ATA187 Compatibility on EOL CME
rossporubski
Level 4
Level 4
We recently moved our site in the UK to another facility. The prior facility had a dedicated pots line for their fax. At the new facility we chose not to port the pots. Instead assign an extension on ATA. The only device we could get is the newest ATA187. When trying to apply the firmware to the router, it doesn't seem to want to take.
Anybody know if the newer device is not compatible with older versions of CME/CUE? Ours is 3.2
Thanks to everybody in advance.
Leonardo Santana
Hello Ross,
The ATA 187 is not compatible with CME 3.2, take a look on CME 3.2 Compatibility matrix, only ATA 186 and 188 are compatible with this CME version!
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme32spc.htm
ATA 187 is compatible with CME 9.0
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme90spc.html
Rate this if helps!
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
Leonardo Santana
Hello Ross,
Rate this if helps!
Leonardo Santana
Leonardo Santana
Aye yi yi. Ok, no prob. Thank you sir.
