07-13-2011 10:25 PM - edited 03-16-2019 05:56 AM
I'm willing to get get the call log from amc performance log.
I want to get logs for a month, but they are held 9 days only, former logs are not shown.
How can I get longer the logs to be collected?
Thanks in advance,
Yasuyuki Hirasawa
Solved! Go to Solution.
07-17-2011 06:10 AM
You can try increase the 'Maximum Number of Files' and 'Maximum File Size' values under 'Trace Output Settings'. Default value is 120 files and 1 MB Size.
Please note that increasing these values would increase the hard disk usage.
Hard disk space required (in MB) = Max no. of Number of files * Max File Size (in MB).
Alternatively you can use scheduled trace collection options in RTMT and save it in remote system.
https://supportforums.cisco.com/docs/DOC-8130
Hope this helps.
Vinay
07-17-2011 06:10 AM
Hope this helps.
Vinay
08-03-2011 07:06 PM
Sorry for my late reply.
Thanks a lot for your advise.
I've changed this parameter.
Yasuyuki Hirasawa
