03-28-2017 12:40 PM - edited 03-18-2019 12:12 PM
A user called me that an ATA had failed so they ordered a new one and changed the MAC in CME and it wasn't working.
It turned out, the POTS line was bad so it was fixed. Now, we can't get either (new or old) ATA to register with CME.
I think everything else correct but it never registers. I also don't see any debugs on "debug tftp" and "debug ephone registration".
I do see the xml.cnf files and I'm able to pull the file off the CME.
ephone-20[19] Mac:0017.E055.38A5 TCP socket:[-1] activeLine:0 whisperLine:0 UNREGISTERED
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:0
IP:0.0.0.0 0 Unknown 0 keepalive 0 max_line 0 available_line 0
Preferred Codec: g711ulaw
Username: edcfax
Here is the interface for the ATA. Everything looks correct to me.
ephone config:
ephone 20
device-security-mode none
mac-address 0017.E055.38A5
ephone-template 16
max-calls-per-button 2
username "edcfax"
type ata
button 1:296
Any ideas? I'm lost.
03-28-2017 09:01 PM
Your TFTP enabled is set to '0' which means disabled. You need to change it to '1' for ATA to initiate TFTP requests
03-29-2017 06:36 AM
How do I change it? I haven't figured that out yet. I did a factory reset on both ATAs. I would figure that setting would default to enable if it needed to be enabled.
I think I read somewhere that "TFTP Enabled" was for something else but I can't find much about that setting right now.
Thanks for your help.
03-29-2017 06:41 AM
Think you have to recreate the CNF files, or do a reboot of CME
JH
03-29-2017 06:48 AM
I've done both of those! I was even able to pull the tftp file manually. I deleted the ephone, verified the config file wasn't there, recreated the ephone and generated the files and verified the cnf files were created.
The ATA doesn't seem to be reaching out to get the configuration because I don't see any tftp debugging with the ATA but I do see it when I manually grab the file.
03-29-2017 11:00 AM
TFTP isn't enabled by default on ATA186. Navigate to ATA URL as below to configure it.
http://x.x.x.x/dev
Set the parameter useTFTP to '1'. By default it is '0'. You can configure other parameters such as UCM, extensions, DHCP, etc.
03-29-2017 11:27 AM
Thanks Mohammed.
That's already set to 1 by default. Or that setting didn't change. It is set to 1. I've set it to 0, rebooted, changed to 1, rebooted with no change.
Any other suggestions?
