IP Telephony and Phones
Labels
Whenever I attempt to run Cisco IP Communicator 8.6.6  it has had a more than 50% chance to simply crash and give Blue Screen of Death   It gives APC_INDEX_MISMATCH as the bug check string.   This occurs whether it is the first program opened after r...
darkkuno by Level 1
  • 822 Views
  • 2 replies
Hi, Need a little help with a route pattern if I may.   Some info: CUCM 11.5.1 No transaltion patterns All patterns below are in the same partition   We have the following route pattern for calls when dialing full 10 digits with area codes 02, 03, 07...
jcopley01 by Level 1
  • 653 Views
  • 7 replies
Hello everyone,I am new to this forum and I have an issue with calling analog phones which have been configured using MGCP. I have a 2621XM router with voice enabled ios 12.4. my cisco ip phones have been connected using 2950 series switch which is c...
niyazabawa by Level 1
  • 3943 Views
  • 11 replies
Resolved! CME Debugging
Hello, I am having CME 11.5 on router 2911  when I write any debug command to examine a call ,it says that the debug is on but there is nothing appear although the call is operating and changes occur  What shall I do ?
