AT&T Megacom SIP GW
tpfrankli
Level 5
Level 5
Is anyone familiar with AT&T megacom PRIs configured on a SIP gateway? I was able to get the PRI to come up with the following configuration last night. However I would not get any calling party information coming across in the Q931 message, just DNIS.
Here's the port configuration:
interface Serial0/0/0:23
description Voice PRI AT&T NFAS Group
no ip address
encapsulation hdlc
isdn switch-type primary-4ess
isdn supp-service name calling
isdn nsf-service megacom
trunk-group ATT-PSTN
no cdp enable
Oddly enough I have some TFCC Megacom signaled trunks and I was able to get ANI across on them just fine. And of course if I swing this back to the legacy PBX we get ANI just fine so it must be some missing piece of special config for AT&T.
Thanks.
Rate helpful posts
Blog - http://tripplehelix.net
~~~ Rate helpful posts Blog - http://tripplehelix.net
paolo bevilacqua
Post the complete trace for an incoming call
That will have to be a next step we take next week when we can take one of the Megacom trunks out of service and I can gather more detailed traces. When I was looking at it a debug isdn q931 did not show any calling number fields at all coming across. Not that they were blank they just weren't there.
Rate helpful posts
That is very strange because there is no mechanism in Q.931 where one side can influence the other in sending calling number or not.
tpfrankli
Level 5
Level 5
Ok so I got the following debugs last night:
Debug voice ccapi inout
Debug ccsip messages
Debug isdn q931
Here’s the topology so it makes some sense but the root issue here is still at the first leg incoming from AT&T.
AT&T NFAS PRI -> PSTN Voice Gateway -> SIP to CUCM -> SIP back to PSTN Voice Gateway -> SIP to PBX Tie Voice Gateway
A messed up call path I realize and a long story however it works and it’s only temporary thankfully. You can see the incoming call from AT&T the DNIS is 7663.
Call comes in as 7663 gets expanded to 89997727663 goes to CUCM who turns it into 37663 and sends it back to the originating Gateway who in turn sends it via SIP off to the PBX Tie GW.
Oct  2 20:33:20 PDT: ISDN Se1/0:23 Q931: RX <- SETUP pd = 8  callref = 0x01DE
Bearer Capability i = 0x8090
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xE1808397
Preferred, Interface 0, Channel 23
Net Specific Fac i = 0x00E2
Called Party Number i = 0xA1, '7663'
Plan:ISDN, Type:National
Oct  2 20:33:20 PDT: ISDN Se1/0:23 Q931: Received SETUP  callref = 0x81DE callID = 0x053C switch = primary-4ess interface = User
Oct  2 20:33:20 PDT: //-1/626690D58299/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=7663
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Oct  2 20:33:20 PDT: //-1/626690D58299/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x70861B54, Call Info(
   Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=7663(TON=National, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=10, Progress Indication=NULL(0), Calling IE Present=FALSE,
   Source Trkgrp Route Label=ATT-PSTN, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Oct  2 20:33:20 PDT: //-1/626690D58299/CCAPI/ccCheckClipClir:
   In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Oct  2 20:33:20 PDT: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Oct  2 20:33:20 PDT: :cc_get_feature_vsa malloc success
Oct  2 20:33:20 PDT:  cc_get_feature_vsa count is 15
Oct  2 20:33:20 PDT: :FEATURE_VSA attributes are: feature_name:0,feature_time:1911137312,feature_id:32855
Oct  2 20:33:20 PDT: //113733/626690D58299/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=7663(TON=National, NPI=ISDN))
Oct  2 20:33:20 PDT: //113733/626690D58299/CCAPI/cc_process_call_setup_ind:
   Event=0x715F14C8
Oct  2 20:33:20 PDT: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 7663
Oct  2 20:33:20 PDT: //113733/626690D58299/CCAPI/ccCallSetContext:
   Context=0x7202FE34
   >>>>CCAPI handed cid 113733 with tag 10 to app "_ManagedAppProcess_Default"
Oct  2 20:33:20 PDT: //113733/626690D58299/CCAPI/ccCallProceeding:
Oct  2 20:33:20 PDT: //113733/626690D58299/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=FALSE, Mode=0,
   Outgoing Dial-peer=4, Params=0x72231904, Progress Indication=NULL(0)
Oct  2 20:33:20 PDT: //113733/626690D58299/CCAPI/ccCheckClipClir:
   Destination Pattern=8.........., Called Number=89997727663, Digit Strip=FALSE
   Called Number=89997727663(TON=National, NPI=ISDN),
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=626690D5-2B13-11E3-8299-0026993FCC50, Outgoing Dial-peer=4
Oct  2 20:33:20 PDT: //113733/626690D58299/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=89997727663
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Oct  2 20:33:20 PDT: //113733/626690D58299/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x70928D98, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=89997727663(TON=National, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=4, Call Count On=FALSE,
   Source Trkgrp Route Label=ATT-PSTN, Target Trkgrp Route Label=, tg_label_flag=1, Application Call Id=)
Oct  2 20:33:20 PDT:  cc_get_feature_vsa count is 16
Oct  2 20:33:20 PDT: :FEATURE_VSA attributes are: feature_name:0,feature_time:1911135520,feature_id:32856
Oct  2 20:33:20 PDT: //113734/626690D58299/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Oct  2 20:33:20 PDT: //113734/626690D58299/CCAPI/ccCallSetContext:
   Context=0x722318B4
Oct  2 20:33:20 PDT: //113733/626690D58299/CCAPI/ccSaveDialpeerTag:
Oct  2 20:33:20 PDT: //113734/626690D58299/CCAPI/cc_api_call_proceeding:
   Interface=0x70928D98, Progress Indication=NULL(0)
Oct  2 20:33:20 PDT: //113734/626690D58299/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:89997727663@BC-CUCM-Cluster.domain.com:5060 SIP/2.0
Via: SIP/2.0/TCP 172.26.6.125:5060;x-route-tag="tgrp:ATT-PSTN";branch=z9hG4bK3D73959
To: <>89997727663@BC-CUCM-Cluster.domain.com>
Date: Thu, 03 Oct 2013 03:33:20 GMT
Call-ID: 6267C9BE-2B1311E3-82AE98BF-AC853E8A@172.26.6.125
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 1650888917-0722670051-2191065126-2571095120
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1380771200
Contact: <172.26.6.125:5060>
Call-Info: <172.26.6.125:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 60
Allow-Events: kpml, telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 446
v=0
o=CiscoSystemsSIP-GW-UserAgent 3169 7711 IN IP4 172.26.6.125
s=SIP Call
c=IN IP4 172.26.6.125
t=0 0
m=audio 18812 RTP/AVP 0 100 101
a=rtpmap:0 PCMU/8000
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194,200-202
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
a=X-sqn:0
a=X-cap: 1 audio RTP/AVP 100
a=X-cpar: a=rtpmap:100 X-NSE/8000
a=X-cpar: a=fmtp:100 192-194,200-202
a=X-cap: 2 image udptl t38
Oct  2 20:33:20 PDT: ISDN Se1/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x81DE
Channel ID i = 0xE9808397
Exclusive, Interface 0, Channel 23
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
Oct  2 20:33:20 PDT: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:37663@172.26.6.125:5060 SIP/2.0
Via: SIP/2.0/TCP 172.26.6.3:5060;branch=z9hG4bK740784bc3d4f
From: <172.26.6.3>;tag=650546~e39b78d8-c692-45de-9bae-90185dfd34e3-89770414
To: <37663>
Call-ID: 8b350580-24c1e580-72651-3061aac@172.26.6.3
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM8.6
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <172.26.6.3:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 2335507840-0000065536-0000001820-0050731692
Session-Expires:  1800
P-Asserted-Identity: <172.26.6.3>
Remote-Party-ID: <172.26.6.3>;party=calling;screen=yes;privacy=off
Contact: <172.26.6.3:5060>
Max-Forwards: 69
Content-Length: 264
v=0
o=CiscoSystemsCCM-SIP 650546 1 IN IP4 172.26.6.3
s=SIP Call
b=TIAS:64000
b=AS:64
t=0 0
m=audio 18812 RTP/AVP 0 101 100
a=ptime:20
a=fmtp:101 0-15
Oct  2 20:33:20 PDT: //-1/8B3505800000/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=37663
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Oct  2 20:33:20 PDT: //-1/8B3505800000/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x70928D98, Call Info(
   Called Number=37663(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=4, Progress Indication=NULL(0), Calling IE Present=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=113735
Oct  2 20:33:20 PDT: //-1/8B3505800000/CCAPI/ccCheckClipClir:
Oct  2 20:33:20 PDT:  cc_get_feature_vsa count is 17
Oct  2 20:33:20 PDT: :FEATURE_VSA attributes are: feature_name:0,feature_time:1911142912,feature_id:32857
Oct  2 20:33:20 PDT: //113735/8B3505800000/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Called Number=37663(TON=Unknown, NPI=Unknown))
Oct  2 20:33:20 PDT: //113735/8B3505800000/CCAPI/cc_process_call_setup_ind:
   Event=0x715F14C8
   Try with the demoted called number 37663
Oct  2 20:33:20 PDT: //113735/8B3505800000/CCAPI/ccCallSetContext:
   Context=0x72025834
   >>>>CCAPI handed cid 113735 with tag 4 to app "_ManagedAppProcess_Default"
Oct  2 20:33:20 PDT: //113735/8B3505800000/CCAPI/ccCallProceeding:
Oct  2 20:33:20 PDT: //113735/8B3505800000/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=5, Params=0x7237CE60, Progress Indication=NULL(0)
Oct  2 20:33:20 PDT: //113735/8B3505800000/CCAPI/ccCheckClipClir:
   Destination Pattern=3[2-7]..., Called Number=37663, Digit Strip=FALSE
   Guid=8B350580-0001-0000-0000-071C03061AAC, Outgoing Dial-peer=5
Oct  2 20:33:20 PDT: //113735/8B3505800000/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=37663
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Oct  2 20:33:20 PDT: //113735/8B3505800000/CCAPI/ccIFCallSetupRequestPrivate:
   Called Number=37663(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=5, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Oct  2 20:33:20 PDT:  cc_get_feature_vsa count is 18
Oct  2 20:33:20 PDT: :FEATURE_VSA attributes are: feature_name:0,feature_time:1911132608,feature_id:32858
Oct  2 20:33:20 PDT: //113736/8B3505800000/CCAPI/ccIFCallSetupRequestPrivate:
Oct  2 20:33:20 PDT: //113736/8B3505800000/CCAPI/ccCallSetContext:
   Context=0x7237CE10
Oct  2 20:33:20 PDT: //113735/8B3505800000/CCAPI/ccSaveDialpeerTag:
Oct  2 20:33:20 PDT: //113736/8B3505800000/CCAPI/cc_api_call_proceeding:
Oct  2 20:33:20 PDT: //113735/8B3505800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <37663>
CSeq: 101 INVITE
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Oct  2 20:33:20 PDT: //113736/8B3505800000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:37663@PDX-Avaya-Tie.domain.com:5060 SIP/2.0
Via: SIP/2.0/TCP 172.26.6.125:5060;branch=z9hG4bK3D741A26
To: <>37663@PDX-Avaya-Tie.domain.com>
Call-ID: 626AD685-2B1311E3-82B498BF-AC853E8A@172.26.6.125
Min-SE:  1800
CSeq: 101 INVITE
Expires: 60
Max-Forwards: 68
Content-Length: 446
v=0
o=CiscoSystemsSIP-GW-UserAgent 8165 7094 IN IP4 172.26.6.125
s=SIP Call
t=0 0
m=audio 16764 RTP/AVP 0 100 101
a=fmtp:101 0-15
a=ptime:20
a=X-sqn:0
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Server: Cisco-SIPGateway/IOS-15.2.4.M4
Content-Length: 0
Oct  2 20:33:20 PDT: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Receiving: Binary Message Body
Oct  2 20:33:20 PDT: Content-Type: application/qsig
08 02 02 56 01 1E 02 81 88 0D 0A
Received:
SIP/2.0 183 Session Progress
To: <>37663@PDX-Avaya-Tie.domain.com>;tag=550296BC-1914
CSeq: 101 INVITE
Require: 100rel
RSeq: 4794
Remote-Party-ID: <7663>;party=called;screen=no;privacy=off
Contact: <37663>
Supported: sdp-anat
Content-Type: multipart/mixed;boundary=uniqueBoundary
Mime-Version: 1.0
Content-Length: 826
--uniqueBoundary
v=0
o=CiscoSystemsSIP-GW-UserAgent 4816 4297 IN IP4 172.26.6.180
s=SIP Call
c=IN IP4 172.26.6.180
t=0 0
m=audio 20754 RTP/AVP 0 101 100
a=fmtp:101 0-16
a=ptime:20
a=X-sqn:0
--uniqueBoundary
Content-Disposition: signal;handling=optional
Content-Length: 11
   V
--uniqueBoundary
Content-Type: application/gtd
ACM,
PRN,isdn*,,QSIG*,
--uniqueBoundary--
Oct  2 20:33:20 PDT: //113736/8B3505800000/CCAPI/cc_api_caps_ind:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=113736,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
   Modem=0x0, Codec Bytes=20, Signal Type=2)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Oct  2 20:33:20 PDT: //113735/8B3505800000/CCAPI/cc_api_caps_ack:
   Destination Interface=0x0, Destination Call Id=-1, Source Call Id=113735,
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1)
Oct  2 20:33:20 PDT: //113736/8B3505800000/CCAPI/cc_api_event_indication:
   Event=171, Call Id=113736
   Event Is Sent To Conferenced SPI(s) Directly
Oct  2 20:33:20 PDT: //113736/8B3505800000/CCAPI/cc_api_call_alert:
   Interface=0x70928D98, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Oct  2 20:33:20 PDT: //113735/8B3505800000/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Oct  2 20:33:20 PDT: //113735/8B3505800000/CCAPI/ccConferenceCreate:
   (confID=0x7241030C, callID1=0x1BC47, gcid=62699E36-2B1311E3-82B198BF-AC853E8A, tag=0x0)
Oct  2 20:33:20 PDT: //113736/8B3505800000/CCAPI/ccConferenceCreate:
   (confID=0x7241030C, callID2=0x1BC48, gcid=62699E36-2B1311E3-82B198BF-AC853E8A, tag=0x0)
   Conference Id=0x7241030C, Call Id1=113735, Call Id2=113736, Tag=0x0
Oct  2 20:33:20 PDT: //113735/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Oct  2 20:33:20 PDT: cc_api_get_xcode_stream : 4702
Oct  2 20:33:20 PDT: //113736/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Oct  2 20:33:20 PDT: ccConferenceCreate: ret1=0, codecMask1=1, bytes1=160, negot1=1, dtmf1=6
                    ret2=0, codecMask2=1, bytes2=160, negot2=1, dtmf2=6,
                    tx_dynamic_pt1=0, rx_dynamic_pt1=0, codec_mode1=0, params_bitmap1 =0
                    tx_dynamic_pt2=0, rx_dynamic_pt2=0, codec_mode2=0, params_bitmap2 =0
   delay media to slow start case, codec negotation is not done
Oct  2 20:33:20 PDT: //113735/8B3505800000/CCAPI/cc_api_bridge_done:
   Conference Id=0x3998, Source Interface=0x70928D98, Source Call Id=113735,
   Destination Call Id=113736, Disposition=0x0, Tag=0x0
Oct  2 20:33:20 PDT: //113736/8B3505800000/CCAPI/cc_api_bridge_done:
   Conference Id=0x3998, Source Interface=0x70928D98, Source Call Id=113736,
   Destination Call Id=113735, Disposition=0x0, Tag=0x0
Oct  2 20:33:20 PDT: //113735/8B3505800000/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x3998, Destination Call Id=113736)
   Call Entry(Conference Id=0x3998, Destination Call Id=113735)
Oct  2 20:33:20 PDT: //113735/8B3505800000/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x3998, Call Id1=113735, Call Id2=113736
Sent:
PRACK sip:37663@172.26.6.180:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 172.26.6.125:5060;branch=z9hG4bK3D7544E
CSeq: 102 PRACK
RAck: 4794 101 INVITE
Max-Forwards: 70
Content-Length: 0
Sent:
To: <37663>;tag=23B416E0-1108
CSeq: 101 INVITE
Remote-Party-ID: <37663>;party=called;screen=no;privacy=off
Contact: <37663>
Supported: sdp-anat
Content-Length: 296
v=0
o=CiscoSystemsSIP-GW-UserAgent 6818 3357 IN IP4 172.26.6.125
s=SIP Call
t=0 0
m=audio 16520 RTP/AVP 0 101 100
a=fmtp:101 0-16
a=fmtp:100 192-194
a=ptime:20
Received:
SIP/2.0 200 OK
CSeq: 102 PRACK
Content-Length: 0
Received:
SUBSCRIBE sip:37663@172.26.6.125:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 172.26.6.3:5060;branch=z9hG4bK7407977b723af
CSeq: 102 SUBSCRIBE
Event: kpml
Expires: 7200
Accept: application/kpml-response+xml
Max-Forwards: 70
Content-Type: application/kpml-request+xml
Content-Length: 370
http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:ietf:params:xml:ns:kpml-request kpml-request.xsd" version="1.0">
    [x*#ABCD]
Sent:
PBC-IPT-3845A#SIP/2.0 200 OK
Via: SIP/2.0/TCP 172.26.6.125:5060;branch=z9hG4bK3D771C5A
To: <>89997727663@BC-CUCM-Cluster.domain.com>;tag=650545~e39b78d8-c692-45de-9bae-90185dfd34e3-89770413
CSeq: 102 NOTIFY
Content-Length: 0
PBC-IPT-3845A#
Oct  2 20:33:22 PDT: //-1/xxxxxxxxxxxx/SIP/Msg/sipDisplayBinaryData:
Oct  2 20:33:22 PDT: Content-Type: application/qsig
08 02 02 56 07 1C 26 9F AA 06 80 01 00 82 01 00 8B 01 00 A1 18 02 02 E0 A7 02 01 02 80 0F 47 65 6E 20 46 72 6F 6E 74 20 41 6E 6E 20 4F 1E 02 81 82 4C 0D A1 38 39 39 39 37 37 32 31 38 37 30 37 0D 0A
Oct  2 20:33:22 PDT: //113736/8B3505800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Remote-Party-ID: "Gen Front Ann O" <7663>;party=called;screen=no;privacy=off
Contact: <37663>
Supported: replaces
Supported: sdp-anat
Require: timer
Session-Expires:  1800;refresher=uac
Supported: timer
Mime-Version: 1.0
Content-Length: 881
--uniqueBoundary
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=X-sqn:0
--uniqueBoundary
Content-Length: 66
Rate helpful posts
