attendant DN versus DN
alex goshtaei
Hi All,
I've setup VG224 with 24 FXS ports. each port has attendant DN and also DN which can be assigned to that port. what's the difference between these two? I know in FXO port, attandant DN is similar to connection plar.
thanks
Alex
When you add the ports you get a choice of loop start/ground start or POTS - POTS is your friend; did you select one of the others?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Rob Huffman
Hi Alex,
For the VG224 the Attendant DN field can be left blank
It appears to be some sort of legacy/remnant left over from the VG200
days in reference to FXO Ports like you nicely noted. Here is a reference
that may help;
How to Configure Cisco VG 224 Analog Voice Gateway Using Cisco Unified Communications Manager Bulk Administration Tool
http://cisco.biz/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080b2592e.shtml
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
thanks for your reply,
but attendant DN is the mandatory field and it can't be blank.
any idea?
thanks again
Aaron
Does seem misleading, been a while since I've worked with a VG224.
I don't have one to test but from what I read and reviewed in a CUCM 8.x this happens when you have selected a MGCP FXS.
For FXS you need to choose:
POTS
Ground Start
Loop Start
The documentation doesn't explain this but apparently you need to use POTS for phones, the other 2 options are meant for trunk lines.
This to address a bug:
CSCse23808
CCMAdmin should support MGCP-controlled analog FXS GroundStart endpoints
But generated another bug to remove that attendant DN and avoid confussion
CSCtf22348
MGCP FXS GroundStart and LoopStart need Prefix DN; remove Attendant DN
So, apparently attendant DN under GS/LS is useless. What you need to use is prefix DN for PLAR from what I read.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
