ATA190 and ATA191 automatically send *XXX as Speed Dial
Hello everybody,
If I understood the below article correctly, the Speed Dial function is reserved for the patterns *1 to *199.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cata/190/1_0/english/administration/guide/sip/ATA190/a190_agAsup.html
Speed Dial
This feature allows users to speed dial a phone number by entering an assigned index code (from *1 to *199) on the phone keypad.
I have a customer with around 1000 translation patterns: *3XXX translating to different external or internal numbers (different customer sites or mobile phones).
For the last 4 months, none of the different types of phones connected to the ATA190 devices can dial these *3XXX anymore (at least the ones verified by the customer). They are receiving a FastBusy tone. So far we have NOT found a single device that works anymore so we assume they are all affected. We are not aware of any CUCM changes and the ATA190 Software is the latest 1-2-2-003_SR2. Same issue happens also with ATA190 v.1-2-1-003 and v1-2-2-003.
Partitions/CSSs should not be a problem since IP Phones are able to call *3XXX and the DECT Phones connected to ATAs can also call #3001 which is just a test pattern created by copying the *3001.
Every setting on the Device page is standard, and I already tried enabling/disabling the "Require DTMF Reception" on the Device page and configured a ## in front of every Vertical Service Activation Code on the ATA190. Nothing seems to show any change. The ATA behaviour is the same:
ATA190 and ATA191 Debug log is showing the pattern *XXX being sent directly to CUCM as Speel Dial.
ATA190 log:
- Digits dialed
Line 105291: Mar 29 15:56:06 ATA190 daemon.debug sprvoip: <159>line:0 DTMFON event received digit *
Line 105318: Mar 29 15:56:06 ATA190 daemon.debug sprvoip: <159>line:0 DTMFOFF event received digit *
Line 105348: Mar 29 15:56:06 ATA190 daemon.debug sprvoip: <159>line:0 DTMFON event received digit 3
Line 105376: Mar 29 15:56:06 ATA190 daemon.debug sprvoip: <159>line:0 DTMFOFF event received digit 3
Line 105406: Mar 29 15:56:07 ATA190 daemon.debug sprvoip: <159>line:0 DTMFON event received digit 0
Line 105434: Mar 29 15:56:07 ATA190 daemon.debug sprvoip: <159>line:0 DTMFOFF event received digit 0
Line 105464: Mar 29 15:56:07 ATA190 daemon.debug sprvoip: <159>line:0 DTMFON event received digit 0
Line 105492: Mar 29 15:56:07 ATA190 daemon.debug sprvoip: <159>line:0 DTMFOFF event received digit 0
Line 105583: Mar 29 15:56:07 ATA190 daemon.debug sprvoip: <159>line:0 DTMFON event received digit 1
Line 105586: Mar 29 15:56:07 ATA190 daemon.debug sprvoip: <159>line:0 DTMFOFF event received digit 1
After the * 3 0 0 are finished to be dialed, ATA sends it as a speed Dial to CUCM and since there are no Speed Dials configured, it fails:
Mar 29 15:56:07 ATA190 daemon.debug sprvoip: <159>[cucm_abbr_dial_final: 184]abbreviate dialing: *300
Mar 29 15:56:07 ATA190 daemon.debug sprvoip: <159>[cucm_feature_code_check: 676]CUCM Feature Code: Abbreviate Dial
Mar 29 15:56:07 ATA190 daemon.debug sprvoip: <159>[cucm_feature_code_process: 1075]dialed string: x-cisco-serviceuri-abbrdial-300
Mar 29 15:56:07 ATA190 daemon.debug sprvoip: <151>Calling:x-cisco-serviceuri-abbrdial-300@REMOVED_IP_ADDRESS:0, rc=0
Mar 29 15:56:07 ATA190 daemon.debug sprvoip: <159>++++ called number = x-cisco-serviceuri-abbrdial-300
Mar 29 15:56:08 ATA190 daemon.debug sprvoip: <159>[rcc_refer_parser: 397]unknown remote cc request: <?xml version=\"1.0\" encoding=\"iso-8859-1\"?> <x-cisco-remotecc-request> <statuslineupdatereq> <action>notify_display</action> <dialogid> <callid>7817f762-99a7943c@REMOVED_IP_ADDRESS</callid> <localtag>176185070</localtag> <remotetag>7e1c0d2a9cf93914o0</remotetag> </dialogid> <statustext>Number Not Configured</statustext> <displaytimeout>10</displaytimeout> <priority>1</priority> </statuslineupdatereq> </x-cisco-remotecc-request>
Mar 29 15:56:08 ATA190 daemon.debug sprvoip: <134>CUCM ERROR!!! [rcc_refer_parser: 402]fail to parse <?xml version=\"1.0\" encoding=\"iso-8859-1\"?> <x-cisco-remotecc-request> <statuslineupdatereq> <action>notify_display</action> <dialogid> <callid>7817f762-99a7943c@REMOVED_IP_ADDRESS</callid> <localtag>176185070</localtag> <remotetag>7e1c0d2a9cf93914o0</remotetag> </dialogid> <statustext>Number Not Configured</statustext> <displaytimeout>10</displaytimeout> <priority>1</priority> </statuslineupdatereq> </x-cisco-remotecc-request> for remote call control
CUCM SDL Log:
09338694.001 |15:56:08.455 |AppInfo |//SIP/SIPUdp/wait_SdlDataInd: Incoming SIP UDP message size 1409 from REMOVED_IP_ADDRESS:[5060]:
Line 14: INVITE sip:x-cisco-serviceuri-abbrdial-300@REMOVED_IP_ADDRESS SIP/2.0
Although we are not aware of any CUCM/ATA global configuration changes, the customer insists that dialing the *3XXX pattern from a ATA end point worked fine until 4 months ago.
So the question is, has anybody been able to call from an ATA to a *3XXX translation pattern which is not configured as a Speed Dial in CUCM?
Thank you!
All troubleshooting test results have been pointing out that ATA devices will automatically invoke the Speed Dial feature when an end device attached dials the pattern *XXX. Discussing the results with the customer and double checking on their side internally, it seems there hasn't been in fact any confirmation that dialing *XXXX ever worked. The case was closed agreeing the ATA devices are working as designed. Dialing the patterns *XXXX is not possible.
7 Replies 7
I just realized I forgot to paste the ATA190 article mentioning the Speed Dial..
Speed Dial
If I understood correctly, this was working before and only after you changed the handset to another brand its toped working.
If that's correct, why dont you use the same handset which worked or the the same model.
Response Signature
I made a typo in the initial post, but I just corrected it. No, it doesn't work with any handset. At the moment, we tried different phone types connected to ATA190/ATA191, none of them can dial these patterns. ATA receives the *XXX pattern and sends it as abbreviated dialing to CUCM automatically. It does not wait for any other digits. I am trying to get  a ATA190 up and running in our lab and will test different scenarios hopefully next week.
I installed a ATA190 in our lab and made a lot of tests, but I couldn't find any configuration setup to make the ATA not use the Speed Dial function.
If anybody succeeds to reach a Translation Pattern by dialing *XXXX from ATA190 instead of matching the *XXX Speed Dial feature (Abbreviated Dialing) or completely deactivate the Speed Dial Service on ATA, I would be curious how that setup would look like.
* I was trying to get CLI access to ATA to try deactivating the Speed Dial Serv, but under Administration -> Management, there are no SSH settings, just the User configuration.
dgonzalez1
Hi, I post this questino here because is related to the topic. I read the documentation about speed dial, the one that you pasted here, but it doesn't say how to configure it. It just say you can use codes from *1 to *199. How are you supposed to configure them? By dialling in the phone attached? In ATA web page or in CUCM?
Thank you.
I don't have access to my test setup anymore, but from what I remember, the *1 - *199 are configurable speed dials on the ATA device page in CUCM. You can add a SD on the ATA Device page in CUCM and place a call to that configured destination number by dialing the speed dial code from a physical phone connected to the ATA.
In this case, a DECT phone connected to this ATA for example, could dial *199 to place a call to the destination number 1234. From what I remember, you do not have to configure anything on the ATA web page.
