Resolved! Block internal calls on CME
Is there anyway to block internal calls on CME? For example, phone 1000 no call to phone 1001 in same Router.
i have CUCM 8.6.2 the and voice security is applied , the phones which has security profile has delay while i press the corporate directry button it take about 6 or 7 seconds till the search items appear ( fist name , last name and extension )while ...
I have a question regarding Cisco 7925g wireless phone...I am wondering if Cisco has any tool to configure wireless profile on these phones in bulk!!! For now, I do one phone at a time and it takes long time to configure the wireless profile and then...
Why "benign" is considered as a characteristics of voice traffic, but not "smooth".thanks,Han
Hi We are running CUCM 8.6 and I want to change my pin on my voicemail as I cannot remember it. I have gone into CUCM, under user management, end user, and found my name and changed the pin. saved this and then tried to access my voicemail. It still ...
Hi All,I am facing PRI Fluctuation , beacuse of which Call are diconnected on regular intervals.below is the error which is gettin on Router Voice Gateway
Dear Sir, Since we dont have a third party softwares to detect all Calls in our System.Is there any command to know the Placed Calls History of every Telephone line.Thanks, Michael
Hi,we want to install rightfax connecting to the callmanager via a SIP trunk. the setup is as follows, however we can't send faxes through.PSTN (PRI) ----> H323/MGCP GW--------->CUCM---------->SIP TRUCK to Rightfax ...
hiii Experts..... I have 8 digit plan ...first four as location code and rest four as local code.....whenever im dialing the local intercom phones using all 8digit (means station code plus 4 digit) and going to call h...
In CME, I can set feature-button 1 NiteSrv on IP phone to manually switch to night mode. User can know the status when the button light on. And set call-forward night-service when night time.But I cannot find this feature in phone button template in ...
Dear Sir, Is there any procedure how to install this Software in Windows System Environment:1. Step by Step procedure and Requirements.2. Needed Softwares.Got an error for replying to this discussion.https://supportforums.cisco.com/message/4073551#40...
Hello,I understand it is possible and supported to be able to cold migrate / host to host move a CUCM VM from one Cisco C220 server to another during a maint window to deal with a server issue.However I can't seem to find the exact process to follow ...
I'm a bit confused on how this works. 3 of our branch offices or in the same area around Kansas city. We have and Olathe, Kansas City, and Liberty branch there.In the route patterns for the 816 area code I have:9.1816XXXXXXX Olathe-TollByPass-RGL9.81...
Hello, running into the following issue and i'm having a hard time narrowing down the problem. Trying to centralize call flow for a number of sites, we ran into an issue when we re routed calls through CUCMOrginal Topology:Avaya PBX --> T1 E&M --> 28...
Hi, We are using model 7945 and 9951 Cisco IP Phones. Is there any security or locked the Telephone? Thanks,Michael
Subject | Author | Posted |
04-15-2025 02:12 PM | ||
04-15-2025 10:57 AM | ||
04-15-2025 03:40 AM | ||
04-14-2025 01:50 PM | ||
04-14-2025 08:21 AM |
User | Count |
3 | |
2 | |
2 | |
1 | |
1 |
