CDR Records Lost
Ruslan Amrahov
Dears,
I've got CCM 7.1.5. When I'm trying to export CDR to CSV, for March for example, it shows me empty results. I checked Alerting for CDR repo limitation, it was set, but no kind of CDR alert I get. What could be the issue?
Thanks!
You can eidther
1. Increase the Max Age of Call Detail Records in CAR -> SYSTEM -> Database -> "Configure Automatic Purge"
or
2. You can configure "Billing Application Server Parameters" in CDR management page to ftp upload the CDR flat files to an external location, in this case, you can keep the records as long as your storage space allowed.
7 Replies 7
Yufang Zhou
CDR can be missing for many possible issues.
Starting to check if the CDR flat files are still in the CDR Repository at the following location:
file list activelog cm/cdr_repository/preserve
file list activelog cm/cdr_repository/processed
file list activelog cm/cdr_repository/tmp
Dear Youfang,
Thank you for your answer. Here is the output:
admin:file list activelog cm/cdr_repository/preserve
   20110723
   20110724
   20110725
   20110726
   20110727
   20110728
   20110729
   20110730
   20110731
   20110801
   20110802
   20110803
   20110804
   20110805
   20110806
   20110807
   20110808
   20110809
   20110810
   20110811
   20110812
   20110813
   20110814
   20110815
   20110816
   20110817
   20110818
   20110819
   20110820
   20110821
   20110822
   20110823
dir count = 32, file count = 0
admin:
admin:
admin:file list activelog cm/cdr_repository/processed
   20110723
   20110724
   20110725
   20110726
   20110727
   20110728
   20110729
   20110730
   20110731
   20110801
   20110802
   20110803
   20110804
   20110805
   20110806
   20110807
   20110808
   20110809
   20110810
   20110811
   20110812
   20110813
   20110814
   20110815
   20110816
   20110817
   20110818
   20110819
   20110820
   20110821
   20110822
   20110823
admin:file list activelog cm/cdr_repository/tmp
cdr_StandAloneCluster_01_201108220408_416970
cmr_StandAloneCluster_01_201108220408_416970
dir count = 0, file count = 2
admin:
As I see I lose CDR records starting from June.
From your output, the records for March has been purged/deleted. In CDR Management page of Unified Servicibility page, by default, it will only retain 30 days records, which seems to be the case from your output. If you are using CAR to export CDR, there is also a system database configuration for automatically purge, which is by default for 60 days.
Since the records are deleted from the server and CAR database by the configuration of the maximum retention duration in the CDR management page and CAR database, so there is no alert raised for data deletion.
Thank you for your answer,
Is there any way to keep these records longer?
You can eidther
or
JiriPrinc
or you can collect the CDR record on FTP server. Your CUCM can actively transport CDR via FTP protocol to specied servers (up to three servers at the same time).
Jiri
Thank you, Yufang!
