Are all the phone firmware needed for CME
ReadersUK
Level 2
Level 2
Hi CME experts
I'm running out of space on my flash memory and wondered if all the telephone firmware files you get in a download are needed. For example im installing a 8841 on a CME 10.5 and there are 14 files in the download. I know i need the "sip88xx.12-1-1-12.loads" file but do i need any others for it to work?
regards
R0g22
Yes, you do need all the files that are part of the firmware package. The .loads is just what you reference and this file contains an archive of all the files files in the package.
Free up firmware/audio files/IOS that you do not need or increase the flash. Alternatively you can use an external TFTP server as well.
R0g22
Thanks I appreciate the quick reply
regards
colin
