IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5599 Views
  • 14 replies
When I attempt to add a new phone in the GUI I get an error pop-up saying "No new phone to add!". Everything else (add DN, etc.) works fine.Someone else had posted a similar problem back in October but didn't get a definitive answer.I have confirmed...
mpitts by Level 1
  • 5535 Views
  • 2 replies
Hi,at my current project I have problems creating a uniform dialplan with the given overlaping DN ranges.So I am thinking about the asterisk (*) as first digit of the new Directory Numbers.Are there any known limitations with this idea ?Thanks
gmahr by Level 1
  • 432 Views
  • 4 replies
Hi thereI have a situation with a customer that puchased CCM5 and used the old CCM4 licensing,is there a way to upgrade the the phone licensing to be compatible with CCM5Thanks in AdvanceTau
tmailula by Level 1
  • 279 Views
  • 2 replies
Hi, I'm using CallManager 5 and have set up a SIP trunk to a remote voice gateway which in turn is connected to the PSTN. I dial a number from the CCM SIP phone (a 7960), it connects but no conversation is heard. Debug on the voice gateway shows the ...
lanksfdj by Level 1
  • 333 Views
  • 2 replies
I saw an old documentation srst for cme, which describes the function of the srst for cme. But this works only for the older phones e.g. 7940 (not for the 7941).I wrote also in a press release at the beginning of december 2006 "Support for srst with ...
pf by Level 1
  • 292 Views
  • 1 replies
Folks, I am confussed. Reading about GK. The routing algorith says that if the zone matches check to see if the zone is local, if the zone if local check to see if technology prefix wa defined. My question is why is the technology prefix chec...
