Assigning Admin role or any other role to Unity Connection user
iptuser55
Level 6
Level 6
How do I assign a role to a user. I`ve given them the admin role as an example but can not log in . What is the GUI log on details I should use Alisa, Extension etc but no luck. The password I`m also using is the VM PIN I use to listen
thanks
Chris Deren
Use System Administrator and login with the web not VM PIN password, if you are LDAP integrated then use your LDAP i.e. AD password.
Chris
Chris,
I`ve sorted it now, I was looking for as separate ssection for PIN and password , I  didn`t realise that they are under the same heading but separated by the drop down menu - Web and VM application
thanks for your help
Great, please mark the question as answered unless you have further related question.
Chris
