02-11-2008 05:03 AM - edited 03-15-2019 08:44 AM
Hi all.
We need to configure CCM (4.1), as it response to inbound calls to our principal number (where there is the attendant console) with a registered message, since operator take the call.
I think that this is the annunciator feature, but I can't make it work.
I've configured a Device Pool, a Media Resource Group and Group List, but it doesn't work.
Any suggestion?
Daniele
Solved! Go to Solution.
04-07-2008 11:01 PM
Hi mowuor,
Just a question, is a gateway able to play the annunciator prompt to a external pstn caller?
Thanks.
04-21-2008 11:23 AM
I am not sure, but can we add a route pattern into a partition visible to the gateway css. Have that route pattern block and a message played.
