IP Telephony and Phones
Labels
I will be installing a UC520 with a PRI for the first time. Previously I have only worked with analog/FXO ports. I have two questions:1) How much different is working with PRI than FXO?2) My main concern is outgoing caller ID. Of all the DIDs only ...
tato386 by Level 6
  • 474 Views
  • 3 replies
I've heard that there will be no further Windows versions after 4.3. I know that 7 was supposed to have it, but that was dropped. But I hadn't appreciated it was completely out of future development. I just wanted to check what others have heard as I...
billybjo1 by Level 3
  • 572 Views
  • 6 replies
I have the following scenarioLAN -- 2651--WAN--3845--LANI would like to set some QOS policing ont he 3845 at the reote site for traffic coming from remote site. I have tried to set a nested policy-map with a police and have recieved an error say not ...
paulhardy by Level 1
  • 774 Views
  • 1 replies
There is a recommended min. 150 RTD for voice but is there a min. for call control. I`m thinking of deploying SRST cluster but only send Call Control across the Link with local telco traffic via a local T1- Th elink back to teh central system has lon...
iptuser55 by Level 6
  • 587 Views
  • 3 replies
Could someone please sanity check this basic QoS design before my brain explodes:IP Phone -- 3750 -- 4500 -- WAN rtr (MPLS Cloud) -- WAN rtr -- 4500 -- 3750Basically I would like to implement a full end to end QoS policy using the Trusted Endpoint mo...
Hi,My customer is having an IP link to make international VoIP calls. The codec used in these trunk is G.729. But the problem is that the other end gateway will accept G.729 calls only with a payload of 30. By default the payload size for G.729 in C...
