08-22-2011 11:36 AM - edited 03-16-2019 06:37 AM
I add ATA-186 SCCP to CME 8.6 infrastrukture, I can make calls and receive them but audio goes only in one direction from CME to ATA-186 . I try different calls from ATA-186 to another SCCP extension , SIP extension , SIP trunk , PSTN line same problem . I try with both phone ports on ATA-186 same result..
Does anybody have idea how to trubelshot problem.
here is some HW and CONF details
ATA-186-I2-A with sw 3.02.04(090202A)
Audio parametars
LBRCodec =3
AudioMode=0x00150015
ConnectMode=0x90002400
FXSInputLevel=-1
FXSOutputLevel=-4
CME ver 8.6 on ISR 2901 with IOS c2900-universalk9-mz.SPA.151-4.M.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol pass-through g711alaw
modem passthrough nse codec
h323
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
dial-peer voice 1002 voip
modem passthrough nse codec g711alaw
dtmf-relay sip-notify rtp-nte
codec g711alaw
fax rate disable
no vad
ephone-dn 15
number 215
label 215
ephone 15
device-security-mode none
mac-address 04FE.7F69.CBB8
max-calls-per-button 2
username "yyy" password xxx
type ata
button 1:15
this two port will be used for credit card POS terminals , they need to support modem connection to bank over SIP trunk
please HELP me
08-24-2011 11:20 PM
My name is Edson Pineiro, I understand that your problem description is in regards to one way audio, were the audio (rtp packet) does not reach the ATA sourced from the CME.
According to your dial-peers your trying to use g711alaw, however your connection mode parameter bit 2 is set to 0, please change it to 1. Your ata configuration should look like the following:
LBRCodec: 2
Audio Mode: 0x00150015
Connection Mode: 0x00002404
Please apply the above change and test. You can confirm if the rtp packet reaches the ata with a packet capture and wire-shark.
Please be advised that ata do not support modem. In most cases it will work using best effort modem calls using purely g711 where this codec is good enough to pass through fax/modem as inband. However in order for inband modem to work (best effort) you need to ensure all dtmf relays are disabled and that the dial-peer is simple.
Please let me know how you go.
Thank you
Edson Pineiro
