Ask the Expert: Configuring and Troubleshooting Faxing in Cisco IP Voice Networks
ciscomoderator
Community Manager
Community Manager
Read the bioWith Edson Pineiro
Welcome to the Cisco Support Community Ask the Expert conversation. This is an opportunity to learn best practices and tech tips from Cisco expert Edson Pineiro on the common and complex  issues with faxing in Cisco IP voice networks. Cisco fax networks run on top of signalling protocols such as fax T.38, T.37, pass-through, NSE based modem passthrough and the underlying fax T.30 protocol with different modulation types. You can ask any questions on how Cisco Fax networks interact with any of the signalling protocols mentioned before.
Edson Pineiro is a senior customer support engineer in the  Cisco Technical Assistance Center in Sydney. His current role includes  configuring, troubleshooting, and designing gateways, gatekeepers, Cisco Unified Border Element Enterprise Edition, and Cisco Unified Call Manager using  his deep knowledge of signaling protocols such as SIP, H.323, MGCP, SKINNY, and  others. He has been involved in several bug fixes, escalations, and critical  account cases from around the globe. He has over seven years of experience in  the IP voice industry.
Remember to use the rating system to let Edson know if you have received an adequate response.
Edson might not be able to answer each question due to the volume expected during this event. Remember that you can continue the conversation on the Collaboration, Voice and Video sub-community forum shortly after the event. This event lasts through Nov 16, 2012. Visit this forum often to view responses to your questions and the questions of other community members.
43 Replies 43
Hello Chris,
     Thank you for the feedback and for posting your question. With regards to SIP trunk integration with CUBE SIP providers, my suggestion would be to verify if they support standard RFC based T.38, please see it referenced below. Also since nse based modem passthrough is a Cisco proprietary protocol it won't work with 3rd party vendors such as your SIP carrier. As for fax protocol based pass-through it is using a Cisco pre-standard which in certain scenarios will cause issues with 3rd party vendors and certain signalling protocols. T.38 provides better stability and reliability when integrated with most protocols including your carriers SIP trunk if they support it, otherwise if there is no fax protocol negotiated the fax will simply send the fax tones using a normal voice call which may or may not work depending on the certain circumstance.
     To keep fax configuration simple, maintainable may I suggest using one fax protocol globally on your cluster as a mix of two or more may result in intermittent fax failures. Given the limited options with integrating 3rd party devices T.38 most likely what will be supported by other vendors. Saying the above you need to choose devices and signalling protocols which support fax protocol T.38 on your network.
     Two limitation, firstly SCCP controlled FXS ports do not support protocol based fax protocols such as protocol based fax pass-through and protocol based T.38.  Thankfully though IOS gateways such as the vg224, can be configured with multiple voice protocols. For example you can leave your analogue handsets running SCCP for supplementary services such as hold, transfer etc and since MGCP supports t.38 my suggestion would be to move the FXS ports on the vg224 that are only connected to fax machines on to the MGCP protocol. Secondly MGCP gateways do not support fax protocol based pass-through and so this narrows the option to only fax protocol T.38.
     The configuration would be simply disabling Cisco Fax protocol, and all other fax and modem protocols and only leaving t.38 on the UCM, the vg224, the gateway and the cube. Please find the following sample mgcp and sip fax t38 configuration.
!#### CUBE global fax configuration
voice service voip
fax protocol t38 nse version 0 ls-redundancy 0 hs-redundancy 0 fallback none
no modem passthrough nse codec g711alaw
!### CUBE SIP dial-peer
dial-peer voice x voip
fax-relay ecm disable
fax rate 14400
fax nsf 000000
!#### VG224/gateway mgcp configuration
no ccm-manager fax protocol cisco
no ccm-manager config
MGCP
mgcp package-capability fxr-package
no mgcp fax t38 inhibit
mgcp fax rate 14400
mgcp fax t38 nsf 000000
     The above sample configuration should take of most issues such as ECM, Speed and NSF. However at times the ECM, Speed and NSF values need to be adjusted on the physical fax machine, this why I recommend to disable ECM and speed to 14400 on the actual fax itself.  To explain the NSF values, they are basically the fax machines manufacturers code, and if both fax machines negotiate the same manufacturers code they will send embedded proprietary T30 signals that are not supported and cause intermittent issues.
     For your reference please review the following documents for commands references and the t.38 standard:
Fax Relay Troubleshooting Guide
http://www.cisco.com/en/US/tech/tk652/tk777/technologies_tech_note09186a0080114565.shtml#topic2-3
Configuring T.38 Fax Relay
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/cisco_ios_fax_services_over_ip_application_guide/t38.html#wp1156988
SIP Support for Real-time Fax Call Flow Example and  Best Current Practices
http://tools.ietf.org/html/draft-ietf-sipping-realtimefax-01
Please let me know if you have any further questions.
Thank you
Edson Pineiro
CISCO
Hi Edson,
thank you very much for your great help! I have changed our VG224 from SCCP to MGCP to do only T.38 and it works perfect in all scenarios (isdn and sip trunks to provider). Because we have no analog phones connected to vg224, wich need supplemental services, we don't need SCCP and MGCP at the vg224. So I have configured CA-controlled MGCP at vg224 and now configuration of new ports is easy as SCCP before, because the dial-peers will be configured automatically from callmanager, when the new pots ports is configured in callmanager. So there is no need to work at vg224-console in normal business.
Regards, Chris
PS: Im sorry, but I want to rate your post with 5 stars but I had clicked wrong to only 3 and I cannot revote... :-( sooorry.
Hello Christian,
     I really appreciate your feedback, it's always good to know the outcome of my suggestions. I'm glad the fax is working for you, in all scenarios.
     The most important recommendation for anyone doing fax over IP, is to choose one fax protocol and design the complete cluster using only the selected fax protocol ensuring all end devices support it. An optional addition to the above point would be to disable SG3 and ECM, as this fixes most of those intermittent fax failures.
     If anyone has any further questions, please do not hesitate to post me a note on this forum.
Thank you
Edson Pineiro
CISCO
In regards to the fax onramp tcl script, are there capacity/volume limitations?  I realize that it'll vary between isr platforms, but even general details or real world usage examples will be helpful.  Also, what are some good troubleshooting commands?  Is there a way to see the number of current sessions -- maybe active and history?  Just viewing the call active/history won't single it out as we have other faxing traversing our voice gateways.  Any info is welcome.
thanks,
will
Hi Edson,
I'm facing an issue with our new ATA 187. We have recentely deployed 2 new ATA 187, when I send fax internal between 2 fax machines that are conncted via ATA it works!!!
But
when I try
FAX-MACHINE-->ATA 187--->CUCM--->SIPGW-->PSTN-->FAX-MACHINE
or vise versa it doesnt work.
And the ATA 187 is using T38 Fax Relay
And the Sip Gateway is configured:
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
allow-connections sip to sip
dial-peer voice 1123 voip
translation-profile outgoing Calls
destination-pattern 9.T
session protocol sipv2
session target ipv4:X.X..XX
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
no vad
Is their any fix for this.
mohsin majeed
Level 2
Level 2
Its my first to configure fax in any voip network even working since 2 years. Consider two scenarios. I have
Sip trunk from ITSP connected with 2921 Router, cucm version 8.x. Internal extension are replaced in DIDs using rules on the GW.
Scenario 1:
SIP(ITSP)-->GW(UBE)-->h323/SIP-->CUCM-->GW-->FXS-->Faxmachine
Scenario 2:
SIP(ITSP)-->GW(UBE)-->CME-->FXS-->Faxmachine
My fax machine will be directly connecting with FXS card. Please help me with step by step config as i never cofigured fax before
Thanks in Advane
vinothsankar
Hi Edson,
We are using Third Party FAX server (FAX CORE) in our setup.
Components:
CUCM 9.0
Cisco Voice Gateway (CUBE) - CISCO 2821
IOS - c2800nm-spservicesk9-mz.151-4.M6.bin
IP FAX Core Server (Third Party FAX Server)
Inbound Fax Call Flow
PSTN—SIP—CUBE—SIP Trunk—CUCM—SIP Trunk—IP FAX server
Outbound Fax Call Flow
IP FAX server—SIP Trunk—CUCM—H.323 Gateway Trunk—CUBE(VG)—PSTN
We are using G711ulaw for both inbound and outbound fax calls.
Problem:
Both Inbound and Outbound fax calls are not working.
Incoming Fax call are landing to fax server and call got disconnected with following error.
SIP/2.0 488 Not Acceptable Media
Wire shark Flow Diagram from FAX server:
10.0.106.14 - CUCM
10.0.103.222 - FAX Server
10.0.106.6 - Gateway(CUBE)
Wire shark Flow Diagram for Inbound FAX call
In Outbound FAX calls, calls were answered by destination fax machine but fax message is not receiving by fax machine.
I have attached the wire shark logs which is taken from FAX server (logs only for Inbound FAX call).
Please let me know if you required any other information from our end.
Kindly help me to solve this issue.
Did you ever resolve this issue? I have a very similar issue and am unable to resolve it. Any information you have on this would be great.
Thank you!
This issue solved for me.
Our service provider do not support t38 protocol for FAX calls.
I am using 'pass-through g711ulaw' instead of t38.
Failure Call logs which was generating when t38 protocol not support by Service Provider.
Inbound FAX from PSTN to CUCM:
Call details:
Calling Number: 0112790986
Called Number: 2188787
CUBE sends a re-invite with T.38 Capabilities to the ITSP
Sent:
INVITE sip:112790986@10.200.7.157:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 172.29.26.106:5060;branch=z9hG4bKE5FC2213
Remote-Party-ID: <sip:8787@172.29.26.106>;party=calling;screen=no;privacy=off
From: <sip:2188787@172.29.26.106;user=phone>;tag=19ABCCA4-B5
To: <sip:112790986@172.29.26.106;user=phone>;tag=sbc0804ectp2bs4-CC-31
Date: Wed, 06 Aug 2014 11:26:30 GMT
Call-ID: isbc7skbusdappc2cbua7o4aspesccbc4hdh@SoftX3000
Route: <sip:10.200.7.157:5060;transport=udp;lr>
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 1459576986-0479400420-2241498593-3224978540
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1407324390
Contact: <sip:2188787@172.29.26.106:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Length: 400
v=0
o=CiscoSystemsSIP-GW-UserAgent 5215 7761 IN IP4 172.29.26.106
s=SIP Call
c=IN IP4 172.29.26.106
t=0 0
m=image 17352 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:14400
a=T38FaxFillBitRemoval:0
a=T38FaxTranscodingMMR:0
a=T38FaxTranscodingJBIG:0
a=T38FaxRateManagement:transferredTCF
a=T38FaxMaxBuffer:200
a=T38FaxMaxDatagram:320
a=T38FaxUdpEC:t38UDPRedundancy
ITSP respond with Trying:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
And then “Media Unacceptable”  from Service Provider End
Received:
SIP/2.0 488 Not Acceptable Here
CSeq: 101 INVITE
Content-Length: 0
Hello Edson Pineiro
       Now I have problem incoming fax
Components
CUCM 10.0
Cisco Voice Gateway (CUBE) - CISCO 2900
Imagicle cisco for UC (Stone fax)
Inbound fax
PSTN (ISP)—SIP—CUBE—SIP Trunk—CUCM—SIP Trunk—IP FAX server(stone fax)
IP FAX server(Stone Fax)—SIP Trunk—CUCM——CUBE(VG)—PSTN(ISP)
Now we are using G711alaw for both inbound and outbound fax calls.
Problem
Inbound fax can receive some number such as my office , my home ,my home friends and my office friends
for outbound it working
Wireshark log and flow diagram
10.2.8.17 -Voice Gateway (CUBE)
10.2.8.13 - CUCM
10.2.8.15 - Fax server (Stone fax)
I have attach log from wireshark.Could you please suggest for any my mistake configuration? and Please let me know if you required any other information
Please Kindly help me to solve this issue.
Nattapong
Risat
Level 3
Level 3
Hi Edson,
We are getting transmission error when we sent faxes to few numbers (outbound calling), mostly international numbers. The Right FAX vendor is claiming that the issue is caused due to line quality issues. Our setup is as below
RightFAX - H323 - Cisco VG - PRI - Service provider (Not touching the CUCM)
We are using T38 for fax communication. How can I verify the line quality is affected in VG or not. I have attached the backup from the VG
Please find the debug attached, in the debug I can see
timestamp=1943793553 FR_BAD_CRC_LS_DATA 0x0 bytes
timestamp=1943793553 fr-msg-tx  bad crc, 0 bytes
Any idea how the the bad CRC would hav been formed, when i checked under the controller there is no input/CRC errors
nabeel asghar
Hi Edson
Hope you doing well
we have configured and installed cisco ATA186 in CUCM 9.1 & VGW H.232 with SIP line from ISP
we are facing issue with incoming fax, incoming fax missed most of the times and showing missed calls notification on fax machine without any ring for incoming fax...fax machine already set to auto answer
Please advice on the above issue urgently
Thanks in advance and waiting for your kind response
Warm Regards:
Nabeel Asghar
Hessellund
Hi Edson
We have cucm setup like this:
SME cluster with
 Cisco 2951 MGCP gateways with ISDN30 connections.
connectied via SIP trunk to
CUCM cluster with
 10+ 2901 MGCP gateways for local backup ISDN30 connections.
 50+ VG202 SCCP gateways for analog devices, mainly faxes.
 30+ VG224 SCCP gateways for analog devices, faxes on some ports.
 20+ VG310 SCCP gateways for analog devices, mainly faxes.
At the moment most of the devices is with default configuration for faxing.
Right now is not very predictable if faxing works or not, and many cases faxes needs to dial more than once to get a fax through the network.
We are looking into doing complete redesign of the fax configurations deployed and my question is very simple.
What is the 2017 recommendation for doing this?
What protocols should be used for faxing?
What protocols should be used for gateways? sccp/mgcp/sip?
(keep in mind that changing protocols is not an easy task based on the number of endpoints deployed)
