asterisk as first digit possible ?
gmahr
at my current project I have problems creating a uniform dialplan with the given overlaping DN ranges.
So I am thinking about the asterisk (*) as first digit of the new Directory Numbers.
Are there any known limitations with this idea ?
gogasca
Level 10
Level 10
It should work fine.
I was told by a colleague that I would get trouble if it later on was necessary to integrate voicemail and that CTI applications (like Cycos) would not run with DNs starting with *.
What about this ?
Jason Hamlett
It works no problem. I use a dial pattern * + extension that goes directly to the extension's voicemail. Admins love it.
Is it possible to insert a Comma into a CLID?
