trunk , for incoming calls how can I show the alerting name instead of numbers
Mike_Brezicky
Is telco sending the CNAME in the SIP INVITE headers?
Its not telco , it s different site connected using sip trunk from cucm . But they are using non cisco product , How to check i about CNAMe in cucm.?
What if I add their name and the number in CUCM ?
The originating system must transmit the calling name information with the call setup information for it to be displayed on the CUCM-registered called endpoint. If this is a SIP Trunk ensure that the two products are configured to use the same header, typically P-Asserted-Identity.
