Audio start only after 15 seconds the use pickup the call
wilsonsant
Level 6
Level 6
Hi Guys,
My Customer have a solution with CUCM 8.6.2 and is having the following problem: When the user to do the call for PSTN (using FXO interface), the user side B (called) pickup the call, but, the audio start only after 15 seconds. The user that is in the site A hear the user site B speaking, but, the audio for both only start 15 seconds after. Any have Idea about this? I suspected about the codec, but, and didn´t found error.
Wilson
5 Replies 5
Anas Abueideh
Level 9
Level 9
it is weird one. is it happenned for all phones or at specific type ?
regards
Anas
Hi Anas,
The problem is aleatory and occur with any user and any IP Phone, but, only when the call is did for PSTN.
Wilson
try this debug while simulating the issue
debug voip ccapi inout
Also plz confirm no routing nor security issue could exist here
Haitham
Hi Haithan,
Hi tryied attach the log, but, I didn´t found the option. Follow the logs below:
Calling Number - cisco-ani=1811032010
Called Number - dest=00151833669800
Wed Mar 20 09:07:35 2013: <191>160919: .Mar 20 09:07:33: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
Wed Mar 20 09:07:35 2013: <191>160920:    ccAppShutdownMode: remove it from the queue
Wed Mar 20 09:07:52 2013: <190>160921: .Mar 20 09:07:50: %IPPHONE-6-UNREGISTER_NORMAL: ephone-8:SEP002699441EB7 IP:10.229.64.43 Socket:5 DeviceType:Phone has unregistered normally.
Wed Mar 20 09:09:32 2013: <190>160922: .Mar 20 09:09:30: %IPPHONE-6-REGISTER_NEW: ephone-11:SEP002699441929 IP:10.229.64.33 Socket:5 DeviceType:Phone has registered.
Wed Mar 20 09:09:47 2013: <191>160923: .Mar 20 09:09:46: //-1/E3FCE46DB3A5/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:09:47 2013: <191>160924:    cc_api_call_setup_ind_common:
Wed Mar 20 09:09:47 2013: <191>160925:    cisco-username=
Wed Mar 20 09:09:47 2013: <191>160926:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:09:47 2013: <191>160927:    cisco-ani=1811032013
Wed Mar 20 09:09:47 2013: <191>160928:    cisco-anitype=0
Wed Mar 20 09:09:47 2013: <191>160929:    cisco-aniplan=0
Wed Mar 20 09:09:47 2013: <191>160930:    cisco-anipi=0
Wed Mar 20 09:09:47 2013: <191>160931:    cisco-anisi=0
Wed Mar 20 09:09:47 2013: <191>160932:    dest=
Wed Mar 20 09:09:47 2013: <191>160933:    cisco-desttype=0
Wed Mar 20 09:09:47 2013: <191>160934:    cisco-destplan=0
Wed Mar 20 09:09:47 2013: <191>160935:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:09:47 2013: <191>160936:    cisco-rdn=
Wed Mar 20 09:09:47 2013: <191>160937:    cisco-lastrdn=
Wed Mar 20 09:09:47 2013: <191>160938:    cisco-rdntype=0
Wed Mar 20 09:09:47 2013: <191>160939:    cisco-rdnplan=0
Wed Mar 20 09:09:47 2013: <191>160940:    cisco-rdnpi=0
Wed Mar 20 09:09:47 2013: <191>160941:    cisco-rdnsi=0
Wed Mar 20 09:09:47 2013: <191>160942:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:09:47 2013: <191>160943:    final_redirectNumber =
Wed Mar 20 09:09:47 2013: <191>160944:    hunt_group_timeout =0
Wed Mar 20 09:09:47 2013: <191>160945:
Wed Mar 20 09:09:47 2013: <191>160946: .Mar 20 09:09:46: //-1/E3FCE46DB3A5/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:09:47 2013: <191>160947:
Wed Mar 20 09:09:47 2013: <191>160948: Interface=0x4B805B90, Call Info(
Wed Mar 20 09:09:47 2013: <191>160949:    Calling Number=1811032013,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:09:47 2013: <191>160950:    Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:09:47 2013: <191>160951:    Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:09:47 2013: <191>160952:    Incoming Dial-peer=20015, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:09:47 2013: <191>160953:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:09:47 2013: <191>160954: .Mar 20 09:09:46: //-1/E3FCE46DB3A5/CCAPI/ccCheckClipClir:
Wed Mar 20 09:09:47 2013: <191>160955:    In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:09:47 2013: <191>160956: .Mar 20 09:09:46: //-1/E3FCE46DB3A5/CCAPI/ccCheckClipClir:
Wed Mar 20 09:09:47 2013: <191>160957:    Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:09:47 2013: <191>160958: .Mar 20 09:09:46: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:09:47 2013: <191>160959:
Wed Mar 20 09:09:47 2013: <191>160960: .Mar 20 09:09:46: :cc_get_feature_vsa malloc success
Wed Mar 20 09:09:47 2013: <191>160961: .Mar 20 09:09:46: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:09:47 2013: <191>160962:
Wed Mar 20 09:09:47 2013: <191>160963: .Mar 20 09:09:46:  cc_get_feature_vsa count is 1
Wed Mar 20 09:09:47 2013: <191>160964: .Mar 20 09:09:46: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:09:47 2013: <191>160965:
Wed Mar 20 09:09:47 2013: <191>160966: .Mar 20 09:09:46: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248360,feature_id:8130
Wed Mar 20 09:09:47 2013: <191>160967: .Mar 20 09:09:46: //8130/E3FCE46DB3A5/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:09:47 2013: <191>160968:
Wed Mar 20 09:09:47 2013: <191>160969: Set Up Event Sent;
Wed Mar 20 09:09:47 2013: <191>160970:    Call Info(Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:09:47 2013: <191>160971:    Called Number=(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:09:47 2013: <191>160974: .Mar 20 09:09:46: //8130/E3FCE46DB3A5/CCAPI/ccCallSetContext:
Wed Mar 20 09:09:47 2013: <191>160975:    Context=0x4BA6C148
Wed Mar 20 09:09:47 2013: <191>160976: .Mar 20 09:09:46: //8130/E3FCE46DB3A5/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:09:47 2013: <191>160977:    >>>>CCAPI handed cid 8130 with tag 20015 to app "_ManagedAppProcess_Default"
Wed Mar 20 09:09:47 2013: <191>160978: .Mar 20 09:09:46: //8130/E3FCE46DB3A5/CCAPI/ccCallSetupAck:
Wed Mar 20 09:09:47 2013: <191>160979:    Call Id=8130
Wed Mar 20 09:09:47 2013: <191>160980: .Mar 20 09:09:46: //8130/E3FCE46DB3A5/CCAPI/cc_api_set_transfer_info:
Wed Mar 20 09:09:47 2013: <191>160981:
Wed Mar 20 09:09:47 2013: <191>160985:    Tone Direction=Network, Params=0x0, Call Id=8130
Wed Mar 20 09:09:47 2013: <191>160986: .Mar 20 09:09:46: //8130/E3FCE46DB3A5/CCAPI/ccSetDigitTimeouts:
Wed Mar 20 09:09:47 2013: <191>160987:    Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
Wed Mar 20 09:09:47 2013: <191>160988: .Mar 20 09:09:46: //8130/E3FCE46DB3A5/CCAPI/ccSetDigitTimeouts:
Wed Mar 20 09:09:48 2013: <191>160994: Enabled=TRUE, Call Id=8130
Wed Mar 20 09:09:48 2013: <191>160995: .Mar 20 09:09:46: //8130/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:09:48 2013: <191>160996:    (vdbPtr=0x4B805B90, callID=0x1FC2, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:09:48 2013: <191>160997: .Mar 20 09:09:46: //8130/E3FCE46DB3A5/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:09:48 2013: <191>160998:    Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8130
Wed Mar 20 09:09:48 2013: <191>160999: .Mar 20 09:09:46: //8130/E3FCE46DB3A5/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:09:48 2013: <191>161000:    Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:09:50 2013: <191>161001: .Mar 20 09:09:49: //8130/E3FCE46DB3A5/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:09:50 2013: <191>161002:    Cause Value=16, Interface=0x4B805B90, Call Id=8130
Wed Mar 20 09:09:50 2013: <191>161003: .Mar 20 09:09:49: //8130/E3FCE46DB3A5/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:09:50 2013: <191>161004:    Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:09:50 2013: <191>161005: .Mar 20 09:09:49: //8130/E3FCE46DB3A5/CCAPI/ccCallDisconnect:
Wed Mar 20 09:09:50 2013: <191>161006:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:09:50 2013: <191>161007: .Mar 20 09:09:49: //8130/E3FCE46DB3A5/CCAPI/ccCallDisconnect:
Wed Mar 20 09:09:50 2013: <191>161008:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:09:50 2013: <191>161009: .Mar 20 09:09:49: //8130/E3FCE46DB3A5/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:09:50 2013: <191>161010:    Transfer Number Is Null
Wed Mar 20 09:09:51 2013: <191>161011: .Mar 20 09:09:49: //8130/E3FCE46DB3A5/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:09:51 2013: <191>161012:    Disposition=0, Interface=0x4B805B90, Tag=0x0, Call Id=8130,
Wed Mar 20 09:09:51 2013: <191>161013:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:09:51 2013: <191>161014: .Mar 20 09:09:49: //8130/E3FCE46DB3A5/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:09:51 2013: <191>161015:    Call Disconnect Event Sent
Wed Mar 20 09:09:51 2013: <191>161016: .Mar 20 09:09:49: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:09:51 2013: <191>161017:
Wed Mar 20 09:09:51 2013: <191>161018: .Mar 20 09:09:49: :cc_free_feature_vsa freeing 47B81CE0
Wed Mar 20 09:09:51 2013: <191>161019: .Mar 20 09:09:49: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:09:51 2013: <191>161020:
Wed Mar 20 09:09:51 2013: <191>161021: .Mar 20 09:09:49:  vsacount in free is 0
Wed Mar 20 09:10:17 2013: <191>161022: .Mar 20 09:10:16: //-1/F5B82C11B3A9/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:10:17 2013: <191>161023:    cc_api_call_setup_ind_common:
Wed Mar 20 09:10:17 2013: <191>161024:    cisco-username=
Wed Mar 20 09:10:17 2013: <191>161025:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:10:17 2013: <191>161026:    cisco-ani=1811032013
Wed Mar 20 09:10:17 2013: <191>161027:    cisco-anitype=0
Wed Mar 20 09:10:17 2013: <191>161028:    cisco-aniplan=0
Wed Mar 20 09:10:17 2013: <191>161029:    cisco-anipi=0
Wed Mar 20 09:10:17 2013: <191>161030:    cisco-anisi=0
Wed Mar 20 09:10:17 2013: <191>161031:    dest=
Wed Mar 20 09:10:17 2013: <191>161032:    cisco-desttype=0
Wed Mar 20 09:10:17 2013: <191>161033:    cisco-destplan=0
Wed Mar 20 09:10:17 2013: <191>161034:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:10:17 2013: <191>161035:    cisco-rdn=
Wed Mar 20 09:10:17 2013: <191>161036:    cisco-lastrdn=
Wed Mar 20 09:10:17 2013: <191>161037:    cisco-rdntype=0
Wed Mar 20 09:10:17 2013: <191>161038:    cisco-rdnplan=0
Wed Mar 20 09:10:17 2013: <191>161039:    cisco-rdnpi=0
Wed Mar 20 09:10:17 2013: <191>161040:    cisco-rdnsi=0
Wed Mar 20 09:10:17 2013: <191>161041:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:10:17 2013: <191>161042:    final_redirectNumber =
Wed Mar 20 09:10:17 2013: <191>161043:    hunt_group_timeout =0
Wed Mar 20 09:10:17 2013: <191>161044:
Wed Mar 20 09:10:17 2013: <191>161045: .Mar 20 09:10:16: //-1/F5B82C11B3A9/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:10:17 2013: <191>161046:
Wed Mar 20 09:10:17 2013: <191>161047: Interface=0x4B805B90, Call Info(
Wed Mar 20 09:10:17 2013: <191>161048:    Calling Number=1811032013,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:10:17 2013: <191>161049:    Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:10:17 2013: <191>161050:    Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:10:17 2013: <191>161051:    Incoming Dial-peer=20015, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:10:17 2013: <191>161052:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:10:17 2013: <191>161053: .Mar 20 09:10:16: //-1/F5B82C11B3A9/CCAPI/ccCheckClipClir:
Wed Mar 20 09:10:17 2013: <191>161054:    In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:10:17 2013: <191>161055: .Mar 20 09:10:16: //-1/F5B82C11B3A9/CCAPI/ccCheckClipClir:
Wed Mar 20 09:10:17 2013: <191>161056:    Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:10:17 2013: <191>161057: .Mar 20 09:10:16: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:17 2013: <191>161058:
Wed Mar 20 09:10:17 2013: <191>161059: .Mar 20 09:10:16: :cc_get_feature_vsa malloc success
Wed Mar 20 09:10:17 2013: <191>161060: .Mar 20 09:10:16: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:17 2013: <191>161061:
Wed Mar 20 09:10:17 2013: <191>161062: .Mar 20 09:10:16:  cc_get_feature_vsa count is 1
Wed Mar 20 09:10:17 2013: <191>161063: .Mar 20 09:10:16: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:17 2013: <191>161064:
Wed Mar 20 09:10:17 2013: <191>161065: .Mar 20 09:10:16: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248360,feature_id:8131
Wed Mar 20 09:10:17 2013: <191>161066: .Mar 20 09:10:16: //8131/F5B82C11B3A9/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:10:17 2013: <191>161067:
Wed Mar 20 09:10:17 2013: <191>161068: Set Up Event Sent;
Wed Mar 20 09:10:17 2013: <191>161069:    Call Info(Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:10:17 2013: <191>161070:    Called Number=(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:10:17 2013: <191>161071: .Mar 20 09:10:16: //8131/F5B82C11B3A9/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:10:17 2013: <191>161072:    Event=0x4982FA50
Wed Mar 20 09:10:17 2013: <191>161090:    (callID=0x1FC3, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:10:17 2013: <191>161091: .Mar 20 09:10:16: //8131/F5B82C11B3A9/CCAPI/ccCallReportDigits:
Wed Mar 20 09:10:17 2013: <191>161092:
Wed Mar 20 09:10:18 2013: <191>161093: Enabled=TRUE, Call Id=8131
Wed Mar 20 09:10:18 2013: <191>161094: .Mar 20 09:10:16: //8131/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:18 2013: <191>161095:    (vdbPtr=0x4B805B90, callID=0x1FC3, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:10:18 2013: <191>161096: .Mar 20 09:10:16: //8131/F5B82C11B3A9/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:18 2013: <191>161097:    Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8131
Wed Mar 20 09:10:18 2013: <191>161098: .Mar 20 09:10:16: //8131/F5B82C11B3A9/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:18 2013: <191>161099:    Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:10:26 2013: <191>161100: .Mar 20 09:10:25: //8131/F5B82C11B3A9/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:10:26 2013: <191>161101:    Cause Value=16, Interface=0x4B805B90, Call Id=8131
Wed Mar 20 09:10:26 2013: <191>161102: .Mar 20 09:10:25: //8131/F5B82C11B3A9/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:10:26 2013: <191>161103:    Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:10:26 2013: <191>161104: .Mar 20 09:10:25: //8131/F5B82C11B3A9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:10:26 2013: <191>161105:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:10:26 2013: <191>161106: .Mar 20 09:10:25: //8131/F5B82C11B3A9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:10:26 2013: <191>161107:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:10:26 2013: <191>161108: .Mar 20 09:10:25: //8131/F5B82C11B3A9/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:10:26 2013: <191>161109:    Transfer Number Is Null
Wed Mar 20 09:10:27 2013: <191>161110: .Mar 20 09:10:25: //8131/F5B82C11B3A9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:10:27 2013: <191>161111:    Disposition=0, Interface=0x4B805B90, Tag=0x0, Call Id=8131,
Wed Mar 20 09:10:27 2013: <191>161112:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:10:27 2013: <191>161113: .Mar 20 09:10:25: //8131/F5B82C11B3A9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:10:27 2013: <191>161114:    Call Disconnect Event Sent
Wed Mar 20 09:10:27 2013: <191>161115: .Mar 20 09:10:25: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:10:27 2013: <191>161116:
Wed Mar 20 09:10:27 2013: <191>161117: .Mar 20 09:10:25: :cc_free_feature_vsa freeing 47B81CE0
Wed Mar 20 09:10:27 2013: <191>161118: .Mar 20 09:10:25: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:10:27 2013: <191>161119:
Wed Mar 20 09:10:27 2013: <191>161120: .Mar 20 09:10:25:  vsacount in free is 0
Wed Mar 20 09:10:28 2013: <191>161121: .Mar 20 09:10:27: //-1/FC6BE765B3AD/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:10:28 2013: <191>161122:    cc_api_call_setup_ind_common:
Wed Mar 20 09:10:28 2013: <191>161123:    cisco-username=
Wed Mar 20 09:10:28 2013: <191>161124:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:10:28 2013: <191>161125:    cisco-ani=1811032013
Wed Mar 20 09:10:28 2013: <191>161126:    cisco-anitype=0
Wed Mar 20 09:10:28 2013: <191>161127:    cisco-aniplan=0
Wed Mar 20 09:10:28 2013: <191>161128:    cisco-anipi=0
Wed Mar 20 09:10:28 2013: <191>161129:    cisco-anisi=0
Wed Mar 20 09:10:28 2013: <191>161130:    dest=
Wed Mar 20 09:10:28 2013: <191>161131:    cisco-desttype=0
Wed Mar 20 09:10:28 2013: <191>161132:    cisco-destplan=0
Wed Mar 20 09:10:28 2013: <191>161133:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:10:28 2013: <191>161134:    cisco-rdn=
Wed Mar 20 09:10:28 2013: <191>161135:    cisco-lastrdn=
Wed Mar 20 09:10:28 2013: <191>161136:    cisco-rdntype=0
Wed Mar 20 09:10:28 2013: <191>161137:    cisco-rdnplan=0
Wed Mar 20 09:10:28 2013: <191>161138:    cisco-rdnpi=0
Wed Mar 20 09:10:28 2013: <191>161139:    cisco-rdnsi=0
Wed Mar 20 09:10:28 2013: <191>161140:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:10:28 2013: <191>161141:    final_redirectNumber =
Wed Mar 20 09:10:28 2013: <191>161142:    hunt_group_timeout =0
Wed Mar 20 09:10:28 2013: <191>161143:
Wed Mar 20 09:10:28 2013: <191>161144: .Mar 20 09:10:27: //-1/FC6BE765B3AD/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:10:28 2013: <191>161145:
Wed Mar 20 09:10:28 2013: <191>161146: Interface=0x4B805B90, Call Info(
Wed Mar 20 09:10:28 2013: <191>161147:    Calling Number=1811032013,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:10:28 2013: <191>161148:    Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:10:28 2013: <191>161149:    Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:10:28 2013: <191>161150:    Incoming Dial-peer=20015, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:10:28 2013: <191>161151:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:10:28 2013: <191>161152: .Mar 20 09:10:27: //-1/FC6BE765B3AD/CCAPI/ccCheckClipClir:
Wed Mar 20 09:10:28 2013: <191>161153:    In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:10:28 2013: <191>161154: .Mar 20 09:10:27: //-1/FC6BE765B3AD/CCAPI/ccCheckClipClir:
Wed Mar 20 09:10:28 2013: <191>161155:    Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:10:28 2013: <191>161156: .Mar 20 09:10:27: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:28 2013: <191>161157:
Wed Mar 20 09:10:28 2013: <191>161158: .Mar 20 09:10:27: :cc_get_feature_vsa malloc success
Wed Mar 20 09:10:28 2013: <191>161159: .Mar 20 09:10:27: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:28 2013: <191>161160:
Wed Mar 20 09:10:28 2013: <191>161161: .Mar 20 09:10:27:  cc_get_feature_vsa count is 1
Wed Mar 20 09:10:28 2013: <191>161162: .Mar 20 09:10:27: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:28 2013: <191>161163:
Wed Mar 20 09:10:28 2013: <191>161164: .Mar 20 09:10:27: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203326024,feature_id:8132
Wed Mar 20 09:10:28 2013: <191>161165: .Mar 20 09:10:27: //8132/FC6BE765B3AD/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:10:28 2013: <191>161166:
Wed Mar 20 09:10:28 2013: <191>161168:    Call Info(Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:10:28 2013: <191>161169:    Called Number=(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:10:28 2013: <191>161172: .Mar 20 09:10:27: //8132/FC6BE765B3AD/CCAPI/ccCallSetContext:
Wed Mar 20 09:10:28 2013: <191>161173:    Context=0x4BA67528
Wed Mar 20 09:10:28 2013: <191>161181: .Mar 20 09:10:27: //8132/FC6BE765B3AD/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:10:28 2013: <191>161182:    Stop Tone On Digit=TRUE, Tone=Dial Tone,
Wed Mar 20 09:10:28 2013: <191>161183:    Tone Direction=Network, Params=0x0, Call Id=8132
Wed Mar 20 09:10:28 2013: <191>161184: .Mar 20 09:10:27: //8132/FC6BE765B3AD/CCAPI/ccSetDigitTimeouts:
Wed Mar 20 09:10:29 2013: <191>161192: Enabled=TRUE, Call Id=8132
Wed Mar 20 09:10:29 2013: <191>161193: .Mar 20 09:10:27: //8132/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:29 2013: <191>161194:    (vdbPtr=0x4B805B90, callID=0x1FC4, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:10:29 2013: <191>161195: .Mar 20 09:10:27: //8132/FC6BE765B3AD/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:29 2013: <191>161196:    Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8132
Wed Mar 20 09:10:29 2013: <191>161197: .Mar 20 09:10:27: //8132/FC6BE765B3AD/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:29 2013: <191>161198:    Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:10:38 2013: <191>161199: .Mar 20 09:10:37: //8132/FC6BE765B3AD/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:10:38 2013: <191>161200:    Cause Value=16, Interface=0x4B805B90, Call Id=8132
Wed Mar 20 09:10:38 2013: <191>161201: .Mar 20 09:10:37: //8132/FC6BE765B3AD/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:10:38 2013: <191>161202:    Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:10:38 2013: <191>161203: .Mar 20 09:10:37: //8132/FC6BE765B3AD/CCAPI/ccCallDisconnect:
Wed Mar 20 09:10:38 2013: <191>161204:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:10:38 2013: <191>161205: .Mar 20 09:10:37: //8132/FC6BE765B3AD/CCAPI/ccCallDisconnect:
Wed Mar 20 09:10:38 2013: <191>161206:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:10:38 2013: <191>161207: .Mar 20 09:10:37: //8132/FC6BE765B3AD/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:10:38 2013: <191>161208:    Transfer Number Is Null
Wed Mar 20 09:10:39 2013: <191>161209: .Mar 20 09:10:37: //8132/FC6BE765B3AD/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:10:39 2013: <191>161210:    Disposition=0, Interface=0x4B805B90, Tag=0x0, Call Id=8132,
Wed Mar 20 09:10:39 2013: <191>161211:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:10:39 2013: <191>161212: .Mar 20 09:10:37: //8132/FC6BE765B3AD/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:10:39 2013: <191>161213:    Call Disconnect Event Sent
Wed Mar 20 09:10:39 2013: <191>161214: .Mar 20 09:10:37: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:10:39 2013: <191>161215:
Wed Mar 20 09:10:39 2013: <191>161216: .Mar 20 09:10:37: :cc_free_feature_vsa freeing 47B94C40
Wed Mar 20 09:10:39 2013: <191>161217: .Mar 20 09:10:37: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:10:39 2013: <191>161218:
Wed Mar 20 09:10:39 2013: <191>161219: .Mar 20 09:10:37:  vsacount in free is 0
Wed Mar 20 09:10:40 2013: <191>161220: .Mar 20 09:10:39: //-1/035C1122B3B1/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:10:40 2013: <191>161221:    cc_api_call_setup_ind_common:
Wed Mar 20 09:10:40 2013: <191>161222:    cisco-username=
Wed Mar 20 09:10:40 2013: <191>161223:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:10:40 2013: <191>161224:    cisco-ani=1811032013
Wed Mar 20 09:10:40 2013: <191>161225:    cisco-anitype=0
Wed Mar 20 09:10:40 2013: <191>161226:    cisco-aniplan=0
Wed Mar 20 09:10:40 2013: <191>161227:    cisco-anipi=0
Wed Mar 20 09:10:40 2013: <191>161228:    cisco-anisi=0
Wed Mar 20 09:10:40 2013: <191>161229:    dest=
Wed Mar 20 09:10:40 2013: <191>161230:    cisco-desttype=0
Wed Mar 20 09:10:40 2013: <191>161231:    cisco-destplan=0
Wed Mar 20 09:10:40 2013: <191>161232:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:10:40 2013: <191>161233:    cisco-rdn=
Wed Mar 20 09:10:40 2013: <191>161234:    cisco-lastrdn=
Wed Mar 20 09:10:40 2013: <191>161235:    cisco-rdntype=0
Wed Mar 20 09:10:40 2013: <191>161236:    cisco-rdnplan=0
Wed Mar 20 09:10:40 2013: <191>161237:    cisco-rdnpi=0
Wed Mar 20 09:10:40 2013: <191>161238:    cisco-rdnsi=0
Wed Mar 20 09:10:40 2013: <191>161239:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:10:40 2013: <191>161240:    final_redirectNumber =
Wed Mar 20 09:10:40 2013: <191>161241:    hunt_group_timeout =0
Wed Mar 20 09:10:40 2013: <191>161242:
Wed Mar 20 09:10:40 2013: <191>161243: .Mar 20 09:10:39: //-1/035C1122B3B1/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:10:40 2013: <191>161244:
Wed Mar 20 09:10:40 2013: <191>161245: Interface=0x4B805B90, Call Info(
Wed Mar 20 09:10:40 2013: <191>161246:    Calling Number=1811032013,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:10:40 2013: <191>161247:    Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:10:40 2013: <191>161248:    Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:10:40 2013: <191>161249:    Incoming Dial-peer=20015, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:10:40 2013: <191>161250:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:10:40 2013: <191>161251: .Mar 20 09:10:39: //-1/035C1122B3B1/CCAPI/ccCheckClipClir:
Wed Mar 20 09:10:40 2013: <191>161252:    In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:10:40 2013: <191>161253: .Mar 20 09:10:39: //-1/035C1122B3B1/CCAPI/ccCheckClipClir:
Wed Mar 20 09:10:40 2013: <191>161254:    Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:10:40 2013: <191>161255: .Mar 20 09:10:39: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:40 2013: <191>161256:
Wed Mar 20 09:10:40 2013: <191>161257: .Mar 20 09:10:39: :cc_get_feature_vsa malloc success
Wed Mar 20 09:10:40 2013: <191>161258: .Mar 20 09:10:39: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:40 2013: <191>161259:
Wed Mar 20 09:10:40 2013: <191>161260: .Mar 20 09:10:39:  cc_get_feature_vsa count is 1
Wed Mar 20 09:10:40 2013: <191>161261: .Mar 20 09:10:39: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:40 2013: <191>161262:
Wed Mar 20 09:10:40 2013: <191>161263: .Mar 20 09:10:39: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248360,feature_id:8133
Wed Mar 20 09:10:40 2013: <191>161264: .Mar 20 09:10:39: //8133/035C1122B3B1/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:10:40 2013: <191>161265:
Wed Mar 20 09:10:40 2013: <191>161266: Set Up Event Sent;
Wed Mar 20 09:10:40 2013: <191>161267:    Call Info(Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:10:40 2013: <191>161270:    Event=0x4982FA50
Wed Mar 20 09:10:40 2013: <191>161274:    >>>>CCAPI handed cid 8133 with tag 20015 to app "_ManagedAppProcess_Default"
Wed Mar 20 09:10:40 2013: <191>161275: .Mar 20 09:10:39: //8133/035C1122B3B1/CCAPI/ccCallSetupAck:
Wed Mar 20 09:10:40 2013: <191>161276:    Call Id=8133
Wed Mar 20 09:10:40 2013: <191>161280: .Mar 20 09:10:39: //8133/035C1122B3B1/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:10:40 2013: <191>161289: .Mar 20 09:10:39: //8133/035C1122B3B1/CCAPI/ccCallReportDigits:
Wed Mar 20 09:10:40 2013: <191>161290:
Wed Mar 20 09:10:41 2013: <191>161291: Enabled=TRUE, Call Id=8133
Wed Mar 20 09:10:41 2013: <191>161292: .Mar 20 09:10:39: //8133/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:41 2013: <191>161293:    (vdbPtr=0x4B805B90, callID=0x1FC5, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:10:41 2013: <191>161294: .Mar 20 09:10:39: //8133/035C1122B3B1/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:41 2013: <191>161295:    Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8133
Wed Mar 20 09:10:41 2013: <191>161296: .Mar 20 09:10:39: //8133/035C1122B3B1/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:41 2013: <191>161297:    Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:10:45 2013: <191>161298: .Mar 20 09:10:43: //8133/035C1122B3B1/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:10:45 2013: <191>161299:    Cause Value=16, Interface=0x4B805B90, Call Id=8133
Wed Mar 20 09:10:45 2013: <191>161300: .Mar 20 09:10:43: //8133/035C1122B3B1/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:10:45 2013: <191>161301:    Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:10:45 2013: <191>161302: .Mar 20 09:10:43: //8133/035C1122B3B1/CCAPI/ccCallDisconnect:
Wed Mar 20 09:10:45 2013: <191>161303:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:10:45 2013: <191>161304: .Mar 20 09:10:43: //8133/035C1122B3B1/CCAPI/ccCallDisconnect:
Wed Mar 20 09:10:45 2013: <191>161305:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:10:45 2013: <191>161306: .Mar 20 09:10:43: //8133/035C1122B3B1/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:10:45 2013: <191>161307:    Transfer Number Is Null
Wed Mar 20 09:10:46 2013: <191>161308: .Mar 20 09:10:43: //8133/035C1122B3B1/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:10:46 2013: <191>161309:    Disposition=0, Interface=0x4B805B90, Tag=0x0, Call Id=8133,
Wed Mar 20 09:10:46 2013: <191>161310:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:10:46 2013: <191>161311: .Mar 20 09:10:43: //8133/035C1122B3B1/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:10:46 2013: <191>161312:    Call Disconnect Event Sent
Wed Mar 20 09:10:46 2013: <191>161313: .Mar 20 09:10:43: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:10:46 2013: <191>161314:
Wed Mar 20 09:10:46 2013: <191>161315: .Mar 20 09:10:43: :cc_free_feature_vsa freeing 47B81CE0
Wed Mar 20 09:10:46 2013: <191>161316: .Mar 20 09:10:43: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:10:46 2013: <191>161317:
Wed Mar 20 09:10:46 2013: <191>161318: .Mar 20 09:10:43:  vsacount in free is 0
Wed Mar 20 09:10:50 2013: <191>161319: .Mar 20 09:10:49: //-1/097909D5B3B5/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:10:50 2013: <191>161320:    cc_api_call_setup_ind_common:
Wed Mar 20 09:10:50 2013: <191>161321:    cisco-username=
Wed Mar 20 09:10:50 2013: <191>161322:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:10:50 2013: <191>161323:    cisco-ani=1811032013
Wed Mar 20 09:10:50 2013: <191>161324:    cisco-anitype=0
Wed Mar 20 09:10:50 2013: <191>161325:    cisco-aniplan=0
Wed Mar 20 09:10:50 2013: <191>161326:    cisco-anipi=0
Wed Mar 20 09:10:50 2013: <191>161327:    cisco-anisi=0
Wed Mar 20 09:10:50 2013: <191>161328:    dest=
Wed Mar 20 09:10:50 2013: <191>161329:    cisco-desttype=0
Wed Mar 20 09:10:50 2013: <191>161330:    cisco-destplan=0
Wed Mar 20 09:10:50 2013: <191>161331:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:10:50 2013: <191>161332:    cisco-rdn=
Wed Mar 20 09:10:50 2013: <191>161333:    cisco-lastrdn=
Wed Mar 20 09:10:50 2013: <191>161334:    cisco-rdntype=0
Wed Mar 20 09:10:50 2013: <191>161335:    cisco-rdnplan=0
Wed Mar 20 09:10:50 2013: <191>161336:    cisco-rdnpi=0
Wed Mar 20 09:10:50 2013: <191>161337:    cisco-rdnsi=0
Wed Mar 20 09:10:50 2013: <191>161338:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:10:50 2013: <191>161339:    final_redirectNumber =
Wed Mar 20 09:10:50 2013: <191>161340:    hunt_group_timeout =0
Wed Mar 20 09:10:50 2013: <191>161341:
Wed Mar 20 09:10:50 2013: <191>161342: .Mar 20 09:10:49: //-1/097909D5B3B5/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:10:50 2013: <191>161343:
Wed Mar 20 09:10:50 2013: <191>161344: Interface=0x4B805B90, Call Info(
Wed Mar 20 09:10:50 2013: <191>161345:    Calling Number=1811032013,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:10:50 2013: <191>161346:    Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:10:50 2013: <191>161347:    Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:10:50 2013: <191>161348:    Incoming Dial-peer=20015, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:10:50 2013: <191>161349:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:10:50 2013: <191>161350: .Mar 20 09:10:49: //-1/097909D5B3B5/CCAPI/ccCheckClipClir:
Wed Mar 20 09:10:50 2013: <191>161351:    In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:10:50 2013: <191>161352: .Mar 20 09:10:49: //-1/097909D5B3B5/CCAPI/ccCheckClipClir:
Wed Mar 20 09:10:50 2013: <191>161353:    Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:10:50 2013: <191>161354: .Mar 20 09:10:49: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:50 2013: <191>161355:
Wed Mar 20 09:10:50 2013: <191>161356: .Mar 20 09:10:49: :cc_get_feature_vsa malloc success
Wed Mar 20 09:10:50 2013: <191>161357: .Mar 20 09:10:49: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:50 2013: <191>161358:
Wed Mar 20 09:10:50 2013: <191>161359: .Mar 20 09:10:49:  cc_get_feature_vsa count is 1
Wed Mar 20 09:10:50 2013: <191>161360: .Mar 20 09:10:49: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:50 2013: <191>161361:
Wed Mar 20 09:10:50 2013: <191>161362: .Mar 20 09:10:49: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203326024,feature_id:8134
Wed Mar 20 09:10:50 2013: <191>161363: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:10:50 2013: <191>161364:
Wed Mar 20 09:10:50 2013: <191>161365: Set Up Event Sent;
Wed Mar 20 09:10:50 2013: <191>161366:    Call Info(Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:10:50 2013: <191>161367:    Called Number=(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:10:50 2013: <191>161368: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:10:50 2013: <191>161369:    Event=0x4982FA50
Wed Mar 20 09:10:50 2013: <191>161370: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/ccCallSetContext:
Wed Mar 20 09:10:50 2013: <191>161371:    Context=0x4BA792A0
Wed Mar 20 09:10:50 2013: <191>161372: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:10:50 2013: <191>161373:    >>>>CCAPI handed cid 8134 with tag 20015 to app "_ManagedAppProcess_Default"
Wed Mar 20 09:10:50 2013: <191>161374: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/ccCallSetupAck:
Wed Mar 20 09:10:50 2013: <191>161375:    Call Id=8134
Wed Mar 20 09:10:50 2013: <191>161376: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/cc_api_set_transfer_info:
Wed Mar 20 09:10:50 2013: <191>161381:    Tone Direction=Network, Params=0x0, Call Id=8134
Wed Mar 20 09:10:50 2013: <191>161382: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/ccSetDigitTimeouts:
Wed Mar 20 09:10:50 2013: <191>161384: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/ccSetDigitTimeouts:
Wed Mar 20 09:10:50 2013: <191>161387:    (callID=0x1FC6, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:10:50 2013: <191>161390: Enabled=TRUE, Call Id=8134
Wed Mar 20 09:10:50 2013: <191>161391: .Mar 20 09:10:49: //8134/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:50 2013: <191>161392:    (vdbPtr=0x4B805B90, callID=0x1FC6, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:10:50 2013: <191>161393: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:50 2013: <191>161394:    Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8134
Wed Mar 20 09:10:50 2013: <191>161395: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:50 2013: <191>161396:    Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:10:50 2013: <191>161397: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:10:50 2013: <191>161398:    Cause Value=16, Interface=0x4B805B90, Call Id=8134
Wed Mar 20 09:10:50 2013: <191>161399: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:10:50 2013: <191>161400:    Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:10:50 2013: <191>161401: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/ccCallDisconnect:
Wed Mar 20 09:10:50 2013: <191>161402:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:10:50 2013: <191>161403: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/ccCallDisconnect:
Wed Mar 20 09:10:50 2013: <191>161404:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:10:50 2013: <191>161405: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:10:50 2013: <191>161406:    Transfer Number Is Null
Wed Mar 20 09:10:50 2013: <191>161407: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:10:50 2013: <191>161408:
Wed Mar 20 09:10:51 2013: <191>161409: Disposition=0, Interface=0x4B805B90, Tag=0x0, Call Id=8134,
Wed Mar 20 09:10:51 2013: <191>161410:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:10:51 2013: <191>161411: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:10:51 2013: <191>161412:    Call Disconnect Event Sent
Wed Mar 20 09:10:51 2013: <191>161413: .Mar 20 09:10:49: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:10:51 2013: <191>161414:
Wed Mar 20 09:10:51 2013: <191>161415: .Mar 20 09:10:49: :cc_free_feature_vsa freeing 47B94C40
Wed Mar 20 09:10:51 2013: <191>161416: .Mar 20 09:10:49: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:10:51 2013: <191>161417:
Wed Mar 20 09:10:51 2013: <191>161418: .Mar 20 09:10:49:  vsacount in free is 0
Wed Mar 20 09:10:52 2013: <191>161419: .Mar 20 09:10:51: //-1/0A8328ABB3B9/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:10:52 2013: <191>161420:    cc_api_call_setup_ind_common:
Wed Mar 20 09:10:52 2013: <191>161421:    cisco-username=
Wed Mar 20 09:10:52 2013: <191>161422:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:10:52 2013: <191>161423:    cisco-ani=1811032013
Wed Mar 20 09:10:52 2013: <191>161424:    cisco-anitype=0
Wed Mar 20 09:10:52 2013: <191>161425:    cisco-aniplan=0
Wed Mar 20 09:10:52 2013: <191>161426:    cisco-anipi=0
Wed Mar 20 09:10:52 2013: <191>161427:    cisco-anisi=0
Wed Mar 20 09:10:52 2013: <191>161428:    dest=
Wed Mar 20 09:10:52 2013: <191>161429:    cisco-desttype=0
Wed Mar 20 09:10:52 2013: <191>161430:    cisco-destplan=0
Wed Mar 20 09:10:52 2013: <191>161431:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:10:52 2013: <191>161432:    cisco-rdn=
Wed Mar 20 09:10:52 2013: <191>161433:    cisco-lastrdn=
Wed Mar 20 09:10:52 2013: <191>161434:    cisco-rdntype=0
Wed Mar 20 09:10:52 2013: <191>161435:    cisco-rdnplan=0
Wed Mar 20 09:10:52 2013: <191>161436:    cisco-rdnpi=0
Wed Mar 20 09:10:52 2013: <191>161437:    cisco-rdnsi=0
Wed Mar 20 09:10:52 2013: <191>161438:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:10:52 2013: <191>161439:    final_redirectNumber =
Wed Mar 20 09:10:52 2013: <191>161440:    hunt_group_timeout =0
Wed Mar 20 09:10:52 2013: <191>161441:
Wed Mar 20 09:10:52 2013: <191>161442: .Mar 20 09:10:51: //-1/0A8328ABB3B9/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:10:52 2013: <191>161443:
Wed Mar 20 09:10:52 2013: <191>161444: Interface=0x4B805B90, Call Info(
Wed Mar 20 09:10:52 2013: <191>161445:    Calling Number=1811032013,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:10:52 2013: <191>161446:    Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:10:52 2013: <191>161447:    Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:10:52 2013: <191>161448:    Incoming Dial-peer=20015, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:10:52 2013: <191>161449:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:10:52 2013: <191>161450: .Mar 20 09:10:51: //-1/0A8328ABB3B9/CCAPI/ccCheckClipClir:
Wed Mar 20 09:10:52 2013: <191>161451:    In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:10:52 2013: <191>161452: .Mar 20 09:10:51: //-1/0A8328ABB3B9/CCAPI/ccCheckClipClir:
Wed Mar 20 09:10:52 2013: <191>161453:    Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:10:52 2013: <191>161454: .Mar 20 09:10:51: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:52 2013: <191>161455:
Wed Mar 20 09:10:52 2013: <191>161456: .Mar 20 09:10:51: :cc_get_feature_vsa malloc success
Wed Mar 20 09:10:52 2013: <191>161457: .Mar 20 09:10:51: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:52 2013: <191>161458:
Wed Mar 20 09:10:52 2013: <191>161459: .Mar 20 09:10:51:  cc_get_feature_vsa count is 1
Wed Mar 20 09:10:52 2013: <191>161460: .Mar 20 09:10:51: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:52 2013: <191>161461:
Wed Mar 20 09:10:52 2013: <191>161462: .Mar 20 09:10:51: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248360,feature_id:8135
Wed Mar 20 09:10:52 2013: <191>161463: .Mar 20 09:10:51: //8135/0A8328ABB3B9/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:10:52 2013: <191>161464:
Wed Mar 20 09:10:52 2013: <191>161465: Set Up Event Sent;
Wed Mar 20 09:10:52 2013: <191>161470: .Mar 20 09:10:51: //8135/0A8328ABB3B9/CCAPI/ccCallSetContext:
Wed Mar 20 09:10:52 2013: <191>161474: .Mar 20 09:10:51: //8135/0A8328ABB3B9/CCAPI/ccCallSetupAck:
Wed Mar 20 09:10:52 2013: <191>161479: .Mar 20 09:10:51: //8135/0A8328ABB3B9/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:10:53 2013: <191>161490: Enabled=TRUE, Call Id=8135
Wed Mar 20 09:10:53 2013: <191>161491: .Mar 20 09:10:51: //8135/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:53 2013: <191>161492:    (vdbPtr=0x4B805B90, callID=0x1FC7, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:10:53 2013: <191>161493: .Mar 20 09:10:51: //8135/0A8328ABB3B9/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:53 2013: <191>161494:    Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8135
Wed Mar 20 09:10:53 2013: <191>161495: .Mar 20 09:10:51: //8135/0A8328ABB3B9/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:53 2013: <191>161496:    Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:11:05 2013: <191>161497: .Mar 20 09:11:04: //8135/0A8328ABB3B9/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:11:05 2013: <191>161498:    Cause Value=16, Interface=0x4B805B90, Call Id=8135
Wed Mar 20 09:11:05 2013: <191>161499: .Mar 20 09:11:04: //8135/0A8328ABB3B9/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:11:05 2013: <191>161500:    Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:11:05 2013: <191>161501: .Mar 20 09:11:04: //8135/0A8328ABB3B9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:05 2013: <191>161502:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:11:05 2013: <191>161503: .Mar 20 09:11:04: //8135/0A8328ABB3B9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:05 2013: <191>161504:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:11:05 2013: <191>161505: .Mar 20 09:11:04: //8135/0A8328ABB3B9/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:11:05 2013: <191>161506:    Transfer Number Is Null
Wed Mar 20 09:11:06 2013: <191>161507: .Mar 20 09:11:04: //8135/0A8328ABB3B9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:06 2013: <191>161508:    Disposition=0, Interface=0x4B805B90, Tag=0x0, Call Id=8135,
Wed Mar 20 09:11:06 2013: <191>161509:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:11:06 2013: <191>161510: .Mar 20 09:11:04: //8135/0A8328ABB3B9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:06 2013: <191>161511:    Call Disconnect Event Sent
Wed Mar 20 09:11:06 2013: <191>161512: .Mar 20 09:11:04: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:06 2013: <191>161513:
Wed Mar 20 09:11:06 2013: <191>161514: .Mar 20 09:11:04: :cc_free_feature_vsa freeing 47B81CE0
Wed Mar 20 09:11:06 2013: <191>161515: .Mar 20 09:11:04: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:06 2013: <191>161516:
Wed Mar 20 09:11:06 2013: <191>161517: .Mar 20 09:11:04:  vsacount in free is 0
Wed Mar 20 09:11:06 2013: <191>161518: .Mar 20 09:11:05: //-1/130B09BAB3BD/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:11:06 2013: <191>161519:    cc_api_call_setup_ind_common:
Wed Mar 20 09:11:06 2013: <191>161520:    cisco-username=
Wed Mar 20 09:11:06 2013: <191>161521:
Wed Mar 20 09:11:06 2013: <191>161522:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:11:06 2013: <191>161523:    cisco-ani=1811032013
Wed Mar 20 09:11:06 2013: <191>161524:    cisco-anitype=0
Wed Mar 20 09:11:06 2013: <191>161525:    cisco-aniplan=0
Wed Mar 20 09:11:06 2013: <191>161526:    cisco-anipi=0
Wed Mar 20 09:11:06 2013: <191>161527:    cisco-anisi=0
Wed Mar 20 09:11:06 2013: <191>161528:    dest=
Wed Mar 20 09:11:06 2013: <191>161529:    cisco-desttype=0
Wed Mar 20 09:11:06 2013: <191>161530:    cisco-destplan=0
Wed Mar 20 09:11:06 2013: <191>161531:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:11:06 2013: <191>161532:    cisco-rdn=
Wed Mar 20 09:11:06 2013: <191>161533:    cisco-lastrdn=
Wed Mar 20 09:11:06 2013: <191>161534:    cisco-rdntype=0
Wed Mar 20 09:11:06 2013: <191>161535:    cisco-rdnplan=0
Wed Mar 20 09:11:06 2013: <191>161536:    cisco-rdnpi=0
Wed Mar 20 09:11:06 2013: <191>161537:    cisco-rdnsi=0
Wed Mar 20 09:11:06 2013: <191>161538:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:11:06 2013: <191>161539:    final_redirectNumber =
Wed Mar 20 09:11:06 2013: <191>161540:    hunt_group_timeout =0
Wed Mar 20 09:11:06 2013: <191>161541:
Wed Mar 20 09:11:06 2013: <191>161542: .Mar 20 09:11:05: //-1/130B09BAB3BD/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:11:06 2013: <191>161543:
Wed Mar 20 09:11:06 2013: <191>161544: Interface=0x4B805B90, Call Info(
Wed Mar 20 09:11:06 2013: <191>161545:    Calling Number=1811032013,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:11:06 2013: <191>161546:    Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:11:06 2013: <191>161547:    Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:11:06 2013: <191>161548:    Incoming Dial-peer=20015, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:11:06 2013: <191>161549:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:11:06 2013: <191>161550: .Mar 20 09:11:05: //-1/130B09BAB3BD/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:06 2013: <191>161551:    In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:06 2013: <191>161554: .Mar 20 09:11:05: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:06 2013: <191>161556: .Mar 20 09:11:05: :cc_get_feature_vsa malloc success
Wed Mar 20 09:11:06 2013: <191>161558:
Wed Mar 20 09:11:06 2013: <191>161561:
Wed Mar 20 09:11:06 2013: <191>161564:
Wed Mar 20 09:11:06 2013: <191>161567:    Called Number=(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:11:06 2013: <191>161568: .Mar 20 09:11:05: //8136/130B09BAB3BD/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:11:06 2013: <191>161569:    Event=0x4982FA50
Wed Mar 20 09:11:06 2013: <191>161570: .Mar 20 09:11:05: //8136/130B09BAB3BD/CCAPI/ccCallSetContext:
Wed Mar 20 09:11:06 2013: <191>161571:    Context=0x4BA6FA60
Wed Mar 20 09:11:06 2013: <191>161574: .Mar 20 09:11:05: //8136/130B09BAB3BD/CCAPI/ccCallSetupAck:
Wed Mar 20 09:11:06 2013: <191>161577:
Wed Mar 20 09:11:06 2013: <191>161581:    Tone Direction=Network, Params=0x0, Call Id=8136
Wed Mar 20 09:11:07 2013: <191>161590: Enabled=TRUE, Call Id=8136
Wed Mar 20 09:11:07 2013: <191>161591: .Mar 20 09:11:05: //8136/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:07 2013: <191>161592:    (vdbPtr=0x4B805B90, callID=0x1FC8, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:11:07 2013: <191>161593: .Mar 20 09:11:05: //8136/130B09BAB3BD/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:07 2013: <191>161594:    Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8136
Wed Mar 20 09:11:07 2013: <191>161595: .Mar 20 09:11:05: //8136/130B09BAB3BD/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:07 2013: <191>161596:    Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:11:09 2013: <191>161597: .Mar 20 09:11:08: //8136/130B09BAB3BD/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:11:09 2013: <191>161598:    Cause Value=16, Interface=0x4B805B90, Call Id=8136
Wed Mar 20 09:11:09 2013: <191>161599: .Mar 20 09:11:08: //8136/130B09BAB3BD/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:11:09 2013: <191>161600:    Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:11:09 2013: <191>161601: .Mar 20 09:11:08: //8136/130B09BAB3BD/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:09 2013: <191>161602:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:11:09 2013: <191>161603: .Mar 20 09:11:08: //8136/130B09BAB3BD/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:09 2013: <191>161604:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:11:09 2013: <191>161605: .Mar 20 09:11:08: //8136/130B09BAB3BD/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:11:09 2013: <191>161606:    Transfer Number Is Null
Wed Mar 20 09:11:10 2013: <191>161607: .Mar 20 09:11:08: //8136/130B09BAB3BD/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:10 2013: <191>161608:    Disposition=0, Interface=0x4B805B90, Tag=0x0, Call Id=8136,
Wed Mar 20 09:11:10 2013: <191>161609:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:11:10 2013: <191>161610: .Mar 20 09:11:08: //8136/130B09BAB3BD/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:10 2013: <191>161611:    Call Disconnect Event Sent
Wed Mar 20 09:11:10 2013: <191>161612: .Mar 20 09:11:08: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:10 2013: <191>161613:
Wed Mar 20 09:11:10 2013: <191>161614: .Mar 20 09:11:08: :cc_free_feature_vsa freeing 47B94C40
Wed Mar 20 09:11:10 2013: <191>161615: .Mar 20 09:11:08: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:10 2013: <191>161616:
Wed Mar 20 09:11:10 2013: <191>161617: .Mar 20 09:11:08:  vsacount in free is 0
Wed Mar 20 09:11:10 2013: <191>161618: .Mar 20 09:11:09: //-1/155F5D54B3C1/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:11:10 2013: <191>161619:    cc_api_call_setup_ind_common:
Wed Mar 20 09:11:10 2013: <191>161620:    cisco-username=
Wed Mar 20 09:11:10 2013: <191>161621:
Wed Mar 20 09:11:10 2013: <191>161622:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:11:10 2013: <191>161623:    cisco-ani=1811032013
Wed Mar 20 09:11:10 2013: <191>161624:    cisco-anitype=0
Wed Mar 20 09:11:10 2013: <191>161625:    cisco-aniplan=0
Wed Mar 20 09:11:10 2013: <191>161626:    cisco-anipi=0
Wed Mar 20 09:11:10 2013: <191>161627:    cisco-anisi=0
Wed Mar 20 09:11:10 2013: <191>161628:    dest=
Wed Mar 20 09:11:10 2013: <191>161629:    cisco-desttype=0
Wed Mar 20 09:11:10 2013: <191>161630:    cisco-destplan=0
Wed Mar 20 09:11:10 2013: <191>161631:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:11:10 2013: <191>161632:    cisco-rdn=
Wed Mar 20 09:11:10 2013: <191>161633:    cisco-lastrdn=
Wed Mar 20 09:11:10 2013: <191>161634:    cisco-rdntype=0
Wed Mar 20 09:11:10 2013: <191>161635:    cisco-rdnplan=0
Wed Mar 20 09:11:10 2013: <191>161636:    cisco-rdnpi=0
Wed Mar 20 09:11:10 2013: <191>161637:    cisco-rdnsi=0
Wed Mar 20 09:11:10 2013: <191>161638:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:11:10 2013: <191>161639:    final_redirectNumber =
Wed Mar 20 09:11:10 2013: <191>161640:    hunt_group_timeout =0
Wed Mar 20 09:11:10 2013: <191>161641:
Wed Mar 20 09:11:10 2013: <191>161642: .Mar 20 09:11:09: //-1/155F5D54B3C1/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:11:10 2013: <191>161643:
Wed Mar 20 09:11:10 2013: <191>161644: Interface=0x4B805B90, Call Info(
Wed Mar 20 09:11:10 2013: <191>161645:    Calling Number=1811032013,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:11:10 2013: <191>161646:    Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:11:10 2013: <191>161647:    Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:11:10 2013: <191>161648:    Incoming Dial-peer=20015, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:11:10 2013: <191>161649:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:11:10 2013: <191>161650: .Mar 20 09:11:09: //-1/155F5D54B3C1/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:10 2013: <191>161651:    In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:10 2013: <191>161652: .Mar 20 09:11:09: //-1/155F5D54B3C1/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:10 2013: <191>161653:    Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:10 2013: <191>161655:
Wed Mar 20 09:11:10 2013: <191>161658:
Wed Mar 20 09:11:10 2013: <191>161661:
Wed Mar 20 09:11:10 2013: <191>161663: .Mar 20 09:11:09: //8137/155F5D54B3C1/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:11:10 2013: <191>161667:    Called Number=(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:11:10 2013: <191>161669:    Event=0x4982FA50
Wed Mar 20 09:11:10 2013: <191>161671:    Context=0x4BA69B38
Wed Mar 20 09:11:10 2013: <191>161672: .Mar 20 09:11:09: //8137/155F5D54B3C1/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:11:10 2013: <191>161675:    Call Id=8137
Wed Mar 20 09:11:10 2013: <191>161677:
Wed Mar 20 09:11:10 2013: <191>161679: .Mar 20 09:11:09: //8137/155F5D54B3C1/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:11:10 2013: <191>161683:    Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
Wed Mar 20 09:11:10 2013: <191>161686: .Mar 20 09:11:09: //8137/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
Wed Mar 20 09:11:11 2013: <191>161690: Enabled=TRUE, Call Id=8137
Wed Mar 20 09:11:11 2013: <191>161691: .Mar 20 09:11:09: //8137/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:11 2013: <191>161692:    (vdbPtr=0x4B805B90, callID=0x1FC9, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:11:11 2013: <191>161693: .Mar 20 09:11:09: //8137/155F5D54B3C1/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:11 2013: <191>161694:    Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8137
Wed Mar 20 09:11:11 2013: <191>161695: .Mar 20 09:11:09: //8137/155F5D54B3C1/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:11 2013: <191>161696:    Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:11:14 2013: <191>161697: .Mar 20 09:11:12: //8137/155F5D54B3C1/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:11:14 2013: <191>161698:    Cause Value=16, Interface=0x4B805B90, Call Id=8137
Wed Mar 20 09:11:14 2013: <191>161699: .Mar 20 09:11:12: //8137/155F5D54B3C1/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:11:14 2013: <191>161700:    Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:11:14 2013: <191>161701: .Mar 20 09:11:12: //8137/155F5D54B3C1/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:14 2013: <191>161702:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:11:14 2013: <191>161703: .Mar 20 09:11:12: //8137/155F5D54B3C1/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:14 2013: <191>161704:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:11:14 2013: <191>161705: .Mar 20 09:11:12: //8137/155F5D54B3C1/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:11:14 2013: <191>161706:    Transfer Number Is Null
Wed Mar 20 09:11:14 2013: <191>161707: .Mar 20 09:11:12: //8137/155F5D54B3C1/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:14 2013: <191>161708:    Disposition=0, Interface=0x4B805B90, Tag=0x0, Call Id=8137,
Wed Mar 20 09:11:14 2013: <191>161709:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:11:14 2013: <191>161710: .Mar 20 09:11:12: //8137/155F5D54B3C1/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:14 2013: <191>161711:    Call Disconnect Event Sent
Wed Mar 20 09:11:14 2013: <191>161712: .Mar 20 09:11:12: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:14 2013: <191>161713:
Wed Mar 20 09:11:14 2013: <191>161714: .Mar 20 09:11:12: :cc_free_feature_vsa freeing 47B81CE0
Wed Mar 20 09:11:14 2013: <191>161715: .Mar 20 09:11:12: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:14 2013: <191>161716:
Wed Mar 20 09:11:14 2013: <191>161717: .Mar 20 09:11:12:  vsacount in free is 0
Wed Mar 20 09:11:14 2013: <191>161718: .Mar 20 09:11:13: //-1/17F46303B3C5/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:11:14 2013: <191>161719:    cc_api_call_setup_ind_common:
Wed Mar 20 09:11:14 2013: <191>161720:    cisco-username=
Wed Mar 20 09:11:14 2013: <191>161721:
Wed Mar 20 09:11:14 2013: <191>161722:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:11:14 2013: <191>161723:    cisco-ani=1811032013
Wed Mar 20 09:11:14 2013: <191>161724:    cisco-anitype=0
Wed Mar 20 09:11:14 2013: <191>161725:    cisco-aniplan=0
Wed Mar 20 09:11:14 2013: <191>161726:    cisco-anipi=0
Wed Mar 20 09:11:14 2013: <191>161727:    cisco-anisi=0
Wed Mar 20 09:11:14 2013: <191>161728:    dest=
Wed Mar 20 09:11:14 2013: <191>161729:    cisco-desttype=0
Wed Mar 20 09:11:14 2013: <191>161730:    cisco-destplan=0
Wed Mar 20 09:11:14 2013: <191>161731:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:11:14 2013: <191>161732:    cisco-rdn=
Wed Mar 20 09:11:14 2013: <191>161733:    cisco-lastrdn=
Wed Mar 20 09:11:14 2013: <191>161734:    cisco-rdntype=0
Wed Mar 20 09:11:14 2013: <191>161735:    cisco-rdnplan=0
Wed Mar 20 09:11:14 2013: <191>161736:    cisco-rdnpi=0
Wed Mar 20 09:11:14 2013: <191>161737:    cisco-rdnsi=0
Wed Mar 20 09:11:14 2013: <191>161738:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:11:14 2013: <191>161739:    final_redirectNumber =
Wed Mar 20 09:11:14 2013: <191>161740:    hunt_group_timeout =0
Wed Mar 20 09:11:14 2013: <191>161741:
Wed Mar 20 09:11:14 2013: <191>161742: .Mar 20 09:11:13: //-1/17F46303B3C5/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:11:14 2013: <191>161743:
Wed Mar 20 09:11:14 2013: <191>161744: Interface=0x4B805B90, Call Info(
Wed Mar 20 09:11:14 2013: <191>161745:    Calling Number=1811032013,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:11:14 2013: <191>161746:    Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:11:14 2013: <191>161747:    Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:11:14 2013: <191>161748:    Incoming Dial-peer=20015, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:11:14 2013: <191>161749:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:11:14 2013: <191>161750: .Mar 20 09:11:13: //-1/17F46303B3C5/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:14 2013: <191>161751:    In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:14 2013: <191>161752: .Mar 20 09:11:13: //-1/17F46303B3C5/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:14 2013: <191>161753:    Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:14 2013: <191>161755:
Wed Mar 20 09:11:14 2013: <191>161756: .Mar 20 09:11:13: :cc_get_feature_vsa malloc success
Wed Mar 20 09:11:14 2013: <191>161759: .Mar 20 09:11:13:  cc_get_feature_vsa count is 1
Wed Mar 20 09:11:14 2013: <191>161761:
Wed Mar 20 09:11:14 2013: <191>161765: Set Up Event Sent;
Wed Mar 20 09:11:14 2013: <191>161767:    Called Number=(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:11:14 2013: <191>161769:    Event=0x4982FA50
Wed Mar 20 09:11:14 2013: <191>161773:    >>>>CCAPI handed cid 8138 with tag 20015 to app "_ManagedAppProcess_Default"
Wed Mar 20 09:11:14 2013: <191>161775:    Call Id=8138
Wed Mar 20 09:11:14 2013: <191>161777:
Wed Mar 20 09:11:14 2013: <191>161781:    Tone Direction=Network, Params=0x0, Call Id=8138
Wed Mar 20 09:11:15 2013: <191>161790: Enabled=TRUE, Call Id=8138
Wed Mar 20 09:11:15 2013: <191>161791: .Mar 20 09:11:13: //8138/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:15 2013: <191>161792:    (vdbPtr=0x4B805B90, callID=0x1FCA, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:11:15 2013: <191>161793: .Mar 20 09:11:13: //8138/17F46303B3C5/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:15 2013: <191>161794:    Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8138
Wed Mar 20 09:11:15 2013: <191>161795: .Mar 20 09:11:13: //8138/17F46303B3C5/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:15 2013: <191>161796:    Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:11:16 2013: <191>161797: .Mar 20 09:11:14: //8138/17F46303B3C5/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:11:16 2013: <191>161798:    Cause Value=16, Interface=0x4B805B90, Call Id=8138
Wed Mar 20 09:11:16 2013: <191>161799: .Mar 20 09:11:14: //8138/17F46303B3C5/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:11:16 2013: <191>161800:    Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:11:16 2013: <191>161801: .Mar 20 09:11:14: //8138/17F46303B3C5/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:16 2013: <191>161802:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:11:16 2013: <191>161803: .Mar 20 09:11:14: //8138/17F46303B3C5/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:16 2013: <191>161804:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:11:16 2013: <191>161805: .Mar 20 09:11:14: //8138/17F46303B3C5/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:11:16 2013: <191>161806:    Transfer Number Is Null
Wed Mar 20 09:11:17 2013: <191>161807: .Mar 20 09:11:14: //8138/17F46303B3C5/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:17 2013: <191>161808:    Disposition=0, Interface=0x4B805B90, Tag=0x0, Call Id=8138,
Wed Mar 20 09:11:17 2013: <191>161809:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:11:17 2013: <191>161810: .Mar 20 09:11:14: //8138/17F46303B3C5/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:17 2013: <191>161811:    Call Disconnect Event Sent
Wed Mar 20 09:11:17 2013: <191>161812: .Mar 20 09:11:14: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:17 2013: <191>161813:
Wed Mar 20 09:11:17 2013: <191>161814: .Mar 20 09:11:14: :cc_free_feature_vsa freeing 47B94C40
Wed Mar 20 09:11:17 2013: <191>161815: .Mar 20 09:11:14: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:17 2013: <191>161816:
Wed Mar 20 09:11:17 2013: <191>161817: .Mar 20 09:11:14:  vsacount in free is 0
Wed Mar 20 09:11:19 2013: <191>161818: .Mar 20 09:11:18: //-1/1A91F618B3C9/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:11:19 2013: <191>161819:    cc_api_call_setup_ind_common:
Wed Mar 20 09:11:19 2013: <191>161820:    cisco-username=
Wed Mar 20 09:11:19 2013: <191>161821:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:11:19 2013: <191>161822:    cisco-ani=1811032013
Wed Mar 20 09:11:19 2013: <191>161823:    cisco-anitype=0
Wed Mar 20 09:11:19 2013: <191>161824:    cisco-aniplan=0
Wed Mar 20 09:11:19 2013: <191>161825:    cisco-anipi=0
Wed Mar 20 09:11:19 2013: <191>161826:    cisco-anisi=0
Wed Mar 20 09:11:19 2013: <191>161827:    dest=
Wed Mar 20 09:11:19 2013: <191>161828:    cisco-desttype=0
Wed Mar 20 09:11:19 2013: <191>161829:    cisco-destplan=0
Wed Mar 20 09:11:19 2013: <191>161830:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:11:19 2013: <191>161831:    cisco-rdn=
Wed Mar 20 09:11:19 2013: <191>161832:    cisco-lastrdn=
Wed Mar 20 09:11:19 2013: <191>161833:    cisco-rdntype=0
Wed Mar 20 09:11:19 2013: <191>161834:    cisco-rdnplan=0
Wed Mar 20 09:11:19 2013: <191>161835:    cisco-rdnpi=0
Wed Mar 20 09:11:19 2013: <191>161836:    cisco-rdnsi=0
Wed Mar 20 09:11:19 2013: <191>161837:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:11:19 2013: <191>161838:    final_redirectNumber =
Wed Mar 20 09:11:19 2013: <191>161839:    hunt_group_timeout =0
Wed Mar 20 09:11:19 2013: <191>161840:
Wed Mar 20 09:11:19 2013: <191>161841: .Mar 20 09:11:18: //-1/1A91F618B3C9/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:11:19 2013: <191>161842:
Wed Mar 20 09:11:19 2013: <191>161843: Interface=0x4B805B90, Call Info(
Wed Mar 20 09:11:19 2013: <191>161844:    Calling Number=1811032013,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:11:19 2013: <191>161845:    Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:11:19 2013: <191>161846:    Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:11:19 2013: <191>161847:    Incoming Dial-peer=20015, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:11:19 2013: <191>161848:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:11:19 2013: <191>161849: .Mar 20 09:11:18: //-1/1A91F618B3C9/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:19 2013: <191>161850:    In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:19 2013: <191>161851: .Mar 20 09:11:18: //-1/1A91F618B3C9/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:19 2013: <191>161852:    Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:19 2013: <191>161853: .Mar 20 09:11:18: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:19 2013: <191>161854:
Wed Mar 20 09:11:19 2013: <191>161855: .Mar 20 09:11:18: :cc_get_feature_vsa malloc success
Wed Mar 20 09:11:19 2013: <191>161856: .Mar 20 09:11:18: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:19 2013: <191>161857:
Wed Mar 20 09:11:19 2013: <191>161858: .Mar 20 09:11:18:  cc_get_feature_vsa count is 1
Wed Mar 20 09:11:19 2013: <191>161859: .Mar 20 09:11:18: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:19 2013: <191>161860:
Wed Mar 20 09:11:19 2013: <191>161861: .Mar 20 09:11:18: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248360,feature_id:8139
Wed Mar 20 09:11:19 2013: <191>161862: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:11:19 2013: <191>161863:
Wed Mar 20 09:11:19 2013: <191>161864: Set Up Event Sent;
Wed Mar 20 09:11:19 2013: <191>161866:    Called Number=(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:11:19 2013: <191>161870:    Context=0x4BA6E758
Wed Mar 20 09:11:19 2013: <191>161878: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:11:19 2013: <191>161879:    Stop Tone On Digit=TRUE, Tone=Dial Tone,
Wed Mar 20 09:11:19 2013: <191>161888:
Wed Mar 20 09:11:19 2013: <191>161889: Enabled=TRUE, Call Id=8139
Wed Mar 20 09:11:19 2013: <191>161890: .Mar 20 09:11:18: //8139/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:19 2013: <191>161891:    (vdbPtr=0x4B805B90, callID=0x1FCB, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:11:19 2013: <191>161892: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:19 2013: <191>161897:
Wed Mar 20 09:11:19 2013: <191>161898: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:19 2013: <191>161899:    Source Call Id=8139, Digit=0, DigitBeginFlags=0x0,
Wed Mar 20 09:11:19 2013: <191>161900:    Rtp Timestamp=0x56EA0, Rtp Expiration=0x0
Wed Mar 20 09:11:19 2013: <191>161901: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:19 2013: <191>161902:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:19 2013: <191>161903:    Source Call Id=8139, Digit=0, Duration=100,
Wed Mar 20 09:11:19 2013: <191>161904:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:19 2013: <191>161905: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:19 2013: <191>161906:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:19 2013: <191>161907: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:19 2013: <191>161908:
Wed Mar 20 09:11:19 2013: <191>161909: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:19 2013: <191>161910:    Source Call Id=8139, Digit=3, DigitBeginFlags=0x0,
Wed Mar 20 09:11:19 2013: <191>161911:    Rtp Timestamp=0x5EBA0, Rtp Expiration=0x0
Wed Mar 20 09:11:19 2013: <191>161912: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:19 2013: <191>161913:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:19 2013: <191>161914:    Source Call Id=8139, Digit=3, Duration=100,
Wed Mar 20 09:11:19 2013: <191>161915:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:19 2013: <191>161916: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:19 2013: <191>161917:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:19 2013: <191>161918: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:19 2013: <191>161919:
Wed Mar 20 09:11:19 2013: <191>161920: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:19 2013: <191>161921:    Source Call Id=8139, Digit=3, DigitBeginFlags=0x0,
Wed Mar 20 09:11:19 2013: <191>161922:    Rtp Timestamp=0x668A0, Rtp Expiration=0x0
Wed Mar 20 09:11:19 2013: <191>161923: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:19 2013: <191>161924:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:19 2013: <191>161925:    Source Call Id=8139, Digit=3, Duration=100,
Wed Mar 20 09:11:19 2013: <191>161926:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:19 2013: <191>161927: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:19 2013: <191>161928:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:19 2013: <191>161929: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:19 2013: <191>161930:
Wed Mar 20 09:11:19 2013: <191>161931: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:19 2013: <191>161932:    Source Call Id=8139, Digit=2, DigitBeginFlags=0x0,
Wed Mar 20 09:11:19 2013: <191>161933:    Rtp Timestamp=0x6E5A0, Rtp Expiration=0x0
Wed Mar 20 09:11:19 2013: <191>161934: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:19 2013: <191>161935:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:19 2013: <191>161936:    Source Call Id=8139, Digit=2, Duration=100,
Wed Mar 20 09:11:19 2013: <191>161937:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:19 2013: <191>161938: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:19 2013: <191>161939:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:19 2013: <191>161940: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:19 2013: <191>161941:
Wed Mar 20 09:11:20 2013: <191>161942: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:20 2013: <191>161943:    Source Call Id=8139, Digit=4, DigitBeginFlags=0x0,
Wed Mar 20 09:11:20 2013: <191>161944:    Rtp Timestamp=0x762A0, Rtp Expiration=0x0
Wed Mar 20 09:11:20 2013: <191>161945: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:20 2013: <191>161946:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:20 2013: <191>161947:    Source Call Id=8139, Digit=4, Duration=100,
Wed Mar 20 09:11:20 2013: <191>161948:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:20 2013: <191>161949: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:20 2013: <191>161950:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:20 2013: <191>161951: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:20 2013: <191>161952:
Wed Mar 20 09:11:20 2013: <191>161953: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:20 2013: <191>161954:    Source Call Id=8139, Digit=1, DigitBeginFlags=0x0,
Wed Mar 20 09:11:20 2013: <191>161955:    Rtp Timestamp=0x7DFA0, Rtp Expiration=0x0
Wed Mar 20 09:11:20 2013: <191>161956: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:20 2013: <191>161957:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:20 2013: <191>161958:    Source Call Id=8139, Digit=1, Duration=100,
Wed Mar 20 09:11:20 2013: <191>161959:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:20 2013: <191>161960: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:20 2013: <191>161961:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:20 2013: <191>161962: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:20 2013: <191>161963:
Wed Mar 20 09:11:20 2013: <191>161964: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:20 2013: <191>161965:    Source Call Id=8139, Digit=5, DigitBeginFlags=0x0,
Wed Mar 20 09:11:20 2013: <191>161966:    Rtp Timestamp=0x85CA0, Rtp Expiration=0x0
Wed Mar 20 09:11:20 2013: <191>161967: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:20 2013: <191>161968:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:20 2013: <191>161969:    Source Call Id=8139, Digit=5, Duration=100,
Wed Mar 20 09:11:20 2013: <191>161970:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:20 2013: <191>161971: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:20 2013: <191>161972:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:20 2013: <191>161973: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:20 2013: <191>161974:
Wed Mar 20 09:11:20 2013: <191>161975: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:20 2013: <191>161976:    Source Call Id=8139, Digit=4, DigitBeginFlags=0x0,
Wed Mar 20 09:11:20 2013: <191>161977:    Rtp Timestamp=0x8D9A0, Rtp Expiration=0x0
Wed Mar 20 09:11:20 2013: <191>161978: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:20 2013: <191>161979:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:20 2013: <191>161980:    Source Call Id=8139, Digit=4, Duration=100,
Wed Mar 20 09:11:20 2013: <191>161981:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:20 2013: <191>161982: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:20 2013: <191>161983:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:20 2013: <191>161984: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:20 2013: <191>161985:
Wed Mar 20 09:11:20 2013: <191>161986: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:20 2013: <191>161987:    Source Call Id=8139, Digit=2, DigitBeginFlags=0x0,
Wed Mar 20 09:11:20 2013: <191>161988:    Rtp Timestamp=0x956A0, Rtp Expiration=0x0
Wed Mar 20 09:11:20 2013: <191>161989: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:20 2013: <191>161990:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:20 2013: <191>161991:    Source Call Id=8139, Digit=2, Duration=100,
Wed Mar 20 09:11:20 2013: <191>161992:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:20 2013: <191>161993: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:20 2013: <191>161994:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:20 2013: <191>161995: .Mar 20 09:11:19: //8139/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
Wed Mar 20 09:11:20 2013: <191>161996:    (callID=0x1FCB, digit_event=0x0, enable=FALSE, consume=FALSE)
Wed Mar 20 09:11:20 2013: <191>161997: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/ccCallReportDigits:
Wed Mar 20 09:11:20 2013: <191>161998:    Enabled=TRUE, Call Id=8139
Wed Mar 20 09:11:20 2013: <191>161999: .Mar 20 09:11:19: //8139/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:20 2013: <191>162000:    (vdbPtr=0x4B805B90, callID=0x1FCB, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Wed Mar 20 09:11:20 2013: <191>162001: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:20 2013: <191>162002:    Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8139
Wed Mar 20 09:11:20 2013: <191>162003: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:20 2013: <191>162004:    Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:11:20 2013: <191>162005: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/ccCallProceeding:
Wed Mar 20 09:11:20 2013: <191>162006:    Progress Indication=NULL(0)
Wed Mar 20 09:11:20 2013: <191>162007: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:11:20 2013: <191>162008:    Destination=, Calling IE Present=TRUE, Mode=0,
Wed Mar 20 09:11:20 2013: <191>162009:    Outgoing Dial-peer=2, Params=0x4BA759D8, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Wed Mar 20 09:11:20 2013: <191>162010: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:20 2013: <191>162011:    In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:20 2013: <191>162012: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:20 2013: <191>162013:    Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:20 2013: <191>162014: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:11:20 2013: <191>162022:    Guid=1A91F618-908E-11E2-B3C9-DE08FC69A21F, Outgoing Dial-peer=2
Wed Mar 20 09:11:20 2013: <191>162023: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:11:20 2013: <191>162024:    ccCallSetupRequest:
Wed Mar 20 09:11:20 2013: <191>162029:    cisco-aniplan=0
Wed Mar 20 09:11:20 2013: <191>162030:
Wed Mar 20 09:11:20 2013: <191>162032:    cisco-anisi=0
Wed Mar 20 09:11:20 2013: <191>162035:    cisco-destplan=0
Wed Mar 20 09:11:20 2013: <191>162046:
Wed Mar 20 09:11:20 2013: <191>162047: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:11:20 2013: <191>162048:
Wed Mar 20 09:11:20 2013: <191>162049: Interface=0x4987DFD8, Interface Type=6, Destination=, Mode=0x0,
Wed Mar 20 09:11:20 2013: <191>162054: .Mar 20 09:11:19: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:20 2013: <191>162056: .Mar 20 09:11:19: :cc_get_feature_vsa malloc success
Wed Mar 20 09:11:20 2013: <191>162057: .Mar 20 09:11:19: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:21 2013: <191>162059: .Mar 20 09:11:19:  cc_get_feature_vsa count is 2
Wed Mar 20 09:11:21 2013: <191>162060: .Mar 20 09:11:19: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:21 2013: <191>162061:
Wed Mar 20 09:11:21 2013: <191>162062: .Mar 20 09:11:19: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248136,feature_id:8140
Wed Mar 20 09:11:21 2013: <191>162063: .Mar 20 09:11:19: //8140/1A91F618B3C9/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:11:21 2013: <191>162064:    SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Wed Mar 20 09:11:21 2013: <191>162065: .Mar 20 09:11:19: //8140/1A91F618B3C9/CCAPI/ccCallSetContext:
Wed Mar 20 09:11:21 2013: <191>162066:    Context=0x4BA75988
Wed Mar 20 09:11:21 2013: <191>162067: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:11:21 2013: <191>162068:    Outgoing Dial-peer=2
Wed Mar 20 09:11:21 2013: <191>162069: .Mar 20 09:11:19: //8140/1A91F618B3C9/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:11:21 2013: <191>162070:    Interface=0x4987DFD8, Progress Indication=NULL(0)
Wed Mar 20 09:11:23 2013: <191>162071: .Mar 20 09:11:22: //8140/1A91F618B3C9/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:11:23 2013: <191>162072:    Interface=0x4987DFD8, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
Wed Mar 20 09:11:23 2013: <191>162073:    Cause Value=0
Wed Mar 20 09:11:23 2013: <191>162074: .Mar 20 09:11:22: //8140/1A91F618B3C9/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:11:23 2013: <191>162075:    Call Entry(Responsed=TRUE)
Wed Mar 20 09:11:23 2013: <191>162076: .Mar 20 09:11:22: //8139/1A91F618B3C9/CCAPI/ccCallCutProgress:
Wed Mar 20 09:11:23 2013: <191>162077:    Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
Wed Mar 20 09:11:23 2013: <191>162078:    Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Wed Mar 20 09:11:23 2013: <191>162079: .Mar 20 09:11:22: //8139/1A91F618B3C9/CCAPI/ccCallCutProgress:
Wed Mar 20 09:11:23 2013: <191>162080:    Call Entry(Responsed=TRUE)
Wed Mar 20 09:11:23 2013: <191>162081: .Mar 20 09:11:22: //8139/1A91F618B3C9/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:11:23 2013: <191>162082:
Wed Mar 20 09:11:23 2013: <191>162083: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:11:23 2013: <191>162084:    Tone Direction=Network, Params=0x0, Call Id=8139
Wed Mar 20 09:11:23 2013: <191>162085: .Mar 20 09:11:22: //8139/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:11:23 2013: <191>162086:    (confID=0x4BB021E8, callID1=0x1FCB, callID2=0x1FCC, tag=0x0)
Wed Mar 20 09:11:23 2013: <191>162087: .Mar 20 09:11:22: //8139/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:11:23 2013: <191>162088:    (confID=0x4BB021E8, callID1=0x1FCB, gcid=1A91F618-908E11E2-B3C9DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:11:23 2013: <191>162089: .Mar 20 09:11:22: //8140/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:11:23 2013: <191>162090:    (confID=0x4BB021E8, callID2=0x1FCC, gcid=1A91F618-908E11E2-B3C9DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:11:23 2013: <191>162091: .Mar 20 09:11:22: //8139/1A91F618B3C9/CCAPI/ccConferenceCreate:
Wed Mar 20 09:11:23 2013: <191>162092:    Conference Id=0x4BB021E8, Call Id1=8139, Call Id2=8140, Tag=0x0
Wed Mar 20 09:11:23 2013: <191>162093: .Mar 20 09:11:22: //8139/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:11:23 2013: <191>162094:    Conference Id=0xE53, Source Interface=0x4B805B90, Source Call Id=8139,
Wed Mar 20 09:11:23 2013: <191>162095:    Destination Call Id=8140, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:11:23 2013: <191>162096: .Mar 20 09:11:22: //8140/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:11:23 2013: <191>162097:    Conference Id=0xE53, Source Interface=0x4987DFD8, Source Call Id=8140,
Wed Mar 20 09:11:23 2013: <191>162098:    Destination Call Id=8139, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:11:23 2013: <191>162099: .Mar 20 09:11:22: //8139/1A91F618B3C9/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:11:23 2013: <191>162100:    Conference Id=0xE53, Source Interface=0x4987DFD8, Source Call Id=8140,
Wed Mar 20 09:11:23 2013: <191>162101:    Destination Call Id=8139, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:11:23 2013: <191>162102: .Mar 20 09:11:22: //8139/1A91F618B3C9/CCAPI/ccConferenceCreate:
Wed Mar 20 09:11:23 2013: <191>162103:
Wed Mar 20 09:11:23 2013: <191>162104: Call Entry(Conference Id=0xE53, Destination Call Id=8140)
Wed Mar 20 09:11:23 2013: <191>162105: .Mar 20 09:11:22: //8140/1A91F618B3C9/CCAPI/ccConferenceCreate:
Wed Mar 20 09:11:23 2013: <191>162106:    Call Entry(Conference Id=0xE53, Destination Call Id=8139)
Wed Mar 20 09:11:23 2013: <191>162107: .Mar 20 09:11:22: //8139/1A91F618B3C9/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:11:23 2013: <191>162108:    Destination Interface=0x4987DFD8, Destination Call Id=8140, Source Call Id=8139,
Wed Mar 20 09:11:23 2013: <191>162111: .Mar 20 09:11:22: //8139/1A91F618B3C9/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:11:23 2013: <191>162112:    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:11:23 2013: <191>162120:    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:11:23 2013: <191>162131:    Conference Id=0xE53, Call Id1=8139, Call Id2=8140
Wed Mar 20 09:11:23 2013: <191>162132: .Mar 20 09:11:22: //8139/1A91F618B3C9/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:11:24 2013: <191>162138: Feature Type=25, Call Id=8139
Wed Mar 20 09:11:24 2013: <191>162139: .Mar 20 09:11:22: //8140/1A91F618B3C9/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:11:24 2013: <191>162140:    Call Id=8140
Wed Mar 20 09:11:24 2013: <191>162141: .Mar 20 09:11:22: //8140/1A91F618B3C9/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:11:24 2013: <191>162142:    Call Entry(Context=0x4BA75988)
Wed Mar 20 09:11:26 2013: <191>162143: .Mar 20 09:11:25: //8139/1A91F618B3C9/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:11:26 2013: <191>162144:    Cause Value=16, Interface=0x4B805B90, Call Id=8139
Wed Mar 20 09:11:26 2013: <191>162145: .Mar 20 09:11:25: //8139/1A91F618B3C9/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:11:26 2013: <191>162146:    Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:11:26 2013: <191>162147: .Mar 20 09:11:25: //8139/1A91F618B3C9/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:11:26 2013: <191>162148:    Conference Id=0xE53, Tag=0x0
Wed Mar 20 09:11:26 2013: <191>162149: .Mar 20 09:11:25: //8139/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:11:26 2013: <191>162150:    Conference Id=0xE53, Source Interface=0x4B805B90, Source Call Id=8139,
Wed Mar 20 09:11:26 2013: <191>162151:    Destination Call Id=8140, Disposition=0x0, Tag=0x0
Wed Mar 20 09:11:26 2013: <191>162152: .Mar 20 09:11:25: //8140/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:11:26 2013: <191>162153:
Wed Mar 20 09:11:26 2013: <191>162154: Conference Id=0xE53, Source Interface=0x4987DFD8, Source Call Id=8140,
Wed Mar 20 09:11:26 2013: <191>162155:    Destination Call Id=8139, Disposition=0x0, Tag=0x0
Wed Mar 20 09:11:26 2013: <191>162156: .Mar 20 09:11:25: //8139/1A91F618B3C9/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:11:26 2013: <191>162157:    Conference Id=0xE53, Source Interface=0x4987DFD8, Source Call Id=8140,
Wed Mar 20 09:11:26 2013: <191>162158:    Destination Call Id=8139, Disposition=0x0, Tag=0x0
Wed Mar 20 09:11:26 2013: <191>162159: .Mar 20 09:11:25: //8140/1A91F618B3C9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:26 2013: <191>162160:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:11:26 2013: <191>162161: .Mar 20 09:11:25: //8140/1A91F618B3C9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:26 2013: <191>162162:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:11:26 2013: <191>162163: .Mar 20 09:11:25: //8140/1A91F618B3C9/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:11:26 2013: <191>162164:
Wed Mar 20 09:11:26 2013: <191>162165: Transfer Number Is Null
Wed Mar 20 09:11:26 2013: <191>162166: .Mar 20 09:11:25: //8139/1A91F618B3C9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:26 2013: <191>162167:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:11:26 2013: <191>162168: .Mar 20 09:11:25: //8139/1A91F618B3C9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:26 2013: <191>162169:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:11:26 2013: <191>162170: .Mar 20 09:11:25: //8139/1A91F618B3C9/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:11:26 2013: <191>162171:    Transfer Number Is Null
Wed Mar 20 09:11:26 2013: <191>162172: .Mar 20 09:11:25: //8139/1A91F618B3C9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:26 2013: <191>162173:    Disposition=0, Interface=0x4B805B90, Tag=0x0, Call Id=8139,
Wed Mar 20 09:11:26 2013: <191>162174:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:11:26 2013: <191>162175: .Mar 20 09:11:25: //8139/1A91F618B3C9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:26 2013: <191>162176:    Call Disconnect Event Sent
Wed Mar 20 09:11:26 2013: <191>162177: .Mar 20 09:11:25: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:26 2013: <191>162179: .Mar 20 09:11:25: :cc_free_feature_vsa freeing 47B81CE0
Wed Mar 20 09:11:26 2013: <191>162180: .Mar 20 09:11:25: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:26 2013: <191>162183: .Mar 20 09:11:25: //8140/1A91F618B3C9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:26 2013: <191>162186: .Mar 20 09:11:25: //8140/1A91F618B3C9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:26 2013: <191>162187:    Call Disconnect Event Sent
Wed Mar 20 09:11:27 2013: <191>162188: .Mar 20 09:11:25: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:27 2013: <191>162189:
Wed Mar 20 09:11:27 2013: <191>162190: .Mar 20 09:11:25: :cc_free_feature_vsa freeing 47B81C00
Wed Mar 20 09:11:27 2013: <191>162191: .Mar 20 09:11:25: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:27 2013: <191>162192:
Wed Mar 20 09:11:27 2013: <191>162193: .Mar 20 09:11:25:  vsacount in free is 0
Wed Mar 20 09:11:28 2013: <191>162194: .Mar 20 09:11:26: //-1/1FDC5A81B3CE/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:11:28 2013: <191>162195:    cc_api_call_setup_ind_common:
Wed Mar 20 09:11:28 2013: <191>162196:    cisco-username=
Wed Mar 20 09:11:28 2013: <191>162197:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:11:28 2013: <191>162198:    cisco-ani=1811032013
Wed Mar 20 09:11:28 2013: <191>162199:    cisco-anitype=0
Wed Mar 20 09:11:28 2013: <191>162200:    cisco-aniplan=0
Wed Mar 20 09:11:28 2013: <191>162201:    cisco-anipi=0
Wed Mar 20 09:11:28 2013: <191>162202:    cisco-anisi=0
Wed Mar 20 09:11:28 2013: <191>162203:    dest=
Wed Mar 20 09:11:28 2013: <191>162204:    cisco-desttype=0
Wed Mar 20 09:11:28 2013: <191>162205:    cisco-destplan=0
Wed Mar 20 09:11:28 2013: <191>162206:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:11:28 2013: <191>162207:    cisco-rdn=
Wed Mar 20 09:11:28 2013: <191>162208:    cisco-lastrdn=
Wed Mar 20 09:11:28 2013: <191>162209:    cisco-rdntype=0
Wed Mar 20 09:11:28 2013: <191>162210:    cisco-rdnplan=0
Wed Mar 20 09:11:28 2013: <191>162211:    cisco-rdnpi=0
Wed Mar 20 09:11:28 2013: <191>162212:    cisco-rdnsi=0
Wed Mar 20 09:11:28 2013: <191>162213:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:11:28 2013: <191>162214:    final_redirectNumber =
Wed Mar 20 09:11:28 2013: <191>162215:    hunt_group_timeout =0
Wed Mar 20 09:11:28 2013: <191>162216:
Wed Mar 20 09:11:28 2013: <191>162217: .Mar 20 09:11:26: //-1/1FDC5A81B3CE/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:11:28 2013: <191>162218:
Wed Mar 20 09:11:28 2013: <191>162219: Interface=0x4B805B90, Call Info(
Wed Mar 20 09:11:28 2013: <191>162220:    Calling Number=1811032013,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:11:28 2013: <191>162221:    Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:11:28 2013: <191>162222:    Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:11:28 2013: <191>162223:    Incoming Dial-peer=20015, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:11:28 2013: <191>162224:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:11:28 2013: <191>162225: .Mar 20 09:11:26: //-1/1FDC5A81B3CE/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:28 2013: <191>162226:    In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:28 2013: <191>162227: .Mar 20 09:11:26: //-1/1FDC5A81B3CE/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:28 2013: <191>162228:    Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:28 2013: <191>162229: .Mar 20 09:11:26: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:28 2013: <191>162230:
Wed Mar 20 09:11:28 2013: <191>162231: .Mar 20 09:11:26: :cc_get_feature_vsa malloc success
Wed Mar 20 09:11:28 2013: <191>162232: .Mar 20 09:11:26: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:28 2013: <191>162233:
Wed Mar 20 09:11:28 2013: <191>162234: .Mar 20 09:11:26:  cc_get_feature_vsa count is 1
Wed Mar 20 09:11:28 2013: <191>162235: .Mar 20 09:11:26: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:28 2013: <191>162236:
Wed Mar 20 09:11:28 2013: <191>162237: .Mar 20 09:11:26: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203326024,feature_id:8141
Wed Mar 20 09:11:28 2013: <191>162238: .Mar 20 09:11:26: //8141/1FDC5A81B3CE/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:11:28 2013: <191>162239:
Wed Mar 20 09:11:28 2013: <191>162240: Set Up Event Sent;
Wed Mar 20 09:11:28 2013: <191>162241:    Call Info(Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:11:28 2013: <191>162243: .Mar 20 09:11:26: //8141/1FDC5A81B3CE/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:11:28 2013: <191>162244:    Event=0x4982C828
Wed Mar 20 09:11:28 2013: <191>162254: .Mar 20 09:11:26: //8141/1FDC5A81B3CE/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:11:28 2013: <191>162255:    Stop Tone On Digit=TRUE, Tone=Dial Tone,
Wed Mar 20 09:11:28 2013: <191>162256:    Tone Direction=Network, Params=0x0, Call Id=8141
Wed Mar 20 09:11:28 2013: <191>162257: .Mar 20 09:11:26: //8141/1FDC5A81B3CE/CCAPI/ccSetDigitTimeouts:
Wed Mar 20 09:11:29 2013: <191>162265: Enabled=TRUE, Call Id=8141
Wed Mar 20 09:11:29 2013: <191>162266: .Mar 20 09:11:26: //8141/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:29 2013: <191>162267:    (vdbPtr=0x4B805B90, callID=0x1FCD, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:11:29 2013: <191>162268: .Mar 20 09:11:26: //8141/1FDC5A81B3CE/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:29 2013: <191>162269:    Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8141
Wed Mar 20 09:11:29 2013: <191>162270: .Mar 20 09:11:26: //8141/1FDC5A81B3CE/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:29 2013: <191>162271:    Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:11:29 2013: <191>162272: .Mar 20 09:11:28: //8141/1FDC5A81B3CE/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:11:29 2013: <191>162273:    Cause Value=16, Interface=0x4B805B90, Call Id=8141
Wed Mar 20 09:11:29 2013: <191>162274: .Mar 20 09:11:28: //8141/1FDC5A81B3CE/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:11:29 2013: <191>162275:    Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:11:29 2013: <191>162276: .Mar 20 09:11:28: //8141/1FDC5A81B3CE/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:29 2013: <191>162277:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:11:29 2013: <191>162278: .Mar 20 09:11:28: //8141/1FDC5A81B3CE/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:29 2013: <191>162279:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:11:29 2013: <191>162280: .Mar 20 09:11:28: //8141/1FDC5A81B3CE/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:11:29 2013: <191>162281:    Transfer Number Is Null
Wed Mar 20 09:11:30 2013: <191>162282: .Mar 20 09:11:28: //8141/1FDC5A81B3CE/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:30 2013: <191>162283:    Disposition=0, Interface=0x4B805B90, Tag=0x0, Call Id=8141,
Wed Mar 20 09:11:30 2013: <191>162284:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:11:30 2013: <191>162285: .Mar 20 09:11:28: //8141/1FDC5A81B3CE/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:30 2013: <191>162286:    Call Disconnect Event Sent
Wed Mar 20 09:11:30 2013: <191>162287: .Mar 20 09:11:28: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:30 2013: <191>162288:
Wed Mar 20 09:11:30 2013: <191>162289: .Mar 20 09:11:28: :cc_free_feature_vsa freeing 47B94C40
Wed Mar 20 09:11:30 2013: <191>162290: .Mar 20 09:11:28: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:30 2013: <191>162291:
Wed Mar 20 09:11:30 2013: <191>162292: .Mar 20 09:11:28:  vsacount in free is 0
Wed Mar 20 09:11:36 2013: <191>162293: .Mar 20 09:11:35: //-1/2529CD1EB3D2/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:11:36 2013: <191>162294:    cc_api_call_setup_ind_common:
Wed Mar 20 09:11:36 2013: <191>162295:    cisco-username=
Wed Mar 20 09:11:36 2013: <191>162296:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:11:36 2013: <191>162297:    cisco-ani=1811032013
Wed Mar 20 09:11:36 2013: <191>162298:    cisco-anitype=0
Wed Mar 20 09:11:36 2013: <191>162299:    cisco-aniplan=0
Wed Mar 20 09:11:36 2013: <191>162300:    cisco-anipi=0
Wed Mar 20 09:11:36 2013: <191>162301:    cisco-anisi=0
Wed Mar 20 09:11:36 2013: <191>162302:    dest=
Wed Mar 20 09:11:36 2013: <191>162303:    cisco-desttype=0
Wed Mar 20 09:11:36 2013: <191>162304:    cisco-destplan=0
Wed Mar 20 09:11:36 2013: <191>162305:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:11:36 2013: <191>162306:    cisco-rdn=
Wed Mar 20 09:11:36 2013: <191>162307:    cisco-lastrdn=
Wed Mar 20 09:11:36 2013: <191>162308:    cisco-rdntype=0
Wed Mar 20 09:11:36 2013: <191>162309:    cisco-rdnplan=0
Wed Mar 20 09:11:36 2013: <191>162310:    cisco-rdnpi=0
Wed Mar 20 09:11:36 2013: <191>162311:    cisco-rdnsi=0
Wed Mar 20 09:11:36 2013: <191>162312:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:11:36 2013: <191>162313:    final_redirectNumber =
Wed Mar 20 09:11:37 2013: <191>162314:    hunt_group_timeout =0
Wed Mar 20 09:11:37 2013: <191>162315:
Wed Mar 20 09:11:37 2013: <191>162316: .Mar 20 09:11:35: //-1/2529CD1EB3D2/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:11:37 2013: <191>162317:
Wed Mar 20 09:11:37 2013: <191>162318: Interface=0x4B805B90, Call Info(
Wed Mar 20 09:11:37 2013: <191>162319:    Calling Number=1811032013,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:11:37 2013: <191>162320:    Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:11:37 2013: <191>162321:    Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:11:37 2013: <191>162322:    Incoming Dial-peer=20015, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:11:37 2013: <191>162323:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:11:37 2013: <191>162324: .Mar 20 09:11:35: //-1/2529CD1EB3D2/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:37 2013: <191>162325:    In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:37 2013: <191>162326: .Mar 20 09:11:35: //-1/2529CD1EB3D2/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:37 2013: <191>162327:    Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:37 2013: <191>162328: .Mar 20 09:11:35: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:37 2013: <191>162329:
Wed Mar 20 09:11:37 2013: <191>162330: .Mar 20 09:11:35: :cc_get_feature_vsa malloc success
Wed Mar 20 09:11:37 2013: <191>162331: .Mar 20 09:11:35: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:37 2013: <191>162332:
Wed Mar 20 09:11:37 2013: <191>162333: .Mar 20 09:11:35:  cc_get_feature_vsa count is 1
Wed Mar 20 09:11:37 2013: <191>162334: .Mar 20 09:11:35: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:37 2013: <191>162335:
Wed Mar 20 09:11:37 2013: <191>162336: .Mar 20 09:11:35: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248360,feature_id:8142
Wed Mar 20 09:11:37 2013: <191>162337: .Mar 20 09:11:35: //8142/2529CD1EB3D2/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:11:37 2013: <191>162338:
Wed Mar 20 09:11:37 2013: <191>162339: Set Up Event Sent;
Wed Mar 20 09:11:37 2013: <191>162340:    Call Info(Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:11:37 2013: <191>162343:    Event=0x4982C828
Wed Mar 20 09:11:37 2013: <191>162344: .Mar 20 09:11:35: //8142/2529CD1EB3D2/CCAPI/ccCallSetContext:
Wed Mar 20 09:11:37 2013: <191>162349:    Call Id=8142
Wed Mar 20 09:11:37 2013: <191>162350: .Mar 20 09:11:35: //8142/2529CD1EB3D2/CCAPI/cc_api_set_transfer_info:
Wed Mar 20 09:11:37 2013: <191>162351:
Wed Mar 20 09:11:37 2013: <191>162352: Transfer Number=, Transfer Reason=0x0
Wed Mar 20 09:11:37 2013: <191>162353: .Mar 20 09:11:35: //8142/2529CD1EB3D2/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:11:37 2013: <191>162361:    (callID=0x1FCE, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:11:37 2013: <191>162362: .Mar 20 09:11:35: //8142/2529CD1EB3D2/CCAPI/ccCallReportDigits:
Wed Mar 20 09:11:37 2013: <191>162363:
Wed Mar 20 09:11:37 2013: <191>162364: Enabled=TRUE, Call Id=8142
Wed Mar 20 09:11:37 2013: <191>162365: .Mar 20 09:11:35: //8142/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:37 2013: <191>162366:    (vdbPtr=0x4B805B90, callID=0x1FCE, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:11:37 2013: <191>162367: .Mar 20 09:11:35: //8142/2529CD1EB3D2/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:37 2013: <191>162368:    Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8142
Wed Mar 20 09:11:37 2013: <191>162369: .Mar 20 09:11:35: //8142/2529CD1EB3D2/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:37 2013: <191>162370:    Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:11:39 2013: <191>162371: .Mar 20 09:11:38: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:39 2013: <191>162372:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:39 2013: <191>162373:    Source Call Id=8142, Digit=0, DigitBeginFlags=0x0,
Wed Mar 20 09:11:39 2013: <191>162374:    Rtp Timestamp=0xE4C28, Rtp Expiration=0x0
Wed Mar 20 09:11:39 2013: <191>162375: .Mar 20 09:11:38: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:39 2013: <191>162376:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:39 2013: <191>162377:    Source Call Id=8142, Digit=0, Duration=100,
Wed Mar 20 09:11:39 2013: <191>162378:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:39 2013: <191>162379: .Mar 20 09:11:38: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:39 2013: <191>162380:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:39 2013: <191>162381: .Mar 20 09:11:38: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:39 2013: <191>162382:
Wed Mar 20 09:11:40 2013: <191>162383: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:40 2013: <191>162384:    Source Call Id=8142, Digit=3, DigitBeginFlags=0x0,
Wed Mar 20 09:11:40 2013: <191>162385:    Rtp Timestamp=0xEC928, Rtp Expiration=0x0
Wed Mar 20 09:11:40 2013: <191>162386: .Mar 20 09:11:38: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:40 2013: <191>162387:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:40 2013: <191>162388:    Source Call Id=8142, Digit=3, Duration=100,
Wed Mar 20 09:11:40 2013: <191>162389:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:40 2013: <191>162390: .Mar 20 09:11:38: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:40 2013: <191>162391:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:40 2013: <191>162392: .Mar 20 09:11:38: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:40 2013: <191>162393:
Wed Mar 20 09:11:40 2013: <191>162394: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:40 2013: <191>162395:    Source Call Id=8142, Digit=3, DigitBeginFlags=0x0,
Wed Mar 20 09:11:40 2013: <191>162396:    Rtp Timestamp=0xF4628, Rtp Expiration=0x0
Wed Mar 20 09:11:40 2013: <191>162397: .Mar 20 09:11:38: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:40 2013: <191>162398:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:40 2013: <191>162399:    Source Call Id=8142, Digit=3, Duration=100,
Wed Mar 20 09:11:40 2013: <191>162400:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:40 2013: <191>162401: .Mar 20 09:11:38: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:40 2013: <191>162402:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:40 2013: <191>162403: .Mar 20 09:11:39: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:40 2013: <191>162404:
Wed Mar 20 09:11:40 2013: <191>162405: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:40 2013: <191>162406:    Source Call Id=8142, Digit=2, DigitBeginFlags=0x0,
Wed Mar 20 09:11:40 2013: <191>162407:    Rtp Timestamp=0xFC328, Rtp Expiration=0x0
Wed Mar 20 09:11:40 2013: <191>162408: .Mar 20 09:11:39: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:40 2013: <191>162409:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:40 2013: <191>162410:    Source Call Id=8142, Digit=2, Duration=100,
Wed Mar 20 09:11:40 2013: <191>162411:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:40 2013: <191>162412: .Mar 20 09:11:39: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:40 2013: <191>162413:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:40 2013: <191>162414: .Mar 20 09:11:39: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:40 2013: <191>162415:
Wed Mar 20 09:11:40 2013: <191>162416: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:40 2013: <191>162417:    Source Call Id=8142, Digit=4, DigitBeginFlags=0x0,
Wed Mar 20 09:11:40 2013: <191>162418:    Rtp Timestamp=0x104028, Rtp Expiration=0x0
Wed Mar 20 09:11:40 2013: <191>162419: .Mar 20 09:11:39: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:40 2013: <191>162420:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:40 2013: <191>162421:    Source Call Id=8142, Digit=4, Duration=100,
Wed Mar 20 09:11:40 2013: <191>162422:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:40 2013: <191>162423: .Mar 20 09:11:39: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:40 2013: <191>162424:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:40 2013: <191>162425: .Mar 20 09:11:39: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:40 2013: <191>162426:
Wed Mar 20 09:11:41 2013: <191>162427: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:41 2013: <191>162428:    Source Call Id=8142, Digit=1, DigitBeginFlags=0x0,
Wed Mar 20 09:11:41 2013: <191>162429:    Rtp Timestamp=0x10BD28, Rtp Expiration=0x0
Wed Mar 20 09:11:41 2013: <191>162430: .Mar 20 09:11:39: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:41 2013: <191>162431:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:41 2013: <191>162432:    Source Call Id=8142, Digit=1, Duration=100,
Wed Mar 20 09:11:41 2013: <191>162433:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:41 2013: <191>162434: .Mar 20 09:11:39: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:41 2013: <191>162435:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:41 2013: <191>162436: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:41 2013: <191>162437:
Wed Mar 20 09:11:41 2013: <191>162438: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:41 2013: <191>162439:    Source Call Id=8142, Digit=5, DigitBeginFlags=0x0,
Wed Mar 20 09:11:41 2013: <191>162440:    Rtp Timestamp=0x113A28, Rtp Expiration=0x0
Wed Mar 20 09:11:41 2013: <191>162441: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:41 2013: <191>162442:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:41 2013: <191>162443:    Source Call Id=8142, Digit=5, Duration=100,
Wed Mar 20 09:11:41 2013: <191>162444:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:41 2013: <191>162445: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:41 2013: <191>162446:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:41 2013: <191>162447: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:41 2013: <191>162448:
Wed Mar 20 09:11:41 2013: <191>162449: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:41 2013: <191>162450:    Source Call Id=8142, Digit=4, DigitBeginFlags=0x0,
Wed Mar 20 09:11:41 2013: <191>162451:    Rtp Timestamp=0x11B728, Rtp Expiration=0x0
Wed Mar 20 09:11:41 2013: <191>162452: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:41 2013: <191>162453:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:41 2013: <191>162454:    Source Call Id=8142, Digit=4, Duration=100,
Wed Mar 20 09:11:41 2013: <191>162455:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:41 2013: <191>162456: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:41 2013: <191>162457:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:41 2013: <191>162458: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:41 2013: <191>162459:
Wed Mar 20 09:11:41 2013: <191>162460: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:41 2013: <191>162461:    Source Call Id=8142, Digit=1, DigitBeginFlags=0x0,
Wed Mar 20 09:11:41 2013: <191>162462:    Rtp Timestamp=0x123428, Rtp Expiration=0x0
Wed Mar 20 09:11:41 2013: <191>162463: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:41 2013: <191>162464:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:41 2013: <191>162465:    Source Call Id=8142, Digit=1, Duration=100,
Wed Mar 20 09:11:41 2013: <191>162466:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:41 2013: <191>162467: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:41 2013: <191>162468:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:41 2013: <191>162469: .Mar 20 09:11:40: //8142/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
Wed Mar 20 09:11:41 2013: <191>162470:    (callID=0x1FCE, digit_event=0x0, enable=FALSE, consume=FALSE)
Wed Mar 20 09:11:41 2013: <191>162471: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/ccCallReportDigits:
Wed Mar 20 09:11:41 2013: <191>162472:    Enabled=TRUE, Call Id=8142
Wed Mar 20 09:11:41 2013: <191>162473: .Mar 20 09:11:40: //8142/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:41 2013: <191>162474:    (vdbPtr=0x4B805B90, callID=0x1FCE, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Wed Mar 20 09:11:41 2013: <191>162475: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:41 2013: <191>162476:    Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8142
Wed Mar 20 09:11:41 2013: <191>162477: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:41 2013: <191>162478:    Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:11:41 2013: <191>162479: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/ccCallProceeding:
Wed Mar 20 09:11:41 2013: <191>162480:    Progress Indication=NULL(0)
Wed Mar 20 09:11:41 2013: <191>162481: .Mar 20 09:11:40: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Wed Mar 20 09:11:41 2013: <191>162482:    Try with the demoted called number 033241541
Wed Mar 20 09:11:41 2013: <191>162483: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:11:41 2013: <191>162484:    Destination=, Calling IE Present=TRUE, Mode=0,
Wed Mar 20 09:11:41 2013: <191>162485:    Outgoing Dial-peer=50, Params=0x4BA70DB8, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Wed Mar 20 09:11:41 2013: <191>162486: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:41 2013: <191>162487:    In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:41 2013: <191>162488: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:41 2013: <191>162489:    Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:41 2013: <191>162492: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:11:41 2013: <191>162493:    Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:11:41 2013: <191>162497:    Guid=2529CD1E-908E-11E2-B3D2-DE08FC69A21F, Outgoing Dial-peer=50
Wed Mar 20 09:11:41 2013: <191>162499:    ccCallSetupRequest:
Wed Mar 20 09:11:41 2013: <191>162500:    cisco-username=
Wed Mar 20 09:11:41 2013: <191>162501:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:11:41 2013: <191>162504:    cisco-anitype=0
Wed Mar 20 09:11:41 2013: <191>162506:    cisco-anipi=0
Wed Mar 20 09:11:41 2013: <191>162509:    cisco-desttype=0
Wed Mar 20 09:11:41 2013: <191>162519:    final_redirectNumber =
Wed Mar 20 09:11:41 2013: <191>162520:    hunt_group_timeout =0
Wed Mar 20 09:11:41 2013: <191>162521:
Wed Mar 20 09:11:41 2013: <191>162522: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:11:41 2013: <191>162526:    Called Number=033241541(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Wed Mar 20 09:11:41 2013: <191>162531: .Mar 20 09:11:40: :cc_get_feature_vsa malloc success
Wed Mar 20 09:11:41 2013: <191>162532: .Mar 20 09:11:40: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:42 2013: <191>162534: .Mar 20 09:11:40:  cc_get_feature_vsa count is 2
Wed Mar 20 09:11:42 2013: <191>162535: .Mar 20 09:11:40: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:42 2013: <191>162536:
Wed Mar 20 09:11:42 2013: <191>162537: .Mar 20 09:11:40: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248136,feature_id:8143
Wed Mar 20 09:11:42 2013: <191>162538: .Mar 20 09:11:40: //8143/2529CD1EB3D2/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:11:42 2013: <191>162539:    SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Wed Mar 20 09:11:42 2013: <191>162540: .Mar 20 09:11:40: //8143/2529CD1EB3D2/CCAPI/ccCallSetContext:
Wed Mar 20 09:11:42 2013: <191>162541:    Context=0x4BA70D68
Wed Mar 20 09:11:42 2013: <191>162542: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:11:42 2013: <191>162543:    Outgoing Dial-peer=50
Wed Mar 20 09:11:42 2013: <191>162544: .Mar 20 09:11:40: //8143/2529CD1EB3D2/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:11:42 2013: <191>162545:    Interface=0x498845E0, Progress Indication=NULL(0)
Wed Mar 20 09:11:44 2013: <191>162546: .Mar 20 09:11:43: //8143/2529CD1EB3D2/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:11:44 2013: <191>162547:    Interface=0x498845E0, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
Wed Mar 20 09:11:44 2013: <191>162548:    Cause Value=0
Wed Mar 20 09:11:44 2013: <191>162549: .Mar 20 09:11:43: //8143/2529CD1EB3D2/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:11:44 2013: <191>162550:    Call Entry(Responsed=TRUE)
Wed Mar 20 09:11:44 2013: <191>162551: .Mar 20 09:11:43: //8142/2529CD1EB3D2/CCAPI/ccCallCutProgress:
Wed Mar 20 09:11:44 2013: <191>162552:    Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
Wed Mar 20 09:11:44 2013: <191>162553:    Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Wed Mar 20 09:11:44 2013: <191>162554: .Mar 20 09:11:43: //8142/2529CD1EB3D2/CCAPI/ccCallCutProgress:
Wed Mar 20 09:11:44 2013: <191>162555:    Call Entry(Responsed=TRUE)
Wed Mar 20 09:11:44 2013: <191>162556: .Mar 20 09:11:43: //8142/2529CD1EB3D2/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:11:44 2013: <191>162557:
Wed Mar 20 09:11:44 2013: <191>162558: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:11:44 2013: <191>162559:    Tone Direction=Network, Params=0x0, Call Id=8142
Wed Mar 20 09:11:44 2013: <191>162560: .Mar 20 09:11:43: //8142/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:11:44 2013: <191>162561:    (confID=0x4BB01FA8, callID1=0x1FCE, callID2=0x1FCF, tag=0x0)
Wed Mar 20 09:11:44 2013: <191>162562: .Mar 20 09:11:43: //8142/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:11:44 2013: <191>162563:    (confID=0x4BB01FA8, callID1=0x1FCE, gcid=2529CD1E-908E11E2-B3D2DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:11:44 2013: <191>162564: .Mar 20 09:11:43: //8143/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:11:44 2013: <191>162565:    (confID=0x4BB01FA8, callID2=0x1FCF, gcid=2529CD1E-908E11E2-B3D2DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:11:44 2013: <191>162566: .Mar 20 09:11:43: //8142/2529CD1EB3D2/CCAPI/ccConferenceCreate:
Wed Mar 20 09:11:44 2013: <191>162567:    Conference Id=0x4BB01FA8, Call Id1=8142, Call Id2=8143, Tag=0x0
Wed Mar 20 09:11:44 2013: <191>162568: .Mar 20 09:11:43: //8142/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:11:44 2013: <191>162569:    Conference Id=0xE54, Source Interface=0x4B805B90, Source Call Id=8142,
Wed Mar 20 09:11:44 2013: <191>162570:    Destination Call Id=8143, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:11:44 2013: <191>162571: .Mar 20 09:11:43: //8143/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:11:44 2013: <191>162572:    Conference Id=0xE54, Source Interface=0x498845E0, Source Call Id=8143,
Wed Mar 20 09:11:44 2013: <191>162573:    Destination Call Id=8142, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:11:44 2013: <191>162574: .Mar 20 09:11:43: //8142/2529CD1EB3D2/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:11:44 2013: <191>162575:    Conference Id=0xE54, Source Interface=0x498845E0, Source Call Id=8143,
Wed Mar 20 09:11:44 2013: <191>162576:    Destination Call Id=8142, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:11:44 2013: <191>162577: .Mar 20 09:11:43: //8142/2529CD1EB3D2/CCAPI/ccConferenceCreate:
Wed Mar 20 09:11:44 2013: <191>162578:
Wed Mar 20 09:11:44 2013: <191>162579: Call Entry(Conference Id=0xE54, Destination Call Id=8143)
Wed Mar 20 09:11:44 2013: <191>162580: .Mar 20 09:11:43: //8143/2529CD1EB3D2/CCAPI/ccConferenceCreate:
Wed Mar 20 09:11:44 2013: <191>162581:    Call Entry(Conference Id=0xE54, Destination Call Id=8142)
Wed Mar 20 09:11:44 2013: <191>162582: .Mar 20 09:11:43: //8142/2529CD1EB3D2/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:11:44 2013: <191>162583:    Destination Interface=0x498845E0, Destination Call Id=8143, Source Call Id=8142,
Wed Mar 20 09:11:44 2013: <191>162586: .Mar 20 09:11:43: //8142/2529CD1EB3D2/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:11:44 2013: <191>162587:    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:11:44 2013: <191>162588:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:11:44 2013: <191>162589: .Mar 20 09:11:43: //8143/2529CD1EB3D2/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:11:44 2013: <191>162590:
Wed Mar 20 09:11:44 2013: <191>162591: Destination Interface=0x4B805B90, Destination Call Id=8142, Source Call Id=8143,
Wed Mar 20 09:11:44 2013: <191>162592:    Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Wed Mar 20 09:11:44 2013: <191>162593:    Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:11:44 2013: <191>162604:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5124)
Wed Mar 20 09:11:44 2013: <191>162605: .Mar 20 09:11:43: //8142/2529CD1EB3D2/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:11:44 2013: <191>162622:    Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:11:44 2013: <191>162623: .Mar 20 09:11:43: //8142/2529CD1EB3D2/CCAPI/ccCallConnect:
Wed Mar 20 09:11:44 2013: <191>162624:    Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
Wed Mar 20 09:11:45 2013: <191>162625: .Mar 20 09:11:43: //8142/2529CD1EB3D2/CCAPI/ccCallConnect:
Wed Mar 20 09:11:45 2013: <191>162626:    Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:11:45 2013: <191>162627: .Mar 20 09:11:43: //8142/2529CD1EB3D2/CCAPI/ccCallFeature:
Wed Mar 20 09:11:45 2013: <191>162628:    Feature Type=25, Call Id=8142
Wed Mar 20 09:12:06 2013: <191>162629: .Mar 20 09:12:04: //-1/80F45E604006/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:12:06 2013: <191>162630:    cc_api_call_setup_ind_common:
Wed Mar 20 09:12:06 2013: <191>162631:    cisco-username=PF-Assis-Margarida
Wed Mar 20 09:12:06 2013: <191>162632:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:12:06 2013: <191>162633:    cisco-ani=1811032010
Wed Mar 20 09:12:06 2013: <191>162634:    cisco-anitype=0
Wed Mar 20 09:12:06 2013: <191>162635:    cisco-aniplan=0
Wed Mar 20 09:12:06 2013: <191>162636:    cisco-anipi=0
Wed Mar 20 09:12:06 2013: <191>162637:    cisco-anisi=1
Wed Mar 20 09:12:06 2013: <191>162638:    dest=00151833669800
Wed Mar 20 09:12:06 2013: <191>162639:    cisco-desttype=0
Wed Mar 20 09:12:06 2013: <191>162640:    cisco-destplan=0
Wed Mar 20 09:12:06 2013: <191>162641:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:12:06 2013: <191>162642:    cisco-rdn=
Wed Mar 20 09:12:06 2013: <191>162643:    cisco-lastrdn=
Wed Mar 20 09:12:06 2013: <191>162644:    cisco-rdntype=-1
Wed Mar 20 09:12:06 2013: <191>162645:    cisco-rdnplan=-1
Wed Mar 20 09:12:06 2013: <191>162646:    cisco-rdnpi=-1
Wed Mar 20 09:12:06 2013: <191>162647:    cisco-rdnsi=-1
Wed Mar 20 09:12:06 2013: <191>162648:    cisco-redirectreason=-1   fwd_final_type =0
Wed Mar 20 09:12:06 2013: <191>162649:    final_redirectNumber =
Wed Mar 20 09:12:06 2013: <191>162650:    hunt_group_timeout =0
Wed Mar 20 09:12:06 2013: <191>162651:
Wed Mar 20 09:12:06 2013: <191>162652: .Mar 20 09:12:04: //-1/80F45E604006/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:12:06 2013: <191>162653:
Wed Mar 20 09:12:06 2013: <191>162654: Interface=0x48A4F728, Call Info(
Wed Mar 20 09:12:06 2013: <191>162655:    Calling Number=1811032010,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Wed Mar 20 09:12:06 2013: <191>162656:    Called Number=00151833669800(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:12:06 2013: <191>162657:    Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Wed Mar 20 09:12:06 2013: <191>162658:    Incoming Dial-peer=200, Progress Indication=NULL(0), Calling IE Present=TRUE,
Wed Mar 20 09:12:06 2013: <191>162659:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=8144
Wed Mar 20 09:12:06 2013: <191>162660: .Mar 20 09:12:04: //-1/80F45E604006/CCAPI/ccCheckClipClir:
Wed Mar 20 09:12:06 2013: <191>162661:    In: Calling Number=1811032010(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Wed Mar 20 09:12:06 2013: <191>162662: .Mar 20 09:12:04: //-1/80F45E604006/CCAPI/ccCheckClipClir:
Wed Mar 20 09:12:06 2013: <191>162663:    Out: Calling Number=1811032010(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Wed Mar 20 09:12:06 2013: <191>162664: .Mar 20 09:12:04: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:12:06 2013: <191>162665:
Wed Mar 20 09:12:06 2013: <191>162666: .Mar 20 09:12:04: :cc_get_feature_vsa malloc success
Wed Mar 20 09:12:06 2013: <191>162667: .Mar 20 09:12:04: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:12:06 2013: <191>162668:
Wed Mar 20 09:12:06 2013: <191>162669: .Mar 20 09:12:04:  cc_get_feature_vsa count is 3
Wed Mar 20 09:12:06 2013: <191>162670: .Mar 20 09:12:04: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:12:06 2013: <191>162671:
Wed Mar 20 09:12:06 2013: <191>162672: .Mar 20 09:12:04: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203247912,feature_id:8144
Wed Mar 20 09:12:06 2013: <191>162673: .Mar 20 09:12:04: //8144/80F45E604006/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:12:06 2013: <191>162674:
Wed Mar 20 09:12:06 2013: <191>162675: Set Up Event Sent;
Wed Mar 20 09:12:06 2013: <191>162676:    Call Info(Calling Number=1811032010(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Wed Mar 20 09:12:06 2013: <191>162677:    Called Number=00151833669800(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:12:06 2013: <191>162678: .Mar 20 09:12:04: //8144/80F45E604006/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:12:06 2013: <191>162689:    Try with the demoted called number 00151833669800
Wed Mar 20 09:12:06 2013: <191>162690: .Mar 20 09:12:04: //8144/80F45E604006/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:12:06 2013: <191>162691:    Destination=, Calling IE Present=TRUE, Mode=0,
Wed Mar 20 09:12:06 2013: <191>162692:    Outgoing Dial-peer=5, Params=0x4BA68880, Progress Indication=NULL(0)
Wed Mar 20 09:12:06 2013: <191>162705:    Guid=80F45E60-96A7-9114-4006-E1040AE54028, Outgoing Dial-peer=5
Wed Mar 20 09:12:06 2013: <191>162706: .Mar 20 09:12:04: //8144/80F45E604006/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:12:06 2013: <191>162709:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:12:06 2013: <191>162710:    cisco-ani=1811032010
Wed Mar 20 09:12:06 2013: <191>162713:    cisco-anipi=0
Wed Mar 20 09:12:06 2013: <191>162716:    cisco-desttype=0
Wed Mar 20 09:12:06 2013: <191>162723:    cisco-rdnpi=-1
Wed Mar 20 09:12:06 2013: <191>162724:    cisco-rdnsi=-1
Wed Mar 20 09:12:06 2013: <191>162726:    final_redirectNumber =
Wed Mar 20 09:12:06 2013: <191>162728:
Wed Mar 20 09:12:07 2013: <191>162741: .Mar 20 09:12:04:  cc_get_feature_vsa count is 4
Wed Mar 20 09:12:07 2013: <191>162742: .Mar 20 09:12:04: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:12:07 2013: <191>162743:
Wed Mar 20 09:12:07 2013: <191>162744: .Mar 20 09:12:04: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203247688,feature_id:8145
Wed Mar 20 09:12:07 2013: <191>162745: .Mar 20 09:12:04: //8145/80F45E604006/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:12:07 2013: <191>162746:    SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Wed Mar 20 09:12:07 2013: <191>162747: .Mar 20 09:12:04: //8145/80F45E604006/CCAPI/ccCallSetContext:
Wed Mar 20 09:12:07 2013: <191>162748:    Context=0x4BA68830
Wed Mar 20 09:12:07 2013: <191>162749: .Mar 20 09:12:04: //8144/80F45E604006/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:12:07 2013: <191>162750:    Outgoing Dial-peer=5
Wed Mar 20 09:12:07 2013: <191>162751: .Mar 20 09:12:04: //8145/80F45E604006/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:12:07 2013: <191>162752:    Interface=0x4987DFD8, Progress Indication=NULL(0)
Wed Mar 20 09:12:10 2013: <191>162753: .Mar 20 09:12:08: //8145/80F45E604006/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:12:10 2013: <191>162754:    Interface=0x4987DFD8, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
Wed Mar 20 09:12:10 2013: <191>162755:    Cause Value=0
Wed Mar 20 09:12:10 2013: <191>162756: .Mar 20 09:12:08: //8145/80F45E604006/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:12:10 2013: <191>162757:    Call Entry(Responsed=TRUE)
Wed Mar 20 09:12:10 2013: <191>162758: .Mar 20 09:12:08: //8144/80F45E604006/CCAPI/ccCallCutProgress:
Wed Mar 20 09:12:10 2013: <191>162759:    Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
Wed Mar 20 09:12:10 2013: <191>162760:    Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Wed Mar 20 09:12:10 2013: <191>162761: .Mar 20 09:12:08: //8144/80F45E604006/CCAPI/ccCallCutProgress:
Wed Mar 20 09:12:10 2013: <191>162762:    Call Entry(Responsed=TRUE)
Wed Mar 20 09:12:10 2013: <191>162763: .Mar 20 09:12:08: //8145/80F45E604006/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:12:10 2013: <191>162764:    CallInfo(ccm detected=0)
Wed Mar 20 09:12:10 2013: <191>162765: .Mar 20 09:12:08: //8144/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:12:10 2013: <191>162766:    (confID=0x4BB02110, callID1=0x1FD0, callID2=0x1FD1, tag=0x0)
Wed Mar 20 09:12:10 2013: <191>162767: .Mar 20 09:12:08: //8144/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:12:10 2013: <191>162768:    (confID=0x4BB02110, callID1=0x1FD0, gcid=0-0-0-0, tag=0x0)
Wed Mar 20 09:12:10 2013: <191>162769: .Mar 20 09:12:08: //8145/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:12:10 2013: <191>162770:    (confID=0x4BB02110, callID2=0x1FD1, gcid=0-0-0-0, tag=0x0)
Wed Mar 20 09:12:10 2013: <191>162771: .Mar 20 09:12:08: //8144/80F45E604006/CCAPI/ccConferenceCreate:
Wed Mar 20 09:12:10 2013: <191>162772:    Conference Id=0x4BB02110, Call Id1=8144, Call Id2=8145, Tag=0x0
Wed Mar 20 09:12:10 2013: <191>162773: .Mar 20 09:12:08: //8144/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:12:10 2013: <191>162774:
Wed Mar 20 09:12:10 2013: <191>162775: .Mar 20 09:12:08: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:12:10 2013: <191>162776: .Mar 20 09:12:08: //8144/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:12:10 2013: <191>162777:    Conference Id=0xE55, Source Interface=0x48A4F728, Source Call Id=8144,
Wed Mar 20 09:12:10 2013: <191>162778:    Destination Call Id=8145, Disposition=0x0, Tag=0x0
Wed Mar 20 09:12:10 2013: <191>162779: .Mar 20 09:12:08: //8145/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:12:10 2013: <191>162780:    Conference Id=0xE55, Source Interface=0x4987DFD8, Source Call Id=8145,
Wed Mar 20 09:12:10 2013: <191>162781:    Destination Call Id=8144, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:12:10 2013: <191>162782: .Mar 20 09:12:08: //8144/80F45E604006/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:12:10 2013: <191>162783:    Conference Id=0xE55, Source Interface=0x4987DFD8, Source Call Id=8145,
Wed Mar 20 09:12:10 2013: <191>162784:    Destination Call Id=8144, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:12:10 2013: <191>162785: .Mar 20 09:12:08: //8144/80F45E604006/CCAPI/ccConferenceCreate:
Wed Mar 20 09:12:10 2013: <191>162786:
Wed Mar 20 09:12:10 2013: <191>162787: Call Entry(Conference Id=0xE55, Destination Call Id=8145)
Wed Mar 20 09:12:10 2013: <191>162788: .Mar 20 09:12:08: //8145/80F45E604006/CCAPI/ccConferenceCreate:
Wed Mar 20 09:12:10 2013: <191>162789:    Call Entry(Conference Id=0xE55, Destination Call Id=8144)
Wed Mar 20 09:12:10 2013: <191>162790: .Mar 20 09:12:08: //8145/80F45E604006/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:12:10 2013: <191>162799: Conference Id=0xE55, Call Id1=8144, Call Id2=8145
Wed Mar 20 09:12:10 2013: <191>162800: .Mar 20 09:12:08: //8144/80F45E604006/CCAPI/ccCallNotify:
Wed Mar 20 09:12:10 2013: <191>162801:    Data Bitmask=0x7, Call Id=8144
Wed Mar 20 09:12:10 2013: <191>162802: .Mar 20 09:12:08: //8145/80F45E604006/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:12:10 2013: <191>162803:    CallInfo(ccm detected=0)
Wed Mar 20 09:12:10 2013: <191>162804: .Mar 20 09:12:09: //8144/80F45E604006/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:12:10 2013: <191>162805:    Destination Interface=0x4987DFD8, Destination Call Id=8145, Source Call Id=8144,
Wed Mar 20 09:12:10 2013: <191>162806:    Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:12:10 2013: <191>162807:    Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:12:10 2013: <191>162808: .Mar 20 09:12:09: //8144/80F45E604006/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:12:10 2013: <191>162809:    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:12:10 2013: <191>162810:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:12:10 2013: <191>162811: .Mar 20 09:12:09: //8144/80F45E604006/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:12:10 2013: <191>162812:    Destination Interface=0x4987DFD8, Destination Call Id=8145, Source Call Id=8144,
Wed Mar 20 09:12:10 2013: <191>162813:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:12:10 2013: <191>162814:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=7077)
Wed Mar 20 09:12:10 2013: <191>162815: .Mar 20 09:12:09: //8145/80F45E604006/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:12:10 2013: <191>162816:    Destination Interface=0x48A4F728, Destination Call Id=8144, Source Call Id=8145,
Wed Mar 20 09:12:10 2013: <191>162817:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:12:10 2013: <191>162818:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=7077)
Wed Mar 20 09:12:10 2013: <191>162819: .Mar 20 09:12:09: //8145/80F45E604006/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:12:10 2013: <191>162820:    Call Id=8145
Wed Mar 20 09:12:11 2013: <191>162821: .Mar 20 09:12:09: //8145/80F45E604006/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:12:11 2013: <191>162822:    Call Entry(Context=0x4BA68830)
Wed Mar 20 09:12:24 2013: <191>162823: .Mar 20 09:12:23: //8145/80F45E604006/CCAPI/cc_api_call_connected:
Wed Mar 20 09:12:24 2013: <191>162824:    Interface=0x4987DFD8, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
Wed Mar 20 09:12:24 2013: <191>162825:    Connection Handle=0
Wed Mar 20 09:12:24 2013: <191>162826: .Mar 20 09:12:23: //8145/80F45E604006/CCAPI/cc_api_call_connected:
Wed Mar 20 09:12:24 2013: <191>162827:    Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:12:24 2013: <191>162828: .Mar 20 09:12:23: //8144/80F45E604006/CCAPI/ccCallConnect:
Wed Mar 20 09:12:24 2013: <191>162829:    Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
Wed Mar 20 09:12:24 2013: <191>162830: .Mar 20 09:12:23: //8145/80F45E604006/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:12:24 2013: <191>162831:    CallInfo(ccm detected=0)
Wed Mar 20 09:12:24 2013: <191>162832: .Mar 20 09:12:23: //8144/80F45E604006/CCAPI/ccCallConnect:
Wed Mar 20 09:12:24 2013: <191>162833:    Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:12:25 2013: <191>162834: .Mar 20 09:12:23: //8144/80F45E604006/CCAPI/ccCallNotify:
Wed Mar 20 09:12:25 2013: <191>162835:    Data Bitmask=0x7, Call Id=8144
Wed Mar 20 09:12:25 2013: <191>162836: .Mar 20 09:12:23: //8145/80F45E604006/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:12:25 2013: <191>162837:    CallInfo(ccm detected=0)
Wed Mar 20 09:13:06 2013: <191>162838: .Mar 20 09:13:05: //8142/2529CD1EB3D2/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:13:06 2013: <191>162839:    Cause Value=16, Interface=0x4B805B90, Call Id=8142
Wed Mar 20 09:13:06 2013: <191>162861: .Mar 20 09:13:05: //8143/2529CD1EB3D2/CCAPI/ccCallDisconnect:
Wed Mar 20 09:13:06 2013: <191>162840: .Mar 20 09:13:05: //8142/2529CD1EB3D2/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:13:06 2013: <191>162841:    Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:13:06 2013: <191>162842: .Mar 20 09:13:05: //8142/2529CD1EB3D2/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:13:06 2013: <191>162843:    Conference Id=0xE54, Tag=0x0
Wed Mar 20 09:13:06 2013: <191>162844: .Mar 20 09:13:05: //8142/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:13:06 2013: <191>162845:    Conference Id=0xE54, Source Interface=0x4B805B90, Source Call Id=8142,
Wed Mar 20 09:13:06 2013: <191>162846:    Destination Call Id=8143, Disposition=0x0, Tag=0x0
Wed Mar 20 09:13:06 2013: <191>162847: .Mar 20 09:13:05: //8143/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:13:06 2013: <191>162848:
Wed Mar 20 09:13:06 2013: <191>162862:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:13:06 2013: <191>162849: Conference Id=0xE54, Source Interface=0x498845E0, Source Call Id=8143,
Wed Mar 20 09:13:06 2013: <191>162863: .Mar 20 09:13:05: //8143/2529CD1EB3D2/CCAPI/ccCallDisconnect:
Wed Mar 20 09:13:06 2013: <191>162850:    Destination Call Id=8142, Disposition=0x0, Tag=0x0
Wed Mar 20 09:13:06 2013: <191>162851: .Mar 20 09:13:05: //8142/2529CD1EB3D2/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:13:06 2013: <191>162852:    Conference Id=0xE54, Source Interface=0x498845E0, Source Call Id=8143,
Wed Mar 20 09:13:06 2013: <191>162864:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:13:06 2013: <191>162853:    Destination Call Id=8142, Disposition=0x0, Tag=0x0
Wed Mar 20 09:13:06 2013: <191>162854: .Mar 20 09:13:05: //8142/2529CD1EB3D2/CCAPI/ccCallDisconnect:
Wed Mar 20 09:13:06 2013: <191>162865: .Mar 20 09:13:05: //8143/2529CD1EB3D2/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:13:06 2013: <191>162855:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:13:06 2013: <191>162856: .Mar 20 09:13:05: //8142/2529CD1EB3D2/CCAPI/ccCallDisconnect:
Wed Mar 20 09:13:06 2013: <191>162866:    Transfer Number Is Null
Wed Mar 20 09:13:06 2013: <191>162857:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:13:06 2013: <191>162867: .Mar 20 09:13:05: //8142/2529CD1EB3D2/CCAPI/cc_api_call_feature:
Wed Mar 20 09:13:06 2013: <191>162868:    Feature Type=6, Interface=0x4B805B90, Call Id=8142
Wed Mar 20 09:13:06 2013: <191>162858: .Mar 20 09:13:05: //8142/2529CD1EB3D2/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:13:06 2013: <191>162859:
Wed Mar 20 09:13:06 2013: <191>162860: Transfer Number Is Null
Wed Mar 20 09:13:06 2013: <191>162869: .Mar 20 09:13:05: //8142/2529CD1EB3D2/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:13:06 2013: <191>162870:
Wed Mar 20 09:13:06 2013: <191>162871: Disposition=0, Interface=0x4B805B90, Tag=0x0, Call Id=8142,
Wed Mar 20 09:13:06 2013: <191>162872:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:13:06 2013: <191>162873: .Mar 20 09:13:05: //8142/2529CD1EB3D2/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:13:06 2013: <191>162874:    Call Disconnect Event Sent
Wed Mar 20 09:13:06 2013: <191>162875: .Mar 20 09:13:05: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:13:06 2013: <191>162876:
Wed Mar 20 09:13:06 2013: <191>162877: .Mar 20 09:13:05: :cc_free_feature_vsa freeing 47B81CE0
Wed Mar 20 09:13:06 2013: <191>162878: .Mar 20 09:13:05: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:13:06 2013: <191>162879:
Wed Mar 20 09:13:06 2013: <191>162880: .Mar 20 09:13:05:  vsacount in free is 3
Wed Mar 20 09:13:06 2013: <191>162881: .Mar 20 09:13:05: //8143/2529CD1EB3D2/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:13:06 2013: <191>162882:    Disposition=0, Interface=0x498845E0, Tag=0x0, Call Id=8143,
Wed Mar 20 09:13:06 2013: <191>162883:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:13:07 2013: <191>162884: .Mar 20 09:13:05: //8143/2529CD1EB3D2/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:13:07 2013: <191>162885:    Call Disconnect Event Sent
Wed Mar 20 09:13:07 2013: <191>162886: .Mar 20 09:13:05: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:13:07 2013: <191>162887:
Wed Mar 20 09:13:07 2013: <191>162888: .Mar 20 09:13:05: :cc_free_feature_vsa freeing 47B81C00
Wed Mar 20 09:13:07 2013: <191>162889: .Mar 20 09:13:05: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:13:07 2013: <191>162890:
Wed Mar 20 09:13:07 2013: <191>162891: .Mar 20 09:13:05:  vsacount in free is 2
Wed Mar 20 09:14:45 2013: <191>162892: .Mar 20 09:14:44: //-1/9561D059B3D9/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:14:45 2013: <191>162893:    cc_api_call_setup_ind_common:
Wed Mar 20 09:14:45 2013: <191>162894:    cisco-username=
Wed Mar 20 09:14:45 2013: <191>162895:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:14:45 2013: <191>162896:    cisco-ani=
Wed Mar 20 09:14:45 2013: <191>162897:    cisco-anitype=0
Wed Mar 20 09:14:45 2013: <191>162898:    cisco-aniplan=0
Wed Mar 20 09:14:45 2013: <191>162899:    cisco-anipi=0
Wed Mar 20 09:14:45 2013: <191>162900:    cisco-anisi=0
Wed Mar 20 09:14:45 2013: <191>162901:    dest=1811032099
Wed Mar 20 09:14:45 2013: <191>162902:    cisco-desttype=0
Wed Mar 20 09:14:45 2013: <191>162903:    cisco-destplan=0
Wed Mar 20 09:14:45 2013: <191>162904:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:14:45 2013: <191>162905:    cisco-rdn=
Wed Mar 20 09:14:45 2013: <191>162906:    cisco-lastrdn=
Wed Mar 20 09:14:45 2013: <191>162907:    cisco-rdntype=0
Wed Mar 20 09:14:45 2013: <191>162908:    cisco-rdnplan=0
Wed Mar 20 09:14:45 2013: <191>162909:    cisco-rdnpi=0
Wed Mar 20 09:14:45 2013: <191>162910:    cisco-rdnsi=0
Wed Mar 20 09:14:45 2013: <191>162911:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:14:45 2013: <191>162912:    final_redirectNumber =
Wed Mar 20 09:14:45 2013: <191>162913:    hunt_group_timeout =0
Wed Mar 20 09:14:45 2013: <191>162914:
Wed Mar 20 09:14:45 2013: <191>162915: .Mar 20 09:14:44: //-1/9561D059B3D9/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:14:45 2013: <191>162916:
Wed Mar 20 09:14:45 2013: <191>162917: Interface=0x4987FF98, Call Info(
Wed Mar 20 09:14:45 2013: <191>162918:    Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:14:45 2013: <191>162919:    Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:14:45 2013: <191>162920:    Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Wed Mar 20 09:14:45 2013: <191>162921:    Incoming Dial-peer=18, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Wed Mar 20 09:14:45 2013: <191>162922:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:14:45 2013: <191>162923: .Mar 20 09:14:44: //-1/9561D059B3D9/CCAPI/ccCheckClipClir:
Wed Mar 20 09:14:45 2013: <191>162924:    In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:14:45 2013: <191>162925: .Mar 20 09:14:44: //-1/9561D059B3D9/CCAPI/ccCheckClipClir:
Wed Mar 20 09:14:45 2013: <191>162926:    Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:14:45 2013: <191>162927: .Mar 20 09:14:44: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:14:45 2013: <191>162928:
Wed Mar 20 09:14:45 2013: <191>162929: .Mar 20 09:14:44: :cc_get_feature_vsa malloc success
Wed Mar 20 09:14:45 2013: <191>162930: .Mar 20 09:14:44: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:14:45 2013: <191>162931:
Wed Mar 20 09:14:45 2013: <191>162932: .Mar 20 09:14:44:  cc_get_feature_vsa count is 3
Wed Mar 20 09:14:45 2013: <191>162933: .Mar 20 09:14:44: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:14:45 2013: <191>162934:
Wed Mar 20 09:14:45 2013: <191>162935: .Mar 20 09:14:44: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248136,feature_id:8146
Wed Mar 20 09:14:45 2013: <191>162936: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:14:45 2013: <191>162937:
Wed Mar 20 09:14:45 2013: <191>162938: Set Up Event Sent;
Wed Mar 20 09:14:45 2013: <191>162939:    Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:14:45 2013: <191>162941: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:14:45 2013: <191>162945: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/ccCallSetContext:
Wed Mar 20 09:14:45 2013: <191>162946:    Context=0x4BA7CBB8
Wed Mar 20 09:14:45 2013: <191>162947: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:14:45 2013: <191>162948:    >>>>CCAPI handed cid 8146 with tag 18 to app "_ManagedAppProcess_Default"
Wed Mar 20 09:14:45 2013: <191>162952: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:14:45 2013: <191>162963:    Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:14:45 2013: <191>162964:    Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:14:45 2013: <191>162965:    Redirect Number=, Display Info=Linha_3322-5220
Wed Mar 20 09:14:45 2013: <191>162966:    Account Number=, Final Destination Flag=TRUE,
Wed Mar 20 09:14:45 2013: <191>162970:    cisco-username=
Wed Mar 20 09:14:45 2013: <191>162972:    cisco-ani=
Wed Mar 20 09:14:45 2013: <191>162976:
Wed Mar 20 09:14:45 2013: <191>162978:    dest=1811032099
Wed Mar 20 09:14:45 2013: <191>162982:    cisco-rdn=
Wed Mar 20 09:14:45 2013: <191>162989:    final_redirectNumber =
Wed Mar 20 09:14:45 2013: <191>162990:    hunt_group_timeout =0
Wed Mar 20 09:14:45 2013: <191>163004: .Mar 20 09:14:44:  cc_get_feature_vsa count is 4
Wed Mar 20 09:14:45 2013: <191>163005: .Mar 20 09:14:44: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:14:45 2013: <191>163006:
Wed Mar 20 09:14:45 2013: <191>163007: .Mar 20 09:14:44: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248360,feature_id:8147
Wed Mar 20 09:14:45 2013: <191>163008: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:14:45 2013: <191>163009:    SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Wed Mar 20 09:14:45 2013: <191>163010: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/ccCallSetContext:
Wed Mar 20 09:14:45 2013: <191>163011:    Context=0x4BA6AE40
Wed Mar 20 09:14:45 2013: <191>163012: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:14:45 2013: <191>163013:    Outgoing Dial-peer=3000
Wed Mar 20 09:14:45 2013: <191>163014: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:14:45 2013: <191>163015:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:14:45 2013: <191>163016: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:14:45 2013: <191>163017:    Interface=0x48A4F728, Progress Indication=NULL(0)
Wed Mar 20 09:14:45 2013: <191>163018: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:14:45 2013: <191>163019:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:14:45 2013: <191>163020: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_set_delay_xport:
Wed Mar 20 09:14:45 2013: <191>163021:    CallInfo(delay xport=TRUE)
Wed Mar 20 09:14:45 2013: <191>163022: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_call_alert:
Wed Mar 20 09:14:45 2013: <191>163023:    Interface=0x48A4F728, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:14:45 2013: <191>163024: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_call_alert:
Wed Mar 20 09:14:45 2013: <191>163025:    Call Entry(Retry Count=0, Responsed=TRUE)
Wed Mar 20 09:14:45 2013: <191>163026: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/ccCallAlert:
Wed Mar 20 09:14:45 2013: <191>163027:
Wed Mar 20 09:14:45 2013: <191>163028: Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:14:45 2013: <191>163029: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/ccCallAlert:
Wed Mar 20 09:14:45 2013: <191>163030:    Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Wed Mar 20 09:14:45 2013: <191>163031: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:14:45 2013: <191>163032:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:14:45 2013: <191>163033: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_call_notify:
Wed Mar 20 09:14:45 2013: <191>163034:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8147
Wed Mar 20 09:14:45 2013: <191>163035: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/ccIsInfoRingback:
Wed Mar 20 09:14:45 2013: <191>163036:    Returning dpRingBack=0
Wed Mar 20 09:14:45 2013: <191>163037: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:14:45 2013: <191>163038:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:14:45 2013: <191>163039: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:14:45 2013: <191>163040:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:14:45 2013: <191>163041: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/ccCallNotify:
Wed Mar 20 09:14:45 2013: <191>163042:    Data Bitmask=0x5, Call Id=8146
Wed Mar 20 09:14:45 2013: <191>163043: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_call_connected:
Wed Mar 20 09:14:45 2013: <191>163044:    Interface=0x48A4F728, Data Bitmask=0x0, Progress Indication=NULL(0),
Wed Mar 20 09:14:45 2013: <191>163045:    Connection Handle=0
Wed Mar 20 09:14:45 2013: <191>163046: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_call_connected:
Wed Mar 20 09:14:45 2013: <191>163047:    Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:14:45 2013: <191>163048: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:14:45 2013: <191>163049:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:14:45 2013: <191>163050: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_call_notify:
Wed Mar 20 09:14:45 2013: <191>163051:
Wed Mar 20 09:14:45 2013: <191>163052: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8147
Wed Mar 20 09:14:45 2013: <191>163053: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:14:45 2013: <191>163054:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:14:45 2013: <191>163055:    Tone Direction=Network, Params=0x0, Call Id=8146
Wed Mar 20 09:14:45 2013: <191>163056: .Mar 20 09:14:44: //8146/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:14:45 2013: <191>163057:    (confID=0x4BB01FF0, callID1=0x1FD2, callID2=0x1FD3, tag=0x0)
Wed Mar 20 09:14:45 2013: <191>163058: .Mar 20 09:14:44: //8146/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:14:45 2013: <191>163059:    (confID=0x4BB01FF0, callID1=0x1FD2, gcid=9561D059-908E11E2-B3D9DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:14:45 2013: <191>163060: .Mar 20 09:14:44: //8147/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:14:45 2013: <191>163061:    (confID=0x4BB01FF0, callID2=0x1FD3, gcid=9561D059-908E11E2-B3D9DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:14:45 2013: <191>163062: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/ccConferenceCreate:
Wed Mar 20 09:14:45 2013: <191>163063:    Conference Id=0x4BB01FF0, Call Id1=8146, Call Id2=8147, Tag=0x0
Wed Mar 20 09:14:45 2013: <191>163064: .Mar 20 09:14:44: //8146/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:14:45 2013: <191>163065:    Conference Id=0xE56, Source Interface=0x4987FF98, Source Call Id=8146,
Wed Mar 20 09:14:45 2013: <191>163066:    Destination Call Id=8147, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:14:45 2013: <191>163067: .Mar 20 09:14:44: //8147/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:14:45 2013: <191>163068:
Wed Mar 20 09:14:45 2013: <191>163069: .Mar 20 09:14:44: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:14:45 2013: <191>163070: .Mar 20 09:14:44: //8147/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:14:45 2013: <191>163071:    Conference Id=0xE56, Source Interface=0x48A4F728, Source Call Id=8147,
Wed Mar 20 09:14:45 2013: <191>163072:    Destination Call Id=8146, Disposition=0x0, Tag=0x0
Wed Mar 20 09:14:45 2013: <191>163073: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:14:45 2013: <191>163074:    Conference Id=0xE56, Source Interface=0x48A4F728, Source Call Id=8147,
Wed Mar 20 09:14:45 2013: <191>163075:    Destination Call Id=8146, Disposition=0x0, Tag=0x0
Wed Mar 20 09:14:45 2013: <191>163076: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/ccConferenceCreate:
Wed Mar 20 09:14:45 2013: <191>163082:    Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Wed Mar 20 09:14:45 2013: <191>163090:    Destination Interface=0x4987FF98, Destination Call Id=8146, Source Call Id=8147,
Wed Mar 20 09:14:45 2013: <191>163091:    Caps(Codec=0x4, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:14:45 2013: <191>163101: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:14:45 2013: <191>163104:    Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=3343)
Wed Mar 20 09:14:45 2013: <191>163105: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:14:45 2013: <191>163106:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:14:45 2013: <191>163110:    Data Bitmask=0x5, Call Id=8146
Wed Mar 20 09:14:45 2013: <191>163111: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:14:45 2013: <191>163112:    Call Id=8146
Wed Mar 20 09:14:45 2013: <191>163113: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:14:45 2013: <191>163116:    Progress Indication=NULL(0), Data Bitmask=0x0
Wed Mar 20 09:14:45 2013: <191>163117: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/ccCallConnect:
Wed Mar 20 09:14:45 2013: <191>163118:
Wed Mar 20 09:14:46 2013: <191>163119: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:14:56 2013: <191>163120: .Mar 20 09:14:55: //8147/9561D059B3D9/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:14:56 2013: <191>163121:    Interface=0x0, Call Id=8147
Wed Mar 20 09:14:56 2013: <191>163122: .Mar 20 09:14:55: //8147/9561D059B3D9/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:14:56 2013: <191>163123:    Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:14:56 2013: <191>163124: .Mar 20 09:14:55: //8147/9561D059B3D9/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:14:56 2013: <191>163125:    Interface=0x48A4F728, Signal Indication=NOT PRESENT(255)
Wed Mar 20 09:14:56 2013: <191>163126: .Mar 20 09:14:55: //8146/9561D059B3D9/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:14:56 2013: <191>163127:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:14:56 2013: <191>163128:    Tone Direction=Network, Params=0x0, Call Id=8146
Wed Mar 20 09:14:56 2013: <191>163129: .Mar 20 09:14:55: //8147/9561D059B3D9/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:14:56 2013: <191>163130:    Interface=0x48A4F728, Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:14:56 2013: <191>163131: .Mar 20 09:14:55: //8146/9561D059B3D9/CCAPI/ccCallUserInfo:
Wed Mar 20 09:14:56 2013: <191>163132:    Call Id=8146
Wed Mar 20 09:14:56 2013: <191>163133: .Mar 20 09:14:55: //8146/9561D059B3D9/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:14:56 2013: <191>163134:    Stop Tone On Digit=FALSE, Tone=Ring Back,
Wed Mar 20 09:14:56 2013: <191>163135:    Tone Direction=Network, Params=0x0, Call Id=8146
Wed Mar 20 09:14:56 2013: <191>163136: .Mar 20 09:14:55: //8147/9561D059B3D9/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:14:56 2013: <191>163137:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:14:56 2013: <191>163138: .Mar 20 09:14:55: //8147/9561D059B3D9/CCAPI/cc_api_call_notify:
Wed Mar 20 09:14:56 2013: <191>163139:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8147
Wed Mar 20 09:14:56 2013: <191>163140: .Mar 20 09:14:55: //8147/9561D059B3D9/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:14:56 2013: <191>163141:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:14:57 2013: <191>163142: .Mar 20 09:14:55: //8147/9561D059B3D9/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:14:57 2013: <191>163143:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:14:57 2013: <191>163144: .Mar 20 09:14:55: //8146/9561D059B3D9/CCAPI/ccCallNotify:
Wed Mar 20 09:14:57 2013: <191>163145:    Data Bitmask=0x5, Call Id=8146
Wed Mar 20 09:15:03 2013: <191>163146: .Mar 20 09:15:02: //8147/9561D059B3D9/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:15:03 2013: <191>163147:    Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:15:03 2013: <191>163148: .Mar 20 09:15:02: //8147/9561D059B3D9/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:15:03 2013: <191>163149:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:15:03 2013: <191>163150: .Mar 20 09:15:02: //8147/9561D059B3D9/CCAPI/cc_api_call_notify:
Wed Mar 20 09:15:03 2013: <191>163151:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8147
Wed Mar 20 09:15:03 2013: <191>163152: .Mar 20 09:15:02: //8146/9561D059B3D9/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:15:04 2013: <191>163153:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:15:04 2013: <191>163154:    Tone Direction=Network, Params=0x0, Call Id=8146
Wed Mar 20 09:15:04 2013: <191>163155: .Mar 20 09:15:02: //8147/9561D059B3D9/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:15:04 2013: <191>163156:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:15:04 2013: <191>163157: .Mar 20 09:15:02: //8147/9561D059B3D9/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:15:04 2013: <191>163158:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:15:04 2013: <191>163159: .Mar 20 09:15:02: //8146/9561D059B3D9/CCAPI/ccCallNotify:
Wed Mar 20 09:15:04 2013: <191>163160:    Data Bitmask=0x5, Call Id=8146
Wed Mar 20 09:15:04 2013: <191>163161: .Mar 20 09:15:02: //8147/9561D059B3D9/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:15:04 2013: <191>163162:    Destination Interface=0x4987FF98, Destination Call Id=8146, Source Call Id=8147,
Wed Mar 20 09:15:04 2013: <191>163163:    Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:15:04 2013: <191>163164:    Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:15:04 2013: <191>163165: .Mar 20 09:15:02: //8147/9561D059B3D9/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:15:04 2013: <191>163166:    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:15:04 2013: <191>163167:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:15:04 2013: <191>163168: .Mar 20 09:15:02: //8147/9561D059B3D9/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:15:04 2013: <191>163169:
Wed Mar 20 09:15:04 2013: <191>163170: Destination Interface=0x4987FF98, Destination Call Id=8146, Source Call Id=8147,
Wed Mar 20 09:15:04 2013: <191>163171:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:15:04 2013: <191>163172:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=3506)
Wed Mar 20 09:15:04 2013: <191>163173: .Mar 20 09:15:02: //8146/9561D059B3D9/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:15:04 2013: <191>163174:    Destination Interface=0x48A4F728, Destination Call Id=8147, Source Call Id=8146,
Wed Mar 20 09:15:04 2013: <191>163175:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:15:04 2013: <191>163176:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=3506)
Wed Mar 20 09:15:04 2013: <191>163177: .Mar 20 09:15:02: //8146/9561D059B3D9/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:15:04 2013: <191>163178:    Call Id=8146
Wed Mar 20 09:15:04 2013: <191>163179: .Mar 20 09:15:02: //8146/9561D059B3D9/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:15:04 2013: <191>163180:
Wed Mar 20 09:15:05 2013: <191>163181: Call Entry(Context=0x4BA7CBB8)
Wed Mar 20 09:15:39 2013: <191>163182: .Mar 20 09:15:38: //-1/B5F97BB2B3DE/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:15:39 2013: <191>163184:    cisco-username=
Wed Mar 20 09:15:39 2013: <191>163183:    cc_api_call_setup_ind_common:
Wed Mar 20 09:15:39 2013: <191>163185:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:15:39 2013: <191>163186:    cisco-ani=
Wed Mar 20 09:15:39 2013: <191>163187:    cisco-anitype=0
Wed Mar 20 09:15:39 2013: <191>163188:    cisco-aniplan=0
Wed Mar 20 09:15:39 2013: <191>163189:    cisco-anipi=0
Wed Mar 20 09:15:39 2013: <191>163190:    cisco-anisi=0
Wed Mar 20 09:15:39 2013: <191>163191:    dest=1811032099
Wed Mar 20 09:15:39 2013: <191>163192:    cisco-desttype=0
Wed Mar 20 09:15:39 2013: <191>163193:    cisco-destplan=0
Wed Mar 20 09:15:39 2013: <191>163194:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:15:39 2013: <191>163195:    cisco-rdn=
Wed Mar 20 09:15:39 2013: <191>163196:    cisco-lastrdn=
Wed Mar 20 09:15:39 2013: <191>163197:    cisco-rdntype=0
Wed Mar 20 09:15:39 2013: <191>163198:    cisco-rdnplan=0
Wed Mar 20 09:15:39 2013: <191>163199:    cisco-rdnpi=0
Wed Mar 20 09:15:39 2013: <191>163200:    cisco-rdnsi=0
Wed Mar 20 09:15:39 2013: <191>163201:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:15:39 2013: <191>163202:    final_redirectNumber =
Wed Mar 20 09:15:39 2013: <191>163203:    hunt_group_timeout =0
Wed Mar 20 09:15:39 2013: <191>163204:
Wed Mar 20 09:15:39 2013: <191>163205: .Mar 20 09:15:38: //-1/B5F97BB2B3DE/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:15:39 2013: <191>163206:
Wed Mar 20 09:15:39 2013: <191>163207: Interface=0x498845E0, Call Info(
Wed Mar 20 09:15:39 2013: <191>163208:    Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:15:39 2013: <191>163209:    Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:15:39 2013: <191>163210:    Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Wed Mar 20 09:15:39 2013: <191>163211:    Incoming Dial-peer=50, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Wed Mar 20 09:15:39 2013: <191>163212:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:15:39 2013: <191>163213: .Mar 20 09:15:38: //-1/B5F97BB2B3DE/CCAPI/ccCheckClipClir:
Wed Mar 20 09:15:39 2013: <191>163214:    In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:15:39 2013: <191>163215: .Mar 20 09:15:38: //-1/B5F97BB2B3DE/CCAPI/ccCheckClipClir:
Wed Mar 20 09:15:39 2013: <191>163216:    Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:15:39 2013: <191>163217: .Mar 20 09:15:38: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:15:39 2013: <191>163218:
Wed Mar 20 09:15:39 2013: <191>163219: .Mar 20 09:15:38: :cc_get_feature_vsa malloc success
Wed Mar 20 09:15:39 2013: <191>163220: .Mar 20 09:15:38: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:15:39 2013: <191>163221:
Wed Mar 20 09:15:39 2013: <191>163222: .Mar 20 09:15:38:  cc_get_feature_vsa count is 5
Wed Mar 20 09:15:39 2013: <191>163223: .Mar 20 09:15:38: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:15:39 2013: <191>163224:
Wed Mar 20 09:15:39 2013: <191>163225: .Mar 20 09:15:38: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203247464,feature_id:8148
Wed Mar 20 09:15:39 2013: <191>163226: .Mar 20 09:15:38: //8148/B5F97BB2B3DE/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:15:39 2013: <191>163227:
Wed Mar 20 09:15:40 2013: <191>163228: Set Up Event Sent;
Wed Mar 20 09:15:40 2013: <191>163229:    Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:15:40 2013: <191>163230:    Called Number=1811032099(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:15:40 2013: <191>163231: .Mar 20 09:15:38: //8148/B5F97BB2B3DE/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:15:40 2013: <191>163232:    Event=0x4982C828
Wed Mar 20 09:15:40 2013: <191>163240:
Wed Mar 20 09:15:40 2013: <191>163241: Progress Indication=NULL(0)
Wed Mar 20 09:15:40 2013: <191>163243:    Destination=, Calling IE Present=FALSE, Mode=0,
Wed Mar 20 09:15:40 2013: <191>163257:    Guid=B5F97BB2-908E-11E2-B3DE-DE08FC69A21F, Outgoing Dial-peer=3000
Wed Mar 20 09:15:40 2013: <191>163258: .Mar 20 09:15:38: //8148/B5F97BB2B3DE/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:15:40 2013: <191>163261:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:15:40 2013: <191>163264:    cisco-aniplan=0
Wed Mar 20 09:15:40 2013: <191>163268:    dest=1811032099
Wed Mar 20 09:15:40 2013: <191>163269:    cisco-desttype=0
Wed Mar 20 09:15:40 2013: <191>163277:    cisco-rdnsi=0
Wed Mar 20 09:15:40 2013: <191>163279:    final_redirectNumber =
Wed Mar 20 09:15:40 2013: <191>163281:
Wed Mar 20 09:15:40 2013: <191>163294: .Mar 20 09:15:38:  cc_get_feature_vsa count is 6
Wed Mar 20 09:15:40 2013: <191>163295: .Mar 20 09:15:38: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:15:40 2013: <191>163296:
Wed Mar 20 09:15:40 2013: <191>163297: .Mar 20 09:15:38: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203247240,feature_id:8149
Wed Mar 20 09:15:40 2013: <191>163298: .Mar 20 09:15:38: //8149/B5F97BB2B3DE/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:15:40 2013: <191>163299:    SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Wed Mar 20 09:15:40 2013: <191>163300: .Mar 20 09:15:38: //8149/B5F97BB2B3DE/CCAPI/ccCallSetContext:
Wed Mar 20 09:15:40 2013: <191>163301:    Context=0x4BA7A5A8
Wed Mar 20 09:15:40 2013: <191>163302: .Mar 20 09:15:38: //8148/B5F97BB2B3DE/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:15:40 2013: <191>163303:    Outgoing Dial-peer=3000
Wed Mar 20 09:15:40 2013: <191>163304: .Mar 20 09:15:38: //8149/B5F97BB2B3DE/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:15:40 2013: <191>163305:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:15:40 2013: <191>163306: .Mar 20 09:15:38: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:15:40 2013: <191>163307:    Interface=0x48A4F728, Progress Indication=NULL(0)
Wed Mar 20 09:15:40 2013: <191>163308: .Mar 20 09:15:38: //8149/B5F97BB2B3DE/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:15:40 2013: <191>163309:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:15:40 2013: <191>163310: .Mar 20 09:15:38: //8149/B5F97BB2B3DE/CCAPI/cc_api_set_delay_xport:
Wed Mar 20 09:15:40 2013: <191>163311:    CallInfo(delay xport=TRUE)
Wed Mar 20 09:15:40 2013: <191>163312: .Mar 20 09:15:38: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_alert:
Wed Mar 20 09:15:40 2013: <191>163313:    Interface=0x48A4F728, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:15:40 2013: <191>163314: .Mar 20 09:15:38: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_alert:
Wed Mar 20 09:15:40 2013: <191>163315:    Call Entry(Retry Count=0, Responsed=TRUE)
Wed Mar 20 09:15:40 2013: <191>163316: .Mar 20 09:15:38: //8148/B5F97BB2B3DE/CCAPI/ccCallAlert:
Wed Mar 20 09:15:40 2013: <191>163317:
Wed Mar 20 09:15:40 2013: <191>163318: Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:15:40 2013: <191>163319: .Mar 20 09:15:38: //8148/B5F97BB2B3DE/CCAPI/ccCallAlert:
Wed Mar 20 09:15:40 2013: <191>163320:    Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Wed Mar 20 09:15:40 2013: <191>163321: .Mar 20 09:15:39: //8149/B5F97BB2B3DE/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:15:40 2013: <191>163322:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:15:40 2013: <191>163323: .Mar 20 09:15:39: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_notify:
Wed Mar 20 09:15:40 2013: <191>163324:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8149
Wed Mar 20 09:15:40 2013: <191>163325: .Mar 20 09:15:39: //8149/B5F97BB2B3DE/CCAPI/ccIsInfoRingback:
Wed Mar 20 09:15:40 2013: <191>163326:    Returning dpRingBack=0
Wed Mar 20 09:15:40 2013: <191>163327: .Mar 20 09:15:39: //8149/B5F97BB2B3DE/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:15:40 2013: <191>163328:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:15:40 2013: <191>163329: .Mar 20 09:15:39: //8149/B5F97BB2B3DE/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:15:40 2013: <191>163330:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:15:40 2013: <191>163331: .Mar 20 09:15:39: //8148/B5F97BB2B3DE/CCAPI/ccCallNotify:
Wed Mar 20 09:15:40 2013: <191>163332:    Data Bitmask=0x5, Call Id=8148
Wed Mar 20 09:15:40 2013: <191>163333: .Mar 20 09:15:39: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_connected:
Wed Mar 20 09:15:40 2013: <191>163334:    Interface=0x48A4F728, Data Bitmask=0x0, Progress Indication=NULL(0),
Wed Mar 20 09:15:40 2013: <191>163335:    Connection Handle=0
Wed Mar 20 09:15:40 2013: <191>163336: .Mar 20 09:15:39: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_connected:
Wed Mar 20 09:15:40 2013: <191>163337:    Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:15:40 2013: <191>163338: .Mar 20 09:15:39: //8149/B5F97BB2B3DE/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:15:40 2013: <191>163339:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:15:40 2013: <191>163340: .Mar 20 09:15:39: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_notify:
Wed Mar 20 09:15:40 2013: <191>163341:
Wed Mar 20 09:15:40 2013: <191>163342: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8149
Wed Mar 20 09:15:40 2013: <191>163343: .Mar 20 09:15:39: //8148/B5F97BB2B3DE/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:15:40 2013: <191>163344:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:15:40 2013: <191>163345:    Tone Direction=Network, Params=0x0, Call Id=8148
Wed Mar 20 09:15:40 2013: <191>163346: .Mar 20 09:15:39: //8148/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:15:40 2013: <191>163347:    (confID=0x4BB01DF8, callID1=0x1FD4, callID2=0x1FD5, tag=0x0)
Wed Mar 20 09:15:40 2013: <191>163348: .Mar 20 09:15:39: //8148/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:15:40 2013: <191>163349:    (confID=0x4BB01DF8, callID1=0x1FD4, gcid=B5F97BB2-908E11E2-B3DEDE08-FC69A21F, tag=0x0)
Wed Mar 20 09:15:40 2013: <191>163350: .Mar 20 09:15:39: //8149/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:15:40 2013: <191>163351:    (confID=0x4BB01DF8, callID2=0x1FD5, gcid=B5F97BB2-908E11E2-B3DEDE08-FC69A21F, tag=0x0)
Wed Mar 20 09:15:40 2013: <191>163352: .Mar 20 09:15:39: //8148/B5F97BB2B3DE/CCAPI/ccConferenceCreate:
Wed Mar 20 09:15:40 2013: <191>163353:    Conference Id=0x4BB01DF8, Call Id1=8148, Call Id2=8149, Tag=0x0
Wed Mar 20 09:15:40 2013: <191>163354: .Mar 20 09:15:39: //8148/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:15:40 2013: <191>163355:    Conference Id=0xE57, Source Interface=0x498845E0, Source Call Id=8148,
Wed Mar 20 09:15:40 2013: <191>163356:    Destination Call Id=8149, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:15:40 2013: <191>163357: .Mar 20 09:15:39: //8149/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:15:40 2013: <191>163358:
Wed Mar 20 09:15:40 2013: <191>163359: .Mar 20 09:15:39: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:15:40 2013: <191>163360: .Mar 20 09:15:39: //8149/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:15:40 2013: <191>163361:    Conference Id=0xE57, Source Interface=0x48A4F728, Source Call Id=8149,
Wed Mar 20 09:15:40 2013: <191>163362:    Destination Call Id=8148, Disposition=0x0, Tag=0x0
Wed Mar 20 09:15:40 2013: <191>163363: .Mar 20 09:15:39: //8148/B5F97BB2B3DE/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:15:40 2013: <191>163364:    Conference Id=0xE57, Source Interface=0x48A4F728, Source Call Id=8149,
Wed Mar 20 09:15:40 2013: <191>163365:    Destination Call Id=8148, Disposition=0x0, Tag=0x0
Wed Mar 20 09:15:40 2013: <191>163366: .Mar 20 09:15:39: //8148/B5F97BB2B3DE/CCAPI/ccConferenceCreate:
Wed Mar 20 09:15:40 2013: <191>163369:    Call Entry(Conference Id=0xE57, Destination Call Id=8148)
Wed Mar 20 09:15:40 2013: <191>163370: .Mar 20 09:15:39: //8148/B5F97BB2B3DE/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:15:40 2013: <191>163383: .Mar 20 09:15:39: //8149/B5F97BB2B3DE/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:15:40 2013: <191>163384:
Wed Mar 20 09:15:40 2013: <191>163385: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:15:40 2013: <191>163389:    Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:15:40 2013: <191>163391: .Mar 20 09:15:39: //8148/B5F97BB2B3DE/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:15:40 2013: <191>163392:    Destination Interface=0x48A4F728, Destination Call Id=8149, Source Call Id=8148,
Wed Mar 20 09:15:40 2013: <191>163393:    Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:15:40 2013: <191>163394:    Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=5309)
Wed Mar 20 09:15:40 2013: <191>163404:    Call Entry(Context=0x4BA76C90)
Wed Mar 20 09:15:40 2013: <191>163408:
Wed Mar 20 09:15:41 2013: <191>163409: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:15:44 2013: <190>163410: .Mar 20 09:15:42: %IPPHONE-6-UNREGISTER_NORMAL: ephone-11:SEP002699441929 IP:10.229.64.33 Socket:5 DeviceType:Phone has unregistered normally.
Wed Mar 20 09:15:51 2013: <191>163411: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:15:51 2013: <191>163412:    Interface=0x0, Call Id=8149
Wed Mar 20 09:15:51 2013: <191>163413: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:15:51 2013: <191>163414:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:15:51 2013: <191>163415: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_notify:
Wed Mar 20 09:15:51 2013: <191>163416:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8149
Wed Mar 20 09:15:51 2013: <191>163417: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:15:51 2013: <191>163418:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:15:51 2013: <191>163419: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:15:51 2013: <191>163420:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:15:51 2013: <191>163421: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/ccCallNotify:
Wed Mar 20 09:15:51 2013: <191>163422:    Data Bitmask=0x5, Call Id=8148
Wed Mar 20 09:15:51 2013: <191>163423: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:15:51 2013: <191>163424:    Destination Interface=0x498845E0, Destination Call Id=8148, Source Call Id=8149,
Wed Mar 20 09:15:51 2013: <191>163425:    Caps(Codec=0x4, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:15:51 2013: <191>163426:    Modem=0x2, Codec Bytes=20, Signal Type=2)
Wed Mar 20 09:15:51 2013: <191>163427: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:15:51 2013: <191>163428:    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:15:51 2013: <191>163429:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:15:51 2013: <191>163430: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:15:51 2013: <191>163431:
Wed Mar 20 09:15:51 2013: <191>163432: Destination Interface=0x498845E0, Destination Call Id=8148, Source Call Id=8149,
Wed Mar 20 09:15:51 2013: <191>163433:    Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:15:51 2013: <191>163434:    Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=5476)
Wed Mar 20 09:15:51 2013: <191>163435: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:15:51 2013: <191>163436:    Destination Interface=0x48A4F728, Destination Call Id=8149, Source Call Id=8148,
Wed Mar 20 09:15:51 2013: <191>163437:    Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:15:51 2013: <191>163438:    Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=5476)
Wed Mar 20 09:15:51 2013: <191>163439: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:15:51 2013: <191>163440:    Call Id=8148
Wed Mar 20 09:15:51 2013: <191>163441: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:15:51 2013: <191>163442:
Wed Mar 20 09:15:51 2013: <191>163443: Call Entry(Context=0x4BA76C90)
Wed Mar 20 09:15:51 2013: <191>163444: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:15:51 2013: <191>163445:    Interface=0x0, Call Id=8149
Wed Mar 20 09:15:51 2013: <191>163446: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:15:51 2013: <191>163447:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:15:51 2013: <191>163448: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_notify:
Wed Mar 20 09:15:51 2013: <191>163449:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8149
Wed Mar 20 09:15:51 2013: <191>163450: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:15:51 2013: <191>163451:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:15:51 2013: <191>163452: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:15:51 2013: <191>163453:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:15:51 2013: <191>163454: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/ccCallNotify:
Wed Mar 20 09:15:51 2013: <191>163455:
Wed Mar 20 09:15:51 2013: <191>163456: Data Bitmask=0x5, Call Id=8148
Wed Mar 20 09:15:51 2013: <191>163457: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:15:51 2013: <191>163458:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:15:51 2013: <191>163459: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_notify:
Wed Mar 20 09:15:51 2013: <191>163460:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8149
Wed Mar 20 09:15:51 2013: <191>163461: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:15:51 2013: <191>163462:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:15:51 2013: <191>163463: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:15:51 2013: <191>163464:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:15:51 2013: <191>163465: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/ccCallNotify:
Wed Mar 20 09:15:51 2013: <191>163466:    Data Bitmask=0x5, Call Id=8148
Wed Mar 20 09:15:51 2013: <191>163467: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:15:51 2013: <191>163468:
Wed Mar 20 09:15:51 2013: <191>163469: Interface=0x0, Call Id=8149
Wed Mar 20 09:15:51 2013: <191>163470: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:15:51 2013: <191>163471:    Cause Value=16, Interface=0x48A4F728, Call Id=8149
Wed Mar 20 09:15:51 2013: <191>163472: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:15:51 2013: <191>163473:    Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:15:51 2013: <191>163474: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:15:51 2013: <191>163475:    Conference Id=0xE57, Tag=0x0
Wed Mar 20 09:15:51 2013: <191>163476: .Mar 20 09:15:50: //8148/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:15:51 2013: <191>163477:    Conference Id=0xE57, Source Interface=0x498845E0, Source Call Id=8148,
Wed Mar 20 09:15:51 2013: <191>163478:    Destination Call Id=8149, Disposition=0x0, Tag=0x0
Wed Mar 20 09:15:51 2013: <191>163479: .Mar 20 09:15:50: //8149/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:15:51 2013: <191>163480:
Wed Mar 20 09:15:51 2013: <191>163481: Conference Id=0xE57, Source Interface=0x48A4F728, Source Call Id=8149,
Wed Mar 20 09:15:51 2013: <191>163482:    Destination Call Id=8148, Disposition=0x0, Tag=0x0
Wed Mar 20 09:15:51 2013: <191>163483: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:15:51 2013: <191>163484:    Conference Id=0xE57, Source Interface=0x48A4F728, Source Call Id=8149,
Wed Mar 20 09:15:51 2013: <191>163485:    Destination Call Id=8148, Disposition=0x0, Tag=0x0
Wed Mar 20 09:15:51 2013: <191>163486: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/ccCallDisconnect:
Wed Mar 20 09:15:51 2013: <191>163487:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:15:51 2013: <191>163488: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/ccCallDisconnect:
Wed Mar 20 09:15:51 2013: <191>163489:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:15:51 2013: <191>163490: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:15:51 2013: <191>163491:
Wed Mar 20 09:15:51 2013: <191>163492: Transfer Number Is Null
Wed Mar 20 09:15:51 2013: <191>163493: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/ccCallDisconnect:
Wed Mar 20 09:15:51 2013: <191>163494:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:15:51 2013: <191>163495: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/ccCallDisconnect:
Wed Mar 20 09:15:51 2013: <191>163496:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:15:51 2013: <191>163497: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:15:51 2013: <191>163498:    Transfer Number Is Null
Wed Mar 20 09:15:51 2013: <191>163499: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:15:51 2013: <191>163500:    Transfer Number Is Null
Wed Mar 20 09:15:51 2013: <191>163501: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:15:51 2013: <191>163502:
Wed Mar 20 09:15:51 2013: <191>163503: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8149,
Wed Mar 20 09:15:51 2013: <191>163504:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:15:51 2013: <191>163505: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:15:51 2013: <191>163506:    Call Disconnect Event Sent
Wed Mar 20 09:15:51 2013: <191>163507: .Mar 20 09:15:50: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:15:51 2013: <191>163508:
Wed Mar 20 09:15:51 2013: <191>163509: .Mar 20 09:15:50: :cc_free_feature_vsa freeing 47B81880
Wed Mar 20 09:15:51 2013: <191>163510: .Mar 20 09:15:50: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:15:51 2013: <191>163511:
Wed Mar 20 09:15:51 2013: <191>163512: .Mar 20 09:15:50:  vsacount in free is 5
Wed Mar 20 09:15:51 2013: <191>163513: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:15:51 2013: <191>163514:    Disposition=0, Interface=0x498845E0, Tag=0x0, Call Id=8148,
Wed Mar 20 09:15:51 2013: <191>163515:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:15:52 2013: <191>163516: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:15:52 2013: <191>163517:    Call Disconnect Event Sent
Wed Mar 20 09:15:52 2013: <191>163518: .Mar 20 09:15:50: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:15:52 2013: <191>163519:
Wed Mar 20 09:15:52 2013: <191>163520: .Mar 20 09:15:50: :cc_free_feature_vsa freeing 47B81960
Wed Mar 20 09:15:52 2013: <191>163521: .Mar 20 09:15:50: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:15:52 2013: <191>163522:
Wed Mar 20 09:15:52 2013: <191>163523: .Mar 20 09:15:50:  vsacount in free is 4
Wed Mar 20 09:16:46 2013: <191>163524: .Mar 20 09:16:45: //8144/80F45E604006/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:16:46 2013: <191>163525:    Cause Value=16, Interface=0x48A4F728, Call Id=8144
Wed Mar 20 09:16:46 2013: <191>163526: .Mar 20 09:16:45: //8144/80F45E604006/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:16:46 2013: <191>163527:    Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:16:46 2013: <191>163528: .Mar 20 09:16:45: //8144/80F45E604006/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:16:46 2013: <191>163529:    Conference Id=0xE55, Tag=0x0
Wed Mar 20 09:16:46 2013: <191>163530: .Mar 20 09:16:45: //8144/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:16:46 2013: <191>163531:    Conference Id=0xE55, Source Interface=0x48A4F728, Source Call Id=8144,
Wed Mar 20 09:16:46 2013: <191>163532:    Destination Call Id=8145, Disposition=0x0, Tag=0x0
Wed Mar 20 09:16:46 2013: <191>163533: .Mar 20 09:16:45: //8145/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:16:46 2013: <191>163534:
Wed Mar 20 09:16:46 2013: <191>163535: Conference Id=0xE55, Source Interface=0x4987DFD8, Source Call Id=8145,
Wed Mar 20 09:16:46 2013: <191>163536:    Destination Call Id=8144, Disposition=0x0, Tag=0x0
Wed Mar 20 09:16:46 2013: <191>163537: .Mar 20 09:16:45: //8144/80F45E604006/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:16:46 2013: <191>163538:    Conference Id=0xE55, Source Interface=0x4987DFD8, Source Call Id=8145,
Wed Mar 20 09:16:46 2013: <191>163539:    Destination Call Id=8144, Disposition=0x0, Tag=0x0
Wed Mar 20 09:16:46 2013: <191>163540: .Mar 20 09:16:45: //8144/80F45E604006/CCAPI/ccCallDisconnect:
Wed Mar 20 09:16:46 2013: <191>163541:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:16:46 2013: <191>163542: .Mar 20 09:16:45: //8144/80F45E604006/CCAPI/ccCallDisconnect:
Wed Mar 20 09:16:46 2013: <191>163543:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:16:46 2013: <191>163544: .Mar 20 09:16:45: //8144/80F45E604006/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:16:46 2013: <191>163545:
Wed Mar 20 09:16:46 2013: <191>163546: Transfer Number Is Null
Wed Mar 20 09:16:46 2013: <191>163547: .Mar 20 09:16:45: //8145/80F45E604006/CCAPI/ccCallDisconnect:
Wed Mar 20 09:16:46 2013: <191>163548:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:16:46 2013: <191>163549: .Mar 20 09:16:45: //8145/80F45E604006/CCAPI/ccCallDisconnect:
Wed Mar 20 09:16:46 2013: <191>163550:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:16:46 2013: <191>163551: .Mar 20 09:16:45: //8145/80F45E604006/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:16:46 2013: <191>163552:    Transfer Number Is Null
Wed Mar 20 09:16:46 2013: <191>163553: .Mar 20 09:16:45: //8144/80F45E604006/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:16:46 2013: <191>163554:    Transfer Number Is Null
Wed Mar 20 09:16:46 2013: <191>163555: .Mar 20 09:16:45: //8144/80F45E604006/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:16:46 2013: <191>163556:
Wed Mar 20 09:16:46 2013: <191>163557: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8144,
Wed Mar 20 09:16:46 2013: <191>163558:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:16:46 2013: <191>163559: .Mar 20 09:16:45: //8144/80F45E604006/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:16:46 2013: <191>163560:    Call Disconnect Event Sent
Wed Mar 20 09:16:46 2013: <191>163561: .Mar 20 09:16:45: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:16:46 2013: <191>163562:
Wed Mar 20 09:16:46 2013: <191>163563: .Mar 20 09:16:45: :cc_free_feature_vsa freeing 47B81B20
Wed Mar 20 09:16:46 2013: <191>163564: .Mar 20 09:16:45: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:16:46 2013: <191>163565:
Wed Mar 20 09:16:46 2013: <191>163566: .Mar 20 09:16:45:  vsacount in free is 3
Wed Mar 20 09:16:46 2013: <191>163567: .Mar 20 09:16:45: //8145/80F45E604006/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:16:46 2013: <191>163568:    Disposition=0, Interface=0x4987DFD8, Tag=0x0, Call Id=8145,
Wed Mar 20 09:16:46 2013: <191>163569:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:16:47 2013: <191>163570: .Mar 20 09:16:45: //8145/80F45E604006/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:16:47 2013: <191>163571:    Call Disconnect Event Sent
Wed Mar 20 09:16:47 2013: <191>163572: .Mar 20 09:16:45: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:16:47 2013: <191>163573:
Wed Mar 20 09:16:47 2013: <191>163574: .Mar 20 09:16:45: :cc_free_feature_vsa freeing 47B81A40
Wed Mar 20 09:16:47 2013: <191>163575: .Mar 20 09:16:45: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:16:47 2013: <191>163576:
Wed Mar 20 09:16:47 2013: <191>163577: .Mar 20 09:16:45:  vsacount in free is 2
Wed Mar 20 09:17:02 2013: <191>163578: .Mar 20 09:17:01: //8147/9561D059B3D9/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:17:02 2013: <191>163579:    Cause Value=16, Interface=0x48A4F728, Call Id=8147
Wed Mar 20 09:17:02 2013: <191>163580: .Mar 20 09:17:01: //8147/9561D059B3D9/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:17:02 2013: <191>163581:    Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:17:02 2013: <191>163582: .Mar 20 09:17:01: //8146/9561D059B3D9/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:17:02 2013: <191>163583:    Conference Id=0xE56, Tag=0x0
Wed Mar 20 09:17:02 2013: <191>163584: .Mar 20 09:17:01: //8146/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:17:02 2013: <191>163585:    Conference Id=0xE56, Source Interface=0x4987FF98, Source Call Id=8146,
Wed Mar 20 09:17:02 2013: <191>163586:    Destination Call Id=8147, Disposition=0x0, Tag=0x0
Wed Mar 20 09:17:02 2013: <191>163587: .Mar 20 09:17:01: //8147/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:17:02 2013: <191>163588:
Wed Mar 20 09:17:02 2013: <191>163589: Conference Id=0xE56, Source Interface=0x48A4F728, Source Call Id=8147,
Wed Mar 20 09:17:02 2013: <191>163590:    Destination Call Id=8146, Disposition=0x0, Tag=0x0
Wed Mar 20 09:17:02 2013: <191>163591: .Mar 20 09:17:01: //8146/9561D059B3D9/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:17:02 2013: <191>163592:    Conference Id=0xE56, Source Interface=0x48A4F728, Source Call Id=8147,
Wed Mar 20 09:17:02 2013: <191>163593:    Destination Call Id=8146, Disposition=0x0, Tag=0x0
Wed Mar 20 09:17:03 2013: <191>163594: .Mar 20 09:17:01: //8146/9561D059B3D9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:17:03 2013: <191>163595:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:17:03 2013: <191>163596: .Mar 20 09:17:01: //8146/9561D059B3D9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:17:03 2013: <191>163597:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:17:03 2013: <191>163598: .Mar 20 09:17:01: //8146/9561D059B3D9/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:17:03 2013: <191>163599:
Wed Mar 20 09:17:03 2013: <191>163600: Transfer Number Is Null
Wed Mar 20 09:17:03 2013: <191>163601: .Mar 20 09:17:01: //8147/9561D059B3D9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:17:03 2013: <191>163602:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:17:03 2013: <191>163603: .Mar 20 09:17:01: //8147/9561D059B3D9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:17:03 2013: <191>163604:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:17:03 2013: <191>163605: .Mar 20 09:17:01: //8147/9561D059B3D9/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:17:03 2013: <191>163606:    Transfer Number Is Null
Wed Mar 20 09:17:03 2013: <191>163607: .Mar 20 09:17:01: //8147/9561D059B3D9/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:17:03 2013: <191>163608:    Transfer Number Is Null
Wed Mar 20 09:17:03 2013: <191>163609: .Mar 20 09:17:01: //8147/9561D059B3D9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:17:03 2013: <191>163610:
Wed Mar 20 09:17:03 2013: <191>163611: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8147,
Wed Mar 20 09:17:03 2013: <191>163612:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:17:03 2013: <191>163613: .Mar 20 09:17:01: //8147/9561D059B3D9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:17:03 2013: <191>163614:    Call Disconnect Event Sent
Wed Mar 20 09:17:03 2013: <191>163615: .Mar 20 09:17:01: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:17:03 2013: <191>163616:
Wed Mar 20 09:17:03 2013: <191>163617: .Mar 20 09:17:01: :cc_free_feature_vsa freeing 47B81CE0
Wed Mar 20 09:17:03 2013: <191>163618: .Mar 20 09:17:01: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:17:03 2013: <191>163619:
Wed Mar 20 09:17:03 2013: <191>163620: .Mar 20 09:17:01:  vsacount in free is 1
Wed Mar 20 09:17:03 2013: <191>163621: .Mar 20 09:17:01: //8146/9561D059B3D9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:17:03 2013: <191>163622:    Disposition=0, Interface=0x4987FF98, Tag=0x0, Call Id=8146,
Wed Mar 20 09:17:03 2013: <191>163623:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:17:03 2013: <191>163624: .Mar 20 09:17:01: //8146/9561D059B3D9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:17:03 2013: <191>163625:    Call Disconnect Event Sent
Wed Mar 20 09:17:03 2013: <191>163626: .Mar 20 09:17:01: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:17:03 2013: <191>163627:
Wed Mar 20 09:17:03 2013: <191>163628: .Mar 20 09:17:01: :cc_free_feature_vsa freeing 47B81C00
Wed Mar 20 09:17:03 2013: <191>163629: .Mar 20 09:17:01: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:17:03 2013: <191>163630:
Wed Mar 20 09:17:03 2013: <191>163631: .Mar 20 09:17:01:  vsacount in free is 0
Wed Mar 20 09:17:12 2013: <191>163632: .Mar 20 09:17:10: //-1/ECF034A4B3E3/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:17:12 2013: <191>163633:    cc_api_call_setup_ind_common:
Wed Mar 20 09:17:12 2013: <191>163634:    cisco-username=
Wed Mar 20 09:17:12 2013: <191>163635:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:17:12 2013: <191>163636:    cisco-ani=
Wed Mar 20 09:17:12 2013: <191>163637:    cisco-anitype=0
Wed Mar 20 09:17:12 2013: <191>163638:    cisco-aniplan=0
Wed Mar 20 09:17:12 2013: <191>163639:    cisco-anipi=0
Wed Mar 20 09:17:12 2013: <191>163640:    cisco-anisi=0
Wed Mar 20 09:17:12 2013: <191>163641:    dest=1811032099
Wed Mar 20 09:17:12 2013: <191>163642:    cisco-desttype=0
Wed Mar 20 09:17:12 2013: <191>163643:    cisco-destplan=0
Wed Mar 20 09:17:12 2013: <191>163644:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:17:12 2013: <191>163645:    cisco-rdn=
Wed Mar 20 09:17:12 2013: <191>163646:    cisco-lastrdn=
Wed Mar 20 09:17:12 2013: <191>163647:    cisco-rdntype=0
Wed Mar 20 09:17:12 2013: <191>163648:    cisco-rdnplan=0
Wed Mar 20 09:17:12 2013: <191>163649:    cisco-rdnpi=0
Wed Mar 20 09:17:12 2013: <191>163650:    cisco-rdnsi=0
Wed Mar 20 09:17:12 2013: <191>163651:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:17:12 2013: <191>163652:    final_redirectNumber =
Wed Mar 20 09:17:12 2013: <191>163653:    hunt_group_timeout =0
Wed Mar 20 09:17:12 2013: <191>163654:
Wed Mar 20 09:17:12 2013: <191>163655: .Mar 20 09:17:10: //-1/ECF034A4B3E3/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:17:12 2013: <191>163656:
Wed Mar 20 09:17:12 2013: <191>163657: Interface=0x498845E0, Call Info(
Wed Mar 20 09:17:12 2013: <191>163658:    Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:17:12 2013: <191>163659:    Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:17:12 2013: <191>163660:    Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Wed Mar 20 09:17:12 2013: <191>163661:    Incoming Dial-peer=50, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Wed Mar 20 09:17:12 2013: <191>163662:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:17:12 2013: <191>163663: .Mar 20 09:17:10: //-1/ECF034A4B3E3/CCAPI/ccCheckClipClir:
Wed Mar 20 09:17:12 2013: <191>163664:    In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:17:12 2013: <191>163665: .Mar 20 09:17:10: //-1/ECF034A4B3E3/CCAPI/ccCheckClipClir:
Wed Mar 20 09:17:12 2013: <191>163666:    Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:17:12 2013: <191>163667: .Mar 20 09:17:10: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:17:12 2013: <191>163668:
Wed Mar 20 09:17:12 2013: <191>163669: .Mar 20 09:17:10: :cc_get_feature_vsa malloc success
Wed Mar 20 09:17:12 2013: <191>163670: .Mar 20 09:17:10: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:17:12 2013: <191>163671:
Wed Mar 20 09:17:12 2013: <191>163672: .Mar 20 09:17:10:  cc_get_feature_vsa count is 1
Wed Mar 20 09:17:12 2013: <191>163673: .Mar 20 09:17:10: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:17:12 2013: <191>163674:
Wed Mar 20 09:17:12 2013: <191>163675: .Mar 20 09:17:10: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203325536,feature_id:8150
Wed Mar 20 09:17:12 2013: <191>163676: .Mar 20 09:17:10: //8150/ECF034A4B3E3/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:17:12 2013: <191>163677:
Wed Mar 20 09:17:12 2013: <191>163678: Set Up Event Sent;
Wed Mar 20 09:17:12 2013: <191>163680:    Called Number=1811032099(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:17:12 2013: <191>163682:    Event=0x4982D230
Wed Mar 20 09:17:12 2013: <191>163683: .Mar 20 09:17:10: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Wed Mar 20 09:17:12 2013: <191>163687: .Mar 20 09:17:10: //8150/ECF034A4B3E3/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:17:12 2013: <191>163689: .Mar 20 09:17:10: //8150/ECF034A4B3E3/CCAPI/ccCallProceeding:
Wed Mar 20 09:17:12 2013: <191>163690:
Wed Mar 20 09:17:12 2013: <191>163691: Progress Indication=NULL(0)
Wed Mar 20 09:17:12 2013: <191>163692: .Mar 20 09:17:10: //8150/ECF034A4B3E3/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:17:12 2013: <191>163696:    In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:17:12 2013: <191>163697: .Mar 20 09:17:10: //8150/ECF034A4B3E3/CCAPI/ccCheckClipClir:
Wed Mar 20 09:17:12 2013: <191>163709:    ccCallSetupRequest:
Wed Mar 20 09:17:12 2013: <191>163711:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:17:12 2013: <191>163713:    cisco-anitype=0
Wed Mar 20 09:17:12 2013: <191>163715:    cisco-anipi=0
Wed Mar 20 09:17:12 2013: <191>163719:    cisco-desttype=0
Wed Mar 20 09:17:12 2013: <191>163724:    cisco-rdntype=0
Wed Mar 20 09:17:12 2013: <191>163728:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:17:12 2013: <191>163731:
Wed Mar 20 09:17:12 2013: <191>163744: .Mar 20 09:17:10:  cc_get_feature_vsa count is 2
Wed Mar 20 09:17:12 2013: <191>163745: .Mar 20 09:17:10: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:17:12 2013: <191>163746:
Wed Mar 20 09:17:12 2013: <191>163747: .Mar 20 09:17:10: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203325312,feature_id:8151
Wed Mar 20 09:17:12 2013: <191>163748: .Mar 20 09:17:10: //8151/ECF034A4B3E3/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:17:12 2013: <191>163749:    SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Wed Mar 20 09:17:12 2013: <191>163750: .Mar 20 09:17:10: //8151/ECF034A4B3E3/CCAPI/ccCallSetContext:
Wed Mar 20 09:17:12 2013: <191>163751:    Context=0x4BA6D450
Wed Mar 20 09:17:12 2013: <191>163752: .Mar 20 09:17:10: //8150/ECF034A4B3E3/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:17:12 2013: <191>163753:    Outgoing Dial-peer=3000
Wed Mar 20 09:17:12 2013: <191>163754: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:17:12 2013: <191>163755:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:17:12 2013: <191>163756: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:17:12 2013: <191>163757:    Interface=0x48A4F728, Progress Indication=NULL(0)
Wed Mar 20 09:17:12 2013: <191>163758: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:17:12 2013: <191>163759:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:17:12 2013: <191>163760: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_set_delay_xport:
Wed Mar 20 09:17:12 2013: <191>163761:    CallInfo(delay xport=TRUE)
Wed Mar 20 09:17:12 2013: <191>163762: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_call_alert:
Wed Mar 20 09:17:12 2013: <191>163763:    Interface=0x48A4F728, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:17:12 2013: <191>163764: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_call_alert:
Wed Mar 20 09:17:12 2013: <191>163765:    Call Entry(Retry Count=0, Responsed=TRUE)
Wed Mar 20 09:17:12 2013: <191>163766: .Mar 20 09:17:11: //8150/ECF034A4B3E3/CCAPI/ccCallAlert:
Wed Mar 20 09:17:12 2013: <191>163767:
Wed Mar 20 09:17:12 2013: <191>163768: Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:17:12 2013: <191>163769: .Mar 20 09:17:11: //8150/ECF034A4B3E3/CCAPI/ccCallAlert:
Wed Mar 20 09:17:12 2013: <191>163770:    Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Wed Mar 20 09:17:12 2013: <191>163771: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:17:12 2013: <191>163772:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:17:12 2013: <191>163773: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_call_notify:
Wed Mar 20 09:17:12 2013: <191>163774:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8151
Wed Mar 20 09:17:12 2013: <191>163775: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/ccIsInfoRingback:
Wed Mar 20 09:17:12 2013: <191>163776:    Returning dpRingBack=0
Wed Mar 20 09:17:12 2013: <191>163777: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:17:12 2013: <191>163778:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:17:12 2013: <191>163779: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:17:12 2013: <191>163780:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:17:12 2013: <191>163781: .Mar 20 09:17:11: //8150/ECF034A4B3E3/CCAPI/ccCallNotify:
Wed Mar 20 09:17:12 2013: <191>163782:    Data Bitmask=0x5, Call Id=8150
Wed Mar 20 09:17:12 2013: <191>163783: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_call_connected:
Wed Mar 20 09:17:12 2013: <191>163784:    Interface=0x48A4F728, Data Bitmask=0x0, Progress Indication=NULL(0),
Wed Mar 20 09:17:12 2013: <191>163785:    Connection Handle=0
Wed Mar 20 09:17:12 2013: <191>163786: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_call_connected:
Wed Mar 20 09:17:12 2013: <191>163787:    Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:17:12 2013: <191>163788: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:17:12 2013: <191>163789:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:17:12 2013: <191>163790: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_call_notify:
Wed Mar 20 09:17:12 2013: <191>163791:
Wed Mar 20 09:17:12 2013: <191>163792: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8151
Wed Mar 20 09:17:12 2013: <191>163793: .Mar 20 09:17:11: //8150/ECF034A4B3E3/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:17:12 2013: <191>163794:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:17:12 2013: <191>163795:    Tone Direction=Network, Params=0x0, Call Id=8150
Wed Mar 20 09:17:12 2013: <191>163796: .Mar 20 09:17:11: //8150/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:17:12 2013: <191>163797:    (confID=0x4BB02080, callID1=0x1FD6, callID2=0x1FD7, tag=0x0)
Wed Mar 20 09:17:12 2013: <191>163798: .Mar 20 09:17:11: //8150/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:17:12 2013: <191>163799:    (confID=0x4BB02080, callID1=0x1FD6, gcid=ECF034A4-908E11E2-B3E3DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:17:12 2013: <191>163800: .Mar 20 09:17:11: //8151/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:17:12 2013: <191>163801:    (confID=0x4BB02080, callID2=0x1FD7, gcid=ECF034A4-908E11E2-B3E3DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:17:12 2013: <191>163802: .Mar 20 09:17:11: //8150/ECF034A4B3E3/CCAPI/ccConferenceCreate:
Wed Mar 20 09:17:12 2013: <191>163803:    Conference Id=0x4BB02080, Call Id1=8150, Call Id2=8151, Tag=0x0
Wed Mar 20 09:17:12 2013: <191>163804: .Mar 20 09:17:11: //8150/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:17:12 2013: <191>163805:    Conference Id=0xE58, Source Interface=0x498845E0, Source Call Id=8150,
Wed Mar 20 09:17:12 2013: <191>163806:    Destination Call Id=8151, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:17:12 2013: <191>163807: .Mar 20 09:17:11: //8151/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:17:12 2013: <191>163808:
Wed Mar 20 09:17:12 2013: <191>163809: .Mar 20 09:17:11: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:17:12 2013: <191>163810: .Mar 20 09:17:11: //8151/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:17:12 2013: <191>163811:    Conference Id=0xE58, Source Interface=0x48A4F728, Source Call Id=8151,
Wed Mar 20 09:17:12 2013: <191>163812:    Destination Call Id=8150, Disposition=0x0, Tag=0x0
Wed Mar 20 09:17:12 2013: <191>163813: .Mar 20 09:17:11: //8150/ECF034A4B3E3/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:17:12 2013: <191>163814:    Conference Id=0xE58, Source Interface=0x48A4F728, Source Call Id=8151,
Wed Mar 20 09:17:12 2013: <191>163816: .Mar 20 09:17:11: //8150/ECF034A4B3E3/CCAPI/ccConferenceCreate:
Wed Mar 20 09:17:12 2013: <191>163818: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/ccConferenceCreate:
Wed Mar 20 09:17:12 2013: <191>163820: .Mar 20 09:17:11: //8150/ECF034A4B3E3/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:17:12 2013: <191>163821:    Destination Interface=0x48A4F728, Destination Call Id=8151, Source Call Id=8150,
Wed Mar 20 09:17:12 2013: <191>163824: .Mar 20 09:17:11: //8150/ECF034A4B3E3/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:17:12 2013: <191>163825:    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:17:12 2013: <191>163826:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:17:12 2013: <191>163827: .Mar 20 09:17:11: //8150/ECF034A4B3E3/CCAPI/cc_process_notify_bridge_done:
Wed Mar 20 09:17:12 2013: <191>163828:    Conference Id=0xE58, Call Id1=8150, Call Id2=8151
Wed Mar 20 09:17:12 2013: <191>163832:    Modem=0x2, Codec Bytes=20, Signal Type=2)
Wed Mar 20 09:17:12 2013: <191>163839:    Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:17:12 2013: <191>163844:    Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=5597)
Wed Mar 20 09:17:12 2013: <191>163845: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:17:12 2013: <191>163846:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:17:12 2013: <191>163847: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:17:12 2013: <191>163858:
Wed Mar 20 09:17:13 2013: <191>163859: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:17:23 2013: <191>163860: .Mar 20 09:17:22: //8151/ECF034A4B3E3/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:17:23 2013: <191>163861:    Interface=0x0, Call Id=8151
Wed Mar 20 09:17:23 2013: <191>163862: .Mar 20 09:17:22: //8151/ECF034A4B3E3/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:17:23 2013: <191>163863:    Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:17:23 2013: <191>163864: .Mar 20 09:17:22: //8150/ECF034A4B3E3/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:17:23 2013: <191>163865:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:17:23 2013: <191>163866:    Tone Direction=Network, Params=0x0, Call Id=8150
Wed Mar 20 09:17:23 2013: <191>163867: .Mar 20 09:17:22: //8151/ECF034A4B3E3/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:17:23 2013: <191>163868:    Interface=0x48A4F728, Signal Indication=NOT PRESENT(255)
Wed Mar 20 09:17:23 2013: <191>163869: .Mar 20 09:17:22: //8151/ECF034A4B3E3/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:17:23 2013: <191>163870:    Interface=0x48A4F728, Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:17:23 2013: <191>163871: .Mar 20 09:17:22: //8150/ECF034A4B3E3/CCAPI/ccCallUserInfo:
Wed Mar 20 09:17:23 2013: <191>163872:    Call Id=8150
Wed Mar 20 09:17:23 2013: <191>163873: .Mar 20 09:17:22: //8150/ECF034A4B3E3/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:17:23 2013: <191>163874:    Stop Tone On Digit=FALSE, Tone=Ring Back,
Wed Mar 20 09:17:23 2013: <191>163875:    Tone Direction=Network, Params=0x0, Call Id=8150
Wed Mar 20 09:17:23 2013: <191>163876: .Mar 20 09:17:22: //8151/ECF034A4B3E3/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:17:23 2013: <191>163877:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:17:23 2013: <191>163878: .Mar 20 09:17:22: //8151/ECF034A4B3E3/CCAPI/cc_api_call_notify:
Wed Mar 20 09:17:23 2013: <191>163879:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8151
Wed Mar 20 09:17:23 2013: <191>163880: .Mar 20 09:17:22: //8151/ECF034A4B3E3/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:17:23 2013: <191>163881:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:17:24 2013: <191>163882: .Mar 20 09:17:22: //8151/ECF034A4B3E3/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:17:24 2013: <191>163883:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:17:24 2013: <191>163884: .Mar 20 09:17:22: //8150/ECF034A4B3E3/CCAPI/ccCallNotify:
Wed Mar 20 09:17:24 2013: <191>163885:    Data Bitmask=0x5, Call Id=8150
Wed Mar 20 09:17:39 2013: <191>163886: .Mar 20 09:17:38: //8151/ECF034A4B3E3/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:17:39 2013: <191>163887:    Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:17:39 2013: <191>163888: .Mar 20 09:17:38: //8151/ECF034A4B3E3/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:17:39 2013: <191>163889:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:17:39 2013: <191>163890: .Mar 20 09:17:38: //8151/ECF034A4B3E3/CCAPI/cc_api_call_notify:
Wed Mar 20 09:17:39 2013: <191>163891:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8151
Wed Mar 20 09:17:39 2013: <191>163892: .Mar 20 09:17:38: //8150/ECF034A4B3E3/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:17:39 2013: <191>163893:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:17:39 2013: <191>163894:    Tone Direction=Network, Params=0x0, Call Id=8150
Wed Mar 20 09:17:39 2013: <191>163895: .Mar 20 09:17:38: //8151/ECF034A4B3E3/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:17:39 2013: <191>163896:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:17:39 2013: <191>163897: .Mar 20 09:17:38: //8151/ECF034A4B3E3/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:17:39 2013: <191>163898:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:17:39 2013: <191>163899: .Mar 20 09:17:38: //8150/ECF034A4B3E3/CCAPI/ccCallNotify:
Wed Mar 20 09:17:39 2013: <191>163900:    Data Bitmask=0x5, Call Id=8150
Wed Mar 20 09:17:39 2013: <191>163901: .Mar 20 09:17:38: //8151/ECF034A4B3E3/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:17:39 2013: <191>163902:    Destination Interface=0x498845E0, Destination Call Id=8150, Source Call Id=8151,
Wed Mar 20 09:17:39 2013: <191>163903:    Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:17:39 2013: <191>163904:    Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:17:39 2013: <191>163905: .Mar 20 09:17:38: //8151/ECF034A4B3E3/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:17:39 2013: <191>163906:    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:17:39 2013: <191>163907:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:17:39 2013: <191>163908: .Mar 20 09:17:38: //8151/ECF034A4B3E3/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:17:39 2013: <191>163909:
Wed Mar 20 09:17:39 2013: <191>163910: Destination Interface=0x498845E0, Destination Call Id=8150, Source Call Id=8151,
Wed Mar 20 09:17:39 2013: <191>163911:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:17:39 2013: <191>163912:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5649)
Wed Mar 20 09:17:39 2013: <191>163913: .Mar 20 09:17:38: //8150/ECF034A4B3E3/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:17:39 2013: <191>163914:    Destination Interface=0x48A4F728, Destination Call Id=8151, Source Call Id=8150,
Wed Mar 20 09:17:39 2013: <191>163915:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:17:39 2013: <191>163916:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5649)
Wed Mar 20 09:17:39 2013: <191>163917: .Mar 20 09:17:38: //8150/ECF034A4B3E3/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:17:39 2013: <191>163918:    Call Id=8150
Wed Mar 20 09:17:39 2013: <191>163919: .Mar 20 09:17:38: //8150/ECF034A4B3E3/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:17:39 2013: <191>163920:
Wed Mar 20 09:17:40 2013: <191>163921: Call Entry(Context=0x4BA6C148)
Wed Mar 20 09:18:13 2013: <191>163922: .Mar 20 09:18:12: //-1/1157400AB3E8/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:18:13 2013: <191>163923:    cc_api_call_setup_ind_common:
Wed Mar 20 09:18:13 2013: <191>163924:    cisco-username=
Wed Mar 20 09:18:13 2013: <191>163925:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:18:13 2013: <191>163926:    cisco-ani=
Wed Mar 20 09:18:13 2013: <191>163927:    cisco-anitype=0
Wed Mar 20 09:18:13 2013: <191>163928:    cisco-aniplan=0
Wed Mar 20 09:18:13 2013: <191>163929:    cisco-anipi=0
Wed Mar 20 09:18:13 2013: <191>163930:    cisco-anisi=0
Wed Mar 20 09:18:13 2013: <191>163931:    dest=1811032099
Wed Mar 20 09:18:13 2013: <191>163932:    cisco-desttype=0
Wed Mar 20 09:18:13 2013: <191>163933:    cisco-destplan=0
Wed Mar 20 09:18:13 2013: <191>163934:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:18:13 2013: <191>163935:    cisco-rdn=
Wed Mar 20 09:18:13 2013: <191>163936:    cisco-lastrdn=
Wed Mar 20 09:18:13 2013: <191>163937:    cisco-rdntype=0
Wed Mar 20 09:18:13 2013: <191>163938:    cisco-rdnplan=0
Wed Mar 20 09:18:13 2013: <191>163939:    cisco-rdnpi=0
Wed Mar 20 09:18:13 2013: <191>163940:    cisco-rdnsi=0
Wed Mar 20 09:18:13 2013: <191>163941:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:18:13 2013: <191>163942:    final_redirectNumber =
Wed Mar 20 09:18:13 2013: <191>163943:    hunt_group_timeout =0
Wed Mar 20 09:18:13 2013: <191>163944:
Wed Mar 20 09:18:13 2013: <191>163945: .Mar 20 09:18:12: //-1/1157400AB3E8/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:18:13 2013: <191>163946:
Wed Mar 20 09:18:13 2013: <191>163947: Interface=0x4987FF98, Call Info(
Wed Mar 20 09:18:13 2013: <191>163948:    Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:18:13 2013: <191>163949:    Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:18:13 2013: <191>163950:    Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Wed Mar 20 09:18:13 2013: <191>163951:    Incoming Dial-peer=18, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Wed Mar 20 09:18:13 2013: <191>163952:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:18:13 2013: <191>163953: .Mar 20 09:18:12: //-1/1157400AB3E8/CCAPI/ccCheckClipClir:
Wed Mar 20 09:18:13 2013: <191>163954:    In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:18:13 2013: <191>163955: .Mar 20 09:18:12: //-1/1157400AB3E8/CCAPI/ccCheckClipClir:
Wed Mar 20 09:18:13 2013: <191>163956:    Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:18:13 2013: <191>163957: .Mar 20 09:18:12: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:18:13 2013: <191>163958:
Wed Mar 20 09:18:13 2013: <191>163959: .Mar 20 09:18:12: :cc_get_feature_vsa malloc success
Wed Mar 20 09:18:13 2013: <191>163960: .Mar 20 09:18:12: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:18:13 2013: <191>163961:
Wed Mar 20 09:18:13 2013: <191>163962: .Mar 20 09:18:12:  cc_get_feature_vsa count is 3
Wed Mar 20 09:18:13 2013: <191>163963: .Mar 20 09:18:12: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:18:13 2013: <191>163964:
Wed Mar 20 09:18:13 2013: <191>163965: .Mar 20 09:18:12: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203325088,feature_id:8152
Wed Mar 20 09:18:13 2013: <191>163966: .Mar 20 09:18:12: //8152/1157400AB3E8/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:18:13 2013: <191>163967:
Wed Mar 20 09:18:13 2013: <191>163968: Set Up Event Sent;
Wed Mar 20 09:18:13 2013: <191>163969:    Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:18:13 2013: <191>163970:    Called Number=1811032099(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:18:13 2013: <191>163972:    Event=0x4982C828
Wed Mar 20 09:18:13 2013: <191>163973: .Mar 20 09:18:12: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Wed Mar 20 09:18:13 2013: <191>163980:
Wed Mar 20 09:18:13 2013: <191>163981: Progress Indication=NULL(0)
Wed Mar 20 09:18:13 2013: <191>163992: .Mar 20 09:18:12: //8152/1157400AB3E8/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:18:13 2013: <191>163993:    Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:18:13 2013: <191>163994:    Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:18:13 2013: <191>163997:    Guid=1157400A-908F-11E2-B3E8-DE08FC69A21F, Outgoing Dial-peer=3000
Wed Mar 20 09:18:13 2013: <191>164002:    cisco-ani=
Wed Mar 20 09:18:13 2013: <191>164007:    cisco-anisi=0
Wed Mar 20 09:18:13 2013: <191>164008:    dest=1811032099
Wed Mar 20 09:18:13 2013: <191>164011:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:18:13 2013: <191>164013:    cisco-lastrdn=
Wed Mar 20 09:18:13 2013: <191>164015:    cisco-rdnplan=0
Wed Mar 20 09:18:13 2013: <191>164019:    final_redirectNumber =
Wed Mar 20 09:18:13 2013: <191>164021:
Wed Mar 20 09:18:13 2013: <191>164034: .Mar 20 09:18:12:  cc_get_feature_vsa count is 4
Wed Mar 20 09:18:13 2013: <191>164035: .Mar 20 09:18:12: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:18:13 2013: <191>164036:
Wed Mar 20 09:18:13 2013: <191>164037: .Mar 20 09:18:12: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203324864,feature_id:8153
Wed Mar 20 09:18:13 2013: <191>164038: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:18:13 2013: <191>164039:    SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Wed Mar 20 09:18:13 2013: <191>164040: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/ccCallSetContext:
Wed Mar 20 09:18:13 2013: <191>164041:    Context=0x4BA72070
Wed Mar 20 09:18:13 2013: <191>164042: .Mar 20 09:18:12: //8152/1157400AB3E8/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:18:13 2013: <191>164043:    Outgoing Dial-peer=3000
Wed Mar 20 09:18:13 2013: <191>164044: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:18:13 2013: <191>164045:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:18:13 2013: <191>164046: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:18:13 2013: <191>164047:    Interface=0x48A4F728, Progress Indication=NULL(0)
Wed Mar 20 09:18:13 2013: <191>164048: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:18:13 2013: <191>164049:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:18:13 2013: <191>164050: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_set_delay_xport:
Wed Mar 20 09:18:13 2013: <191>164051:    CallInfo(delay xport=TRUE)
Wed Mar 20 09:18:13 2013: <191>164052: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_call_alert:
Wed Mar 20 09:18:13 2013: <191>164053:    Interface=0x48A4F728, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:18:13 2013: <191>164054: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_call_alert:
Wed Mar 20 09:18:13 2013: <191>164055:    Call Entry(Retry Count=0, Responsed=TRUE)
Wed Mar 20 09:18:13 2013: <191>164056: .Mar 20 09:18:12: //8152/1157400AB3E8/CCAPI/ccCallAlert:
Wed Mar 20 09:18:13 2013: <191>164057:
Wed Mar 20 09:18:13 2013: <191>164058: Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:18:13 2013: <191>164059: .Mar 20 09:18:12: //8152/1157400AB3E8/CCAPI/ccCallAlert:
Wed Mar 20 09:18:13 2013: <191>164060:    Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Wed Mar 20 09:18:13 2013: <191>164061: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:18:13 2013: <191>164062:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:18:13 2013: <191>164063: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_call_notify:
Wed Mar 20 09:18:13 2013: <191>164064:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8153
Wed Mar 20 09:18:13 2013: <191>164065: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/ccIsInfoRingback:
Wed Mar 20 09:18:13 2013: <191>164066:    Returning dpRingBack=0
Wed Mar 20 09:18:13 2013: <191>164067: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:18:13 2013: <191>164068:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:18:13 2013: <191>164069: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:18:13 2013: <191>164070:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:18:13 2013: <191>164071: .Mar 20 09:18:12: //8152/1157400AB3E8/CCAPI/ccCallNotify:
Wed Mar 20 09:18:13 2013: <191>164072:    Data Bitmask=0x5, Call Id=8152
Wed Mar 20 09:18:13 2013: <191>164073: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_call_connected:
Wed Mar 20 09:18:13 2013: <191>164074:    Interface=0x48A4F728, Data Bitmask=0x0, Progress Indication=NULL(0),
Wed Mar 20 09:18:13 2013: <191>164075:    Connection Handle=0
Wed Mar 20 09:18:13 2013: <191>164076: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_call_connected:
Wed Mar 20 09:18:13 2013: <191>164077:    Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:18:13 2013: <191>164078: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:18:13 2013: <191>164079:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:18:13 2013: <191>164080: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_call_notify:
Wed Mar 20 09:18:13 2013: <191>164081:
Wed Mar 20 09:18:13 2013: <191>164082: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8153
Wed Mar 20 09:18:13 2013: <191>164083: .Mar 20 09:18:12: //8152/1157400AB3E8/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:18:13 2013: <191>164084:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:18:13 2013: <191>164085:    Tone Direction=Network, Params=0x0, Call Id=8152
Wed Mar 20 09:18:13 2013: <191>164086: .Mar 20 09:18:12: //8152/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:18:13 2013: <191>164087:    (confID=0x4BB01F60, callID1=0x1FD8, callID2=0x1FD9, tag=0x0)
Wed Mar 20 09:18:13 2013: <191>164088: .Mar 20 09:18:12: //8152/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:18:13 2013: <191>164089:    (confID=0x4BB01F60, callID1=0x1FD8, gcid=1157400A-908F11E2-B3E8DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:18:13 2013: <191>164090: .Mar 20 09:18:12: //8153/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:18:13 2013: <191>164091:    (confID=0x4BB01F60, callID2=0x1FD9, gcid=1157400A-908F11E2-B3E8DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:18:13 2013: <191>164092: .Mar 20 09:18:12: //8152/1157400AB3E8/CCAPI/ccConferenceCreate:
Wed Mar 20 09:18:13 2013: <191>164093:    Conference Id=0x4BB01F60, Call Id1=8152, Call Id2=8153, Tag=0x0
Wed Mar 20 09:18:13 2013: <191>164094: .Mar 20 09:18:12: //8152/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:18:13 2013: <191>164095:    Conference Id=0xE59, Source Interface=0x4987FF98, Source Call Id=8152,
Wed Mar 20 09:18:13 2013: <191>164096:    Destination Call Id=8153, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:18:13 2013: <191>164097: .Mar 20 09:18:12: //8153/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:18:13 2013: <191>164098:
Wed Mar 20 09:18:13 2013: <191>164099: .Mar 20 09:18:12: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:18:13 2013: <191>164100: .Mar 20 09:18:12: //8153/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:18:13 2013: <191>164101:    Conference Id=0xE59, Source Interface=0x48A4F728, Source Call Id=8153,
Wed Mar 20 09:18:13 2013: <191>164102:    Destination Call Id=8152, Disposition=0x0, Tag=0x0
Wed Mar 20 09:18:13 2013: <191>164103: .Mar 20 09:18:12: //8152/1157400AB3E8/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:18:13 2013: <191>164104:    Conference Id=0xE59, Source Interface=0x48A4F728, Source Call Id=8153,
Wed Mar 20 09:18:13 2013: <191>164105:    Destination Call Id=8152, Disposition=0x0, Tag=0x0
Wed Mar 20 09:18:13 2013: <191>164107:    Call Entry(Conference Id=0xE59, Destination Call Id=8153)
Wed Mar 20 09:18:13 2013: <191>164109:    Call Entry(Conference Id=0xE59, Destination Call Id=8152)
Wed Mar 20 09:18:13 2013: <191>164112:    Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Wed Mar 20 09:18:13 2013: <191>164116:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:18:13 2013: <191>164117: .Mar 20 09:18:12: //8152/1157400AB3E8/CCAPI/cc_process_notify_bridge_done:
Wed Mar 20 09:18:13 2013: <191>164124:
Wed Mar 20 09:18:13 2013: <191>164129:    Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:18:13 2013: <191>164143: .Mar 20 09:18:12: //8152/1157400AB3E8/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:18:13 2013: <191>164144:    Call Entry(Context=0x4BA67528)
Wed Mar 20 09:18:13 2013: <191>164148:
Wed Mar 20 09:18:14 2013: <191>164149: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:18:24 2013: <191>164150: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:18:24 2013: <191>164151:    Interface=0x0, Call Id=8153
Wed Mar 20 09:18:24 2013: <191>164152: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:18:24 2013: <191>164153:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:18:24 2013: <191>164154: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_call_notify:
Wed Mar 20 09:18:24 2013: <191>164155:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8153
Wed Mar 20 09:18:24 2013: <191>164156: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:18:24 2013: <191>164157:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:18:24 2013: <191>164158: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:18:24 2013: <191>164159:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:18:24 2013: <191>164160: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/ccCallNotify:
Wed Mar 20 09:18:24 2013: <191>164161:    Data Bitmask=0x5, Call Id=8152
Wed Mar 20 09:18:24 2013: <191>164162: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:18:24 2013: <191>164163:    Destination Interface=0x4987FF98, Destination Call Id=8152, Source Call Id=8153,
Wed Mar 20 09:18:24 2013: <191>164164:    Caps(Codec=0x4, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:18:24 2013: <191>164165:    Modem=0x2, Codec Bytes=20, Signal Type=2)
Wed Mar 20 09:18:24 2013: <191>164166: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:18:24 2013: <191>164167:    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:18:24 2013: <191>164168:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:18:24 2013: <191>164169: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:18:24 2013: <191>164170:
Wed Mar 20 09:18:24 2013: <191>164171: Destination Interface=0x4987FF98, Destination Call Id=8152, Source Call Id=8153,
Wed Mar 20 09:18:24 2013: <191>164172:    Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:18:24 2013: <191>164173:    Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=172)
Wed Mar 20 09:18:24 2013: <191>164174: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:18:24 2013: <191>164175:    Destination Interface=0x48A4F728, Destination Call Id=8153, Source Call Id=8152,
Wed Mar 20 09:18:24 2013: <191>164176:    Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:18:24 2013: <191>164177:    Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=172)
Wed Mar 20 09:18:24 2013: <191>164178: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:18:24 2013: <191>164179:    Call Id=8152
Wed Mar 20 09:18:24 2013: <191>164180: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:18:24 2013: <191>164181:
Wed Mar 20 09:18:25 2013: <191>164182: Call Entry(Context=0x4BA67528)
Wed Mar 20 09:18:25 2013: <191>164183: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:18:25 2013: <191>164184:    Interface=0x0, Call Id=8153
Wed Mar 20 09:18:25 2013: <191>164185: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:18:25 2013: <191>164186:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:18:25 2013: <191>164187: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_call_notify:
Wed Mar 20 09:18:25 2013: <191>164188:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8153
Wed Mar 20 09:18:25 2013: <191>164189: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:18:25 2013: <191>164190:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:18:25 2013: <191>164191: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:18:25 2013: <191>164192:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:18:25 2013: <191>164193: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/ccCallNotify:
Wed Mar 20 09:18:25 2013: <191>164194:
Wed Mar 20 09:18:25 2013: <191>164195: Data Bitmask=0x5, Call Id=8152
Wed Mar 20 09:18:25 2013: <191>164196: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:18:25 2013: <191>164197:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:18:25 2013: <191>164198: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_call_notify:
Wed Mar 20 09:18:25 2013: <191>164199:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8153
Wed Mar 20 09:18:25 2013: <191>164200: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:18:25 2013: <191>164201:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:18:25 2013: <191>164202: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:18:25 2013: <191>164203:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:18:25 2013: <191>164204: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/ccCallNotify:
Wed Mar 20 09:18:25 2013: <191>164205:    Data Bitmask=0x5, Call Id=8152
Wed Mar 20 09:18:25 2013: <191>164206: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:18:25 2013: <191>164207:
Wed Mar 20 09:18:25 2013: <191>164208: Interface=0x0, Call Id=8153
Wed Mar 20 09:18:25 2013: <191>164209: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:18:25 2013: <191>164210:    Cause Value=16, Interface=0x48A4F728, Call Id=8153
Wed Mar 20 09:18:25 2013: <191>164211: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:18:25 2013: <191>164212:    Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:18:25 2013: <191>164213: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:18:25 2013: <191>164214:    Conference Id=0xE59, Tag=0x0
Wed Mar 20 09:18:25 2013: <191>164215: .Mar 20 09:18:23: //8152/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:18:25 2013: <191>164216:    Conference Id=0xE59, Source Interface=0x4987FF98, Source Call Id=8152,
Wed Mar 20 09:18:25 2013: <191>164217:    Destination Call Id=8153, Disposition=0x0, Tag=0x0
Wed Mar 20 09:18:25 2013: <191>164218: .Mar 20 09:18:23: //8153/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:18:25 2013: <191>164219:
Wed Mar 20 09:18:25 2013: <191>164220: Conference Id=0xE59, Source Interface=0x48A4F728, Source Call Id=8153,
Wed Mar 20 09:18:25 2013: <191>164221:    Destination Call Id=8152, Disposition=0x0, Tag=0x0
Wed Mar 20 09:18:25 2013: <191>164222: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:18:25 2013: <191>164223:    Conference Id=0xE59, Source Interface=0x48A4F728, Source Call Id=8153,
Wed Mar 20 09:18:25 2013: <191>164224:    Destination Call Id=8152, Disposition=0x0, Tag=0x0
Wed Mar 20 09:18:25 2013: <191>164225: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/ccCallDisconnect:
Wed Mar 20 09:18:25 2013: <191>164226:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:18:25 2013: <191>164227: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/ccCallDisconnect:
Wed Mar 20 09:18:25 2013: <191>164228:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:18:25 2013: <191>164229: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:18:25 2013: <191>164230:
Wed Mar 20 09:18:25 2013: <191>164231: Transfer Number Is Null
Wed Mar 20 09:18:25 2013: <191>164232: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/ccCallDisconnect:
Wed Mar 20 09:18:25 2013: <191>164233:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:18:25 2013: <191>164234: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/ccCallDisconnect:
Wed Mar 20 09:18:25 2013: <191>164235:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:18:25 2013: <191>164236: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:18:25 2013: <191>164237:    Transfer Number Is Null
Wed Mar 20 09:18:25 2013: <191>164238: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:18:25 2013: <191>164239:    Transfer Number Is Null
Wed Mar 20 09:18:25 2013: <191>164240: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:18:25 2013: <191>164241:
Wed Mar 20 09:18:25 2013: <191>164242: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8153,
Wed Mar 20 09:18:25 2013: <191>164243:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:18:25 2013: <191>164244: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:18:25 2013: <191>164245:    Call Disconnect Event Sent
Wed Mar 20 09:18:25 2013: <191>164246: .Mar 20 09:18:23: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:18:25 2013: <191>164247:
Wed Mar 20 09:18:25 2013: <191>164248: .Mar 20 09:18:23: :cc_free_feature_vsa freeing 47B947B8
Wed Mar 20 09:18:25 2013: <191>164249: .Mar 20 09:18:23: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:18:25 2013: <191>164250:
Wed Mar 20 09:18:25 2013: <191>164251: .Mar 20 09:18:23:  vsacount in free is 3
Wed Mar 20 09:18:25 2013: <191>164252: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:18:25 2013: <191>164253:    Disposition=0, Interface=0x4987FF98, Tag=0x0, Call Id=8152,
Wed Mar 20 09:18:25 2013: <191>164254:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:18:26 2013: <191>164255: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:18:26 2013: <191>164256:    Call Disconnect Event Sent
Wed Mar 20 09:18:26 2013: <191>164257: .Mar 20 09:18:23: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:18:26 2013: <191>164258:
Wed Mar 20 09:18:26 2013: <191>164259: .Mar 20 09:18:23: :cc_free_feature_vsa freeing 47B94898
Wed Mar 20 09:18:26 2013: <191>164260: .Mar 20 09:18:23: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:18:26 2013: <191>164261:
Wed Mar 20 09:18:26 2013: <191>164262: .Mar 20 09:18:23:  vsacount in free is 2
Wed Mar 20 09:19:07 2013: <191>164263: .Mar 20 09:19:06: //8151/ECF034A4B3E3/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:19:07 2013: <191>164264:    Cause Value=16, Interface=0x48A4F728, Call Id=8151
Wed Mar 20 09:19:07 2013: <191>164265: .Mar 20 09:19:06: //8151/ECF034A4B3E3/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:19:07 2013: <191>164266:    Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:19:07 2013: <191>164267: .Mar 20 09:19:06: //8150/ECF034A4B3E3/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:19:07 2013: <191>164268:    Conference Id=0xE58, Tag=0x0
Wed Mar 20 09:19:07 2013: <191>164269: .Mar 20 09:19:06: //8150/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:19:07 2013: <191>164270:    Conference Id=0xE58, Source Interface=0x498845E0, Source Call Id=8150,
Wed Mar 20 09:19:07 2013: <191>164271:    Destination Call Id=8151, Disposition=0x0, Tag=0x0
Wed Mar 20 09:19:07 2013: <191>164272: .Mar 20 09:19:06: //8151/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:19:07 2013: <191>164273:
Wed Mar 20 09:19:07 2013: <191>164274: Conference Id=0xE58, Source Interface=0x48A4F728, Source Call Id=8151,
Wed Mar 20 09:19:07 2013: <191>164275:    Destination Call Id=8150, Disposition=0x0, Tag=0x0
Wed Mar 20 09:19:07 2013: <191>164276: .Mar 20 09:19:06: //8150/ECF034A4B3E3/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:19:07 2013: <191>164277:    Conference Id=0xE58, Source Interface=0x48A4F728, Source Call Id=8151,
Wed Mar 20 09:19:07 2013: <191>164278:    Destination Call Id=8150, Disposition=0x0, Tag=0x0
Wed Mar 20 09:19:07 2013: <191>164279: .Mar 20 09:19:06: //8150/ECF034A4B3E3/CCAPI/ccCallDisconnect:
Wed Mar 20 09:19:07 2013: <191>164280:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:19:07 2013: <191>164281: .Mar 20 09:19:06: //8150/ECF034A4B3E3/CCAPI/ccCallDisconnect:
Wed Mar 20 09:19:07 2013: <191>164282:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:19:07 2013: <191>164283: .Mar 20 09:19:06: //8150/ECF034A4B3E3/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:19:07 2013: <191>164284:
Wed Mar 20 09:19:07 2013: <191>164285: Transfer Number Is Null
Wed Mar 20 09:19:07 2013: <191>164286: .Mar 20 09:19:06: //8151/ECF034A4B3E3/CCAPI/ccCallDisconnect:
Wed Mar 20 09:19:07 2013: <191>164287:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:19:07 2013: <191>164288: .Mar 20 09:19:06: //8151/ECF034A4B3E3/CCAPI/ccCallDisconnect:
Wed Mar 20 09:19:07 2013: <191>164289:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:19:07 2013: <191>164290: .Mar 20 09:19:06: //8151/ECF034A4B3E3/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:19:07 2013: <191>164291:    Transfer Number Is Null
Wed Mar 20 09:19:07 2013: <191>164292: .Mar 20 09:19:06: //8151/ECF034A4B3E3/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:19:07 2013: <191>164293:    Transfer Number Is Null
Wed Mar 20 09:19:07 2013: <191>164294: .Mar 20 09:19:06: //8151/ECF034A4B3E3/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:19:07 2013: <191>164295:
Wed Mar 20 09:19:07 2013: <191>164296: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8151,
Wed Mar 20 09:19:07 2013: <191>164297:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:19:07 2013: <191>164298: .Mar 20 09:19:06: //8151/ECF034A4B3E3/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:19:07 2013: <191>164299:    Call Disconnect Event Sent
Wed Mar 20 09:19:07 2013: <191>164300: .Mar 20 09:19:06: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:19:07 2013: <191>164301:
Wed Mar 20 09:19:07 2013: <191>164302: .Mar 20 09:19:06: :cc_free_feature_vsa freeing 47B94978
Wed Mar 20 09:19:07 2013: <191>164303: .Mar 20 09:19:06: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:19:07 2013: <191>164304:
Wed Mar 20 09:19:07 2013: <191>164305: .Mar 20 09:19:06:  vsacount in free is 1
Wed Mar 20 09:19:07 2013: <191>164306: .Mar 20 09:19:06: //8150/ECF034A4B3E3/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:19:07 2013: <191>164307:    Disposition=0, Interface=0x498845E0, Tag=0x0, Call Id=8150,
Wed Mar 20 09:19:07 2013: <191>164308:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:19:08 2013: <191>164309: .Mar 20 09:19:06: //8150/ECF034A4B3E3/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:19:08 2013: <191>164310:    Call Disconnect Event Sent
Wed Mar 20 09:19:08 2013: <191>164311: .Mar 20 09:19:06: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:19:08 2013: <191>164312:
Wed Mar 20 09:19:08 2013: <191>164313: .Mar 20 09:19:06: :cc_free_feature_vsa freeing 47B94A58
Wed Mar 20 09:19:08 2013: <191>164314: .Mar 20 09:19:06: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:19:08 2013: <191>164315:
Wed Mar 20 09:19:08 2013: <191>164316: .Mar 20 09:19:06:  vsacount in free is 0
Wed Mar 20 09:19:51 2013: <191>164317: .Mar 20 09:19:50: //-1/4C22D265B3ED/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:19:51 2013: <191>164320:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:19:51 2013: <191>164321:    cisco-ani=
Wed Mar 20 09:19:51 2013: <191>164322:    cisco-anitype=0
Wed Mar 20 09:19:51 2013: <191>164318:    cc_api_call_setup_ind_common:
Wed Mar 20 09:19:51 2013: <191>164323:    cisco-aniplan=0
Wed Mar 20 09:19:51 2013: <191>164324:    cisco-anipi=0
Wed Mar 20 09:19:51 2013: <191>164319:    cisco-username=
Wed Mar 20 09:19:51 2013: <191>164325:    cisco-anisi=0
Wed Mar 20 09:19:51 2013: <191>164326:    dest=1811032099
Wed Mar 20 09:19:51 2013: <191>164327:    cisco-desttype=0
Wed Mar 20 09:19:51 2013: <191>164328:    cisco-destplan=0
Wed Mar 20 09:19:51 2013: <191>164329:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:19:51 2013: <191>164330:    cisco-rdn=
Wed Mar 20 09:19:51 2013: <191>164331:    cisco-lastrdn=
Wed Mar 20 09:19:51 2013: <191>164332:    cisco-rdntype=0
Wed Mar 20 09:19:51 2013: <191>164333:    cisco-rdnplan=0
Wed Mar 20 09:19:51 2013: <191>164334:    cisco-rdnpi=0
Wed Mar 20 09:19:51 2013: <191>164335:    cisco-rdnsi=0
Wed Mar 20 09:19:51 2013: <191>164336:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:19:51 2013: <191>164337:    final_redirectNumber =
Wed Mar 20 09:19:51 2013: <191>164338:    hunt_group_timeout =0
Wed Mar 20 09:19:51 2013: <191>164339:
Wed Mar 20 09:19:51 2013: <191>164340: .Mar 20 09:19:50: //-1/4C22D265B3ED/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:19:51 2013: <191>164341:
Wed Mar 20 09:19:51 2013: <191>164342: Interface=0x498845E0, Call Info(
Wed Mar 20 09:19:51 2013: <191>164343:    Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:19:51 2013: <191>164344:    Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:19:51 2013: <191>164345:    Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Wed Mar 20 09:19:51 2013: <191>164346:    Incoming Dial-peer=50, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Wed Mar 20 09:19:51 2013: <191>164347:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:19:51 2013: <191>164348: .Mar 20 09:19:50: //-1/4C22D265B3ED/CCAPI/ccCheckClipClir:
Wed Mar 20 09:19:51 2013: <191>164349:    In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:19:51 2013: <191>164350: .Mar 20 09:19:50: //-1/4C22D265B3ED/CCAPI/ccCheckClipClir:
Wed Mar 20 09:19:51 2013: <191>164351:    Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:19:51 2013: <191>164352: .Mar 20 09:19:50: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:19:51 2013: <191>164353:
Wed Mar 20 09:19:51 2013: <191>164354: .Mar 20 09:19:50: :cc_get_feature_vsa malloc success
Wed Mar 20 09:19:51 2013: <191>164355: .Mar 20 09:19:50: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:19:51 2013: <191>164356:
Wed Mar 20 09:19:51 2013: <191>164357: .Mar 20 09:19:50:  cc_get_feature_vsa count is 1
Wed Mar 20 09:19:51 2013: <191>164358: .Mar 20 09:19:50: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:19:51 2013: <191>164359:
Wed Mar 20 09:19:51 2013: <191>164360: .Mar 20 09:19:50: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203322344,feature_id:8154
Wed Mar 20 09:19:51 2013: <191>164361: .Mar 20 09:19:50: //8154/4C22D265B3ED/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:19:51 2013: <191>164362:
Wed Mar 20 09:19:51 2013: <191>164363: Set Up Event Sent;
Wed Mar 20 09:19:51 2013: <191>164364:    Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:19:51 2013: <191>164365:    Called Number=1811032099(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:19:51 2013: <191>164368: .Mar 20 09:19:50: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Wed Mar 20 09:19:51 2013: <191>164376: Progress Indication=NULL(0)
Wed Mar 20 09:19:51 2013: <191>164385:
Wed Mar 20 09:19:51 2013: <191>164386: Destination Pattern=1811032099, Called Number=1811032099, Digit Strip=FALSE
Wed Mar 20 09:19:51 2013: <191>164387: .Mar 20 09:19:50: //8154/4C22D265B3ED/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:19:51 2013: <191>164388:    Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:19:51 2013: <191>164394:    ccCallSetupRequest:
Wed Mar 20 09:19:51 2013: <191>164398:    cisco-anitype=0
Wed Mar 20 09:19:51 2013: <191>164399:    cisco-aniplan=0
Wed Mar 20 09:19:51 2013: <191>164401:
Wed Mar 20 09:19:51 2013: <191>164404:    cisco-desttype=0
Wed Mar 20 09:19:51 2013: <191>164412:    cisco-rdnsi=0
Wed Mar 20 09:19:51 2013: <191>164413:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:19:51 2013: <191>164416:
Wed Mar 20 09:19:51 2013: <191>164429: .Mar 20 09:19:50:  cc_get_feature_vsa count is 2
Wed Mar 20 09:19:51 2013: <191>164430: .Mar 20 09:19:50: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:19:51 2013: <191>164431:
Wed Mar 20 09:19:51 2013: <191>164432: .Mar 20 09:19:50: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203322120,feature_id:8155
Wed Mar 20 09:19:51 2013: <191>164433: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:19:51 2013: <191>164434:    SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Wed Mar 20 09:19:51 2013: <191>164435: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/ccCallSetContext:
Wed Mar 20 09:19:51 2013: <191>164436:    Context=0x4BA73378
Wed Mar 20 09:19:51 2013: <191>164437: .Mar 20 09:19:50: //8154/4C22D265B3ED/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:19:51 2013: <191>164438:    Outgoing Dial-peer=3000
Wed Mar 20 09:19:51 2013: <191>164439: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:19:51 2013: <191>164440:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:19:51 2013: <191>164441: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:19:51 2013: <191>164442:    Interface=0x48A4F728, Progress Indication=NULL(0)
Wed Mar 20 09:19:51 2013: <191>164443: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:19:51 2013: <191>164444:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:19:51 2013: <191>164445: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/cc_api_set_delay_xport:
Wed Mar 20 09:19:51 2013: <191>164446:    CallInfo(delay xport=TRUE)
Wed Mar 20 09:19:51 2013: <191>164447: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/cc_api_call_alert:
Wed Mar 20 09:19:51 2013: <191>164448:    Interface=0x48A4F728, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:19:51 2013: <191>164449: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/cc_api_call_alert:
Wed Mar 20 09:19:51 2013: <191>164450:    Call Entry(Retry Count=0, Responsed=TRUE)
Wed Mar 20 09:19:51 2013: <191>164451: .Mar 20 09:19:50: //8154/4C22D265B3ED/CCAPI/ccCallAlert:
Wed Mar 20 09:19:51 2013: <191>164452:
Wed Mar 20 09:19:52 2013: <191>164453: Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:19:52 2013: <191>164454: .Mar 20 09:19:50: //8154/4C22D265B3ED/CCAPI/ccCallAlert:
Wed Mar 20 09:19:52 2013: <191>164455:    Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Wed Mar 20 09:19:52 2013: <191>164456: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:19:52 2013: <191>164457:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:19:52 2013: <191>164458: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/cc_api_call_notify:
Wed Mar 20 09:19:52 2013: <191>164459:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8155
Wed Mar 20 09:19:52 2013: <191>164460: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/ccIsInfoRingback:
Wed Mar 20 09:19:52 2013: <191>164461:    Returning dpRingBack=0
Wed Mar 20 09:19:52 2013: <191>164462: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:19:52 2013: <191>164463:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:19:52 2013: <191>164464: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:19:52 2013: <191>164465:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:19:52 2013: <191>164466: .Mar 20 09:19:50: //8154/4C22D265B3ED/CCAPI/ccCallNotify:
Wed Mar 20 09:19:52 2013: <191>164467:    Data Bitmask=0x5, Call Id=8154
Wed Mar 20 09:19:52 2013: <191>164468: .Mar 20 09:19:51: //8155/4C22D265B3ED/CCAPI/cc_api_call_connected:
Wed Mar 20 09:19:52 2013: <191>164469:    Interface=0x48A4F728, Data Bitmask=0x0, Progress Indication=NULL(0),
Wed Mar 20 09:19:52 2013: <191>164470:    Connection Handle=0
Wed Mar 20 09:19:52 2013: <191>164471: .Mar 20 09:19:51: //8155/4C22D265B3ED/CCAPI/cc_api_call_connected:
Wed Mar 20 09:19:52 2013: <191>164472:    Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:19:52 2013: <191>164473: .Mar 20 09:19:51: //8155/4C22D265B3ED/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:19:52 2013: <191>164474:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:19:52 2013: <191>164475: .Mar 20 09:19:51: //8155/4C22D265B3ED/CCAPI/cc_api_call_notify:
Wed Mar 20 09:19:52 2013: <191>164476:
Wed Mar 20 09:19:52 2013: <191>164477: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8155
Wed Mar 20 09:19:52 2013: <191>164478: .Mar 20 09:19:51: //8154/4C22D265B3ED/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:19:52 2013: <191>164479:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:19:52 2013: <191>164480:    Tone Direction=Network, Params=0x0, Call Id=8154
Wed Mar 20 09:19:52 2013: <191>164481: .Mar 20 09:19:51: //8154/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:19:52 2013: <191>164482:    (confID=0x4BB02158, callID1=0x1FDA, callID2=0x1FDB, tag=0x0)
Wed Mar 20 09:19:52 2013: <191>164483: .Mar 20 09:19:51: //8154/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:19:52 2013: <191>164484:    (confID=0x4BB02158, callID1=0x1FDA, gcid=4C22D265-908F11E2-B3EDDE08-FC69A21F, tag=0x0)
Wed Mar 20 09:19:52 2013: <191>164485: .Mar 20 09:19:51: //8155/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:19:52 2013: <191>164486:    (confID=0x4BB02158, callID2=0x1FDB, gcid=4C22D265-908F11E2-B3EDDE08-FC69A21F, tag=0x0)
Wed Mar 20 09:19:52 2013: <191>164487: .Mar 20 09:19:51: //8154/4C22D265B3ED/CCAPI/ccConferenceCreate:
Wed Mar 20 09:19:52 2013: <191>164488:    Conference Id=0x4BB02158, Call Id1=8154, Call Id2=8155, Tag=0x0
Wed Mar 20 09:19:52 2013: <191>164489: .Mar 20 09:19:51: //8154/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:19:52 2013: <191>164490:    Conference Id=0xE5A, Source Interface=0x498845E0, Source Call Id=8154,
Wed Mar 20 09:19:52 2013: <191>164491:    Destination Call Id=8155, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:19:52 2013: <191>164492: .Mar 20 09:19:51: //8155/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:19:52 2013: <191>164493:
Wed Mar 20 09:19:52 2013: <191>164494: .Mar 20 09:19:51: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:19:52 2013: <191>164495: .Mar 20 09:19:51: //8155/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:19:52 2013: <191>164496:    Conference Id=0xE5A, Source Interface=0x48A4F728, Source Call Id=8155,
Wed Mar 20 09:19:52 2013: <191>164497:    Destination Call Id=8154, Disposition=0x0, Tag=0x0
Wed Mar 20 09:19:52 2013: <191>164500:    Destination Call Id=8154, Disposition=0x0, Tag=0x0
Wed Mar 20 09:19:52 2013: <191>164502:    Call Entry(Conference Id=0xE5A, Destination Call Id=8155)
Wed Mar 20 09:19:52 2013: <191>164503: .Mar 20 09:19:51: //8155/4C22D265B3ED/CCAPI/ccConferenceCreate:
Wed Mar 20 09:19:52 2013: <191>164504:    Call Entry(Conference Id=0xE5A, Destination Call Id=8154)
Wed Mar 20 09:19:52 2013: <191>164506:    Destination Interface=0x48A4F728, Destination Call Id=8155, Source Call Id=8154,
Wed Mar 20 09:19:52 2013: <191>164514: .Mar 20 09:19:51: //8155/4C22D265B3ED/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:19:52 2013: <191>164523:    Destination Interface=0x498845E0, Destination Call Id=8154, Source Call Id=8155,
Wed Mar 20 09:19:52 2013: <191>164529:    Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=5320)
Wed Mar 20 09:19:52 2013: <191>164530: .Mar 20 09:19:51: //8155/4C22D265B3ED/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:19:52 2013: <191>164531:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:19:52 2013: <191>164532: .Mar 20 09:19:51: //8155/4C22D265B3ED/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:19:52 2013: <191>164533:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:19:52 2013: <191>164535:    Data Bitmask=0x5, Call Id=8154
Wed Mar 20 09:19:52 2013: <191>164536: .Mar 20 09:19:51: //8154/4C22D265B3ED/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:19:52 2013: <191>164537:    Call Id=8154
Wed Mar 20 09:19:52 2013: <191>164538: .Mar 20 09:19:51: //8154/4C22D265B3ED/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:19:52 2013: <191>164543:
Wed Mar 20 09:19:53 2013: <191>164544: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:20:03 2013: <191>164545: .Mar 20 09:20:02: //8155/4C22D265B3ED/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:20:03 2013: <191>164546:    Interface=0x0, Call Id=8155
Wed Mar 20 09:20:03 2013: <191>164547: .Mar 20 09:20:02: //8155/4C22D265B3ED/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:20:03 2013: <191>164548:    Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:20:03 2013: <191>164549: .Mar 20 09:20:02: //8155/4C22D265B3ED/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:20:03 2013: <191>164550:    Interface=0x48A4F728, Signal Indication=NOT PRESENT(255)
Wed Mar 20 09:20:03 2013: <191>164551: .Mar 20 09:20:02: //8154/4C22D265B3ED/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:20:03 2013: <191>164552:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:20:03 2013: <191>164553:    Tone Direction=Network, Params=0x0, Call Id=8154
Wed Mar 20 09:20:03 2013: <191>164554: .Mar 20 09:20:02: //8155/4C22D265B3ED/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:20:03 2013: <191>164555:    Interface=0x48A4F728, Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:20:03 2013: <191>164556: .Mar 20 09:20:02: //8154/4C22D265B3ED/CCAPI/ccCallUserInfo:
Wed Mar 20 09:20:03 2013: <191>164557:    Call Id=8154
Wed Mar 20 09:20:03 2013: <191>164558: .Mar 20 09:20:02: //8154/4C22D265B3ED/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:20:03 2013: <191>164559:    Stop Tone On Digit=FALSE, Tone=Ring Back,
Wed Mar 20 09:20:03 2013: <191>164560:    Tone Direction=Network, Params=0x0, Call Id=8154
Wed Mar 20 09:20:03 2013: <191>164561: .Mar 20 09:20:02: //8155/4C22D265B3ED/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:20:03 2013: <191>164562:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:20:03 2013: <191>164563: .Mar 20 09:20:02: //8155/4C22D265B3ED/CCAPI/cc_api_call_notify:
Wed Mar 20 09:20:03 2013: <191>164564:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8155
Wed Mar 20 09:20:03 2013: <191>164565: .Mar 20 09:20:02: //8155/4C22D265B3ED/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:20:03 2013: <191>164566:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:20:04 2013: <191>164567: .Mar 20 09:20:02: //8155/4C22D265B3ED/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:20:04 2013: <191>164568:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:20:04 2013: <191>164569: .Mar 20 09:20:02: //8154/4C22D265B3ED/CCAPI/ccCallNotify:
Wed Mar 20 09:20:04 2013: <191>164570:    Data Bitmask=0x5, Call Id=8154
Wed Mar 20 09:20:18 2013: <191>164571: .Mar 20 09:20:17: //8155/4C22D265B3ED/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:20:18 2013: <191>164572:    Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:20:18 2013: <191>164573: .Mar 20 09:20:17: //8155/4C22D265B3ED/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:20:18 2013: <191>164574:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:20:18 2013: <191>164575: .Mar 20 09:20:17: //8155/4C22D265B3ED/CCAPI/cc_api_call_notify:
Wed Mar 20 09:20:18 2013: <191>164576:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8155
Wed Mar 20 09:20:18 2013: <191>164577: .Mar 20 09:20:17: //8154/4C22D265B3ED/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:20:18 2013: <191>164578:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:20:18 2013: <191>164579:    Tone Direction=Network, Params=0x0, Call Id=8154
Wed Mar 20 09:20:18 2013: <191>164580: .Mar 20 09:20:17: //8155/4C22D265B3ED/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:20:18 2013: <191>164581:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:20:18 2013: <191>164582: .Mar 20 09:20:17: //8155/4C22D265B3ED/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:20:18 2013: <191>164583:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:20:18 2013: <191>164584: .Mar 20 09:20:17: //8154/4C22D265B3ED/CCAPI/ccCallNotify:
Wed Mar 20 09:20:18 2013: <191>164585:    Data Bitmask=0x5, Call Id=8154
Wed Mar 20 09:20:18 2013: <191>164586: .Mar 20 09:20:17: //8155/4C22D265B3ED/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:20:18 2013: <191>164587:    Destination Interface=0x498845E0, Destination Call Id=8154, Source Call Id=8155,
Wed Mar 20 09:20:18 2013: <191>164588:    Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:20:18 2013: <191>164589:    Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:20:18 2013: <191>164590: .Mar 20 09:20:17: //8155/4C22D265B3ED/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:20:18 2013: <191>164591:    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:20:18 2013: <191>164592:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:20:18 2013: <191>164593: .Mar 20 09:20:17: //8155/4C22D265B3ED/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:20:18 2013: <191>164594:
Wed Mar 20 09:20:18 2013: <191>164595: Destination Interface=0x498845E0, Destination Call Id=8154, Source Call Id=8155,
Wed Mar 20 09:20:18 2013: <191>164596:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:20:18 2013: <191>164597:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5364)
Wed Mar 20 09:20:18 2013: <191>164598: .Mar 20 09:20:17: //8154/4C22D265B3ED/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:20:18 2013: <191>164599:    Destination Interface=0x48A4F728, Destination Call Id=8155, Source Call Id=8154,
Wed Mar 20 09:20:18 2013: <191>164600:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:20:18 2013: <191>164601:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5364)
Wed Mar 20 09:20:18 2013: <191>164602: .Mar 20 09:20:17: //8154/4C22D265B3ED/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:20:18 2013: <191>164603:    Call Id=8154
Wed Mar 20 09:20:18 2013: <191>164604: .Mar 20 09:20:17: //8154/4C22D265B3ED/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:20:18 2013: <191>164605:
Wed Mar 20 09:20:19 2013: <191>164606: Call Entry(Context=0x4BA792A0)
Wed Mar 20 09:20:50 2013: <191>164607: .Mar 20 09:20:49: //8155/4C22D265B3ED/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:20:50 2013: <191>164608:    Interface=0x0, Call Id=8155
Wed Mar 20 09:20:50 2013: <191>164609: .Mar 20 09:20:49: //8155/4C22D265B3ED/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:20:50 2013: <191>164610:    Destination Interface=0x498845E0, Destination Call Id=8154, Source Call Id=8155,
Wed Mar 20 09:20:50 2013: <191>164611:    Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:20:50 2013: <191>164612:    Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:20:50 2013: <191>164613: .Mar 20 09:20:49: //8155/4C22D265B3ED/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:20:50 2013: <191>164614:    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:20:50 2013: <191>164615:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:20:50 2013: <191>164616: .Mar 20 09:20:49: //8155/4C22D265B3ED/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:20:50 2013: <191>164617:
Wed Mar 20 09:20:50 2013: <191>164618: Destination Interface=0x498845E0, Destination Call Id=8154, Source Call Id=8155,
Wed Mar 20 09:20:50 2013: <191>164619:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:20:50 2013: <191>164620:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5988)
Wed Mar 20 09:20:50 2013: <191>164621: .Mar 20 09:20:49: //8154/4C22D265B3ED/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:20:50 2013: <191>164622:    Destination Interface=0x48A4F728, Destination Call Id=8155, Source Call Id=8154,
Wed Mar 20 09:20:50 2013: <191>164623:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:20:50 2013: <191>164624:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5988)
Wed Mar 20 09:20:50 2013: <191>164625: .Mar 20 09:20:49: //8154/4C22D265B3ED/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:20:50 2013: <191>164626:    Call Id=8154
Wed Mar 20 09:20:50 2013: <191>164627: .Mar 20 09:20:49: //8154/4C22D265B3ED/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:20:50 2013: <191>164628:
Wed Mar 20 09:20:51 2013: <191>164629: Call Entry(Context=0x4BA792A0)
Wed Mar 20 09:20:54 2013: <191>164630: .Mar 20 09:20:52: //8155/4C22D265B3ED/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:20:54 2013: <191>164631:    Interface=0x0, Call Id=8155
Wed Mar 20 09:20:54 2013: <191>164632: .Mar 20 09:20:52: //8155/4C22D265B3ED/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:20:54 2013: <191>164633:    Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:20:54 2013: <191>164634: .Mar 20 09:20:52: //8154/4C22D265B3ED/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:20:54 2013: <191>164635:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:20:54 2013: <191>164636:    Tone Direction=Network, Params=0x0, Call Id=8154
Wed Mar 20 09:20:54 2013: <191>164637: .Mar 20 09:20:52: //8155/4C22D265B3ED/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:20:54 2013: <191>164638:    Interface=0x48A4F728, Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:20:54 2013: <191>164639: .Mar 20 09:20:52: //8155/4C22D265B3ED/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:20:54 2013: <191>164640:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:20:55 2013: <191>164641: .Mar 20 09:20:52: //8155/4C22D265B3ED/CCAPI/cc_api_call_notify:
Wed Mar 20 09:20:55 2013: <191>164642:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8155
Wed Mar 20 09:20:55 2013: <191>164643: .Mar 20 09:20:52: //8154/4C22D265B3ED/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:20:55 2013: <191>164644:    Stop Tone On Digit=FALSE, Tone=Ring Back,
Wed Mar 20 09:20:55 2013: <191>164645:    Tone Direction=Network, Params=0x0, Call Id=8154
Wed Mar 20 09:20:55 2013: <191>164646: .Mar 20 09:20:52: //8155/4C22D265B3ED/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:20:55 2013: <191>164647:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:20:55 2013: <191>164648: .Mar 20 09:20:52: //8155/4C22D265B3ED/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:20:55 2013: <191>164649:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:20:55 2013: <191>164650: .Mar 20 09:20:52: //8154/4C22D265B3ED/CCAPI/ccCallNotify:
Wed Mar 20 09:20:55 2013: <191>164651:    Data Bitmask=0x5, Call Id=8154
Wed Mar 20 09:21:00 2013: <191>164652: .Mar 20 09:20:59: //8155/4C22D265B3ED/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:21:00 2013: <191>164653:    Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:21:00 2013: <191>164654: .Mar 20 09:20:59: //8155/4C22D265B3ED/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:21:00 2013: <191>164655:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:21:00 2013: <191>164656: .Mar 20 09:20:59: //8155/4C22D265B3ED/CCAPI/cc_api_call_notify:
Wed Mar 20 09:21:00 2013: <191>164657:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8155
Wed Mar 20 09:21:00 2013: <191>164658: .Mar 20 09:20:59: //8154/4C22D265B3ED/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:21:00 2013: <191>164659:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:21:00 2013: <191>164660:    Tone Direction=Network, Params=0x0, Call Id=8154
Wed Mar 20 09:21:00 2013: <191>164661: .Mar 20 09:20:59: //8155/4C22D265B3ED/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:21:00 2013: <191>164662:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:21:00 2013: <191>164663: .Mar 20 09:20:59: //8155/4C22D265B3ED/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:21:00 2013: <191>164664:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:21:00 2013: <191>164665: .Mar 20 09:20:59: //8154/4C22D265B3ED/CCAPI/ccCallNotify:
Wed Mar 20 09:21:00 2013: <191>164666:    Data Bitmask=0x5, Call Id=8154
Wed Mar 20 09:21:00 2013: <191>164667: .Mar 20 09:20:59: //8155/4C22D265B3ED/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:21:00 2013: <191>164668:    Destination Interface=0x498845E0, Destination Call Id=8154, Source Call Id=8155,
Wed Mar 20 09:21:00 2013: <191>164669:    Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:21:00 2013: <191>164670:    Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:21:00 2013: <191>164671: .Mar 20 09:20:59: //8155/4C22D265B3ED/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:21:00 2013: <191>164672:    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:21:00 2013: <191>164673:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:21:00 2013: <191>164674: .Mar 20 09:20:59: //8155/4C22D265B3ED/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:21:00 2013: <191>164675:
Wed Mar 20 09:21:00 2013: <191>164676: Destination Interface=0x498845E0, Destination Call Id=8154, Source Call Id=8155,
Wed Mar 20 09:21:00 2013: <191>164677:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:21:00 2013: <191>164678:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6101)
Wed Mar 20 09:21:00 2013: <191>164679: .Mar 20 09:20:59: //8154/4C22D265B3ED/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:21:00 2013: <191>164680:    Destination Interface=0x48A4F728, Destination Call Id=8155, Source Call Id=8154,
Wed Mar 20 09:21:00 2013: <191>164681:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:21:00 2013: <191>164682:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6101)
Wed Mar 20 09:21:00 2013: <191>164683: .Mar 20 09:20:59: //8154/4C22D265B3ED/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:21:00 2013: <191>164684:    Call Id=8154
Wed Mar 20 09:21:00 2013: <191>164685: .Mar 20 09:20:59: //8154/4C22D265B3ED/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:21:00 2013: <191>164686:
Wed Mar 20 09:21:01 2013: <191>164687: Call Entry(Context=0x4BA792A0)
Wed Mar 20 09:21:56 2013: <191>164688: .Mar 20 09:21:55: //8155/4C22D265B3ED/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:21:56 2013: <191>164689:    Interface=0x0, Call Id=8155
Wed Mar 20 09:21:56 2013: <191>164690: .Mar 20 09:21:55: //8155/4C22D265B3ED/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:21:56 2013: <191>164691:    Cause Value=16, Interface=0x48A4F728, Call Id=8155
Wed Mar 20 09:21:56 2013: <191>164692: .Mar 20 09:21:55: //8155/4C22D265B3ED/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:21:56 2013: <191>164693:    Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:21:56 2013: <191>164694: .Mar 20 09:21:55: //8154/4C22D265B3ED/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:21:56 2013: <191>164695:    Conference Id=0xE5A, Tag=0x0
Wed Mar 20 09:21:56 2013: <191>164696: .Mar 20 09:21:55: //8154/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:21:56 2013: <191>164697:    Conference Id=0xE5A, Source Interface=0x498845E0, Source Call Id=8154,
Wed Mar 20 09:21:56 2013: <191>164698:    Destination Call Id=8155, Disposition=0x0, Tag=0x0
Wed Mar 20 09:21:56 2013: <191>164699: .Mar 20 09:21:55: //8155/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:21:56 2013: <191>164700:    Conference Id=0xE5A, Source Interface=0x48A4F728, Source Call Id=8155,
Wed Mar 20 09:21:56 2013: <191>164701:    Destination Call Id=8154, Disposition=0x0, Tag=0x0
Wed Mar 20 09:21:56 2013: <191>164702: .Mar 20 09:21:55: //8154/4C22D265B3ED/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:21:56 2013: <191>164703:    Conference Id=0xE5A, Source Interface=0x48A4F728, Source Call Id=8155,
Wed Mar 20 09:21:56 2013: <191>164704:    Destination Call Id=8154, Disposition=0x0, Tag=0x0
Wed Mar 20 09:21:56 2013: <191>164705: .Mar 20 09:21:55: //8154/4C22D265B3ED/CCAPI/ccCallDisconnect:
Wed Mar 20 09:21:56 2013: <191>164706:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:21:56 2013: <191>164707: .Mar 20 09:21:55: //8154/4C22D265B3ED/CCAPI/ccCallDisconnect:
Wed Mar 20 09:21:56 2013: <191>164708:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:21:56 2013: <191>164709: .Mar 20 09:21:55: //8154/4C22D265B3ED/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:21:56 2013: <191>164710:    Transfer Number Is Null
Wed Mar 20 09:21:56 2013: <191>164711: .Mar 20 09:21:55: //8155/4C22D265B3ED/CCAPI/ccCallDisconnect:
Wed Mar 20 09:21:56 2013: <191>164712:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:21:56 2013: <191>164713: .Mar 20 09:21:55: //8155/4C22D265B3ED/CCAPI/ccCallDisconnect:
Wed Mar 20 09:21:56 2013: <191>164714:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:21:56 2013: <191>164715: .Mar 20 09:21:55: //8155/4C22D265B3ED/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:21:56 2013: <191>164716:    Transfer Number Is Null
Wed Mar 20 09:21:56 2013: <191>164717: .Mar 20 09:21:55: //8155/4C22D265B3ED/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:21:56 2013: <191>164718:    Transfer Number Is Null
Wed Mar 20 09:21:56 2013: <191>164719: .Mar 20 09:21:55: //8155/4C22D265B3ED/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:21:56 2013: <191>164720:
Wed Mar 20 09:21:56 2013: <191>164721: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8155,
Wed Mar 20 09:21:56 2013: <191>164722:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:21:56 2013: <191>164723: .Mar 20 09:21:55: //8155/4C22D265B3ED/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:21:56 2013: <191>164724:    Call Disconnect Event Sent
Wed Mar 20 09:21:56 2013: <191>164725: .Mar 20 09:21:55: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:21:56 2013: <191>164726:
Wed Mar 20 09:21:56 2013: <191>164727: .Mar 20 09:21:55: :cc_free_feature_vsa freeing 47B93D00
Wed Mar 20 09:21:56 2013: <191>164728: .Mar 20 09:21:55: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:21:56 2013: <191>164729:
Wed Mar 20 09:21:56 2013: <191>164730: .Mar 20 09:21:55:  vsacount in free is 1
Wed Mar 20 09:21:56 2013: <191>164731: .Mar 20 09:21:55: //8154/4C22D265B3ED/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:21:56 2013: <191>164732:    Disposition=0, Interface=0x498845E0, Tag=0x0, Call Id=8154,
Wed Mar 20 09:21:56 2013: <191>164733:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:21:57 2013: <191>164734: .Mar 20 09:21:55: //8154/4C22D265B3ED/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:21:57 2013: <191>164735:    Call Disconnect Event Sent
Wed Mar 20 09:21:57 2013: <191>164736: .Mar 20 09:21:55: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:21:57 2013: <191>164737:
Wed Mar 20 09:21:57 2013: <191>164738: .Mar 20 09:21:55: :cc_free_feature_vsa freeing 47B93DE0
Wed Mar 20 09:21:57 2013: <191>164739: .Mar 20 09:21:55: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:21:57 2013: <191>164740:
Wed Mar 20 09:21:57 2013: <191>164741: .Mar 20 09:21:55:  vsacount in free is 0
Wed Mar 20 09:23:15 2013: <191>164744:    cisco-username=
Wed Mar 20 09:23:15 2013: <191>164742: .Mar 20 09:23:14: //-1/C58B2C38B3F2/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:23:15 2013: <191>164743:    cc_api_call_setup_ind_common:
Wed Mar 20 09:23:15 2013: <191>164745:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:23:15 2013: <191>164746:    cisco-ani=
Wed Mar 20 09:23:15 2013: <191>164747:    cisco-anitype=0
Wed Mar 20 09:23:15 2013: <191>164748:    cisco-aniplan=0
Wed Mar 20 09:23:15 2013: <191>164749:    cisco-anipi=0
Wed Mar 20 09:23:15 2013: <191>164750:    cisco-anisi=0
Wed Mar 20 09:23:15 2013: <191>164751:    dest=1811032099
Wed Mar 20 09:23:15 2013: <191>164752:    cisco-desttype=0
Wed Mar 20 09:23:15 2013: <191>164753:    cisco-destplan=0
Wed Mar 20 09:23:15 2013: <191>164754:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:23:15 2013: <191>164755:    cisco-rdn=
Wed Mar 20 09:23:15 2013: <191>164756:    cisco-lastrdn=
Wed Mar 20 09:23:15 2013: <191>164757:    cisco-rdntype=0
Wed Mar 20 09:23:15 2013: <191>164758:    cisco-rdnplan=0
Wed Mar 20 09:23:15 2013: <191>164759:    cisco-rdnpi=0
Wed Mar 20 09:23:15 2013: <191>164760:    cisco-rdnsi=0
Wed Mar 20 09:23:15 2013: <191>164761:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:23:15 2013: <191>164762:    final_redirectNumber =
Wed Mar 20 09:23:15 2013: <191>164763:    hunt_group_timeout =0
Wed Mar 20 09:23:15 2013: <191>164764:
Wed Mar 20 09:23:15 2013: <191>164765: .Mar 20 09:23:14: //-1/C58B2C38B3F2/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:23:15 2013: <191>164766:
Wed Mar 20 09:23:15 2013: <191>164767: Interface=0x4987FF98, Call Info(
Wed Mar 20 09:23:15 2013: <191>164768:    Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:23:15 2013: <191>164769:    Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:23:15 2013: <191>164770:    Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Wed Mar 20 09:23:15 2013: <191>164771:    Incoming Dial-peer=18, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Wed Mar 20 09:23:15 2013: <191>164772:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:23:15 2013: <191>164773: .Mar 20 09:23:14: //-1/C58B2C38B3F2/CCAPI/ccCheckClipClir:
Wed Mar 20 09:23:15 2013: <191>164774:    In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:23:15 2013: <191>164775: .Mar 20 09:23:14: //-1/C58B2C38B3F2/CCAPI/ccCheckClipClir:
Wed Mar 20 09:23:15 2013: <191>164776:    Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:23:15 2013: <191>164777: .Mar 20 09:23:14: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:23:15 2013: <191>164778:
Wed Mar 20 09:23:15 2013: <191>164779: .Mar 20 09:23:14: :cc_get_feature_vsa malloc success
Wed Mar 20 09:23:15 2013: <191>164780: .Mar 20 09:23:14: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:23:15 2013: <191>164781:
Wed Mar 20 09:23:15 2013: <191>164782: .Mar 20 09:23:14:  cc_get_feature_vsa count is 1
Wed Mar 20 09:23:15 2013: <191>164783: .Mar 20 09:23:14: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:23:15 2013: <191>164784:
Wed Mar 20 09:23:15 2013: <191>164785: .Mar 20 09:23:14: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203322344,feature_id:8156
Wed Mar 20 09:23:15 2013: <191>164786: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:23:15 2013: <191>164787:
Wed Mar 20 09:23:15 2013: <191>164788: Set Up Event Sent;
Wed Mar 20 09:23:15 2013: <191>164789:    Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:23:15 2013: <191>164792:    Event=0x4982D230
Wed Mar 20 09:23:15 2013: <191>164796:    Context=0x4BA6FA60
Wed Mar 20 09:23:15 2013: <191>164797: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:23:15 2013: <191>164798:    >>>>CCAPI handed cid 8156 with tag 18 to app "_ManagedAppProcess_Default"
Wed Mar 20 09:23:15 2013: <191>164799: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/ccCallProceeding:
Wed Mar 20 09:23:15 2013: <191>164800:
Wed Mar 20 09:23:15 2013: <191>164808:    Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:23:15 2013: <191>164809: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:23:15 2013: <191>164810:
Wed Mar 20 09:23:15 2013: <191>164821:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:23:15 2013: <191>164824:    cisco-aniplan=0
Wed Mar 20 09:23:15 2013: <191>164827:    cisco-anisi=0
Wed Mar 20 09:23:15 2013: <191>164831:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:23:15 2013: <191>164836:    cisco-rdnpi=0
Wed Mar 20 09:23:15 2013: <191>164838:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:23:15 2013: <191>164854: .Mar 20 09:23:14:  cc_get_feature_vsa count is 2
Wed Mar 20 09:23:15 2013: <191>164855: .Mar 20 09:23:14: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:23:15 2013: <191>164856:
Wed Mar 20 09:23:15 2013: <191>164857: .Mar 20 09:23:14: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203322120,feature_id:8157
Wed Mar 20 09:23:15 2013: <191>164858: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:23:15 2013: <191>164859:    SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Wed Mar 20 09:23:15 2013: <191>164860: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/ccCallSetContext:
Wed Mar 20 09:23:15 2013: <191>164861:    Context=0x4BA69B38
Wed Mar 20 09:23:15 2013: <191>164862: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:23:15 2013: <191>164863:    Outgoing Dial-peer=3000
Wed Mar 20 09:23:15 2013: <191>164864: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:23:15 2013: <191>164865:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:23:15 2013: <191>164866: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:23:15 2013: <191>164867:    Interface=0x48A4F728, Progress Indication=NULL(0)
Wed Mar 20 09:23:15 2013: <191>164868: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:23:15 2013: <191>164869:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:23:15 2013: <191>164870: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_set_delay_xport:
Wed Mar 20 09:23:15 2013: <191>164871:    CallInfo(delay xport=TRUE)
Wed Mar 20 09:23:15 2013: <191>164872: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_call_alert:
Wed Mar 20 09:23:15 2013: <191>164873:    Interface=0x48A4F728, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:23:15 2013: <191>164874: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_call_alert:
Wed Mar 20 09:23:15 2013: <191>164875:    Call Entry(Retry Count=0, Responsed=TRUE)
Wed Mar 20 09:23:15 2013: <191>164876: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/ccCallAlert:
Wed Mar 20 09:23:15 2013: <191>164877:
Wed Mar 20 09:23:15 2013: <191>164878: Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:23:15 2013: <191>164879: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/ccCallAlert:
Wed Mar 20 09:23:15 2013: <191>164880:    Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Wed Mar 20 09:23:15 2013: <191>164881: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:23:15 2013: <191>164882:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:23:15 2013: <191>164883: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_call_notify:
Wed Mar 20 09:23:15 2013: <191>164884:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8157
Wed Mar 20 09:23:15 2013: <191>164885: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/ccIsInfoRingback:
Wed Mar 20 09:23:15 2013: <191>164886:    Returning dpRingBack=0
Wed Mar 20 09:23:15 2013: <191>164887: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:23:15 2013: <191>164888:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:23:15 2013: <191>164889: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:23:15 2013: <191>164890:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:23:15 2013: <191>164891: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/ccCallNotify:
Wed Mar 20 09:23:15 2013: <191>164892:    Data Bitmask=0x5, Call Id=8156
Wed Mar 20 09:23:15 2013: <191>164893: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_call_connected:
Wed Mar 20 09:23:15 2013: <191>164894:    Interface=0x48A4F728, Data Bitmask=0x0, Progress Indication=NULL(0),
Wed Mar 20 09:23:15 2013: <191>164895:    Connection Handle=0
Wed Mar 20 09:23:15 2013: <191>164896: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_call_connected:
Wed Mar 20 09:23:15 2013: <191>164897:    Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:23:15 2013: <191>164898: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:23:15 2013: <191>164899:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:23:15 2013: <191>164900: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_call_notify:
Wed Mar 20 09:23:15 2013: <191>164901:
Wed Mar 20 09:23:15 2013: <191>164902: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8157
Wed Mar 20 09:23:15 2013: <191>164903: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:23:15 2013: <191>164904:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:23:15 2013: <191>164905:    Tone Direction=Network, Params=0x0, Call Id=8156
Wed Mar 20 09:23:15 2013: <191>164906: .Mar 20 09:23:14: //8156/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:23:15 2013: <191>164907:    (confID=0x4BB01D68, callID1=0x1FDC, callID2=0x1FDD, tag=0x0)
Wed Mar 20 09:23:15 2013: <191>164908: .Mar 20 09:23:14: //8156/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:23:15 2013: <191>164909:    (confID=0x4BB01D68, callID1=0x1FDC, gcid=C58B2C38-908F11E2-B3F2DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:23:15 2013: <191>164910: .Mar 20 09:23:14: //8157/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:23:15 2013: <191>164911:    (confID=0x4BB01D68, callID2=0x1FDD, gcid=C58B2C38-908F11E2-B3F2DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:23:16 2013: <191>164912: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/ccConferenceCreate:
Wed Mar 20 09:23:16 2013: <191>164913:    Conference Id=0x4BB01D68, Call Id1=8156, Call Id2=8157, Tag=0x0
Wed Mar 20 09:23:16 2013: <191>164914: .Mar 20 09:23:14: //8156/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:23:16 2013: <191>164915:    Conference Id=0xE5B, Source Interface=0x4987FF98, Source Call Id=8156,
Wed Mar 20 09:23:16 2013: <191>164916:    Destination Call Id=8157, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:23:16 2013: <191>164917: .Mar 20 09:23:14: //8157/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:23:16 2013: <191>164918:
Wed Mar 20 09:23:16 2013: <191>164919: .Mar 20 09:23:14: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:23:16 2013: <191>164920: .Mar 20 09:23:14: //8157/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:23:16 2013: <191>164921:    Conference Id=0xE5B, Source Interface=0x48A4F728, Source Call Id=8157,
Wed Mar 20 09:23:16 2013: <191>164922:    Destination Call Id=8156, Disposition=0x0, Tag=0x0
Wed Mar 20 09:23:16 2013: <191>164923: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:23:16 2013: <191>164924:    Conference Id=0xE5B, Source Interface=0x48A4F728, Source Call Id=8157,
Wed Mar 20 09:23:16 2013: <191>164926: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/ccConferenceCreate:
Wed Mar 20 09:23:16 2013: <191>164928: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/ccConferenceCreate:
Wed Mar 20 09:23:16 2013: <191>164929:    Call Entry(Conference Id=0xE5B, Destination Call Id=8156)
Wed Mar 20 09:23:16 2013: <191>164931:    Destination Interface=0x48A4F728, Destination Call Id=8157, Source Call Id=8156,
Wed Mar 20 09:23:16 2013: <191>164932:    Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Wed Mar 20 09:23:16 2013: <191>164940:    Destination Interface=0x4987FF98, Destination Call Id=8156, Source Call Id=8157,
Wed Mar 20 09:23:16 2013: <191>164950:    Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=5687)
Wed Mar 20 09:23:16 2013: <191>164951: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:23:16 2013: <191>164952:    Destination Interface=0x48A4F728, Destination Call Id=8157, Source Call Id=8156,
Wed Mar 20 09:23:16 2013: <191>164953:    Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:23:16 2013: <191>164966:    Progress Indication=NULL(0), Data Bitmask=0x0
Wed Mar 20 09:23:16 2013: <191>164967: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/ccCallConnect:
Wed Mar 20 09:23:16 2013: <191>164968:
Wed Mar 20 09:23:16 2013: <191>164969: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:23:27 2013: <191>164970: .Mar 20 09:23:25: //8157/C58B2C38B3F2/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:23:27 2013: <191>164971:    Interface=0x0, Call Id=8157
Wed Mar 20 09:23:27 2013: <191>164972: .Mar 20 09:23:25: //8157/C58B2C38B3F2/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:23:27 2013: <191>164973:    Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:23:27 2013: <191>164974: .Mar 20 09:23:25: //8157/C58B2C38B3F2/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:23:27 2013: <191>164975:    Interface=0x48A4F728, Signal Indication=NOT PRESENT(255)
Wed Mar 20 09:23:27 2013: <191>164976: .Mar 20 09:23:25: //8156/C58B2C38B3F2/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:23:27 2013: <191>164977:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:23:27 2013: <191>164978:    Tone Direction=Network, Params=0x0, Call Id=8156
Wed Mar 20 09:23:27 2013: <191>164979: .Mar 20 09:23:25: //8157/C58B2C38B3F2/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:23:27 2013: <191>164980:    Interface=0x48A4F728, Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:23:27 2013: <191>164981: .Mar 20 09:23:25: //8156/C58B2C38B3F2/CCAPI/ccCallUserInfo:
Wed Mar 20 09:23:27 2013: <191>164982:    Call Id=8156
Wed Mar 20 09:23:27 2013: <191>164983: .Mar 20 09:23:25: //8156/C58B2C38B3F2/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:23:27 2013: <191>164984:    Stop Tone On Digit=FALSE, Tone=Ring Back,
Wed Mar 20 09:23:27 2013: <191>164985:    Tone Direction=Network, Params=0x0, Call Id=8156
Wed Mar 20 09:23:27 2013: <191>164986: .Mar 20 09:23:25: //8157/C58B2C38B3F2/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:23:27 2013: <191>164987:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:23:27 2013: <191>164988: .Mar 20 09:23:25: //8157/C58B2C38B3F2/CCAPI/cc_api_call_notify:
Wed Mar 20 09:23:27 2013: <191>164989:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8157
Wed Mar 20 09:23:27 2013: <191>164990: .Mar 20 09:23:25: //8157/C58B2C38B3F2/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:23:27 2013: <191>164991:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:23:28 2013: <191>164992: .Mar 20 09:23:25: //8157/C58B2C38B3F2/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:23:28 2013: <191>164993:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:23:28 2013: <191>164994: .Mar 20 09:23:25: //8156/C58B2C38B3F2/CCAPI/ccCallNotify:
Wed Mar 20 09:23:28 2013: <191>164995:    Data Bitmask=0x5, Call Id=8156
Wed Mar 20 09:23:33 2013: <191>164996: .Mar 20 09:23:32: //8157/C58B2C38B3F2/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:23:33 2013: <191>164997:    Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:23:33 2013: <191>164998: .Mar 20 09:23:32: //8157/C58B2C38B3F2/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:23:33 2013: <191>164999:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:23:33 2013: <191>165000: .Mar 20 09:23:32: //8157/C58B2C38B3F2/CCAPI/cc_api_call_notify:
Wed Mar 20 09:23:33 2013: <191>165001:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8157
Wed Mar 20 09:23:33 2013: <191>165002: .Mar 20 09:23:32: //8156/C58B2C38B3F2/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:23:33 2013: <191>165003:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:23:33 2013: <191>165004:    Tone Direction=Network, Params=0x0, Call Id=8156
Wed Mar 20 09:23:33 2013: <191>165005: .Mar 20 09:23:32: //8157/C58B2C38B3F2/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:23:33 2013: <191>165006:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:23:33 2013: <191>165007: .Mar 20 09:23:32: //8157/C58B2C38B3F2/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:23:33 2013: <191>165008:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:23:33 2013: <191>165009: .Mar 20 09:23:32: //8156/C58B2C38B3F2/CCAPI/ccCallNotify:
Wed Mar 20 09:23:33 2013: <191>165010:    Data Bitmask=0x5, Call Id=8156
Wed Mar 20 09:23:33 2013: <191>165011: .Mar 20 09:23:32: //8157/C58B2C38B3F2/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:23:33 2013: <191>165012:    Destination Interface=0x4987FF98, Destination Call Id=8156, Source Call Id=8157,
Wed Mar 20 09:23:33 2013: <191>165013:    Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:23:33 2013: <191>165014:    Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:23:33 2013: <191>165015: .Mar 20 09:23:32: //8157/C58B2C38B3F2/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:23:33 2013: <191>165016:    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:23:33 2013: <191>165017:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:23:33 2013: <191>165018: .Mar 20 09:23:32: //8157/C58B2C38B3F2/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:23:33 2013: <191>165019:
Wed Mar 20 09:23:33 2013: <191>165020: Destination Interface=0x4987FF98, Destination Call Id=8156, Source Call Id=8157,
Wed Mar 20 09:23:33 2013: <191>165021:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:23:33 2013: <191>165022:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5785)
Wed Mar 20 09:23:33 2013: <191>165023: .Mar 20 09:23:32: //8156/C58B2C38B3F2/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:23:33 2013: <191>165024:    Destination Interface=0x48A4F728, Destination Call Id=8157, Source Call Id=8156,
Wed Mar 20 09:23:33 2013: <191>165025:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:23:33 2013: <191>165026:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5785)
Wed Mar 20 09:23:33 2013: <191>165027: .Mar 20 09:23:32: //8156/C58B2C38B3F2/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:23:33 2013: <191>165028:    Call Id=8156
Wed Mar 20 09:23:33 2013: <191>165029: .Mar 20 09:23:32: //8156/C58B2C38B3F2/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:23:33 2013: <191>165030:
Wed Mar 20 09:23:34 2013: <191>165031: Call Entry(Context=0x4BA6FA60)
Wed Mar 20 09:24:02 2013: <191>165032: .Mar 20 09:24:00: //8157/C58B2C38B3F2/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:24:02 2013: <191>165033:    Interface=0x0, Call Id=8157
Wed Mar 20 09:24:02 2013: <191>165034: .Mar 20 09:24:01: //8157/C58B2C38B3F2/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:24:02 2013: <191>165035:    Destination Interface=0x4987FF98, Destination Call Id=8156, Source Call Id=8157,
Wed Mar 20 09:24:02 2013: <191>165036:    Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:24:02 2013: <191>165037:    Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:24:02 2013: <191>165038: .Mar 20 09:24:01: //8157/C58B2C38B3F2/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:24:02 2013: <191>165039:    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:24:02 2013: <191>165040:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:24:02 2013: <191>165041: .Mar 20 09:24:01: //8157/C58B2C38B3F2/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:24:02 2013: <191>165042:
Wed Mar 20 09:24:02 2013: <191>165043: Destination Interface=0x4987FF98, Destination Call Id=8156, Source Call Id=8157,
Wed Mar 20 09:24:02 2013: <191>165044:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:24:02 2013: <191>165045:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6388)
Wed Mar 20 09:24:02 2013: <191>165046: .Mar 20 09:24:01: //8156/C58B2C38B3F2/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:24:02 2013: <191>165047:    Destination Interface=0x48A4F728, Destination Call Id=8157, Source Call Id=8156,
Wed Mar 20 09:24:02 2013: <191>165048:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:24:02 2013: <191>165049:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6388)
Wed Mar 20 09:24:02 2013: <191>165050: .Mar 20 09:24:01: //8156/C58B2C38B3F2/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:24:02 2013: <191>165051:    Call Id=8156
Wed Mar 20 09:24:02 2013: <191>165052: .Mar 20 09:24:01: //8156/C58B2C38B3F2/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:24:02 2013: <191>165053:
Wed Mar 20 09:24:03 2013: <191>165054: Call Entry(Context=0x4BA6FA60)
Wed Mar 20 09:24:05 2013: <191>165055: .Mar 20 09:24:04: //8157/C58B2C38B3F2/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:24:05 2013: <191>165056:    Interface=0x0, Call Id=8157
Wed Mar 20 09:24:05 2013: <191>165057: .Mar 20 09:24:04: //8157/C58B2C38B3F2/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:24:05 2013: <191>165058:    Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:24:05 2013: <191>165059: .Mar 20 09:24:04: //8156/C58B2C38B3F2/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:24:05 2013: <191>165060:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:24:05 2013: <191>165061:    Tone Direction=Network, Params=0x0, Call Id=8156
Wed Mar 20 09:24:05 2013: <191>165062: .Mar 20 09:24:04: //8157/C58B2C38B3F2/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:24:05 2013: <191>165063:    Interface=0x48A4F728, Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:24:05 2013: <191>165064: .Mar 20 09:24:04: //8157/C58B2C38B3F2/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:24:05 2013: <191>165065:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:24:06 2013: <191>165066: .Mar 20 09:24:04: //8157/C58B2C38B3F2/CCAPI/cc_api_call_notify:
Wed Mar 20 09:24:06 2013: <191>165067:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8157
Wed Mar 20 09:24:06 2013: <191>165068: .Mar 20 09:24:04: //8156/C58B2C38B3F2/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:24:06 2013: <191>165069:    Stop Tone On Digit=FALSE, Tone=Ring Back,
Wed Mar 20 09:24:06 2013: <191>165070:    Tone Direction=Network, Params=0x0, Call Id=8156
Wed Mar 20 09:24:06 2013: <191>165071: .Mar 20 09:24:04: //8157/C58B2C38B3F2/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:24:06 2013: <191>165072:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:24:06 2013: <191>165073: .Mar 20 09:24:04: //8157/C58B2C38B3F2/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:24:06 2013: <191>165074:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:24:06 2013: <191>165075: .Mar 20 09:24:04: //8156/C58B2C38B3F2/CCAPI/ccCallNotify:
Wed Mar 20 09:24:06 2013: <191>165076:    Data Bitmask=0x5, Call Id=8156
Wed Mar 20 09:24:17 2013: <191>165077: .Mar 20 09:24:16: //8157/C58B2C38B3F2/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:24:17 2013: <191>165078:    Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:24:17 2013: <191>165079: .Mar 20 09:24:16: //8157/C58B2C38B3F2/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:24:17 2013: <191>165080:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:24:17 2013: <191>165081: .Mar 20 09:24:16: //8157/C58B2C38B3F2/CCAPI/cc_api_call_notify:
Wed Mar 20 09:24:17 2013: <191>165082:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8157
Wed Mar 20 09:24:17 2013: <191>165083: .Mar 20 09:24:16: //8156/C58B2C38B3F2/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:24:17 2013: <191>165084:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:24:17 2013: <191>165085:    Tone Direction=Network, Params=0x0, Call Id=8156
Wed Mar 20 09:24:17 2013: <191>165086: .Mar 20 09:24:16: //8157/C58B2C38B3F2/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:24:17 2013: <191>165087:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:24:17 2013: <191>165088: .Mar 20 09:24:16: //8157/C58B2C38B3F2/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:24:17 2013: <191>165089:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:24:17 2013: <191>165090: .Mar 20 09:24:16: //8156/C58B2C38B3F2/CCAPI/ccCallNotify:
Wed Mar 20 09:24:17 2013: <191>165091:    Data Bitmask=0x5, Call Id=8156
Wed Mar 20 09:24:17 2013: <191>165092: .Mar 20 09:24:16: //8157/C58B2C38B3F2/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:24:17 2013: <191>165093:    Destination Interface=0x4987FF98, Destination Call Id=8156, Source Call Id=8157,
Wed Mar 20 09:24:17 2013: <191>165094:    Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:24:17 2013: <191>165095:    Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:24:17 2013: <191>165096: .Mar 20 09:24:16: //8157/C58B2C38B3F2/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:24:17 2013: <191>165097:    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:24:17 2013: <191>165098:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:24:17 2013: <191>165099: .Mar 20 09:24:16: //8157/C58B2C38B3F2/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:24:17 2013: <191>165100:
Wed Mar 20 09:24:17 2013: <191>165101: Destination Interface=0x4987FF98, Destination Call Id=8156, Source Call Id=8157,
Wed Mar 20 09:24:17 2013: <191>165102:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:24:17 2013: <191>165103:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6501)
Wed Mar 20 09:24:17 2013: <191>165104: .Mar 20 09:24:16: //8156/C58B2C38B3F2/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:24:17 2013: <191>165105:    Destination Interface=0x48A4F728, Destination Call Id=8157, Source Call Id=8156,
Wed Mar 20 09:24:17 2013: <191>165106:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:24:17 2013: <191>165107:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6501)
Wed Mar 20 09:24:17 2013: <191>165108: .Mar 20 09:24:16: //8156/C58B2C38B3F2/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:24:17 2013: <191>165109:    Call Id=8156
Wed Mar 20 09:24:17 2013: <191>165110: .Mar 20 09:24:16: //8156/C58B2C38B3F2/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:24:17 2013: <191>165111:
Wed Mar 20 09:24:18 2013: <191>165112: Call Entry(Context=0x4BA6FA60)
Wed Mar 20 09:24:45 2013: <191>165113: .Mar 20 09:24:44: //8157/C58B2C38B3F2/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:24:45 2013: <191>165114:    Interface=0x0, Call Id=8157
Wed Mar 20 09:24:45 2013: <191>165115: .Mar 20 09:24:44: //8157/C58B2C38B3F2/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:24:45 2013: <191>165116:    Cause Value=16, Interface=0x48A4F728, Call Id=8157
Wed Mar 20 09:24:45 2013: <191>165117: .Mar 20 09:24:44: //8157/C58B2C38B3F2/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:24:45 2013: <191>165118:    Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:24:45 2013: <191>165119: .Mar 20 09:24:44: //8156/C58B2C38B3F2/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:24:45 2013: <191>165120:    Conference Id=0xE5B, Tag=0x0
Wed Mar 20 09:24:45 2013: <191>165121: .Mar 20 09:24:44: //8156/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:24:45 2013: <191>165122:    Conference Id=0xE5B, Source Interface=0x4987FF98, Source Call Id=8156,
Wed Mar 20 09:24:45 2013: <191>165123:    Destination Call Id=8157, Disposition=0x0, Tag=0x0
Wed Mar 20 09:24:45 2013: <191>165124: .Mar 20 09:24:44: //8157/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:24:45 2013: <191>165125:    Conference Id=0xE5B, Source Interface=0x48A4F728, Source Call Id=8157,
Wed Mar 20 09:24:45 2013: <191>165126:    Destination Call Id=8156, Disposition=0x0, Tag=0x0
Wed Mar 20 09:24:45 2013: <191>165127: .Mar 20 09:24:44: //8156/C58B2C38B3F2/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:24:45 2013: <191>165128:    Conference Id=0xE5B, Source Interface=0x48A4F728, Source Call Id=8157,
Wed Mar 20 09:24:45 2013: <191>165129:    Destination Call Id=8156, Disposition=0x0, Tag=0x0
Wed Mar 20 09:24:45 2013: <191>165130: .Mar 20 09:24:44: //8156/C58B2C38B3F2/CCAPI/ccCallDisconnect:
Wed Mar 20 09:24:45 2013: <191>165131:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:24:45 2013: <191>165132: .Mar 20 09:24:44: //8156/C58B2C38B3F2/CCAPI/ccCallDisconnect:
Wed Mar 20 09:24:45 2013: <191>165133:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:24:45 2013: <191>165134: .Mar 20 09:24:44: //8156/C58B2C38B3F2/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:24:45 2013: <191>165135:    Transfer Number Is Null
Wed Mar 20 09:24:45 2013: <191>165136: .Mar 20 09:24:44: //8157/C58B2C38B3F2/CCAPI/ccCallDisconnect:
Wed Mar 20 09:24:45 2013: <191>165137:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:24:45 2013: <191>165138: .Mar 20 09:24:44: //8157/C58B2C38B3F2/CCAPI/ccCallDisconnect:
Wed Mar 20 09:24:45 2013: <191>165139:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:24:45 2013: <191>165140: .Mar 20 09:24:44: //8157/C58B2C38B3F2/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:24:45 2013: <191>165141:    Transfer Number Is Null
Wed Mar 20 09:24:45 2013: <191>165142: .Mar 20 09:24:44: //8157/C58B2C38B3F2/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:24:45 2013: <191>165143:    Transfer Number Is Null
Wed Mar 20 09:24:45 2013: <191>165144: .Mar 20 09:24:44: //8157/C58B2C38B3F2/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:24:45 2013: <191>165145:
Wed Mar 20 09:24:45 2013: <191>165146: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8157,
Wed Mar 20 09:24:45 2013: <191>165147:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:24:45 2013: <191>165148: .Mar 20 09:24:44: //8157/C58B2C38B3F2/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:24:45 2013: <191>165149:    Call Disconnect Event Sent
Wed Mar 20 09:24:45 2013: <191>165150: .Mar 20 09:24:44: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:24:45 2013: <191>165151:
Wed Mar 20 09:24:45 2013: <191>165152: .Mar 20 09:24:44: :cc_free_feature_vsa freeing 47B93D00
Wed Mar 20 09:24:45 2013: <191>165153: .Mar 20 09:24:44: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:24:45 2013: <191>165154:
Wed Mar 20 09:24:45 2013: <191>165155: .Mar 20 09:24:44:  vsacount in free is 1
Wed Mar 20 09:24:45 2013: <191>165156: .Mar 20 09:24:44: //8156/C58B2C38B3F2/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:24:45 2013: <191>165157:    Disposition=0, Interface=0x4987FF98, Tag=0x0, Call Id=8156,
Wed Mar 20 09:24:45 2013: <191>165158:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:24:46 2013: <191>165159: .Mar 20 09:24:44: //8156/C58B2C38B3F2/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:24:46 2013: <191>165160:    Call Disconnect Event Sent
Wed Mar 20 09:24:46 2013: <191>165161: .Mar 20 09:24:44: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:24:46 2013: <191>165162:
Wed Mar 20 09:24:46 2013: <191>165163: .Mar 20 09:24:44: :cc_free_feature_vsa freeing 47B93DE0
Wed Mar 20 09:24:46 2013: <191>165164: .Mar 20 09:24:44: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:24:46 2013: <191>165165:
Wed Mar 20 09:24:46 2013: <191>165166: .Mar 20 09:24:44:  vsacount in free is 0
Wed Mar 20 09:25:02 2013: <190>165167: .Mar 20 09:25:00: %IPPHONE-6-REGISTER_NEW: ephone-7:SEP002699442108 IP:10.229.64.50 Socket:5 DeviceType:Phone has registered.
Wed Mar 20 09:25:35 2013: <191>165168: .Mar 20 09:25:34: //-1/008F92424106/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:25:35 2013: <191>165169:    cc_api_call_setup_ind_common:
Wed Mar 20 09:25:35 2013: <191>165170:    cisco-username=PF-Assis-Margarida
Wed Mar 20 09:25:35 2013: <191>165171:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:25:35 2013: <191>165172:    cisco-ani=1811032010
Wed Mar 20 09:25:35 2013: <191>165173:    cisco-anitype=0
Wed Mar 20 09:25:35 2013: <191>165174:    cisco-aniplan=0
Wed Mar 20 09:25:35 2013: <191>165175:    cisco-anipi=0
Wed Mar 20 09:25:35 2013: <191>165176:    cisco-anisi=1
Wed Mar 20 09:25:35 2013: <191>165177:    dest=033222776
Wed Mar 20 09:25:35 2013: <191>165178:    cisco-desttype=0
Wed Mar 20 09:25:35 2013: <191>165179:    cisco-destplan=0
Wed Mar 20 09:25:35 2013: <191>165180:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:25:35 2013: <191>165181:    cisco-rdn=
Wed Mar 20 09:25:35 2013: <191>165182:    cisco-lastrdn=
Wed Mar 20 09:25:35 2013: <191>165183:    cisco-rdntype=-1
Wed Mar 20 09:25:35 2013: <191>165184:    cisco-rdnplan=-1
Wed Mar 20 09:25:35 2013: <191>165185:    cisco-rdnpi=-1
Wed Mar 20 09:25:35 2013: <191>165186:    cisco-rdnsi=-1
Wed Mar 20 09:25:35 2013: <191>165187:    cisco-redirectreason=-1   fwd_final_type =0
Wed Mar 20 09:25:35 2013: <191>165188:    final_redirectNumber =
Wed Mar 20 09:25:35 2013: <191>165189:    hunt_group_timeout =0
Wed Mar 20 09:25:35 2013: <191>165190:
Wed Mar 20 09:25:35 2013: <191>165191: .Mar 20 09:25:34: //-1/008F92424106/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:25:35 2013: <191>165192:
Wed Mar 20 09:25:35 2013: <191>165193: Interface=0x48A4F728, Call Info(
Wed Mar 20 09:25:35 2013: <191>165194:    Calling Number=1811032010,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Wed Mar 20 09:25:35 2013: <191>165195:    Called Number=033222776(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:25:35 2013: <191>165196:    Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Wed Mar 20 09:25:35 2013: <191>165197:    Incoming Dial-peer=200, Progress Indication=NULL(0), Calling IE Present=TRUE,
Wed Mar 20 09:25:35 2013: <191>165198:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=8158
Wed Mar 20 09:25:35 2013: <191>165199: .Mar 20 09:25:34: //-1/008F92424106/CCAPI/ccCheckClipClir:
Wed Mar 20 09:25:35 2013: <191>165200:    In: Calling Number=1811032010(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Wed Mar 20 09:25:35 2013: <191>165201: .Mar 20 09:25:34: //-1/008F92424106/CCAPI/ccCheckClipClir:
Wed Mar 20 09:25:35 2013: <191>165202:    Out: Calling Number=1811032010(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Wed Mar 20 09:25:35 2013: <191>165203: .Mar 20 09:25:34: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:25:35 2013: <191>165204:
Wed Mar 20 09:25:35 2013: <191>165205: .Mar 20 09:25:34: :cc_get_feature_vsa malloc success
Wed Mar 20 09:25:35 2013: <191>165206: .Mar 20 09:25:34: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:25:35 2013: <191>165207:
Wed Mar 20 09:25:35 2013: <191>165208: .Mar 20 09:25:34:  cc_get_feature_vsa count is 1
Wed Mar 20 09:25:35 2013: <191>165209: .Mar 20 09:25:34: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:25:35 2013: <191>165210:
Wed Mar 20 09:25:35 2013: <191>165211: .Mar 20 09:25:34: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248360,feature_id:8158
Wed Mar 20 09:25:35 2013: <191>165212: .Mar 20 09:25:34: //8158/008F92424106/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:25:35 2013: <191>165213:
Wed Mar 20 09:25:35 2013: <191>165215:    Call Info(Calling Number=1811032010(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Wed Mar 20 09:25:35 2013: <191>165217: .Mar 20 09:25:34: //8158/008F92424106/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:25:35 2013: <191>165221: .Mar 20 09:25:34: //8158/008F92424106/CCAPI/ccCallSetContext:
Wed Mar 20 09:25:35 2013: <191>165226:    Progress Indication=NULL(0)
Wed Mar 20 09:25:35 2013: <191>165227: .Mar 20 09:25:34: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Wed Mar 20 09:25:35 2013: <191>165235:
Wed Mar 20 09:25:35 2013: <191>165236: Out: Calling Number=1811032010(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Wed Mar 20 09:25:35 2013: <191>165237: .Mar 20 09:25:34: //8158/008F92424106/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:25:35 2013: <191>165238:    Destination Pattern=0[2-5]......., Called Number=033222776, Digit Strip=TRUE
Wed Mar 20 09:25:35 2013: <191>165239: .Mar 20 09:25:34: //8158/008F92424106/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:25:35 2013: <191>165250:    cisco-anitype=0
Wed Mar 20 09:25:35 2013: <191>165251:    cisco-aniplan=0
Wed Mar 20 09:25:35 2013: <191>165254:    dest=033222776
Wed Mar 20 09:25:35 2013: <191>165257:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:25:35 2013: <191>165258:    cisco-rdn=
Wed Mar 20 09:25:35 2013: <191>165264:    cisco-redirectreason=-1   fwd_final_type =0
Wed Mar 20 09:25:35 2013: <191>165266:    hunt_group_timeout =0
Wed Mar 20 09:25:35 2013: <191>165267:
Wed Mar 20 09:25:36 2013: <191>165280: .Mar 20 09:25:34:  cc_get_feature_vsa count is 2
Wed Mar 20 09:25:36 2013: <191>165281: .Mar 20 09:25:34: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:25:36 2013: <191>165282:
Wed Mar 20 09:25:36 2013: <191>165283: .Mar 20 09:25:34: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248136,feature_id:8159
Wed Mar 20 09:25:36 2013: <191>165284: .Mar 20 09:25:34: //8159/008F92424106/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:25:36 2013: <191>165285:    SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Wed Mar 20 09:25:36 2013: <191>165286: .Mar 20 09:25:34: //8159/008F92424106/CCAPI/ccCallSetContext:
Wed Mar 20 09:25:36 2013: <191>165287:    Context=0x4BA6E758
Wed Mar 20 09:25:36 2013: <191>165288: .Mar 20 09:25:34: //8158/008F92424106/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:25:36 2013: <191>165289:    Outgoing Dial-peer=18
Wed Mar 20 09:25:36 2013: <191>165290: .Mar 20 09:25:34: //8159/008F92424106/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:25:36 2013: <191>165291:    Interface=0x4987FF98, Progress Indication=NULL(0)
Wed Mar 20 09:25:38 2013: <191>165292: .Mar 20 09:25:37: //8159/008F92424106/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:25:38 2013: <191>165293:    Interface=0x4987FF98, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
Wed Mar 20 09:25:38 2013: <191>165294:    Cause Value=0
Wed Mar 20 09:25:38 2013: <191>165295: .Mar 20 09:25:37: //8159/008F92424106/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:25:38 2013: <191>165296:    Call Entry(Responsed=TRUE)
Wed Mar 20 09:25:38 2013: <191>165297: .Mar 20 09:25:37: //8158/008F92424106/CCAPI/ccCallCutProgress:
Wed Mar 20 09:25:38 2013: <191>165298:    Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
Wed Mar 20 09:25:38 2013: <191>165299:    Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Wed Mar 20 09:25:38 2013: <191>165300: .Mar 20 09:25:37: //8158/008F92424106/CCAPI/ccCallCutProgress:
Wed Mar 20 09:25:38 2013: <191>165301:    Call Entry(Responsed=TRUE)
Wed Mar 20 09:25:38 2013: <191>165302: .Mar 20 09:25:37: //8159/008F92424106/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:25:38 2013: <191>165303:    CallInfo(ccm detected=0)
Wed Mar 20 09:25:38 2013: <191>165304: .Mar 20 09:25:37: //8158/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:25:38 2013: <191>165305:    (confID=0x4BB020C8, callID1=0x1FDE, callID2=0x1FDF, tag=0x0)
Wed Mar 20 09:25:38 2013: <191>165306: .Mar 20 09:25:37: //8158/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:25:38 2013: <191>165307:    (confID=0x4BB020C8, callID1=0x1FDE, gcid=0-0-0-0, tag=0x0)
Wed Mar 20 09:25:38 2013: <191>165308: .Mar 20 09:25:37: //8159/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:25:38 2013: <191>165309:    (confID=0x4BB020C8, callID2=0x1FDF, gcid=0-0-0-0, tag=0x0)
Wed Mar 20 09:25:38 2013: <191>165310: .Mar 20 09:25:37: //8158/008F92424106/CCAPI/ccConferenceCreate:
Wed Mar 20 09:25:38 2013: <191>165311:    Conference Id=0x4BB020C8, Call Id1=8158, Call Id2=8159, Tag=0x0
Wed Mar 20 09:25:38 2013: <191>165312: .Mar 20 09:25:37: //8158/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:25:38 2013: <191>165313:
Wed Mar 20 09:25:38 2013: <191>165314: .Mar 20 09:25:37: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:25:38 2013: <191>165315: .Mar 20 09:25:37: //8158/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:25:38 2013: <191>165316:    Conference Id=0xE5C, Source Interface=0x48A4F728, Source Call Id=8158,
Wed Mar 20 09:25:38 2013: <191>165317:    Destination Call Id=8159, Disposition=0x0, Tag=0x0
Wed Mar 20 09:25:38 2013: <191>165318: .Mar 20 09:25:37: //8159/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:25:38 2013: <191>165319:    Conference Id=0xE5C, Source Interface=0x4987FF98, Source Call Id=8159,
Wed Mar 20 09:25:38 2013: <191>165320:    Destination Call Id=8158, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:25:38 2013: <191>165321: .Mar 20 09:25:37: //8158/008F92424106/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:25:38 2013: <191>165322:    Conference Id=0xE5C, Source Interface=0x4987FF98, Source Call Id=8159,
Wed Mar 20 09:25:38 2013: <191>165323:    Destination Call Id=8158, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:25:38 2013: <191>165324: .Mar 20 09:25:37: //8158/008F92424106/CCAPI/ccConferenceCreate:
Wed Mar 20 09:25:38 2013: <191>165325:
Wed Mar 20 09:25:38 2013: <191>165326: Call Entry(Conference Id=0xE5C, Destination Call Id=8159)
Wed Mar 20 09:25:38 2013: <191>165327: .Mar 20 09:25:37: //8159/008F92424106/CCAPI/ccConferenceCreate:
Wed Mar 20 09:25:38 2013: <191>165328:    Call Entry(Conference Id=0xE5C, Destination Call Id=8158)
Wed Mar 20 09:25:38 2013: <191>165338: Conference Id=0xE5C, Call Id1=8158, Call Id2=8159
Wed Mar 20 09:25:38 2013: <191>165339: .Mar 20 09:25:37: //8158/008F92424106/CCAPI/ccCallNotify:
Wed Mar 20 09:25:38 2013: <191>165340:    Data Bitmask=0x7, Call Id=8158
Wed Mar 20 09:25:38 2013: <191>165341: .Mar 20 09:25:37: //8159/008F92424106/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:25:38 2013: <191>165342:    CallInfo(ccm detected=0)
Wed Mar 20 09:25:38 2013: <191>165343: .Mar 20 09:25:37: //8158/008F92424106/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:25:38 2013: <191>165344:    Destination Interface=0x4987FF98, Destination Call Id=8159, Source Call Id=8158,
Wed Mar 20 09:25:38 2013: <191>165345:    Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:25:38 2013: <191>165346:    Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:25:38 2013: <191>165347: .Mar 20 09:25:37: //8158/008F92424106/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:25:38 2013: <191>165348:    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:25:38 2013: <191>165349:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:25:38 2013: <191>165350: .Mar 20 09:25:37: //8158/008F92424106/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:25:38 2013: <191>165351:    Destination Interface=0x4987FF98, Destination Call Id=8159, Source Call Id=8158,
Wed Mar 20 09:25:38 2013: <191>165352:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:25:38 2013: <191>165353:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=8026)
Wed Mar 20 09:25:38 2013: <191>165354: .Mar 20 09:25:37: //8159/008F92424106/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:25:38 2013: <191>165355:    Destination Interface=0x48A4F728, Destination Call Id=8158, Source Call Id=8159,
Wed Mar 20 09:25:38 2013: <191>165356:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:25:38 2013: <191>165357:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=8026)
Wed Mar 20 09:25:38 2013: <191>165358: .Mar 20 09:25:37: //8159/008F92424106/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:25:38 2013: <191>165359:    Call Id=8159
Wed Mar 20 09:25:38 2013: <191>165360: .Mar 20 09:25:37: //8159/008F92424106/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:25:38 2013: <191>165361:    Call Entry(Context=0x4BA6E758)
Wed Mar 20 09:25:38 2013: <191>165362: .Mar 20 09:25:37: //8159/008F92424106/CCAPI/cc_api_call_connected:
Wed Mar 20 09:25:38 2013: <191>165363:    Interface=0x4987FF98, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
Wed Mar 20 09:25:38 2013: <191>165364:    Connection Handle=0
Wed Mar 20 09:25:38 2013: <191>165365: .Mar 20 09:25:37: //8159/008F92424106/CCAPI/cc_api_call_connected:
Wed Mar 20 09:25:38 2013: <191>165366:    Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:25:38 2013: <191>165367: .Mar 20 09:25:37: //8158/008F92424106/CCAPI/ccCallConnect:
Wed Mar 20 09:25:38 2013: <191>165368:    Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
Wed Mar 20 09:25:38 2013: <191>165369: .Mar 20 09:25:37: //8159/008F92424106/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:25:38 2013: <191>165370:    CallInfo(ccm detected=0)
Wed Mar 20 09:25:39 2013: <191>165371: .Mar 20 09:25:37: //8158/008F92424106/CCAPI/ccCallConnect:
Wed Mar 20 09:25:39 2013: <191>165372:    Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:25:39 2013: <191>165373: .Mar 20 09:25:37: //8158/008F92424106/CCAPI/ccCallNotify:
Wed Mar 20 09:25:39 2013: <191>165374:    Data Bitmask=0x7, Call Id=8158
Wed Mar 20 09:25:39 2013: <191>165375: .Mar 20 09:25:37: //8159/008F92424106/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:25:39 2013: <191>165376:    CallInfo(ccm detected=0)
Wed Mar 20 09:26:23 2013: <191>165378:    cc_api_call_setup_ind_common:
Wed Mar 20 09:26:23 2013: <191>165377: .Mar 20 09:26:21: //-1/355ACD39B3F9/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:26:23 2013: <191>165379:    cisco-username=
Wed Mar 20 09:26:23 2013: <191>165380:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:26:23 2013: <191>165381:    cisco-ani=
Wed Mar 20 09:26:23 2013: <191>165382:    cisco-anitype=0
Wed Mar 20 09:26:23 2013: <191>165383:    cisco-aniplan=0
Wed Mar 20 09:26:23 2013: <191>165384:    cisco-anipi=0
Wed Mar 20 09:26:23 2013: <191>165385:    cisco-anisi=0
Wed Mar 20 09:26:23 2013: <191>165386:    dest=1811032099
Wed Mar 20 09:26:23 2013: <191>165387:    cisco-desttype=0
Wed Mar 20 09:26:23 2013: <191>165388:    cisco-destplan=0
Wed Mar 20 09:26:23 2013: <191>165389:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:26:23 2013: <191>165390:    cisco-rdn=
Wed Mar 20 09:26:23 2013: <191>165391:    cisco-lastrdn=
Wed Mar 20 09:26:23 2013: <191>165392:    cisco-rdntype=0
Wed Mar 20 09:26:23 2013: <191>165393:    cisco-rdnplan=0
Wed Mar 20 09:26:23 2013: <191>165394:    cisco-rdnpi=0
Wed Mar 20 09:26:23 2013: <191>165395:    cisco-rdnsi=0
Wed Mar 20 09:26:23 2013: <191>165396:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:26:23 2013: <191>165397:    final_redirectNumber =
Wed Mar 20 09:26:23 2013: <191>165398:    hunt_group_timeout =0
Wed Mar 20 09:26:23 2013: <191>165399:
Wed Mar 20 09:26:23 2013: <191>165400: .Mar 20 09:26:21: //-1/355ACD39B3F9/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:26:23 2013: <191>165401:
Wed Mar 20 09:26:23 2013: <191>165402: Interface=0x498845E0, Call Info(
Wed Mar 20 09:26:23 2013: <191>165403:    Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:26:23 2013: <191>165404:    Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:26:23 2013: <191>165405:    Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Wed Mar 20 09:26:23 2013: <191>165406:    Incoming Dial-peer=50, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Wed Mar 20 09:26:23 2013: <191>165407:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:26:23 2013: <191>165408: .Mar 20 09:26:21: //-1/355ACD39B3F9/CCAPI/ccCheckClipClir:
Wed Mar 20 09:26:23 2013: <191>165409:    In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:26:23 2013: <191>165410: .Mar 20 09:26:21: //-1/355ACD39B3F9/CCAPI/ccCheckClipClir:
Wed Mar 20 09:26:23 2013: <191>165411:    Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:26:23 2013: <191>165412: .Mar 20 09:26:21: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:26:23 2013: <191>165413:
Wed Mar 20 09:26:23 2013: <191>165414: .Mar 20 09:26:21: :cc_get_feature_vsa malloc success
Wed Mar 20 09:26:23 2013: <191>165415: .Mar 20 09:26:21: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:26:23 2013: <191>165416:
Wed Mar 20 09:26:23 2013: <191>165417: .Mar 20 09:26:21:  cc_get_feature_vsa count is 3
Wed Mar 20 09:26:23 2013: <191>165418: .Mar 20 09:26:21: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:26:23 2013: <191>165419:
Wed Mar 20 09:26:23 2013: <191>165420: .Mar 20 09:26:21: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203247912,feature_id:8160
Wed Mar 20 09:26:23 2013: <191>165421: .Mar 20 09:26:21: //8160/355ACD39B3F9/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:26:23 2013: <191>165422:
Wed Mar 20 09:26:23 2013: <191>165423: Set Up Event Sent;
Wed Mar 20 09:26:23 2013: <191>165424:    Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:26:23 2013: <191>165428: .Mar 20 09:26:21: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Wed Mar 20 09:26:23 2013: <191>165432: .Mar 20 09:26:21: //8160/355ACD39B3F9/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:26:23 2013: <191>165433:    >>>>CCAPI handed cid 8160 with tag 50 to app "_ManagedAppProcess_Default"
Wed Mar 20 09:26:23 2013: <191>165437: .Mar 20 09:26:21: //8160/355ACD39B3F9/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:26:23 2013: <191>165448:    Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:26:23 2013: <191>165449:    Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:26:23 2013: <191>165450:    Redirect Number=, Display Info=Linha_3325-1786
Wed Mar 20 09:26:23 2013: <191>165451:    Account Number=, Final Destination Flag=TRUE,
Wed Mar 20 09:26:23 2013: <191>165452:    Guid=355ACD39-9090-11E2-B3F9-DE08FC69A21F, Outgoing Dial-peer=3000
Wed Mar 20 09:26:23 2013: <191>165457:    cisco-ani=
Wed Mar 20 09:26:23 2013: <191>165460:    cisco-anipi=0
Wed Mar 20 09:26:23 2013: <191>165462:    cisco-anisi=0
Wed Mar 20 09:26:23 2013: <191>165466:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:26:23 2013: <191>165472:    cisco-rdnsi=0
Wed Mar 20 09:26:23 2013: <191>165473:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:26:23 2013: <191>165476:
Wed Mar 20 09:26:23 2013: <191>165489: .Mar 20 09:26:21:  cc_get_feature_vsa count is 4
Wed Mar 20 09:26:23 2013: <191>165490: .Mar 20 09:26:21: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:26:23 2013: <191>165491:
Wed Mar 20 09:26:23 2013: <191>165492: .Mar 20 09:26:21: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203247688,feature_id:8161
Wed Mar 20 09:26:23 2013: <191>165493: .Mar 20 09:26:21: //8161/355ACD39B3F9/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:26:23 2013: <191>165494:    SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Wed Mar 20 09:26:23 2013: <191>165495: .Mar 20 09:26:21: //8161/355ACD39B3F9/CCAPI/ccCallSetContext:
Wed Mar 20 09:26:23 2013: <191>165496:    Context=0x4BA66220
Wed Mar 20 09:26:23 2013: <191>165497: .Mar 20 09:26:21: //8160/355ACD39B3F9/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:26:23 2013: <191>165498:    Outgoing Dial-peer=3000
Wed Mar 20 09:26:23 2013: <191>165499: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:26:23 2013: <191>165500:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:26:23 2013: <191>165501: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:26:23 2013: <191>165502:    Interface=0x48A4F728, Progress Indication=NULL(0)
Wed Mar 20 09:26:23 2013: <191>165503: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:26:23 2013: <191>165504:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:26:23 2013: <191>165505: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_set_delay_xport:
Wed Mar 20 09:26:23 2013: <191>165506:    CallInfo(delay xport=TRUE)
Wed Mar 20 09:26:23 2013: <191>165507: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_call_alert:
Wed Mar 20 09:26:23 2013: <191>165508:    Interface=0x48A4F728, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:26:23 2013: <191>165509: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_call_alert:
Wed Mar 20 09:26:23 2013: <191>165510:    Call Entry(Retry Count=0, Responsed=TRUE)
Wed Mar 20 09:26:23 2013: <191>165511: .Mar 20 09:26:22: //8160/355ACD39B3F9/CCAPI/ccCallAlert:
Wed Mar 20 09:26:23 2013: <191>165512:
Wed Mar 20 09:26:23 2013: <191>165513: Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:26:23 2013: <191>165514: .Mar 20 09:26:22: //8160/355ACD39B3F9/CCAPI/ccCallAlert:
Wed Mar 20 09:26:23 2013: <191>165515:    Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Wed Mar 20 09:26:23 2013: <191>165516: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:26:23 2013: <191>165517:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:26:23 2013: <191>165518: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_call_notify:
Wed Mar 20 09:26:23 2013: <191>165519:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8161
Wed Mar 20 09:26:23 2013: <191>165520: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/ccIsInfoRingback:
Wed Mar 20 09:26:23 2013: <191>165521:    Returning dpRingBack=0
Wed Mar 20 09:26:23 2013: <191>165522: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:26:23 2013: <191>165523:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:26:23 2013: <191>165524: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:26:23 2013: <191>165525:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:26:23 2013: <191>165526: .Mar 20 09:26:22: //8160/355ACD39B3F9/CCAPI/ccCallNotify:
Wed Mar 20 09:26:23 2013: <191>165527:    Data Bitmask=0x5, Call Id=8160
Wed Mar 20 09:26:23 2013: <191>165528: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_call_connected:
Wed Mar 20 09:26:23 2013: <191>165529:    Interface=0x48A4F728, Data Bitmask=0x0, Progress Indication=NULL(0),
Wed Mar 20 09:26:23 2013: <191>165530:    Connection Handle=0
Wed Mar 20 09:26:23 2013: <191>165531: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_call_connected:
Wed Mar 20 09:26:23 2013: <191>165532:    Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:26:23 2013: <191>165533: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:26:23 2013: <191>165534:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:26:23 2013: <191>165535: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_call_notify:
Wed Mar 20 09:26:23 2013: <191>165536:
Wed Mar 20 09:26:23 2013: <191>165537: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8161
Wed Mar 20 09:26:23 2013: <191>165538: .Mar 20 09:26:22: //8160/355ACD39B3F9/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:26:23 2013: <191>165539:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:26:23 2013: <191>165540:    Tone Direction=Network, Params=0x0, Call Id=8160
Wed Mar 20 09:26:23 2013: <191>165541: .Mar 20 09:26:22: //8160/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:26:23 2013: <191>165542:    (confID=0x4BB01CD8, callID1=0x1FE0, callID2=0x1FE1, tag=0x0)
Wed Mar 20 09:26:23 2013: <191>165543: .Mar 20 09:26:22: //8160/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:26:23 2013: <191>165544:    (confID=0x4BB01CD8, callID1=0x1FE0, gcid=355ACD39-909011E2-B3F9DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:26:23 2013: <191>165545: .Mar 20 09:26:22: //8161/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:26:23 2013: <191>165546:    (confID=0x4BB01CD8, callID2=0x1FE1, gcid=355ACD39-909011E2-B3F9DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:26:23 2013: <191>165547: .Mar 20 09:26:22: //8160/355ACD39B3F9/CCAPI/ccConferenceCreate:
Wed Mar 20 09:26:23 2013: <191>165548:    Conference Id=0x4BB01CD8, Call Id1=8160, Call Id2=8161, Tag=0x0
Wed Mar 20 09:26:23 2013: <191>165549: .Mar 20 09:26:22: //8160/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:26:23 2013: <191>165550:    Conference Id=0xE5D, Source Interface=0x498845E0, Source Call Id=8160,
Wed Mar 20 09:26:23 2013: <191>165551:    Destination Call Id=8161, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:26:23 2013: <191>165552: .Mar 20 09:26:22: //8161/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:26:23 2013: <191>165553:
Wed Mar 20 09:26:23 2013: <191>165554: .Mar 20 09:26:22: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:26:23 2013: <191>165555: .Mar 20 09:26:22: //8161/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:26:23 2013: <191>165556:    Conference Id=0xE5D, Source Interface=0x48A4F728, Source Call Id=8161,
Wed Mar 20 09:26:23 2013: <191>165557:    Destination Call Id=8160, Disposition=0x0, Tag=0x0
Wed Mar 20 09:26:23 2013: <191>165558: .Mar 20 09:26:22: //8160/355ACD39B3F9/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:26:23 2013: <191>165559:    Conference Id=0xE5D, Source Interface=0x48A4F728, Source Call Id=8161,
Wed Mar 20 09:26:23 2013: <191>165560:    Destination Call Id=8160, Disposition=0x0, Tag=0x0
Wed Mar 20 09:26:23 2013: <191>165561: .Mar 20 09:26:22: //8160/355ACD39B3F9/CCAPI/ccConferenceCreate:
Wed Mar 20 09:26:23 2013: <191>165563: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/ccConferenceCreate:
Wed Mar 20 09:26:23 2013: <191>165564:    Call Entry(Conference Id=0xE5D, Destination Call Id=8160)
Wed Mar 20 09:26:23 2013: <191>165568:    Modem=0x2, Codec Bytes=20, Signal Type=3)
Wed Mar 20 09:26:23 2013: <191>165569: .Mar 20 09:26:22: //8160/355ACD39B3F9/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:26:23 2013: <191>165580: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:26:23 2013: <191>165581:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:26:23 2013: <191>165582: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:26:23 2013: <191>165583:    Destination Interface=0x498845E0, Destination Call Id=8160, Source Call Id=8161,
Wed Mar 20 09:26:23 2013: <191>165584:    Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:26:23 2013: <191>165594: .Mar 20 09:26:22: //8160/355ACD39B3F9/CCAPI/ccCallNotify:
Wed Mar 20 09:26:23 2013: <191>165595:    Data Bitmask=0x5, Call Id=8160
Wed Mar 20 09:26:23 2013: <191>165598: .Mar 20 09:26:22: //8160/355ACD39B3F9/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:26:23 2013: <191>165599:    Call Entry(Context=0x4BA75988)
Wed Mar 20 09:26:23 2013: <191>165600: .Mar 20 09:26:22: //8160/355ACD39B3F9/CCAPI/ccCallConnect:
Wed Mar 20 09:26:23 2013: <191>165603:
Wed Mar 20 09:26:24 2013: <191>165604: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:26:34 2013: <191>165605: .Mar 20 09:26:33: //8161/355ACD39B3F9/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:26:34 2013: <191>165606:    Interface=0x0, Call Id=8161
Wed Mar 20 09:26:34 2013: <191>165607: .Mar 20 09:26:33: //8161/355ACD39B3F9/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:26:34 2013: <191>165608:    Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:26:34 2013: <191>165609: .Mar 20 09:26:33: //8161/355ACD39B3F9/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:26:34 2013: <191>165610:    Interface=0x48A4F728, Signal Indication=NOT PRESENT(255)
Wed Mar 20 09:26:34 2013: <191>165611: .Mar 20 09:26:33: //8160/355ACD39B3F9/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:26:34 2013: <191>165612:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:26:34 2013: <191>165613:    Tone Direction=Network, Params=0x0, Call Id=8160
Wed Mar 20 09:26:34 2013: <191>165614: .Mar 20 09:26:33: //8161/355ACD39B3F9/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:26:34 2013: <191>165615:    Interface=0x48A4F728, Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:26:34 2013: <191>165616: .Mar 20 09:26:33: //8160/355ACD39B3F9/CCAPI/ccCallUserInfo:
Wed Mar 20 09:26:34 2013: <191>165617:    Call Id=8160
Wed Mar 20 09:26:34 2013: <191>165618: .Mar 20 09:26:33: //8160/355ACD39B3F9/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:26:34 2013: <191>165619:    Stop Tone On Digit=FALSE, Tone=Ring Back,
Wed Mar 20 09:26:34 2013: <191>165620:    Tone Direction=Network, Params=0x0, Call Id=8160
Wed Mar 20 09:26:34 2013: <191>165621: .Mar 20 09:26:33: //8161/355ACD39B3F9/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:26:34 2013: <191>165622:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:26:34 2013: <191>165623: .Mar 20 09:26:33: //8161/355ACD39B3F9/CCAPI/cc_api_call_notify:
Wed Mar 20 09:26:34 2013: <191>165624:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8161
Wed Mar 20 09:26:34 2013: <191>165625: .Mar 20 09:26:33: //8161/355ACD39B3F9/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:26:34 2013: <191>165626:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:26:35 2013: <191>165627: .Mar 20 09:26:33: //8161/355ACD39B3F9/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:26:35 2013: <191>165628:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:26:35 2013: <191>165629: .Mar 20 09:26:33: //8160/355ACD39B3F9/CCAPI/ccCallNotify:
Wed Mar 20 09:26:35 2013: <191>165630:    Data Bitmask=0x5, Call Id=8160
Wed Mar 20 09:26:45 2013: <191>165631: .Mar 20 09:26:44: //8161/355ACD39B3F9/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:26:45 2013: <191>165632:    Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:26:45 2013: <191>165633: .Mar 20 09:26:44: //8161/355ACD39B3F9/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:26:45 2013: <191>165634:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:26:45 2013: <191>165635: .Mar 20 09:26:44: //8161/355ACD39B3F9/CCAPI/cc_api_call_notify:
Wed Mar 20 09:26:45 2013: <191>165636:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8161
Wed Mar 20 09:26:45 2013: <191>165637: .Mar 20 09:26:44: //8160/355ACD39B3F9/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:26:45 2013: <191>165638:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:26:45 2013: <191>165639:    Tone Direction=Network, Params=0x0, Call Id=8160
Wed Mar 20 09:26:45 2013: <191>165640: .Mar 20 09:26:44: //8161/355ACD39B3F9/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:26:45 2013: <191>165641:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:26:45 2013: <191>165642: .Mar 20 09:26:44: //8161/355ACD39B3F9/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:26:45 2013: <191>165643:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:26:45 2013: <191>165644: .Mar 20 09:26:44: //8160/355ACD39B3F9/CCAPI/ccCallNotify:
Wed Mar 20 09:26:45 2013: <191>165645:    Data Bitmask=0x5, Call Id=8160
Wed Mar 20 09:26:45 2013: <191>165646: .Mar 20 09:26:44: //8161/355ACD39B3F9/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:26:45 2013: <191>165647:    Destination Interface=0x498845E0, Destination Call Id=8160, Source Call Id=8161,
Wed Mar 20 09:26:45 2013: <191>165648:    Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:26:45 2013: <191>165649:    Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:26:45 2013: <191>165650: .Mar 20 09:26:44: //8161/355ACD39B3F9/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:26:45 2013: <191>165651:    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:26:45 2013: <191>165652:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:26:45 2013: <191>165653: .Mar 20 09:26:44: //8161/355ACD39B3F9/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:26:45 2013: <191>165654:
Wed Mar 20 09:26:45 2013: <191>165655: Destination Interface=0x498845E0, Destination Call Id=8160, Source Call Id=8161,
Wed Mar 20 09:26:45 2013: <191>165656:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:26:45 2013: <191>165657:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=507)
Wed Mar 20 09:26:45 2013: <191>165658: .Mar 20 09:26:44: //8160/355ACD39B3F9/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:26:45 2013: <191>165659:    Destination Interface=0x48A4F728, Destination Call Id=8161, Source Call Id=8160,
Wed Mar 20 09:26:45 2013: <191>165660:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:26:45 2013: <191>165661:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=507)
Wed Mar 20 09:26:45 2013: <191>165662: .Mar 20 09:26:44: //8160/355ACD39B3F9/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:26:45 2013: <191>165663:    Call Id=8160
Wed Mar 20 09:26:45 2013: <191>165664: .Mar 20 09:26:44: //8160/355ACD39B3F9/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:26:45 2013: <191>165665:
Wed Mar 20 09:26:46 2013: <191>165666: Call Entry(Context=0x4BA75988)
Wed Mar 20 09:26:55 2013: <191>165667: .Mar 20 09:26:54: //8158/008F92424106/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:26:55 2013: <191>165668:    Cause Value=16, Interface=0x48A4F728, Call Id=8158
Wed Mar 20 09:26:55 2013: <191>165669: .Mar 20 09:26:54: //8158/008F92424106/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:26:55 2013: <191>165670:    Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:26:55 2013: <191>165671: .Mar 20 09:26:54: //8158/008F92424106/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:26:55 2013: <191>165672:    Conference Id=0xE5C, Tag=0x0
Wed Mar 20 09:26:55 2013: <191>165673: .Mar 20 09:26:54: //8158/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:26:55 2013: <191>165674:    Conference Id=0xE5C, Source Interface=0x48A4F728, Source Call Id=8158,
Wed Mar 20 09:26:55 2013: <191>165675:    Destination Call Id=8159, Disposition=0x0, Tag=0x0
Wed Mar 20 09:26:55 2013: <191>165676: .Mar 20 09:26:54: //8159/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:26:55 2013: <191>165677:
Wed Mar 20 09:26:55 2013: <191>165678: Conference Id=0xE5C, Source Interface=0x4987FF98, Source Call Id=8159,
Wed Mar 20 09:26:55 2013: <191>165679:    Destination Call Id=8158, Disposition=0x0, Tag=0x0
Wed Mar 20 09:26:55 2013: <191>165680: .Mar 20 09:26:54: //8158/008F92424106/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:26:55 2013: <191>165681:    Conference Id=0xE5C, Source Interface=0x4987FF98, Source Call Id=8159,
Wed Mar 20 09:26:55 2013: <191>165682:    Destination Call Id=8158, Disposition=0x0, Tag=0x0
Wed Mar 20 09:26:55 2013: <191>165683: .Mar 20 09:26:54: //8158/008F92424106/CCAPI/ccCallDisconnect:
Wed Mar 20 09:26:55 2013: <191>165684:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:26:55 2013: <191>165685: .Mar 20 09:26:54: //8158/008F92424106/CCAPI/ccCallDisconnect:
Wed Mar 20 09:26:55 2013: <191>165686:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:26:55 2013: <191>165687: .Mar 20 09:26:54: //8158/008F92424106/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:26:55 2013: <191>165688:
Wed Mar 20 09:26:55 2013: <191>165689: Transfer Number Is Null
Wed Mar 20 09:26:55 2013: <191>165690: .Mar 20 09:26:54: //8159/008F92424106/CCAPI/ccCallDisconnect:
Wed Mar 20 09:26:55 2013: <191>165691:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:26:55 2013: <191>165692: .Mar 20 09:26:54: //8159/008F92424106/CCAPI/ccCallDisconnect:
Wed Mar 20 09:26:55 2013: <191>165693:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:26:55 2013: <191>165694: .Mar 20 09:26:54: //8159/008F92424106/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:26:55 2013: <191>165695:    Transfer Number Is Null
Wed Mar 20 09:26:55 2013: <191>165696: .Mar 20 09:26:54: //8158/008F92424106/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:26:55 2013: <191>165697:    Transfer Number Is Null
Wed Mar 20 09:26:55 2013: <191>165698: .Mar 20 09:26:54: //8158/008F92424106/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:26:55 2013: <191>165699:
Wed Mar 20 09:26:55 2013: <191>165700: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8158,
Wed Mar 20 09:26:55 2013: <191>165701:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:26:55 2013: <191>165702: .Mar 20 09:26:54: //8158/008F92424106/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:26:55 2013: <191>165703:    Call Disconnect Event Sent
Wed Mar 20 09:26:55 2013: <191>165704: .Mar 20 09:26:54: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:26:55 2013: <191>165705:
Wed Mar 20 09:26:55 2013: <191>165706: .Mar 20 09:26:54: :cc_free_feature_vsa freeing 47B81CE0
Wed Mar 20 09:26:55 2013: <191>165707: .Mar 20 09:26:54: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:26:55 2013: <191>165708:
Wed Mar 20 09:26:55 2013: <191>165709: .Mar 20 09:26:54:  vsacount in free is 3
Wed Mar 20 09:26:55 2013: <191>165710: .Mar 20 09:26:54: //8159/008F92424106/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:26:55 2013: <191>165711:    Disposition=0, Interface=0x4987FF98, Tag=0x0, Call Id=8159,
Wed Mar 20 09:26:55 2013: <191>165712:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:26:56 2013: <191>165713: .Mar 20 09:26:54: //8159/008F92424106/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:26:56 2013: <191>165714:    Call Disconnect Event Sent
Wed Mar 20 09:26:56 2013: <191>165715: .Mar 20 09:26:54: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:26:56 2013: <191>165716:
Wed Mar 20 09:26:56 2013: <191>165717: .Mar 20 09:26:54: :cc_free_feature_vsa freeing 47B81C00
Wed Mar 20 09:26:56 2013: <191>165718: .Mar 20 09:26:54: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:26:56 2013: <191>165719:
Wed Mar 20 09:26:56 2013: <191>165720: .Mar 20 09:26:54:  vsacount in free is 2
Wed Mar 20 09:27:30 2013: <191>165721: .Mar 20 09:27:29: //8161/355ACD39B3F9/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:27:30 2013: <191>165722:    Cause Value=16, Interface=0x48A4F728, Call Id=8161
Wed Mar 20 09:27:30 2013: <191>165723: .Mar 20 09:27:29: //8161/355ACD39B3F9/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:27:30 2013: <191>165724:    Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:27:30 2013: <191>165725: .Mar 20 09:27:29: //8160/355ACD39B3F9/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:27:30 2013: <191>165726:    Conference Id=0xE5D, Tag=0x0
Wed Mar 20 09:27:30 2013: <191>165727: .Mar 20 09:27:29: //8160/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:27:30 2013: <191>165728:    Conference Id=0xE5D, Source Interface=0x498845E0, Source Call Id=8160,
Wed Mar 20 09:27:30 2013: <191>165729:    Destination Call Id=8161, Disposition=0x0, Tag=0x0
Wed Mar 20 09:27:30 2013: <191>165730: .Mar 20 09:27:29: //8161/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:27:30 2013: <191>165731:
Wed Mar 20 09:27:30 2013: <191>165732: Conference Id=0xE5D, Source Interface=0x48A4F728, Source Call Id=8161,
Wed Mar 20 09:27:30 2013: <191>165733:    Destination Call Id=8160, Disposition=0x0, Tag=0x0
Wed Mar 20 09:27:30 2013: <191>165734: .Mar 20 09:27:29: //8160/355ACD39B3F9/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:27:30 2013: <191>165735:    Conference Id=0xE5D, Source Interface=0x48A4F728, Source Call Id=8161,
Wed Mar 20 09:27:30 2013: <191>165736:    Destination Call Id=8160, Disposition=0x0, Tag=0x0
Wed Mar 20 09:27:30 2013: <191>165737: .Mar 20 09:27:29: //8160/355ACD39B3F9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:27:30 2013: <191>165738:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:27:30 2013: <191>165739: .Mar 20 09:27:29: //8160/355ACD39B3F9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:27:30 2013: <191>165740:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:27:30 2013: <191>165741: .Mar 20 09:27:29: //8160/355ACD39B3F9/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:27:30 2013: <191>165742:
Wed Mar 20 09:27:30 2013: <191>165743: Transfer Number Is Null
Wed Mar 20 09:27:30 2013: <191>165744: .Mar 20 09:27:29: //8161/355ACD39B3F9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:27:30 2013: <191>165745:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:27:30 2013: <191>165746: .Mar 20 09:27:29: //8161/355ACD39B3F9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:27:30 2013: <191>165747:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:27:30 2013: <191>165748: .Mar 20 09:27:29: //8161/355ACD39B3F9/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:27:30 2013: <191>165749:    Transfer Number Is Null
Wed Mar 20 09:27:30 2013: <191>165750: .Mar 20 09:27:29: //8161/355ACD39B3F9/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:27:30 2013: <191>165751:    Transfer Number Is Null
Wed Mar 20 09:27:30 2013: <191>165752: .Mar 20 09:27:29: //8161/355ACD39B3F9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:27:30 2013: <191>165753:
Wed Mar 20 09:27:30 2013: <191>165754: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8161,
Wed Mar 20 09:27:30 2013: <191>165755:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:27:30 2013: <191>165756: .Mar 20 09:27:29: //8161/355ACD39B3F9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:27:30 2013: <191>165757:    Call Disconnect Event Sent
Wed Mar 20 09:27:30 2013: <191>165758: .Mar 20 09:27:29: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:27:30 2013: <191>165759:
Wed Mar 20 09:27:30 2013: <191>165760: .Mar 20 09:27:29: :cc_free_feature_vsa freeing 47B81A40
Wed Mar 20 09:27:30 2013: <191>165761: .Mar 20 09:27:29: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:27:30 2013: <191>165762:
Wed Mar 20 09:27:30 2013: <191>165763: .Mar 20 09:27:29:  vsacount in free is 1
Wed Mar 20 09:27:30 2013: <191>165764: .Mar 20 09:27:29: //8160/355ACD39B3F9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:27:30 2013: <191>165765:    Disposition=0, Interface=0x498845E0, Tag=0x0, Call Id=8160,
Wed Mar 20 09:27:30 2013: <191>165766:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:27:31 2013: <191>165767: .Mar 20 09:27:29: //8160/355ACD39B3F9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:27:31 2013: <191>165768:    Call Disconnect Event Sent
Wed Mar 20 09:27:31 2013: <191>165769: .Mar 20 09:27:29: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:27:31 2013: <191>165770:
Wed Mar 20 09:27:31 2013: <191>165771: .Mar 20 09:27:29: :cc_free_feature_vsa freeing 47B81B20
Wed Mar 20 09:27:31 2013: <191>165772: .Mar 20 09:27:29: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:27:31 2013: <191>165773:
Wed Mar 20 09:27:31 2013: <191>165774: .Mar 20 09:27:29:  vsacount in free is 0
Wed Mar 20 09:27:54 2013: <190>165775: .Mar 20 09:27:52: %IPPHONE-6-UNREGISTER_NORMAL: ephone-7:SEP002699442108 IP:10.229.64.50 Socket:5 DeviceType:Phone has unregistered normally.
Wed Mar 20 09:28:18 2013: <191>165776: .Mar 20 09:28:16: //-1/8062BAA34206/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:28:18 2013: <191>165777:    cc_api_call_setup_ind_common:
Wed Mar 20 09:28:18 2013: <191>165778:    cisco-username=PF-Assis-Margarida
Wed Mar 20 09:28:18 2013: <191>165779:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:28:18 2013: <191>165780:    cisco-ani=1811032010
Wed Mar 20 09:28:18 2013: <191>165781:    cisco-anitype=0
Wed Mar 20 09:28:18 2013: <191>165782:    cisco-aniplan=0
Wed Mar 20 09:28:18 2013: <191>165783:    cisco-anipi=0
Wed Mar 20 09:28:18 2013: <191>165784:    cisco-anisi=1
Wed Mar 20 09:28:18 2013: <191>165785:    dest=033225465
Wed Mar 20 09:28:18 2013: <191>165786:    cisco-desttype=0
Wed Mar 20 09:28:18 2013: <191>165787:    cisco-destplan=0
Wed Mar 20 09:28:18 2013: <191>165788:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:28:18 2013: <191>165789:    cisco-rdn=
Wed Mar 20 09:28:18 2013: <191>165790:    cisco-lastrdn=
Wed Mar 20 09:28:18 2013: <191>165791:    cisco-rdntype=-1
Wed Mar 20 09:28:18 2013: <191>165792:    cisco-rdnplan=-1
Wed Mar 20 09:28:18 2013: <191>165793:    cisco-rdnpi=-1
Wed Mar 20 09:28:18 2013: <191>165794:    cisco-rdnsi=-1
Wed Mar 20 09:28:18 2013: <191>165795:    cisco-redirectreason=-1   fwd_final_type =0
Wed Mar 20 09:28:18 2013: <191>165796:    final_redirectNumber =
Wed Mar 20 09:28:18 2013: <191>165797:    hunt_group_timeout =0
Wed Mar 20 09:28:18 2013: <191>165798:
Wed Mar 20 09:28:18 2013: <191>165799: .Mar 20 09:28:16: //-1/8062BAA34206/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:28:18 2013: <191>165800:
Wed Mar 20 09:28:18 2013: <191>165801: Interface=0x48A4F728, Call Info(
Wed Mar 20 09:28:18 2013: <191>165802:    Calling Number=1811032010,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Wed Mar 20 09:28:18 2013: <191>165803:    Called Number=033225465(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:28:18 2013: <191>165804:    Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Wed Mar 20 09:28:18 2013: <191>165805:    Incoming Dial-peer=200, Progress Indication=NULL(0), Calling IE Present=TRUE,
Wed Mar 20 09:28:18 2013: <191>165806:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=8162
Wed Mar 20 09:28:18 2013: <191>165807: .Mar 20 09:28:16: //-1/8062BAA34206/CCAPI/ccCheckClipClir:
Wed Mar 20 09:28:18 2013: <191>165808:    In: Calling Number=1811032010(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Wed Mar 20 09:28:18 2013: <191>165809: .Mar 20 09:28:16: //-1/8062BAA34206/CCAPI/ccCheckClipClir:
Wed Mar 20 09:28:18 2013: <191>165810:    Out: Calling Number=1811032010(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Wed Mar 20 09:28:18 2013: <191>165811: .Mar 20 09:28:16: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:28:18 2013: <191>165812:
Wed Mar 20 09:28:18 2013: <191>165813: .Mar 20 09:28:16: :cc_get_feature_vsa malloc success
Wed Mar 20 09:28:18 2013: <191>165814: .Mar 20 09:28:16: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:28:18 2013: <191>165815:
Wed Mar 20 09:28:18 2013: <191>165816: .Mar 20 09:28:16:  cc_get_feature_vsa count is 1
Wed Mar 20 09:28:18 2013: <191>165817: .Mar 20 09:28:16: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:28:18 2013: <191>165818:
Wed Mar 20 09:28:18 2013: <191>165819: .Mar 20 09:28:16: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203322344,feature_id:8162
Wed Mar 20 09:28:18 2013: <191>165820: .Mar 20 09:28:16: //8162/8062BAA34206/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:28:18 2013: <191>165821:
Wed Mar 20 09:28:18 2013: <191>165822: Set Up Event Sent;
Wed Mar 20 09:28:18 2013: <191>165824:    Called Number=033225465(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:28:18 2013: <191>165828:    Try with the demoted called number 033225465
Wed Mar 20 09:28:18 2013: <191>165832:    >>>>CCAPI handed cid 8162 with tag 200 to app "_ManagedAppProcess_Default"
Wed Mar 20 09:28:18 2013: <191>165833: .Mar 20 09:28:16: //8162/8062BAA34206/CCAPI/ccCallProceeding:
Wed Mar 20 09:28:18 2013: <191>165838: .Mar 20 09:28:16: //8162/8062BAA34206/CCAPI/ccCheckClipClir:
Wed Mar 20 09:28:18 2013: <191>165839:    In: Calling Number=1811032010(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Wed Mar 20 09:28:18 2013: <191>165840: .Mar 20 09:28:16: //8162/8062BAA34206/CCAPI/ccCheckClipClir:
Wed Mar 20 09:28:18 2013: <191>165841:    Out: Calling Number=1811032010(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Wed Mar 20 09:28:18 2013: <191>165842: .Mar 20 09:28:16: //8162/8062BAA34206/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:28:18 2013: <191>165843:
Wed Mar 20 09:28:18 2013: <191>165855:    cisco-ani=1811032010
Wed Mar 20 09:28:18 2013: <191>165856:    cisco-anitype=0
Wed Mar 20 09:28:18 2013: <191>165857:
Wed Mar 20 09:28:18 2013: <191>165860:    cisco-anisi=1
Wed Mar 20 09:28:18 2013: <191>165862:    cisco-desttype=0
Wed Mar 20 09:28:18 2013: <191>165863:    cisco-destplan=0
Wed Mar 20 09:28:18 2013: <191>165866:    cisco-lastrdn=
Wed Mar 20 09:28:18 2013: <191>165871:    cisco-redirectreason=-1   fwd_final_type =0
Wed Mar 20 09:28:18 2013: <191>165875: .Mar 20 09:28:16: //8162/8062BAA34206/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:28:19 2013: <191>165887: .Mar 20 09:28:16:  cc_get_feature_vsa count is 2
Wed Mar 20 09:28:19 2013: <191>165888: .Mar 20 09:28:16: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:28:19 2013: <191>165889:
Wed Mar 20 09:28:19 2013: <191>165890: .Mar 20 09:28:16: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203322120,feature_id:8163
Wed Mar 20 09:28:19 2013: <191>165891: .Mar 20 09:28:16: //8163/8062BAA34206/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:28:19 2013: <191>165892:    SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Wed Mar 20 09:28:19 2013: <191>165893: .Mar 20 09:28:16: //8163/8062BAA34206/CCAPI/ccCallSetContext:
Wed Mar 20 09:28:19 2013: <191>165894:    Context=0x4BA70D68
Wed Mar 20 09:28:19 2013: <191>165895: .Mar 20 09:28:16: //8162/8062BAA34206/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:28:19 2013: <191>165896:    Outgoing Dial-peer=18
Wed Mar 20 09:28:19 2013: <191>165897: .Mar 20 09:28:16: //8163/8062BAA34206/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:28:19 2013: <191>165898:    Interface=0x4987FF98, Progress Indication=NULL(0)
Wed Mar 20 09:28:20 2013: <191>165899: .Mar 20 09:28:19: //8163/8062BAA34206/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:28:20 2013: <191>165900:    Interface=0x4987FF98, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
Wed Mar 20 09:28:20 2013: <191>165901:    Cause Value=0
Wed Mar 20 09:28:20 2013: <191>165902: .Mar 20 09:28:19: //8163/8062BAA34206/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:28:20 2013: <191>165903:    Call Entry(Responsed=TRUE)
Wed Mar 20 09:28:20 2013: <191>165904: .Mar 20 09:28:19: //8162/8062BAA34206/CCAPI/ccCallCutProgress:
Wed Mar 20 09:28:20 2013: <191>165905:    Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
Wed Mar 20 09:28:20 2013: <191>165906:    Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Wed Mar 20 09:28:20 2013: <191>165907: .Mar 20 09:28:19: //8162/8062BAA34206/CCAPI/ccCallCutProgress:
Wed Mar 20 09:28:20 2013: <191>165908:    Call Entry(Responsed=TRUE)
Wed Mar 20 09:28:20 2013: <191>165909: .Mar 20 09:28:19: //8163/8062BAA34206/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:28:20 2013: <191>165910:    CallInfo(ccm detected=0)
Wed Mar 20 09:28:20 2013: <191>165911: .Mar 20 09:28:19: //8162/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:28:20 2013: <191>165912:    (confID=0x4BB01E40, callID1=0x1FE2, callID2=0x1FE3, tag=0x0)
Wed Mar 20 09:28:21 2013: <191>165913: .Mar 20 09:28:19: //8162/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:28:21 2013: <191>165914:    (confID=0x4BB01E40, callID1=0x1FE2, gcid=0-0-0-0, tag=0x0)
Wed Mar 20 09:28:21 2013: <191>165915: .Mar 20 09:28:19: //8163/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:28:21 2013: <191>165916:    (confID=0x4BB01E40, callID2=0x1FE3, gcid=0-0-0-0, tag=0x0)
Wed Mar 20 09:28:21 2013: <191>165917: .Mar 20 09:28:19: //8162/8062BAA34206/CCAPI/ccConferenceCreate:
Wed Mar 20 09:28:21 2013: <191>165918:    Conference Id=0x4BB01E40, Call Id1=8162, Call Id2=8163, Tag=0x0
Wed Mar 20 09:28:21 2013: <191>165919: .Mar 20 09:28:19: //8162/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:28:21 2013: <191>165920:
Wed Mar 20 09:28:21 2013: <191>165921: .Mar 20 09:28:19: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:28:21 2013: <191>165922: .Mar 20 09:28:19: //8162/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:28:21 2013: <191>165923:    Conference Id=0xE5E, Source Interface=0x48A4F728, Source Call Id=8162,
Wed Mar 20 09:28:21 2013: <191>165924:    Destination Call Id=8163, Disposition=0x0, Tag=0x0
Wed Mar 20 09:28:21 2013: <191>165925: .Mar 20 09:28:19: //8163/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:28:21 2013: <191>165926:    Conference Id=0xE5E, Source Interface=0x4987FF98, Source Call Id=8163,
Wed Mar 20 09:28:21 2013: <191>165927:    Destination Call Id=8162, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:28:21 2013: <191>165928: .Mar 20 09:28:19: //8162/8062BAA34206/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:28:21 2013: <191>165929:    Conference Id=0xE5E, Source Interface=0x4987FF98, Source Call Id=8163,
Wed Mar 20 09:28:21 2013: <191>165930:    Destination Call Id=8162, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:28:21 2013: <191>165931: .Mar 20 09:28:19: //8162/8062BAA34206/CCAPI/ccConferenceCreate:
Wed Mar 20 09:28:21 2013: <191>165932:
Wed Mar 20 09:28:21 2013: <191>165933: Call Entry(Conference Id=0xE5E, Destination Call Id=8163)
Wed Mar 20 09:28:21 2013: <191>165934: .Mar 20 09:28:19: //8163/8062BAA34206/CCAPI/ccConferenceCreate:
Wed Mar 20 09:28:21 2013: <191>165935:    Call Entry(Conference Id=0xE5E, Destination Call Id=8162)
Wed Mar 20 09:28:21 2013: <191>165945: Conference Id=0xE5E, Call Id1=8162, Call Id2=8163
Wed Mar 20 09:28:21 2013: <191>165946: .Mar 20 09:28:19: //8162/8062BAA34206/CCAPI/ccCallNotify:
Wed Mar 20 09:28:21 2013: <191>165947:    Data Bitmask=0x7, Call Id=8162
Wed Mar 20 09:28:21 2013: <191>165948: .Mar 20 09:28:19: //8163/8062BAA34206/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:28:21 2013: <191>165949:    CallInfo(ccm detected=0)
Wed Mar 20 09:28:21 2013: <191>165950: .Mar 20 09:28:19: //8162/8062BAA34206/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:28:21 2013: <191>165951:    Destination Interface=0x4987FF98, Destination Call Id=8163, Source Call Id=8162,
Wed Mar 20 09:28:21 2013: <191>165952:    Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:28:21 2013: <191>165953:    Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:28:21 2013: <191>165954: .Mar 20 09:28:19: //8162/8062BAA34206/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:28:21 2013: <191>165955:    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:28:21 2013: <191>165956:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:28:21 2013: <191>165957: .Mar 20 09:28:19: //8162/8062BAA34206/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:28:21 2013: <191>165958:    Destination Interface=0x4987FF98, Destination Call Id=8163, Source Call Id=8162,
Wed Mar 20 09:28:21 2013: <191>165959:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:28:21 2013: <191>165960:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=4671)
Wed Mar 20 09:28:21 2013: <191>165961: .Mar 20 09:28:19: //8163/8062BAA34206/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:28:21 2013: <191>165962:    Destination Interface=0x48A4F728, Destination Call Id=8162, Source Call Id=8163,
Wed Mar 20 09:28:21 2013: <191>165963:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:28:21 2013: <191>165964:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=4671)
Wed Mar 20 09:28:21 2013: <191>165965: .Mar 20 09:28:19: //8163/8062BAA34206/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:28:21 2013: <191>165966:    Call Id=8163
Wed Mar 20 09:28:21 2013: <191>165967: .Mar 20 09:28:19: //8163/8062BAA34206/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:28:21 2013: <191>165968:    Call Entry(Context=0x4BA70D68)
Wed Mar 20 09:28:21 2013: <191>165969: .Mar 20 09:28:19: //8163/8062BAA34206/CCAPI/cc_api_call_connected:
Wed Mar 20 09:28:21 2013: <191>165970:    Interface=0x4987FF98, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
Wed Mar 20 09:28:21 2013: <191>165971:    Connection Handle=0
Wed Mar 20 09:28:21 2013: <191>165972: .Mar 20 09:28:19: //8163/8062BAA34206/CCAPI/cc_api_call_connected:
Wed Mar 20 09:28:21 2013: <191>165973:    Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:28:21 2013: <191>165974: .Mar 20 09:28:19: //8162/8062BAA34206/CCAPI/ccCallConnect:
Wed Mar 20 09:28:21 2013: <191>165975:    Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
Wed Mar 20 09:28:21 2013: <191>165976: .Mar 20 09:28:19: //8163/8062BAA34206/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:28:21 2013: <191>165977:    CallInfo(ccm detected=0)
Wed Mar 20 09:28:22 2013: <191>165978: .Mar 20 09:28:19: //8162/8062BAA34206/CCAPI/ccCallConnect:
Wed Mar 20 09:28:22 2013: <191>165979:    Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:28:22 2013: <191>165980: .Mar 20 09:28:19: //8162/8062BAA34206/CCAPI/ccCallNotify:
Wed Mar 20 09:28:22 2013: <191>165981:    Data Bitmask=0x7, Call Id=8162
Wed Mar 20 09:28:22 2013: <191>165982: .Mar 20 09:28:19: //8163/8062BAA34206/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:28:22 2013: <191>165983:    CallInfo(ccm detected=0)
Wed Mar 20 09:28:39 2013: <191>165984: .Mar 20 09:28:38: //-1/867FF001B400/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:28:39 2013: <191>165985:    cc_api_call_setup_ind_common:
Wed Mar 20 09:28:39 2013: <191>165986:    cisco-username=
Wed Mar 20 09:28:39 2013: <191>165987:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:28:39 2013: <191>165988:    cisco-ani=
Wed Mar 20 09:28:39 2013: <191>165989:    cisco-anitype=0
Wed Mar 20 09:28:39 2013: <191>165990:    cisco-aniplan=0
Wed Mar 20 09:28:39 2013: <191>165991:    cisco-anipi=0
Wed Mar 20 09:28:39 2013: <191>165992:    cisco-anisi=0
Wed Mar 20 09:28:39 2013: <191>165993:    dest=1811032099
Wed Mar 20 09:28:39 2013: <191>165994:    cisco-desttype=0
Wed Mar 20 09:28:39 2013: <191>165995:    cisco-destplan=0
Wed Mar 20 09:28:39 2013: <191>165996:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:28:39 2013: <191>165997:    cisco-rdn=
Wed Mar 20 09:28:39 2013: <191>165998:    cisco-lastrdn=
Wed Mar 20 09:28:39 2013: <191>165999:    cisco-rdntype=0
Wed Mar 20 09:28:39 2013: <191>166000:    cisco-rdnplan=0
Wed Mar 20 09:28:39 2013: <191>166001:    cisco-rdnpi=0
Wed Mar 20 09:28:39 2013: <191>166002:    cisco-rdnsi=0
Wed Mar 20 09:28:39 2013: <191>166003:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:28:39 2013: <191>166004:    final_redirectNumber =
Wed Mar 20 09:28:39 2013: <191>166005:    hunt_group_timeout =0
Wed Mar 20 09:28:39 2013: <191>166006:
Wed Mar 20 09:28:39 2013: <191>166007: .Mar 20 09:28:38: //-1/867FF001B400/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:28:39 2013: <191>166008:
Wed Mar 20 09:28:39 2013: <191>166009: Interface=0x498845E0, Call Info(
Wed Mar 20 09:28:39 2013: <191>166010:    Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:28:39 2013: <191>166011:    Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:28:39 2013: <191>166012:    Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Wed Mar 20 09:28:39 2013: <191>166013:    Incoming Dial-peer=50, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Wed Mar 20 09:28:39 2013: <191>166014:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:28:39 2013: <191>166015: .Mar 20 09:28:38: //-1/867FF001B400/CCAPI/ccCheckClipClir:
Wed Mar 20 09:28:39 2013: <191>166016:    In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:28:39 2013: <191>166017: .Mar 20 09:28:38: //-1/867FF001B400/CCAPI/ccCheckClipClir:
Wed Mar 20 09:28:39 2013: <191>166018:    Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:28:39 2013: <191>166019: .Mar 20 09:28:38: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:28:39 2013: <191>166020:
Wed Mar 20 09:28:39 2013: <191>166021: .Mar 20 09:28:38: :cc_get_feature_vsa malloc success
Wed Mar 20 09:28:39 2013: <191>166022: .Mar 20 09:28:38: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:28:39 2013: <191>166023:
Wed Mar 20 09:28:39 2013: <191>166024: .Mar 20 09:28:38:  cc_get_feature_vsa count is 3
Wed Mar 20 09:28:39 2013: <191>166025: .Mar 20 09:28:38: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:28:39 2013: <191>166026:
Wed Mar 20 09:28:39 2013: <191>166027: .Mar 20 09:28:38: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203321896,feature_id:8164
Wed Mar 20 09:28:39 2013: <191>166028: .Mar 20 09:28:38: //8164/867FF001B400/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:28:39 2013: <191>166029:
Wed Mar 20 09:28:39 2013: <191>166030: Set Up Event Sent;
Wed Mar 20 09:28:39 2013: <191>166032:    Called Number=1811032099(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:28:39 2013: <191>166036:    Try with the demoted called number 1811032099
Wed Mar 20 09:28:39 2013: <191>166042:
Wed Mar 20 09:28:39 2013: <191>166043: Progress Indication=NULL(0)
Wed Mar 20 09:28:39 2013: <191>166044: .Mar 20 09:28:38: //8164/867FF001B400/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:28:39 2013: <191>166053: Destination Pattern=1811032099, Called Number=1811032099, Digit Strip=FALSE
Wed Mar 20 09:28:39 2013: <191>166054: .Mar 20 09:28:38: //8164/867FF001B400/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:28:39 2013: <191>166055:    Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:28:39 2013: <191>166056:    Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:28:39 2013: <191>166057:    Redirect Number=, Display Info=Linha_3325-1786
Wed Mar 20 09:28:39 2013: <191>166058:    Account Number=, Final Destination Flag=TRUE,
Wed Mar 20 09:28:39 2013: <191>166059:    Guid=867FF001-9090-11E2-B400-DE08FC69A21F, Outgoing Dial-peer=3000
Wed Mar 20 09:28:39 2013: <191>166067:    cisco-anipi=0
Wed Mar 20 09:28:39 2013: <191>166069:    cisco-anisi=0
Wed Mar 20 09:28:39 2013: <191>166073:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:28:39 2013: <191>166081:    final_redirectNumber =
Wed Mar 20 09:28:39 2013: <191>166082:    hunt_group_timeout =0
Wed Mar 20 09:28:39 2013: <191>166096: .Mar 20 09:28:38:  cc_get_feature_vsa count is 4
Wed Mar 20 09:28:39 2013: <191>166097: .Mar 20 09:28:38: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:28:39 2013: <191>166098:
Wed Mar 20 09:28:39 2013: <191>166099: .Mar 20 09:28:38: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203321672,feature_id:8165
Wed Mar 20 09:28:39 2013: <191>166100: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:28:39 2013: <191>166101:    SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Wed Mar 20 09:28:39 2013: <191>166102: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/ccCallSetContext:
Wed Mar 20 09:28:39 2013: <191>166103:    Context=0x4BA76C90
Wed Mar 20 09:28:39 2013: <191>166104: .Mar 20 09:28:38: //8164/867FF001B400/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:28:39 2013: <191>166105:    Outgoing Dial-peer=3000
Wed Mar 20 09:28:39 2013: <191>166106: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:28:39 2013: <191>166107:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:28:39 2013: <191>166108: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:28:39 2013: <191>166109:    Interface=0x48A4F728, Progress Indication=NULL(0)
Wed Mar 20 09:28:39 2013: <191>166110: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:28:39 2013: <191>166111:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:28:39 2013: <191>166112: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_set_delay_xport:
Wed Mar 20 09:28:39 2013: <191>166113:    CallInfo(delay xport=TRUE)
Wed Mar 20 09:28:39 2013: <191>166114: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_call_alert:
Wed Mar 20 09:28:39 2013: <191>166115:    Interface=0x48A4F728, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:28:39 2013: <191>166116: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_call_alert:
Wed Mar 20 09:28:39 2013: <191>166117:    Call Entry(Retry Count=0, Responsed=TRUE)
Wed Mar 20 09:28:39 2013: <191>166118: .Mar 20 09:28:38: //8164/867FF001B400/CCAPI/ccCallAlert:
Wed Mar 20 09:28:39 2013: <191>166119:
Wed Mar 20 09:28:39 2013: <191>166120: Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:28:39 2013: <191>166121: .Mar 20 09:28:38: //8164/867FF001B400/CCAPI/ccCallAlert:
Wed Mar 20 09:28:39 2013: <191>166122:    Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Wed Mar 20 09:28:39 2013: <191>166123: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:28:39 2013: <191>166124:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:28:39 2013: <191>166125: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_call_notify:
Wed Mar 20 09:28:39 2013: <191>166126:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8165
Wed Mar 20 09:28:39 2013: <191>166127: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/ccIsInfoRingback:
Wed Mar 20 09:28:39 2013: <191>166128:    Returning dpRingBack=0
Wed Mar 20 09:28:39 2013: <191>166129: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:28:39 2013: <191>166130:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:28:39 2013: <191>166131: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:28:39 2013: <191>166132:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:28:39 2013: <191>166133: .Mar 20 09:28:38: //8164/867FF001B400/CCAPI/ccCallNotify:
Wed Mar 20 09:28:39 2013: <191>166134:    Data Bitmask=0x5, Call Id=8164
Wed Mar 20 09:28:39 2013: <191>166135: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_call_connected:
Wed Mar 20 09:28:39 2013: <191>166136:    Interface=0x48A4F728, Data Bitmask=0x0, Progress Indication=NULL(0),
Wed Mar 20 09:28:39 2013: <191>166137:    Connection Handle=0
Wed Mar 20 09:28:39 2013: <191>166138: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_call_connected:
Wed Mar 20 09:28:39 2013: <191>166139:    Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:28:39 2013: <191>166140: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:28:39 2013: <191>166141:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:28:39 2013: <191>166142: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_call_notify:
Wed Mar 20 09:28:39 2013: <191>166143:
Wed Mar 20 09:28:39 2013: <191>166144: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8165
Wed Mar 20 09:28:39 2013: <191>166145: .Mar 20 09:28:38: //8164/867FF001B400/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:28:39 2013: <191>166146:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:28:39 2013: <191>166147:    Tone Direction=Network, Params=0x0, Call Id=8164
Wed Mar 20 09:28:39 2013: <191>166148: .Mar 20 09:28:38: //8164/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:28:39 2013: <191>166149:    (confID=0x4BB01DB0, callID1=0x1FE4, callID2=0x1FE5, tag=0x0)
Wed Mar 20 09:28:39 2013: <191>166150: .Mar 20 09:28:38: //8164/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:28:39 2013: <191>166151:    (confID=0x4BB01DB0, callID1=0x1FE4, gcid=867FF001-909011E2-B400DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:28:39 2013: <191>166152: .Mar 20 09:28:38: //8165/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:28:39 2013: <191>166153:    (confID=0x4BB01DB0, callID2=0x1FE5, gcid=867FF001-909011E2-B400DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:28:39 2013: <191>166154: .Mar 20 09:28:38: //8164/867FF001B400/CCAPI/ccConferenceCreate:
Wed Mar 20 09:28:39 2013: <191>166155:    Conference Id=0x4BB01DB0, Call Id1=8164, Call Id2=8165, Tag=0x0
Wed Mar 20 09:28:39 2013: <191>166156: .Mar 20 09:28:38: //8164/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:28:39 2013: <191>166157:    Conference Id=0xE5F, Source Interface=0x498845E0, Source Call Id=8164,
Wed Mar 20 09:28:39 2013: <191>166158:    Destination Call Id=8165, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:28:39 2013: <191>166159: .Mar 20 09:28:38: //8165/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:28:39 2013: <191>166160:
Wed Mar 20 09:28:39 2013: <191>166161: .Mar 20 09:28:38: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:28:39 2013: <191>166162: .Mar 20 09:28:38: //8165/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:28:39 2013: <191>166163:    Conference Id=0xE5F, Source Interface=0x48A4F728, Source Call Id=8165,
Wed Mar 20 09:28:39 2013: <191>166164:    Destination Call Id=8164, Disposition=0x0, Tag=0x0
Wed Mar 20 09:28:39 2013: <191>166165: .Mar 20 09:28:38: //8164/867FF001B400/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:28:39 2013: <191>166166:    Conference Id=0xE5F, Source Interface=0x48A4F728, Source Call Id=8165,
Wed Mar 20 09:28:39 2013: <191>166167:    Destination Call Id=8164, Disposition=0x0, Tag=0x0
Wed Mar 20 09:28:39 2013: <191>166168: .Mar 20 09:28:38: //8164/867FF001B400/CCAPI/ccConferenceCreate:
Wed Mar 20 09:28:39 2013: <191>166169:    Call Entry(Conference Id=0xE5F, Destination Call Id=8165)
Wed Mar 20 09:28:39 2013: <191>166170: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/ccConferenceCreate:
Wed Mar 20 09:28:39 2013: <191>166171:    Call Entry(Conference Id=0xE5F, Destination Call Id=8164)
Wed Mar 20 09:28:39 2013: <191>166180:    Conference Id=0xE5F, Call Id1=8164, Call Id2=8165
Wed Mar 20 09:28:39 2013: <191>166181: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:28:39 2013: <191>166182:    Destination Interface=0x498845E0, Destination Call Id=8164, Source Call Id=8165,
Wed Mar 20 09:28:39 2013: <191>166191:    Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:28:39 2013: <191>166192:    Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=1162)
Wed Mar 20 09:28:39 2013: <191>166193: .Mar 20 09:28:38: //8164/867FF001B400/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:28:39 2013: <191>166194:    Destination Interface=0x48A4F728, Destination Call Id=8165, Source Call Id=8164,
Wed Mar 20 09:28:39 2013: <191>166206:    Call Entry(Context=0x4BA7A5A8)
Wed Mar 20 09:28:40 2013: <191>166211: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:28:50 2013: <191>166212: .Mar 20 09:28:49: //8165/867FF001B400/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:28:50 2013: <191>166213:    Interface=0x0, Call Id=8165
Wed Mar 20 09:28:50 2013: <191>166214: .Mar 20 09:28:49: //8165/867FF001B400/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:28:50 2013: <191>166215:    Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:28:50 2013: <191>166216: .Mar 20 09:28:49: //8165/867FF001B400/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:28:50 2013: <191>166217:    Interface=0x48A4F728, Signal Indication=NOT PRESENT(255)
Wed Mar 20 09:28:50 2013: <191>166218: .Mar 20 09:28:49: //8164/867FF001B400/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:28:50 2013: <191>166219:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:28:50 2013: <191>166220:    Tone Direction=Network, Params=0x0, Call Id=8164
Wed Mar 20 09:28:50 2013: <191>166221: .Mar 20 09:28:49: //8165/867FF001B400/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:28:50 2013: <191>166222:    Interface=0x48A4F728, Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:28:50 2013: <191>166223: .Mar 20 09:28:49: //8164/867FF001B400/CCAPI/ccCallUserInfo:
Wed Mar 20 09:28:50 2013: <191>166224:    Call Id=8164
Wed Mar 20 09:28:50 2013: <191>166225: .Mar 20 09:28:49: //8164/867FF001B400/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:28:50 2013: <191>166226:    Stop Tone On Digit=FALSE, Tone=Ring Back,
Wed Mar 20 09:28:50 2013: <191>166227:    Tone Direction=Network, Params=0x0, Call Id=8164
Wed Mar 20 09:28:50 2013: <191>166228: .Mar 20 09:28:49: //8165/867FF001B400/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:28:50 2013: <191>166229:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:28:50 2013: <191>166230: .Mar 20 09:28:49: //8165/867FF001B400/CCAPI/cc_api_call_notify:
Wed Mar 20 09:28:50 2013: <191>166231:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8165
Wed Mar 20 09:28:50 2013: <191>166232: .Mar 20 09:28:49: //8165/867FF001B400/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:28:50 2013: <191>166233:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:28:51 2013: <191>166234: .Mar 20 09:28:49: //8165/867FF001B400/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:28:51 2013: <191>166235:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:28:51 2013: <191>166236: .Mar 20 09:28:49: //8164/867FF001B400/CCAPI/ccCallNotify:
Wed Mar 20 09:28:51 2013: <191>166237:    Data Bitmask=0x5, Call Id=8164
Wed Mar 20 09:28:53 2013: <191>166238: .Mar 20 09:28:52: //8165/867FF001B400/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:28:53 2013: <191>166239:    Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:28:53 2013: <191>166240: .Mar 20 09:28:52: //8165/867FF001B400/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:28:53 2013: <191>166241:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:28:53 2013: <191>166242: .Mar 20 09:28:52: //8165/867FF001B400/CCAPI/cc_api_call_notify:
Wed Mar 20 09:28:53 2013: <191>166243:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8165
Wed Mar 20 09:28:53 2013: <191>166244: .Mar 20 09:28:52: //8164/867FF001B400/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:28:53 2013: <191>166245:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:28:53 2013: <191>166246:    Tone Direction=Network, Params=0x0, Call Id=8164
Wed Mar 20 09:28:53 2013: <191>166247: .Mar 20 09:28:52: //8165/867FF001B400/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:28:53 2013: <191>166248:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:28:53 2013: <191>166249: .Mar 20 09:28:52: //8165/867FF001B400/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:28:53 2013: <191>166250:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:28:53 2013: <191>166251: .Mar 20 09:28:52: //8164/867FF001B400/CCAPI/ccCallNotify:
Wed Mar 20 09:28:53 2013: <191>166252:    Data Bitmask=0x5, Call Id=8164
Wed Mar 20 09:28:53 2013: <191>166253: .Mar 20 09:28:52: //8165/867FF001B400/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:28:53 2013: <191>166254:    Destination Interface=0x498845E0, Destination Call Id=8164, Source Call Id=8165,
Wed Mar 20 09:28:53 2013: <191>166255:    Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:28:53 2013: <191>166256:    Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:28:53 2013: <191>166257: .Mar 20 09:28:52: //8165/867FF001B400/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:28:53 2013: <191>166258:    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:28:53 2013: <191>166259:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:28:53 2013: <191>166260: .Mar 20 09:28:52: //8165/867FF001B400/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:28:53 2013: <191>166261:
Wed Mar 20 09:28:53 2013: <191>166262: Destination Interface=0x498845E0, Destination Call Id=8164, Source Call Id=8165,
Wed Mar 20 09:28:53 2013: <191>166263:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:28:53 2013: <191>166264:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1197)
Wed Mar 20 09:28:53 2013: <191>166265: .Mar 20 09:28:52: //8164/867FF001B400/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:28:53 2013: <191>166266:    Destination Interface=0x48A4F728, Destination Call Id=8165, Source Call Id=8164,
Wed Mar 20 09:28:53 2013: <191>166267:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:28:53 2013: <191>166268:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1197)
Wed Mar 20 09:28:53 2013: <191>166269: .Mar 20 09:28:52: //8164/867FF001B400/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:28:53 2013: <191>166270:    Call Id=8164
Wed Mar 20 09:28:53 2013: <191>166271: .Mar 20 09:28:52: //8164/867FF001B400/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:28:53 2013: <191>166272:
Wed Mar 20 09:28:54 2013: <191>166273: Call Entry(Context=0x4BA7A5A8)
Wed Mar 20 09:29:46 2013: <191>166274: .Mar 20 09:29:45: //8165/867FF001B400/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:29:46 2013: <191>166276: .Mar 20 09:29:45: //8165/867FF001B400/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:29:46 2013: <191>166275:    Interface=0x0, Call Id=8165
Wed Mar 20 09:29:46 2013: <191>166277:    Destination Interface=0x498845E0, Destination Call Id=8164, Source Call Id=8165,
Wed Mar 20 09:29:46 2013: <191>166278:    Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:29:46 2013: <191>166279:    Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:29:46 2013: <191>166280: .Mar 20 09:29:45: //8165/867FF001B400/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:29:46 2013: <191>166281:    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:29:46 2013: <191>166282:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:29:46 2013: <191>166283: .Mar 20 09:29:45: //8165/867FF001B400/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:29:46 2013: <191>166284:
Wed Mar 20 09:29:46 2013: <191>166285: Destination Interface=0x498845E0, Destination Call Id=8164, Source Call Id=8165,
Wed Mar 20 09:29:46 2013: <191>166286:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:29:46 2013: <191>166287:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1809)
Wed Mar 20 09:29:46 2013: <191>166288: .Mar 20 09:29:45: //8164/867FF001B400/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:29:46 2013: <191>166289:    Destination Interface=0x48A4F728, Destination Call Id=8165, Source Call Id=8164,
Wed Mar 20 09:29:46 2013: <191>166290:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:29:46 2013: <191>166291:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1809)
Wed Mar 20 09:29:46 2013: <191>166292: .Mar 20 09:29:45: //8164/867FF001B400/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:29:46 2013: <191>166293:    Call Id=8164
Wed Mar 20 09:29:46 2013: <191>166294: .Mar 20 09:29:45: //8164/867FF001B400/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:29:46 2013: <191>166295:
Wed Mar 20 09:29:47 2013: <191>166296: Call Entry(Context=0x4BA7A5A8)
Wed Mar 20 09:29:50 2013: <191>166297: .Mar 20 09:29:48: //8165/867FF001B400/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:29:50 2013: <191>166298:    Interface=0x0, Call Id=8165
Wed Mar 20 09:29:50 2013: <191>166299: .Mar 20 09:29:48: //8165/867FF001B400/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:29:50 2013: <191>166300:    Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:29:50 2013: <191>166301: .Mar 20 09:29:48: //8164/867FF001B400/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:29:50 2013: <191>166302:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:29:50 2013: <191>166303:    Tone Direction=Network, Params=0x0, Call Id=8164
Wed Mar 20 09:29:50 2013: <191>166304: .Mar 20 09:29:48: //8165/867FF001B400/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:29:50 2013: <191>166305:    Interface=0x48A4F728, Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:29:50 2013: <191>166306: .Mar 20 09:29:48: //8165/867FF001B400/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:29:50 2013: <191>166307:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:29:51 2013: <191>166308: .Mar 20 09:29:48: //8165/867FF001B400/CCAPI/cc_api_call_notify:
Wed Mar 20 09:29:51 2013: <191>166309:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8165
Wed Mar 20 09:29:51 2013: <191>166310: .Mar 20 09:29:48: //8164/867FF001B400/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:29:51 2013: <191>166311:    Stop Tone On Digit=FALSE, Tone=Ring Back,
Wed Mar 20 09:29:51 2013: <191>166312:    Tone Direction=Network, Params=0x0, Call Id=8164
Wed Mar 20 09:29:51 2013: <191>166313: .Mar 20 09:29:48: //8165/867FF001B400/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:29:51 2013: <191>166314:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:29:51 2013: <191>166315: .Mar 20 09:29:48: //8165/867FF001B400/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:29:51 2013: <191>166316:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:29:51 2013: <191>166317: .Mar 20 09:29:48: //8164/867FF001B400/CCAPI/ccCallNotify:
Wed Mar 20 09:29:51 2013: <191>166318:    Data Bitmask=0x5, Call Id=8164
Wed Mar 20 09:29:51 2013: <191>166319: .Mar 20 09:29:50: //8165/867FF001B400/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:29:51 2013: <191>166320:    Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:29:51 2013: <191>166321: .Mar 20 09:29:50: //8164/867FF001B400/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:29:51 2013: <191>166322:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:29:51 2013: <191>166323:    Tone Direction=Network, Params=0x0, Call Id=8164
Wed Mar 20 09:29:51 2013: <191>166324: .Mar 20 09:29:50: //8165/867FF001B400/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:29:51 2013: <191>166325:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:29:51 2013: <191>166326: .Mar 20 09:29:50: //8165/867FF001B400/CCAPI/cc_api_call_notify:
Wed Mar 20 09:29:51 2013: <191>166327:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8165
Wed Mar 20 09:29:51 2013: <191>166328: .Mar 20 09:29:50: //8165/867FF001B400/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:29:51 2013: <191>166329:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:29:51 2013: <191>166330: .Mar 20 09:29:50: //8165/867FF001B400/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:29:51 2013: <191>166331:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:29:51 2013: <191>166332: .Mar 20 09:29:50: //8164/867FF001B400/CCAPI/ccCallNotify:
Wed Mar 20 09:29:51 2013: <191>166333:    Data Bitmask=0x5, Call Id=8164
Wed Mar 20 09:29:51 2013: <191>166334: .Mar 20 09:29:50: //8165/867FF001B400/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:29:51 2013: <191>166335:    Destination Interface=0x498845E0, Destination Call Id=8164, Source Call Id=8165,
Wed Mar 20 09:29:51 2013: <191>166336:    Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:29:51 2013: <191>166337:    Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:29:51 2013: <191>166338: .Mar 20 09:29:50: //8165/867FF001B400/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:29:51 2013: <191>166339:    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:29:51 2013: <191>166340:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:29:51 2013: <191>166341: .Mar 20 09:29:50: //8165/867FF001B400/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:29:51 2013: <191>166342:
Wed Mar 20 09:29:51 2013: <191>166343: Destination Interface=0x498845E0, Destination Call Id=8164, Source Call Id=8165,
Wed Mar 20 09:29:51 2013: <191>166344:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:29:51 2013: <191>166345:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1922)
Wed Mar 20 09:29:51 2013: <191>166346: .Mar 20 09:29:50: //8164/867FF001B400/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:29:51 2013: <191>166347:    Destination Interface=0x48A4F728, Destination Call Id=8165, Source Call Id=8164,
Wed Mar 20 09:29:51 2013: <191>166348:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:29:51 2013: <191>166349:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1922)
Wed Mar 20 09:29:51 2013: <191>166350: .Mar 20 09:29:50: //8164/867FF001B400/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:29:51 2013: <191>166351:    Call Id=8164
Wed Mar 20 09:29:51 2013: <191>166352: .Mar 20 09:29:50: //8164/867FF001B400/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:29:51 2013: <191>166353:
Wed Mar 20 09:29:52 2013: <191>166354: Call Entry(Context=0x4BA7A5A8)
Wed Mar 20 09:33:44 2013: <191>166355: .Mar 20 09:33:43: //8165/867FF001B400/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:33:44 2013: <191>166356:    Interface=0x0, Call Id=8165
Wed Mar 20 09:33:44 2013: <191>166357: .Mar 20 09:33:43: //8165/867FF001B400/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:33:44 2013: <191>166358:    Cause Value=16, Interface=0x48A4F728, Call Id=8165
Wed Mar 20 09:33:44 2013: <191>166359: .Mar 20 09:33:43: //8165/867FF001B400/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:33:44 2013: <191>166360:    Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:33:44 2013: <191>166361: .Mar 20 09:33:43: //8164/867FF001B400/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:33:44 2013: <191>166362:    Conference Id=0xE5F, Tag=0x0
Wed Mar 20 09:33:44 2013: <191>166363: .Mar 20 09:33:43: //8164/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:33:44 2013: <191>166364:    Conference Id=0xE5F, Source Interface=0x498845E0, Source Call Id=8164,
Wed Mar 20 09:33:44 2013: <191>166365:    Destination Call Id=8165, Disposition=0x0, Tag=0x0
Wed Mar 20 09:33:44 2013: <191>166366: .Mar 20 09:33:43: //8165/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:33:44 2013: <191>166367:    Conference Id=0xE5F, Source Interface=0x48A4F728, Source Call Id=8165,
Wed Mar 20 09:33:44 2013: <191>166368:    Destination Call Id=8164, Disposition=0x0, Tag=0x0
Wed Mar 20 09:33:44 2013: <191>166369: .Mar 20 09:33:43: //8164/867FF001B400/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:33:44 2013: <191>166370:    Conference Id=0xE5F, Source Interface=0x48A4F728, Source Call Id=8165,
Wed Mar 20 09:33:44 2013: <191>166371:    Destination Call Id=8164, Disposition=0x0, Tag=0x0
Wed Mar 20 09:33:44 2013: <191>166372: .Mar 20 09:33:43: //8164/867FF001B400/CCAPI/ccCallDisconnect:
Wed Mar 20 09:33:44 2013: <191>166373:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:33:44 2013: <191>166374: .Mar 20 09:33:43: //8164/867FF001B400/CCAPI/ccCallDisconnect:
Wed Mar 20 09:33:44 2013: <191>166375:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:33:44 2013: <191>166376: .Mar 20 09:33:43: //8164/867FF001B400/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:33:44 2013: <191>166377:    Transfer Number Is Null
Wed Mar 20 09:33:44 2013: <191>166378: .Mar 20 09:33:43: //8165/867FF001B400/CCAPI/ccCallDisconnect:
Wed Mar 20 09:33:44 2013: <191>166379:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:33:44 2013: <191>166380: .Mar 20 09:33:43: //8165/867FF001B400/CCAPI/ccCallDisconnect:
Wed Mar 20 09:33:44 2013: <191>166381:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:33:44 2013: <191>166382: .Mar 20 09:33:43: //8165/867FF001B400/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:33:44 2013: <191>166383:    Transfer Number Is Null
Wed Mar 20 09:33:44 2013: <191>166384: .Mar 20 09:33:43: //8165/867FF001B400/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:33:44 2013: <191>166385:    Transfer Number Is Null
Wed Mar 20 09:33:44 2013: <191>166386: .Mar 20 09:33:43: //8165/867FF001B400/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:33:44 2013: <191>166387:
Wed Mar 20 09:33:44 2013: <191>166388: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8165,
Wed Mar 20 09:33:44 2013: <191>166389:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:33:44 2013: <191>166390: .Mar 20 09:33:43: //8165/867FF001B400/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:33:44 2013: <191>166391:    Call Disconnect Event Sent
Wed Mar 20 09:33:44 2013: <191>166392: .Mar 20 09:33:43: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:33:44 2013: <191>166393:
Wed Mar 20 09:33:44 2013: <191>166394: .Mar 20 09:33:43: :cc_free_feature_vsa freeing 47B93B40
Wed Mar 20 09:33:44 2013: <191>166395: .Mar 20 09:33:43: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:33:44 2013: <191>166396:
Wed Mar 20 09:33:45 2013: <191>166397: .Mar 20 09:33:43:  vsacount in free is 3
Wed Mar 20 09:33:45 2013: <191>166398: .Mar 20 09:33:43: //8164/867FF001B400/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:33:45 2013: <191>166399:    Disposition=0, Interface=0x498845E0, Tag=0x0, Call Id=8164,
Wed Mar 20 09:33:45 2013: <191>166400:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:33:45 2013: <191>166401: .Mar 20 09:33:43: //8164/867FF001B400/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:33:45 2013: <191>166402:    Call Disconnect Event Sent
Wed Mar 20 09:33:45 2013: <191>166403: .Mar 20 09:33:43: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:33:45 2013: <191>166404:
Wed Mar 20 09:33:45 2013: <191>166405: .Mar 20 09:33:43: :cc_free_feature_vsa freeing 47B93C20
Wed Mar 20 09:33:45 2013: <191>166406: .Mar 20 09:33:43: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:33:45 2013: <191>166407:
Wed Mar 20 09:33:45 2013: <191>166408: .Mar 20 09:33:43:  vsacount in free is 2
Wed Mar 20 09:38:02 2013: <191>166409: .Mar 20 09:38:00: //-1/D5F89820B405/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:38:02 2013: <191>166410:    cc_api_call_setup_ind_common:
Wed Mar 20 09:38:02 2013: <191>166411:    cisco-username=
Wed Mar 20 09:38:02 2013: <191>166412:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:38:02 2013: <191>166413:    cisco-ani=
Wed Mar 20 09:38:02 2013: <191>166414:    cisco-anitype=0
Wed Mar 20 09:38:02 2013: <191>166415:    cisco-aniplan=0
Wed Mar 20 09:38:02 2013: <191>166416:    cisco-anipi=0
Wed Mar 20 09:38:02 2013: <191>166417:    cisco-anisi=0
Wed Mar 20 09:38:02 2013: <191>166418:    dest=1811032099
Wed Mar 20 09:38:02 2013: <191>166419:    cisco-desttype=0
Wed Mar 20 09:38:02 2013: <191>166420:    cisco-destplan=0
Wed Mar 20 09:38:02 2013: <191>166421:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:38:02 2013: <191>166422:    cisco-rdn=
Wed Mar 20 09:38:02 2013: <191>166423:    cisco-lastrdn=
Wed Mar 20 09:38:02 2013: <191>166424:    cisco-rdntype=0
Wed Mar 20 09:38:02 2013: <191>166425:    cisco-rdnplan=0
Wed Mar 20 09:38:02 2013: <191>166426:    cisco-rdnpi=0
Wed Mar 20 09:38:02 2013: <191>166427:    cisco-rdnsi=0
Wed Mar 20 09:38:02 2013: <191>166428:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:38:02 2013: <191>166429:    final_redirectNumber =
Wed Mar 20 09:38:02 2013: <191>166430:    hunt_group_timeout =0
Wed Mar 20 09:38:02 2013: <191>166431:
Wed Mar 20 09:38:02 2013: <191>166432: .Mar 20 09:38:00: //-1/D5F89820B405/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:38:02 2013: <191>166433:
Wed Mar 20 09:38:02 2013: <191>166434: Interface=0x498845E0, Call Info(
Wed Mar 20 09:38:02 2013: <191>166435:    Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:38:02 2013: <191>166436:    Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:38:02 2013: <191>166437:    Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Wed Mar 20 09:38:02 2013: <191>166438:    Incoming Dial-peer=50, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Wed Mar 20 09:38:02 2013: <191>166439:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:38:02 2013: <191>166440: .Mar 20 09:38:00: //-1/D5F89820B405/CCAPI/ccCheckClipClir:
Wed Mar 20 09:38:02 2013: <191>166441:    In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:38:02 2013: <191>166442: .Mar 20 09:38:00: //-1/D5F89820B405/CCAPI/ccCheckClipClir:
Wed Mar 20 09:38:02 2013: <191>166443:    Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:38:02 2013: <191>166444: .Mar 20 09:38:00: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:38:02 2013: <191>166445:
Wed Mar 20 09:38:02 2013: <191>166446: .Mar 20 09:38:00: :cc_get_feature_vsa malloc success
Wed Mar 20 09:38:02 2013: <191>166447: .Mar 20 09:38:00: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:38:02 2013: <191>166448:
Wed Mar 20 09:38:02 2013: <191>166449: .Mar 20 09:38:00:  cc_get_feature_vsa count is 3
Wed Mar 20 09:38:02 2013: <191>166450: .Mar 20 09:38:00: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:38:02 2013: <191>166451:
Wed Mar 20 09:38:02 2013: <191>166452: .Mar 20 09:38:00: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203321896,feature_id:8166
Wed Mar 20 09:38:02 2013: <191>166453: .Mar 20 09:38:00: //8166/D5F89820B405/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:38:02 2013: <191>166454:
Wed Mar 20 09:38:02 2013: <191>166455: Set Up Event Sent;
Wed Mar 20 09:38:02 2013: <191>166456:    Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:38:02 2013: <191>166457:    Called Number=1811032099(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:38:02 2013: <191>166460: .Mar 20 09:38:00: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Wed Mar 20 09:38:02 2013: <191>166461:    Try with the demoted called number 1811032099
Wed Mar 20 09:38:02 2013: <191>166465:    >>>>CCAPI handed cid 8166 with tag 50 to app "_ManagedAppProcess_Default"
Wed Mar 20 09:38:02 2013: <191>166474: .Mar 20 09:38:00: //8166/D5F89820B405/CCAPI/ccCheckClipClir:
Wed Mar 20 09:38:02 2013: <191>166475:    Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:38:02 2013: <191>166476: .Mar 20 09:38:00: //8166/D5F89820B405/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:38:02 2013: <191>166486:    ccCallSetupRequest:
Wed Mar 20 09:38:02 2013: <191>166487:    cisco-username=
Wed Mar 20 09:38:02 2013: <191>166488:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:38:02 2013: <191>166492:    cisco-anipi=0
Wed Mar 20 09:38:02 2013: <191>166494:    cisco-anisi=0
Wed Mar 20 09:38:02 2013: <191>166497:    cisco-destplan=0
Wed Mar 20 09:38:02 2013: <191>166498:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:38:02 2013: <191>166503:    cisco-rdnpi=0
Wed Mar 20 09:38:02 2013: <191>166507:    hunt_group_timeout =0
Wed Mar 20 09:38:02 2013: <191>166521: .Mar 20 09:38:00:  cc_get_feature_vsa count is 4
Wed Mar 20 09:38:02 2013: <191>166522: .Mar 20 09:38:00: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:38:02 2013: <191>166523:
Wed Mar 20 09:38:02 2013: <191>166524: .Mar 20 09:38:00: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203321672,feature_id:8167
Wed Mar 20 09:38:02 2013: <191>166525: .Mar 20 09:38:00: //8167/D5F89820B405/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:38:02 2013: <191>166526:    SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Wed Mar 20 09:38:02 2013: <191>166527: .Mar 20 09:38:00: //8167/D5F89820B405/CCAPI/ccCallSetContext:
Wed Mar 20 09:38:02 2013: <191>166528:    Context=0x4BA68830
Wed Mar 20 09:38:02 2013: <191>166529: .Mar 20 09:38:00: //8166/D5F89820B405/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:38:02 2013: <191>166530:    Outgoing Dial-peer=3000
Wed Mar 20 09:38:02 2013: <191>166531: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:38:02 2013: <191>166532:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:38:02 2013: <191>166533: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:38:02 2013: <191>166534:    Interface=0x48A4F728, Progress Indication=NULL(0)
Wed Mar 20 09:38:02 2013: <191>166535: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:38:02 2013: <191>166536:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:38:02 2013: <191>166537: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_set_delay_xport:
Wed Mar 20 09:38:02 2013: <191>166538:    CallInfo(delay xport=TRUE)
Wed Mar 20 09:38:02 2013: <191>166539: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_call_alert:
Wed Mar 20 09:38:02 2013: <191>166540:    Interface=0x48A4F728, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:38:02 2013: <191>166541: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_call_alert:
Wed Mar 20 09:38:02 2013: <191>166542:    Call Entry(Retry Count=0, Responsed=TRUE)
Wed Mar 20 09:38:02 2013: <191>166543: .Mar 20 09:38:01: //8166/D5F89820B405/CCAPI/ccCallAlert:
Wed Mar 20 09:38:02 2013: <191>166544:
Wed Mar 20 09:38:02 2013: <191>166545: Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:38:02 2013: <191>166546: .Mar 20 09:38:01: //8166/D5F89820B405/CCAPI/ccCallAlert:
Wed Mar 20 09:38:02 2013: <191>166547:    Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Wed Mar 20 09:38:02 2013: <191>166548: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:38:02 2013: <191>166549:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:38:02 2013: <191>166550: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_call_notify:
Wed Mar 20 09:38:02 2013: <191>166551:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8167
Wed Mar 20 09:38:02 2013: <191>166552: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/ccIsInfoRingback:
Wed Mar 20 09:38:02 2013: <191>166553:    Returning dpRingBack=0
Wed Mar 20 09:38:02 2013: <191>166554: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:38:02 2013: <191>166555:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:38:02 2013: <191>166556: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:38:02 2013: <191>166557:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:38:02 2013: <191>166558: .Mar 20 09:38:01: //8166/D5F89820B405/CCAPI/ccCallNotify:
Wed Mar 20 09:38:02 2013: <191>166559:    Data Bitmask=0x5, Call Id=8166
Wed Mar 20 09:38:02 2013: <191>166560: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_call_connected:
Wed Mar 20 09:38:02 2013: <191>166561:    Interface=0x48A4F728, Data Bitmask=0x0, Progress Indication=NULL(0),
Wed Mar 20 09:38:02 2013: <191>166562:    Connection Handle=0
Wed Mar 20 09:38:02 2013: <191>166563: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_call_connected:
Wed Mar 20 09:38:02 2013: <191>166564:    Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:38:02 2013: <191>166565: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:38:02 2013: <191>166566:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:38:02 2013: <191>166567: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_call_notify:
Wed Mar 20 09:38:02 2013: <191>166568:
Wed Mar 20 09:38:02 2013: <191>166569: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8167
Wed Mar 20 09:38:02 2013: <191>166570: .Mar 20 09:38:01: //8166/D5F89820B405/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:38:02 2013: <191>166571:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:38:02 2013: <191>166572:    Tone Direction=Network, Params=0x0, Call Id=8166
Wed Mar 20 09:38:02 2013: <191>166573: .Mar 20 09:38:01: //8166/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:38:02 2013: <191>166574:    (confID=0x4BB021A0, callID1=0x1FE6, callID2=0x1FE7, tag=0x0)
Wed Mar 20 09:38:02 2013: <191>166575: .Mar 20 09:38:01: //8166/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:38:02 2013: <191>166576:    (confID=0x4BB021A0, callID1=0x1FE6, gcid=D5F89820-909111E2-B405DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:38:02 2013: <191>166577: .Mar 20 09:38:01: //8167/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:38:02 2013: <191>166578:    (confID=0x4BB021A0, callID2=0x1FE7, gcid=D5F89820-909111E2-B405DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:38:02 2013: <191>166579: .Mar 20 09:38:01: //8166/D5F89820B405/CCAPI/ccConferenceCreate:
Wed Mar 20 09:38:02 2013: <191>166580:    Conference Id=0x4BB021A0, Call Id1=8166, Call Id2=8167, Tag=0x0
Wed Mar 20 09:38:02 2013: <191>166581: .Mar 20 09:38:01: //8166/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:38:02 2013: <191>166582:    Conference Id=0xE60, Source Interface=0x498845E0, Source Call Id=8166,
Wed Mar 20 09:38:02 2013: <191>166583:    Destination Call Id=8167, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:38:02 2013: <191>166584: .Mar 20 09:38:01: //8167/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:38:02 2013: <191>166585:
Wed Mar 20 09:38:02 2013: <191>166586: .Mar 20 09:38:01: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:38:02 2013: <191>166587: .Mar 20 09:38:01: //8167/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:38:02 2013: <191>166588:    Conference Id=0xE60, Source Interface=0x48A4F728, Source Call Id=8167,
Wed Mar 20 09:38:02 2013: <191>166589:    Destination Call Id=8166, Disposition=0x0, Tag=0x0
Wed Mar 20 09:38:02 2013: <191>166590: .Mar 20 09:38:01: //8166/D5F89820B405/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:38:02 2013: <191>166591:    Conference Id=0xE60, Source Interface=0x48A4F728, Source Call Id=8167,
Wed Mar 20 09:38:02 2013: <191>166593: .Mar 20 09:38:01: //8166/D5F89820B405/CCAPI/ccConferenceCreate:
Wed Mar 20 09:38:02 2013: <191>166595: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/ccConferenceCreate:
Wed Mar 20 09:38:02 2013: <191>166596:    Call Entry(Conference Id=0xE60, Destination Call Id=8166)
Wed Mar 20 09:38:02 2013: <191>166597: .Mar 20 09:38:01: //8166/D5F89820B405/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:38:02 2013: <191>166609:    Modem=0x2, Codec Bytes=20, Signal Type=2)
Wed Mar 20 09:38:02 2013: <191>166610: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:38:02 2013: <191>166611:
Wed Mar 20 09:38:02 2013: <191>166616:    Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:38:02 2013: <191>166617:    Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=3211)
Wed Mar 20 09:38:02 2013: <191>166618: .Mar 20 09:38:01: //8166/D5F89820B405/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:38:02 2013: <191>166631:    Call Entry(Context=0x4BA74680)
Wed Mar 20 09:38:03 2013: <191>166636: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:38:13 2013: <191>166637: .Mar 20 09:38:12: //8167/D5F89820B405/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:38:13 2013: <191>166638:    Interface=0x0, Call Id=8167
Wed Mar 20 09:38:13 2013: <191>166639: .Mar 20 09:38:12: //8167/D5F89820B405/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:38:13 2013: <191>166640:    Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:38:13 2013: <191>166641: .Mar 20 09:38:12: //8166/D5F89820B405/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:38:13 2013: <191>166642:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:38:13 2013: <191>166643:    Tone Direction=Network, Params=0x0, Call Id=8166
Wed Mar 20 09:38:13 2013: <191>166644: .Mar 20 09:38:12: //8167/D5F89820B405/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:38:13 2013: <191>166645:    Interface=0x48A4F728, Signal Indication=NOT PRESENT(255)
Wed Mar 20 09:38:13 2013: <191>166646: .Mar 20 09:38:12: //8167/D5F89820B405/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:38:13 2013: <191>166647:    Interface=0x48A4F728, Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:38:13 2013: <191>166648: .Mar 20 09:38:12: //8166/D5F89820B405/CCAPI/ccCallUserInfo:
Wed Mar 20 09:38:13 2013: <191>166649:    Call Id=8166
Wed Mar 20 09:38:13 2013: <191>166650: .Mar 20 09:38:12: //8166/D5F89820B405/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:38:13 2013: <191>166651:    Stop Tone On Digit=FALSE, Tone=Ring Back,
Wed Mar 20 09:38:13 2013: <191>166652:    Tone Direction=Network, Params=0x0, Call Id=8166
Wed Mar 20 09:38:13 2013: <191>166653: .Mar 20 09:38:12: //8167/D5F89820B405/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:38:13 2013: <191>166654:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:38:13 2013: <191>166655: .Mar 20 09:38:12: //8167/D5F89820B405/CCAPI/cc_api_call_notify:
Wed Mar 20 09:38:13 2013: <191>166656:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8167
Wed Mar 20 09:38:13 2013: <191>166657: .Mar 20 09:38:12: //8167/D5F89820B405/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:38:13 2013: <191>166658:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:38:14 2013: <191>166659: .Mar 20 09:38:12: //8167/D5F89820B405/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:38:14 2013: <191>166660:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:38:14 2013: <191>166661: .Mar 20 09:38:12: //8166/D5F89820B405/CCAPI/ccCallNotify:
Wed Mar 20 09:38:14 2013: <191>166662:    Data Bitmask=0x5, Call Id=8166
Wed Mar 20 09:38:16 2013: <191>166663: .Mar 20 09:38:14: //8167/D5F89820B405/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:38:16 2013: <191>166664:    Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:38:16 2013: <191>166665: .Mar 20 09:38:14: //8167/D5F89820B405/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:38:16 2013: <191>166666:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:38:16 2013: <191>166667: .Mar 20 09:38:14: //8167/D5F89820B405/CCAPI/cc_api_call_notify:
Wed Mar 20 09:38:16 2013: <191>166668:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8167
Wed Mar 20 09:38:16 2013: <191>166669: .Mar 20 09:38:14: //8166/D5F89820B405/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:38:16 2013: <191>166670:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:38:16 2013: <191>166671:    Tone Direction=Network, Params=0x0, Call Id=8166
Wed Mar 20 09:38:16 2013: <191>166672: .Mar 20 09:38:14: //8167/D5F89820B405/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:38:16 2013: <191>166673:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:38:16 2013: <191>166674: .Mar 20 09:38:14: //8167/D5F89820B405/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:38:16 2013: <191>166675:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:38:16 2013: <191>166676: .Mar 20 09:38:14: //8166/D5F89820B405/CCAPI/ccCallNotify:
Wed Mar 20 09:38:16 2013: <191>166677:    Data Bitmask=0x5, Call Id=8166
Wed Mar 20 09:38:16 2013: <191>166678: .Mar 20 09:38:15: //8167/D5F89820B405/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:38:16 2013: <191>166679:    Destination Interface=0x498845E0, Destination Call Id=8166, Source Call Id=8167,
Wed Mar 20 09:38:16 2013: <191>166680:    Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:38:16 2013: <191>166681:    Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:38:16 2013: <191>166682: .Mar 20 09:38:15: //8167/D5F89820B405/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:38:16 2013: <191>166683:    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:38:16 2013: <191>166684:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:38:16 2013: <191>166685: .Mar 20 09:38:15: //8167/D5F89820B405/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:38:16 2013: <191>166686:
Wed Mar 20 09:38:16 2013: <191>166687: Destination Interface=0x498845E0, Destination Call Id=8166, Source Call Id=8167,
Wed Mar 20 09:38:16 2013: <191>166688:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:38:16 2013: <191>166689:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=3247)
Wed Mar 20 09:38:16 2013: <191>166690: .Mar 20 09:38:15: //8166/D5F89820B405/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:38:16 2013: <191>166691:    Destination Interface=0x48A4F728, Destination Call Id=8167, Source Call Id=8166,
Wed Mar 20 09:38:16 2013: <191>166692:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:38:16 2013: <191>166693:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=3247)
Wed Mar 20 09:38:16 2013: <191>166694: .Mar 20 09:38:15: //8166/D5F89820B405/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:38:16 2013: <191>166695:    Call Id=8166
Wed Mar 20 09:38:16 2013: <191>166696: .Mar 20 09:38:15: //8166/D5F89820B405/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:38:16 2013: <191>166697:
Wed Mar 20 09:38:17 2013: <191>166698: Call Entry(Context=0x4BA74680)
Wed Mar 20 09:39:06 2013: <191>166699: .Mar 20 09:39:04: //8162/8062BAA34206/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:39:06 2013: <191>166700:    Cause Value=16, Interface=0x48A4F728, Call Id=8162
Wed Mar 20 09:39:06 2013: <191>166701: .Mar 20 09:39:04: //8162/8062BAA34206/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:39:06 2013: <191>166702:    Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:39:06 2013: <191>166703: .Mar 20 09:39:04: //8162/8062BAA34206/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:39:06 2013: <191>166704:    Conference Id=0xE5E, Tag=0x0
Wed Mar 20 09:39:06 2013: <191>166705: .Mar 20 09:39:04: //8162/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:39:06 2013: <191>166706:    Conference Id=0xE5E, Source Interface=0x48A4F728, Source Call Id=8162,
Wed Mar 20 09:39:06 2013: <191>166707:    Destination Call Id=8163, Disposition=0x0, Tag=0x0
Wed Mar 20 09:39:06 2013: <191>166708: .Mar 20 09:39:04: //8163/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:39:06 2013: <191>166709:
Wed Mar 20 09:39:06 2013: <191>166710: Conference Id=0xE5E, Source Interface=0x4987FF98, Source Call Id=8163,
Wed Mar 20 09:39:06 2013: <191>166711:    Destination Call Id=8162, Disposition=0x0, Tag=0x0
Wed Mar 20 09:39:06 2013: <191>166712: .Mar 20 09:39:04: //8162/8062BAA34206/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:39:06 2013: <191>166713:    Conference Id=0xE5E, Source Interface=0x4987FF98, Source Call Id=8163,
Wed Mar 20 09:39:06 2013: <191>166714:    Destination Call Id=8162, Disposition=0x0, Tag=0x0
Wed Mar 20 09:39:06 2013: <191>166715: .Mar 20 09:39:04: //8162/8062BAA34206/CCAPI/ccCallDisconnect:
Wed Mar 20 09:39:06 2013: <191>166716:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:39:06 2013: <191>166717: .Mar 20 09:39:04: //8162/8062BAA34206/CCAPI/ccCallDisconnect:
Wed Mar 20 09:39:06 2013: <191>166718:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:39:06 2013: <191>166719: .Mar 20 09:39:04: //8162/8062BAA34206/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:39:06 2013: <191>166720:
Wed Mar 20 09:39:06 2013: <191>166721: Transfer Number Is Null
Wed Mar 20 09:39:06 2013: <191>166722: .Mar 20 09:39:04: //8163/8062BAA34206/CCAPI/ccCallDisconnect:
Wed Mar 20 09:39:06 2013: <191>166723:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:39:06 2013: <191>166724: .Mar 20 09:39:04: //8163/8062BAA34206/CCAPI/ccCallDisconnect:
Wed Mar 20 09:39:06 2013: <191>166725:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:39:06 2013: <191>166726: .Mar 20 09:39:04: //8163/8062BAA34206/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:39:06 2013: <191>166727:    Transfer Number Is Null
Wed Mar 20 09:39:06 2013: <191>166728: .Mar 20 09:39:04: //8162/8062BAA34206/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:39:06 2013: <191>166729:    Transfer Number Is Null
Wed Mar 20 09:39:06 2013: <191>166730: .Mar 20 09:39:04: //8162/8062BAA34206/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:39:06 2013: <191>166731:
Wed Mar 20 09:39:06 2013: <191>166732: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8162,
Wed Mar 20 09:39:06 2013: <191>166733:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:39:06 2013: <191>166734: .Mar 20 09:39:04: //8162/8062BAA34206/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:39:06 2013: <191>166735:    Call Disconnect Event Sent
Wed Mar 20 09:39:06 2013: <191>166736: .Mar 20 09:39:04: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:39:06 2013: <191>166737:
Wed Mar 20 09:39:06 2013: <191>166738: .Mar 20 09:39:04: :cc_free_feature_vsa freeing 47B93DE0
Wed Mar 20 09:39:06 2013: <191>166739: .Mar 20 09:39:04: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:39:06 2013: <191>166740:
Wed Mar 20 09:39:06 2013: <191>166741: .Mar 20 09:39:04:  vsacount in free is 3
Wed Mar 20 09:39:06 2013: <191>166742: .Mar 20 09:39:04: //8163/8062BAA34206/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:39:06 2013: <191>166743:    Disposition=0, Interface=0x4987FF98, Tag=0x0, Call Id=8163,
Wed Mar 20 09:39:06 2013: <191>166744:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:39:07 2013: <191>166745: .Mar 20 09:39:04: //8163/8062BAA34206/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:39:07 2013: <191>166746:    Call Disconnect Event Sent
Wed Mar 20 09:39:07 2013: <191>166747: .Mar 20 09:39:04: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:39:07 2013: <191>166748:
Wed Mar 20 09:39:07 2013: <191>166749: .Mar 20 09:39:04: :cc_free_feature_vsa freeing 47B93D00
Wed Mar 20 09:39:07 2013: <191>166750: .Mar 20 09:39:04: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:39:07 2013: <191>166751:
Wed Mar 20 09:39:07 2013: <191>166752: .Mar 20 09:39:04:  vsacount in free is 2
Wed Mar 20 09:40:02 2013: <191>166753: .Mar 20 09:40:01: //8166/D5F89820B405/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:40:02 2013: <191>166754:    Cause Value=86, Interface=0x498845E0, Call Id=8166
Wed Mar 20 09:40:02 2013: <191>166755: .Mar 20 09:40:01: //8166/D5F89820B405/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:40:02 2013: <191>166756:    Call Entry(Responsed=TRUE, Cause Value=86, Retry Count=0)
Wed Mar 20 09:40:02 2013: <191>166757: .Mar 20 09:40:01: //8166/D5F89820B405/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:40:02 2013: <191>166758:    Conference Id=0xE60, Tag=0x0
Wed Mar 20 09:40:02 2013: <191>166759: .Mar 20 09:40:01: //8166/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:40:02 2013: <191>166760:    Conference Id=0xE60, Source Interface=0x498845E0, Source Call Id=8166,
Wed Mar 20 09:40:02 2013: <191>166761:    Destination Call Id=8167, Disposition=0x0, Tag=0x0
Wed Mar 20 09:40:02 2013: <191>166762: .Mar 20 09:40:01: //8167/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:40:02 2013: <191>166763:
Wed Mar 20 09:40:02 2013: <191>166764: Conference Id=0xE60, Source Interface=0x48A4F728, Source Call Id=8167,
Wed Mar 20 09:40:02 2013: <191>166765:    Destination Call Id=8166, Disposition=0x0, Tag=0x0
Wed Mar 20 09:40:02 2013: <191>166766: .Mar 20 09:40:01: //8166/D5F89820B405/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:40:02 2013: <191>166767:    Conference Id=0xE60, Source Interface=0x48A4F728, Source Call Id=8167,
Wed Mar 20 09:40:02 2013: <191>166768:    Destination Call Id=8166, Disposition=0x0, Tag=0x0
Wed Mar 20 09:40:02 2013: <191>166769: .Mar 20 09:40:01: //8166/D5F89820B405/CCAPI/ccCallDisconnect:
Wed Mar 20 09:40:02 2013: <191>166770:    Cause Value=86, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=86)
Wed Mar 20 09:40:02 2013: <191>166771: .Mar 20 09:40:01: //8166/D5F89820B405/CCAPI/ccCallDisconnect:
Wed Mar 20 09:40:02 2013: <191>166772:    Cause Value=86, Call Entry(Responsed=TRUE, Cause Value=86)
Wed Mar 20 09:40:02 2013: <191>166773: .Mar 20 09:40:01: //8166/D5F89820B405/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:40:02 2013: <191>166774:
Wed Mar 20 09:40:02 2013: <191>166775: Transfer Number Is Null
Wed Mar 20 09:40:02 2013: <191>166776: .Mar 20 09:40:01: //8167/D5F89820B405/CCAPI/ccCallDisconnect:
Wed Mar 20 09:40:02 2013: <191>166777:    Cause Value=86, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:40:02 2013: <191>166778: .Mar 20 09:40:01: //8167/D5F89820B405/CCAPI/ccCallDisconnect:
Wed Mar 20 09:40:02 2013: <191>166779:    Cause Value=86, Call Entry(Responsed=TRUE, Cause Value=86)
Wed Mar 20 09:40:02 2013: <191>166780: .Mar 20 09:40:01: //8167/D5F89820B405/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:40:02 2013: <191>166781:    Transfer Number Is Null
Wed Mar 20 09:40:02 2013: <191>166782: .Mar 20 09:40:01: //8167/D5F89820B405/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:40:02 2013: <191>166783:    Transfer Number Is Null
Wed Mar 20 09:40:02 2013: <191>166784: .Mar 20 09:40:01: //8167/D5F89820B405/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:40:02 2013: <191>166785:
Wed Mar 20 09:40:02 2013: <191>166786: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8167,
Wed Mar 20 09:40:02 2013: <191>166787:    Call Entry(Disconnect Cause=86, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:40:02 2013: <191>166788: .Mar 20 09:40:01: //8167/D5F89820B405/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:40:02 2013: <191>166789:    Call Disconnect Event Sent
Wed Mar 20 09:40:02 2013: <191>166790: .Mar 20 09:40:01: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:40:02 2013: <191>166791:
Wed Mar 20 09:40:02 2013: <191>166792: .Mar 20 09:40:01: :cc_free_feature_vsa freeing 47B93B40
Wed Mar 20 09:40:02 2013: <191>166793: .Mar 20 09:40:01: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:40:02 2013: <191>166794:
Wed Mar 20 09:40:02 2013: <191>166795: .Mar 20 09:40:01:  vsacount in free is 1
Wed Mar 20 09:40:02 2013: <191>166796: .Mar 20 09:40:01: //8166/D5F89820B405/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:40:02 2013: <191>166797:    Disposition=0, Interface=0x498845E0, Tag=0x0, Call Id=8166,
Wed Mar 20 09:40:02 2013: <191>166798:    Call Entry(Disconnect Cause=86, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:40:03 2013: <191>166799: .Mar 20 09:40:01: //8166/D5F89820B405/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:40:03 2013: <191>166800:    Call Disconnect Event Sent
Wed Mar 20 09:40:03 2013: <191>166801: .Mar 20 09:40:01: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:40:03 2013: <191>166802:
Wed Mar 20 09:40:03 2013: <191>166803: .Mar 20 09:40:01: :cc_free_feature_vsa freeing 47B93C20
Wed Mar 20 09:40:03 2013: <191>166804: .Mar 20 09:40:01: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:40:03 2013: <191>166805:
Wed Mar 20 09:40:03 2013: <191>166806: .Mar 20 09:40:01:  vsacount in free is 0
Wed Mar 20 09:43:03 2013: <191>166807: .Mar 20 09:43:01: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
Wed Mar 20 09:43:03 2013: <191>166808:    ccAppShutdownMode: remove it from the queue
Wed Mar 20 09:47:32 2013: <191>166809: .Mar 20 09:47:31: //-1/29DFEE4BB40A/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:47:32 2013: <191>166810:    cc_api_call_setup_ind_common:
Wed Mar 20 09:47:32 2013: <191>166811:    cisco-username=
Wed Mar 20 09:47:32 2013: <191>166812:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:47:32 2013: <191>166813:    cisco-ani=
Wed Mar 20 09:47:32 2013: <191>166814:    cisco-anitype=0
Wed Mar 20 09:47:32 2013: <191>166815:    cisco-aniplan=0
Wed Mar 20 09:47:32 2013: <191>166816:    cisco-anipi=0
Wed Mar 20 09:47:32 2013: <191>166817:    cisco-anisi=0
Wed Mar 20 09:47:32 2013: <191>166818:    dest=1811032099
Wed Mar 20 09:47:32 2013: <191>166819:    cisco-desttype=0
Wed Mar 20 09:47:32 2013: <191>166820:    cisco-destplan=0
Wed Mar 20 09:47:32 2013: <191>166821:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:47:32 2013: <191>166822:    cisco-rdn=
Wed Mar 20 09:47:32 2013: <191>166823:    cisco-lastrdn=
Wed Mar 20 09:47:32 2013: <191>166824:    cisco-rdntype=0
Wed Mar 20 09:47:32 2013: <191>166825:    cisco-rdnplan=0
Wed Mar 20 09:47:32 2013: <191>166826:    cisco-rdnpi=0
Wed Mar 20 09:47:32 2013: <191>166827:    cisco-rdnsi=0
Wed Mar 20 09:47:32 2013: <191>166828:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:47:32 2013: <191>166829:    final_redirectNumber =
Wed Mar 20 09:47:32 2013: <191>166830:    hunt_group_timeout =0
Wed Mar 20 09:47:32 2013: <191>166831:
Wed Mar 20 09:47:32 2013: <191>166832: .Mar 20 09:47:31: //-1/29DFEE4BB40A/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:47:32 2013: <191>166833:
Wed Mar 20 09:47:32 2013: <191>166834: Interface=0x498845E0, Call Info(
Wed Mar 20 09:47:32 2013: <191>166835:    Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:47:32 2013: <191>166836:    Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:47:32 2013: <191>166837:    Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Wed Mar 20 09:47:32 2013: <191>166838:    Incoming Dial-peer=50, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Wed Mar 20 09:47:32 2013: <191>166839:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:47:32 2013: <191>166840: .Mar 20 09:47:31: //-1/29DFEE4BB40A/CCAPI/ccCheckClipClir:
Wed Mar 20 09:47:32 2013: <191>166841:    In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:47:32 2013: <191>166842: .Mar 20 09:47:31: //-1/29DFEE4BB40A/CCAPI/ccCheckClipClir:
Wed Mar 20 09:47:32 2013: <191>166843:    Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:47:32 2013: <191>166844: .Mar 20 09:47:31: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:47:32 2013: <191>166845:
Wed Mar 20 09:47:32 2013: <191>166846: .Mar 20 09:47:31: :cc_get_feature_vsa malloc success
Wed Mar 20 09:47:32 2013: <191>166847: .Mar 20 09:47:31: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:47:32 2013: <191>166848:
Wed Mar 20 09:47:32 2013: <191>166849: .Mar 20 09:47:31:  cc_get_feature_vsa count is 1
Wed Mar 20 09:47:32 2013: <191>166850: .Mar 20 09:47:31: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:47:32 2013: <191>166851:
Wed Mar 20 09:47:32 2013: <191>166852: .Mar 20 09:47:31: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248360,feature_id:8168
Wed Mar 20 09:47:32 2013: <191>166853: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:47:32 2013: <191>166854:
Wed Mar 20 09:47:32 2013: <191>166855: Set Up Event Sent;
Wed Mar 20 09:47:32 2013: <191>166857:    Called Number=1811032099(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:47:32 2013: <191>166858: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:47:32 2013: <191>166861:    Try with the demoted called number 1811032099
Wed Mar 20 09:47:32 2013: <191>166862: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/ccCallSetContext:
Wed Mar 20 09:47:32 2013: <191>166867:
Wed Mar 20 09:47:32 2013: <191>166868: Progress Indication=NULL(0)
Wed Mar 20 09:47:32 2013: <191>166873:    In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:47:32 2013: <191>166874: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/ccCheckClipClir:
Wed Mar 20 09:47:32 2013: <191>166875:    Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:47:32 2013: <191>166876: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:47:32 2013: <191>166884:    Guid=29DFEE4B-9093-11E2-B40A-DE08FC69A21F, Outgoing Dial-peer=3000
Wed Mar 20 09:47:32 2013: <191>166886:    ccCallSetupRequest:
Wed Mar 20 09:47:32 2013: <191>166888:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:47:32 2013: <191>166889:    cisco-ani=
Wed Mar 20 09:47:32 2013: <191>166890:    cisco-anitype=0
Wed Mar 20 09:47:32 2013: <191>166891:    cisco-aniplan=0
Wed Mar 20 09:47:32 2013: <191>166892:    cisco-anipi=0
Wed Mar 20 09:47:32 2013: <191>166894:    cisco-anisi=0
Wed Mar 20 09:47:32 2013: <191>166899:    cisco-rdn=
Wed Mar 20 09:47:32 2013: <191>166903:    cisco-rdnpi=0
Wed Mar 20 09:47:32 2013: <191>166904:    cisco-rdnsi=0
Wed Mar 20 09:47:32 2013: <191>166908:
Wed Mar 20 09:47:32 2013: <191>166921: .Mar 20 09:47:31:  cc_get_feature_vsa count is 2
Wed Mar 20 09:47:32 2013: <191>166922: .Mar 20 09:47:31: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:47:32 2013: <191>166923:
Wed Mar 20 09:47:32 2013: <191>166924: .Mar 20 09:47:31: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248136,feature_id:8169
Wed Mar 20 09:47:32 2013: <191>166925: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:47:32 2013: <191>166926:    SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Wed Mar 20 09:47:32 2013: <191>166927: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/ccCallSetContext:
Wed Mar 20 09:47:32 2013: <191>166928:    Context=0x4BA7CBB8
Wed Mar 20 09:47:32 2013: <191>166929: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:47:32 2013: <191>166930:    Outgoing Dial-peer=3000
Wed Mar 20 09:47:32 2013: <191>166931: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:47:32 2013: <191>166932:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:47:32 2013: <191>166933: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:47:32 2013: <191>166934:    Interface=0x48A4F728, Progress Indication=NULL(0)
Wed Mar 20 09:47:32 2013: <191>166935: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:47:32 2013: <191>166936:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:47:32 2013: <191>166937: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_set_delay_xport:
Wed Mar 20 09:47:32 2013: <191>166938:    CallInfo(delay xport=TRUE)
Wed Mar 20 09:47:32 2013: <191>166939: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_call_alert:
Wed Mar 20 09:47:32 2013: <191>166940:    Interface=0x48A4F728, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:47:32 2013: <191>166941: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_call_alert:
Wed Mar 20 09:47:32 2013: <191>166942:    Call Entry(Retry Count=0, Responsed=TRUE)
Wed Mar 20 09:47:32 2013: <191>166943: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/ccCallAlert:
Wed Mar 20 09:47:32 2013: <191>166944:
Wed Mar 20 09:47:32 2013: <191>166945: Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:47:32 2013: <191>166946: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/ccCallAlert:
Wed Mar 20 09:47:32 2013: <191>166947:    Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Wed Mar 20 09:47:32 2013: <191>166948: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:47:32 2013: <191>166949:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:47:32 2013: <191>166950: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_call_notify:
Wed Mar 20 09:47:32 2013: <191>166951:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8169
Wed Mar 20 09:47:32 2013: <191>166952: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/ccIsInfoRingback:
Wed Mar 20 09:47:32 2013: <191>166953:    Returning dpRingBack=0
Wed Mar 20 09:47:32 2013: <191>166954: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:47:32 2013: <191>166955:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:47:32 2013: <191>166956: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:47:32 2013: <191>166957:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:47:32 2013: <191>166958: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/ccCallNotify:
Wed Mar 20 09:47:32 2013: <191>166959:    Data Bitmask=0x5, Call Id=8168
Wed Mar 20 09:47:32 2013: <191>166960: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_call_connected:
Wed Mar 20 09:47:32 2013: <191>166961:    Interface=0x48A4F728, Data Bitmask=0x0, Progress Indication=NULL(0),
Wed Mar 20 09:47:32 2013: <191>166962:    Connection Handle=0
Wed Mar 20 09:47:32 2013: <191>166963: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_call_connected:
Wed Mar 20 09:47:32 2013: <191>166964:    Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:47:32 2013: <191>166965: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:47:32 2013: <191>166966:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:47:32 2013: <191>166967: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_call_notify:
Wed Mar 20 09:47:32 2013: <191>166968:
Wed Mar 20 09:47:32 2013: <191>166969: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8169
Wed Mar 20 09:47:32 2013: <191>166970: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:47:32 2013: <191>166971:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:47:32 2013: <191>166972:    Tone Direction=Network, Params=0x0, Call Id=8168
Wed Mar 20 09:47:32 2013: <191>166973: .Mar 20 09:47:31: //8168/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:47:32 2013: <191>166974:    (confID=0x4BB01D20, callID1=0x1FE8, callID2=0x1FE9, tag=0x0)
Wed Mar 20 09:47:32 2013: <191>166975: .Mar 20 09:47:31: //8168/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:47:32 2013: <191>166976:    (confID=0x4BB01D20, callID1=0x1FE8, gcid=29DFEE4B-909311E2-B40ADE08-FC69A21F, tag=0x0)
Wed Mar 20 09:47:32 2013: <191>166977: .Mar 20 09:47:31: //8169/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:47:32 2013: <191>166978:    (confID=0x4BB01D20, callID2=0x1FE9, gcid=29DFEE4B-909311E2-B40ADE08-FC69A21F, tag=0x0)
Wed Mar 20 09:47:32 2013: <191>166979: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/ccConferenceCreate:
Wed Mar 20 09:47:32 2013: <191>166980:    Conference Id=0x4BB01D20, Call Id1=8168, Call Id2=8169, Tag=0x0
Wed Mar 20 09:47:32 2013: <191>166981: .Mar 20 09:47:31: //8168/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:47:32 2013: <191>166982:    Conference Id=0xE61, Source Interface=0x498845E0, Source Call Id=8168,
Wed Mar 20 09:47:32 2013: <191>166983:    Destination Call Id=8169, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:47:32 2013: <191>166984: .Mar 20 09:47:31: //8169/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:47:32 2013: <191>166985:
Wed Mar 20 09:47:32 2013: <191>166986: .Mar 20 09:47:31: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:47:32 2013: <191>166987: .Mar 20 09:47:31: //8169/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:47:32 2013: <191>166988:    Conference Id=0xE61, Source Interface=0x48A4F728, Source Call Id=8169,
Wed Mar 20 09:47:32 2013: <191>166989:    Destination Call Id=8168, Disposition=0x0, Tag=0x0
Wed Mar 20 09:47:32 2013: <191>166990: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:47:32 2013: <191>166991:    Conference Id=0xE61, Source Interface=0x48A4F728, Source Call Id=8169,
Wed Mar 20 09:47:32 2013: <191>166992:    Destination Call Id=8168, Disposition=0x0, Tag=0x0
Wed Mar 20 09:47:32 2013: <191>166993: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/ccConferenceCreate:
Wed Mar 20 09:47:32 2013: <191>166995: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/ccConferenceCreate:
Wed Mar 20 09:47:32 2013: <191>166997: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:47:32 2013: <191>167006: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:47:32 2013: <191>167013:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:47:32 2013: <191>167014: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:47:32 2013: <191>167015:    Destination Interface=0x498845E0, Destination Call Id=8168, Source Call Id=8169,
Wed Mar 20 09:47:32 2013: <191>167018: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:47:32 2013: <191>167019:    Destination Interface=0x48A4F728, Destination Call Id=8169, Source Call Id=8168,
Wed Mar 20 09:47:32 2013: <191>167032: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/ccCallConnect:
Wed Mar 20 09:47:32 2013: <191>167033:    Progress Indication=NULL(0), Data Bitmask=0x0
Wed Mar 20 09:47:32 2013: <191>167034: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/ccCallConnect:
Wed Mar 20 09:47:33 2013: <191>167036: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:47:43 2013: <191>167037: .Mar 20 09:47:42: //8169/29DFEE4BB40A/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:47:43 2013: <191>167038:    Interface=0x0, Call Id=8169
Wed Mar 20 09:47:43 2013: <191>167039: .Mar 20 09:47:42: //8169/29DFEE4BB40A/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:47:43 2013: <191>167040:    Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:47:43 2013: <191>167041: .Mar 20 09:47:42: //8168/29DFEE4BB40A/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:47:43 2013: <191>167042:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:47:43 2013: <191>167043:    Tone Direction=Network, Params=0x0, Call Id=8168
Wed Mar 20 09:47:43 2013: <191>167044: .Mar 20 09:47:42: //8169/29DFEE4BB40A/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:47:43 2013: <191>167045:    Interface=0x48A4F728, Signal Indication=NOT PRESENT(255)
Wed Mar 20 09:47:43 2013: <191>167046: .Mar 20 09:47:42: //8169/29DFEE4BB40A/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:47:43 2013: <191>167047:    Interface=0x48A4F728, Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:47:43 2013: <191>167048: .Mar 20 09:47:42: //8168/29DFEE4BB40A/CCAPI/ccCallUserInfo:
Wed Mar 20 09:47:43 2013: <191>167049:    Call Id=8168
Wed Mar 20 09:47:43 2013: <191>167050: .Mar 20 09:47:42: //8168/29DFEE4BB40A/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:47:43 2013: <191>167051:    Stop Tone On Digit=FALSE, Tone=Ring Back,
Wed Mar 20 09:47:43 2013: <191>167052:    Tone Direction=Network, Params=0x0, Call Id=8168
Wed Mar 20 09:47:43 2013: <191>167053: .Mar 20 09:47:42: //8169/29DFEE4BB40A/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:47:43 2013: <191>167054:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:47:43 2013: <191>167055: .Mar 20 09:47:42: //8169/29DFEE4BB40A/CCAPI/cc_api_call_notify:
Wed Mar 20 09:47:43 2013: <191>167056:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8169
Wed Mar 20 09:47:43 2013: <191>167057: .Mar 20 09:47:42: //8169/29DFEE4BB40A/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:47:43 2013: <191>167058:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:47:44 2013: <191>167059: .Mar 20 09:47:42: //8169/29DFEE4BB40A/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:47:44 2013: <191>167060:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:47:44 2013: <191>167061: .Mar 20 09:47:42: //8168/29DFEE4BB40A/CCAPI/ccCallNotify:
Wed Mar 20 09:47:44 2013: <191>167062:    Data Bitmask=0x5, Call Id=8168
Wed Mar 20 09:47:46 2013: <191>167063: .Mar 20 09:47:45: //8169/29DFEE4BB40A/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:47:46 2013: <191>167064:    Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:47:46 2013: <191>167065: .Mar 20 09:47:45: //8168/29DFEE4BB40A/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:47:46 2013: <191>167066:    Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:47:46 2013: <191>167067:    Tone Direction=Network, Params=0x0, Call Id=8168
Wed Mar 20 09:47:46 2013: <191>167068: .Mar 20 09:47:45: //8169/29DFEE4BB40A/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:47:46 2013: <191>167069:    CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:47:46 2013: <191>167070: .Mar 20 09:47:45: //8169/29DFEE4BB40A/CCAPI/cc_api_call_notify:
Wed Mar 20 09:47:46 2013: <191>167071:    Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8169
Wed Mar 20 09:47:46 2013: <191>167072: .Mar 20 09:47:45: //8169/29DFEE4BB40A/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:47:46 2013: <191>167073:    CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:47:46 2013: <191>167074: .Mar 20 09:47:45: //8169/29DFEE4BB40A/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:47:46 2013: <191>167075:    CallInfo(ccm detected=TRUE)
Wed Mar 20 09:47:46 2013: <191>167076: .Mar 20 09:47:45: //8168/29DFEE4BB40A/CCAPI/ccCallNotify:
Wed Mar 20 09:47:46 2013: <191>167077:    Data Bitmask=0x5, Call Id=8168
Wed Mar 20 09:47:46 2013: <191>167078: .Mar 20 09:47:45: //8169/29DFEE4BB40A/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:47:46 2013: <191>167079:    Destination Interface=0x498845E0, Destination Call Id=8168, Source Call Id=8169,
Wed Mar 20 09:47:46 2013: <191>167080:    Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:47:46 2013: <191>167081:    Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:47:46 2013: <191>167082: .Mar 20 09:47:45: //8169/29DFEE4BB40A/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:47:46 2013: <191>167083:    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:47:46 2013: <191>167084:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:47:46 2013: <191>167085: .Mar 20 09:47:45: //8169/29DFEE4BB40A/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:47:46 2013: <191>167086:
Wed Mar 20 09:47:46 2013: <191>167087: Destination Interface=0x498845E0, Destination Call Id=8168, Source Call Id=8169,
Wed Mar 20 09:47:46 2013: <191>167088:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:47:46 2013: <191>167089:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6796)
Wed Mar 20 09:47:46 2013: <191>167090: .Mar 20 09:47:45: //8168/29DFEE4BB40A/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:47:46 2013: <191>167091:    Destination Interface=0x48A4F728, Destination Call Id=8169, Source Call Id=8168,
Wed Mar 20 09:47:46 2013: <191>167092:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:47:46 2013: <191>167093:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6796)
Wed Mar 20 09:47:46 2013: <191>167094: .Mar 20 09:47:45: //8168/29DFEE4BB40A/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:47:46 2013: <191>167095:    Call Id=8168
Wed Mar 20 09:47:46 2013: <191>167096: .Mar 20 09:47:45: //8168/29DFEE4BB40A/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:47:46 2013: <191>167097:
Wed Mar 20 09:47:47 2013: <191>167098: Call Entry(Context=0x4BA6AE40)
Wed Mar 20 09:49:53 2013: <191>167099: .Mar 20 09:49:52: //8169/29DFEE4BB40A/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:49:53 2013: <191>167100:    Cause Value=16, Interface=0x48A4F728, Call Id=8169
Wed Mar 20 09:49:53 2013: <191>167101: .Mar 20 09:49:52: //8169/29DFEE4BB40A/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:49:53 2013: <191>167102:    Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:49:53 2013: <191>167103: .Mar 20 09:49:52: //8168/29DFEE4BB40A/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:49:53 2013: <191>167104:    Conference Id=0xE61, Tag=0x0
Wed Mar 20 09:49:53 2013: <191>167105: .Mar 20 09:49:52: //8168/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:49:53 2013: <191>167106:    Conference Id=0xE61, Source Interface=0x498845E0, Source Call Id=8168,
Wed Mar 20 09:49:53 2013: <191>167107:    Destination Call Id=8169, Disposition=0x0, Tag=0x0
Wed Mar 20 09:49:53 2013: <191>167108: .Mar 20 09:49:52: //8169/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:49:53 2013: <191>167109:
Wed Mar 20 09:49:53 2013: <191>167110: Conference Id=0xE61, Source Interface=0x48A4F728, Source Call Id=8169,
Wed Mar 20 09:49:53 2013: <191>167111:    Destination Call Id=8168, Disposition=0x0, Tag=0x0
Wed Mar 20 09:49:53 2013: <191>167112: .Mar 20 09:49:52: //8168/29DFEE4BB40A/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:49:53 2013: <191>167113:    Conference Id=0xE61, Source Interface=0x48A4F728, Source Call Id=8169,
Wed Mar 20 09:49:53 2013: <191>167114:    Destination Call Id=8168, Disposition=0x0, Tag=0x0
Wed Mar 20 09:49:53 2013: <191>167115: .Mar 20 09:49:52: //8168/29DFEE4BB40A/CCAPI/ccCallDisconnect:
Wed Mar 20 09:49:53 2013: <191>167116:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:49:53 2013: <191>167117: .Mar 20 09:49:52: //8168/29DFEE4BB40A/CCAPI/ccCallDisconnect:
Wed Mar 20 09:49:53 2013: <191>167118:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:49:53 2013: <191>167119: .Mar 20 09:49:52: //8168/29DFEE4BB40A/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:49:53 2013: <191>167120:
Wed Mar 20 09:49:53 2013: <191>167121: Transfer Number Is Null
Wed Mar 20 09:49:53 2013: <191>167122: .Mar 20 09:49:52: //8169/29DFEE4BB40A/CCAPI/ccCallDisconnect:
Wed Mar 20 09:49:53 2013: <191>167123:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:49:53 2013: <191>167124: .Mar 20 09:49:52: //8169/29DFEE4BB40A/CCAPI/ccCallDisconnect:
Wed Mar 20 09:49:53 2013: <191>167125:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:49:53 2013: <191>167126: .Mar 20 09:49:52: //8169/29DFEE4BB40A/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:49:53 2013: <191>167127:    Transfer Number Is Null
Wed Mar 20 09:49:53 2013: <191>167128: .Mar 20 09:49:52: //8169/29DFEE4BB40A/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:49:53 2013: <191>167129:    Transfer Number Is Null
Wed Mar 20 09:49:53 2013: <191>167130: .Mar 20 09:49:52: //8169/29DFEE4BB40A/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:49:53 2013: <191>167131:
Wed Mar 20 09:49:53 2013: <191>167132: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8169,
Wed Mar 20 09:49:53 2013: <191>167133:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:49:53 2013: <191>167134: .Mar 20 09:49:52: //8169/29DFEE4BB40A/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:49:53 2013: <191>167135:    Call Disconnect Event Sent
Wed Mar 20 09:49:53 2013: <191>167136: .Mar 20 09:49:52: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:49:53 2013: <191>167137:
Wed Mar 20 09:49:53 2013: <191>167138: .Mar 20 09:49:52: :cc_free_feature_vsa freeing 47B81C00
Wed Mar 20 09:49:53 2013: <191>167139: .Mar 20 09:49:52: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:49:53 2013: <191>167140:
Wed Mar 20 09:49:53 2013: <191>167141: .Mar 20 09:49:52:  vsacount in free is 1
Wed Mar 20 09:49:53 2013: <191>167142: .Mar 20 09:49:52: //8168/29DFEE4BB40A/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:49:53 2013: <191>167143:    Disposition=0, Interface=0x498845E0, Tag=0x0, Call Id=8168,
Wed Mar 20 09:49:53 2013: <191>167144:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:49:54 2013: <191>167145: .Mar 20 09:49:52: //8168/29DFEE4BB40A/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:49:54 2013: <191>167146:    Call Disconnect Event Sent
Wed Mar 20 09:49:54 2013: <191>167147: .Mar 20 09:49:52: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:49:54 2013: <191>167148:
Wed Mar 20 09:49:54 2013: <191>167149: .Mar 20 09:49:52: :cc_free_feature_vsa freeing 47B81CE0
Wed Mar 20 09:49:54 2013: <191>167150: .Mar 20 09:49:52: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:49:54 2013: <191>167151:
Wed Mar 20 09:49:54 2013: <191>167152: .Mar 20 09:49:52:  vsacount in free is 0
Wed Mar 20 09:51:52 2013: <190>167153: .Mar 20 09:51:50: %IPPHONE-6-REGISTER_NEW: ephone-5:SEP002699441E44 IP:10.229.64.32 Socket:5 DeviceType:Phone has registered.
Wed Mar 20 09:52:54 2013: <191>167154: .Mar 20 09:52:52: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
Wed Mar 20 09:52:54 2013: <191>167155:    ccAppShutdownMode: remove it from the queue
Wed Mar 20 09:53:41 2013: <191>167156: .Mar 20 09:53:40: //-1/05FF2D55B40F/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:53:41 2013: <191>167157:    cc_api_call_setup_ind_common:
Wed Mar 20 09:53:41 2013: <191>167159:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:53:41 2013: <191>167158:    cisco-username=
Wed Mar 20 09:53:41 2013: <191>167160:    cisco-ani=1811032004
Wed Mar 20 09:53:41 2013: <191>167161:    cisco-anitype=0
Wed Mar 20 09:53:41 2013: <191>167162:    cisco-aniplan=0
Wed Mar 20 09:53:41 2013: <191>167163:    cisco-anipi=0
Wed Mar 20 09:53:41 2013: <191>167164:    cisco-anisi=0
Wed Mar 20 09:53:41 2013: <191>167165:    dest=
Wed Mar 20 09:53:41 2013: <191>167166:    cisco-desttype=0
Wed Mar 20 09:53:41 2013: <191>167167:    cisco-destplan=0
Wed Mar 20 09:53:41 2013: <191>167168:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:53:41 2013: <191>167169:    cisco-rdn=
Wed Mar 20 09:53:41 2013: <191>167170:    cisco-lastrdn=
Wed Mar 20 09:53:41 2013: <191>167171:    cisco-rdntype=0
Wed Mar 20 09:53:41 2013: <191>167172:    cisco-rdnplan=0
Wed Mar 20 09:53:41 2013: <191>167173:    cisco-rdnpi=0
Wed Mar 20 09:53:41 2013: <191>167174:    cisco-rdnsi=0
Wed Mar 20 09:53:41 2013: <191>167175:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:53:41 2013: <191>167176:    final_redirectNumber =
Wed Mar 20 09:53:41 2013: <191>167177:    hunt_group_timeout =0
Wed Mar 20 09:53:41 2013: <191>167178:
Wed Mar 20 09:53:41 2013: <191>167179: .Mar 20 09:53:40: //-1/05FF2D55B40F/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:53:41 2013: <191>167180:
Wed Mar 20 09:53:41 2013: <191>167181: Interface=0x4B806530, Call Info(
Wed Mar 20 09:53:41 2013: <191>167182:    Calling Number=1811032004,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:53:41 2013: <191>167183:    Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:53:41 2013: <191>167184:    Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:53:41 2013: <191>167185:    Incoming Dial-peer=20009, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:53:41 2013: <191>167186:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:53:41 2013: <191>167187: .Mar 20 09:53:40: //-1/05FF2D55B40F/CCAPI/ccCheckClipClir:
Wed Mar 20 09:53:41 2013: <191>167188:    In: Calling Number=1811032004(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:53:41 2013: <191>167189: .Mar 20 09:53:40: //-1/05FF2D55B40F/CCAPI/ccCheckClipClir:
Wed Mar 20 09:53:41 2013: <191>167190:    Out: Calling Number=1811032004(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:53:41 2013: <191>167191: .Mar 20 09:53:40: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:53:41 2013: <191>167192:
Wed Mar 20 09:53:41 2013: <191>167193: .Mar 20 09:53:40: :cc_get_feature_vsa malloc success
Wed Mar 20 09:53:41 2013: <191>167194: .Mar 20 09:53:40: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:53:41 2013: <191>167195:
Wed Mar 20 09:53:41 2013: <191>167196: .Mar 20 09:53:40:  cc_get_feature_vsa count is 1
Wed Mar 20 09:53:41 2013: <191>167197: .Mar 20 09:53:40: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:53:41 2013: <191>167198:
Wed Mar 20 09:53:41 2013: <191>167199: .Mar 20 09:53:40: :FEATURE_VSA attributes are: feature_name:0,feature_time:1271880472,feature_id:8170
Wed Mar 20 09:53:41 2013: <191>167200: .Mar 20 09:53:40: //8170/05FF2D55B40F/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:53:41 2013: <191>167201:
Wed Mar 20 09:53:41 2013: <191>167202: Set Up Event Sent;
Wed Mar 20 09:53:41 2013: <191>167203:    Call Info(Calling Number=1811032004(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:53:41 2013: <191>167205: .Mar 20 09:53:40: //8170/05FF2D55B40F/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:53:41 2013: <191>167209: .Mar 20 09:53:40: //8170/05FF2D55B40F/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:53:41 2013: <191>167213: .Mar 20 09:53:40: //8170/05FF2D55B40F/CCAPI/cc_api_set_transfer_info:
Wed Mar 20 09:53:41 2013: <191>167214:
Wed Mar 20 09:53:41 2013: <191>167215: Transfer Number=, Transfer Reason=0x0
Wed Mar 20 09:53:41 2013: <191>167216: .Mar 20 09:53:40: //8170/05FF2D55B40F/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:53:41 2013: <191>167223: .Mar 20 09:53:40: //8170/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
Wed Mar 20 09:53:41 2013: <191>167224:    (callID=0x1FEA, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:53:41 2013: <191>167225: .Mar 20 09:53:40: //8170/05FF2D55B40F/CCAPI/ccCallReportDigits:
Wed Mar 20 09:53:42 2013: <191>167227: Enabled=TRUE, Call Id=8170
Wed Mar 20 09:53:42 2013: <191>167228: .Mar 20 09:53:40: //8170/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:53:42 2013: <191>167229:    (vdbPtr=0x4B806530, callID=0x1FEA, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:53:42 2013: <191>167230: .Mar 20 09:53:40: //8170/05FF2D55B40F/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:53:42 2013: <191>167231:    Enabled=TRUE, Disposition=0x0, Interface=0x4B806530, Call Id=8170
Wed Mar 20 09:53:42 2013: <191>167232: .Mar 20 09:53:40: //8170/05FF2D55B40F/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:53:42 2013: <191>167233:    Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:53:42 2013: <191>167234: .Mar 20 09:53:41: //8170/05FF2D55B40F/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:53:42 2013: <191>167235:    Cause Value=16, Interface=0x4B806530, Call Id=8170
Wed Mar 20 09:53:42 2013: <191>167236: .Mar 20 09:53:41: //8170/05FF2D55B40F/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:53:42 2013: <191>167237:    Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:53:42 2013: <191>167238: .Mar 20 09:53:41: //8170/05FF2D55B40F/CCAPI/ccCallDisconnect:
Wed Mar 20 09:53:42 2013: <191>167239:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:53:42 2013: <191>167240: .Mar 20 09:53:41: //8170/05FF2D55B40F/CCAPI/ccCallDisconnect:
Wed Mar 20 09:53:42 2013: <191>167241:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:53:42 2013: <191>167242: .Mar 20 09:53:41: //8170/05FF2D55B40F/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:53:42 2013: <191>167243:    Transfer Number Is Null
Wed Mar 20 09:53:42 2013: <191>167244: .Mar 20 09:53:41: //8170/05FF2D55B40F/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:53:42 2013: <191>167245:
Wed Mar 20 09:53:43 2013: <191>167246: Disposition=0, Interface=0x4B806530, Tag=0x0, Call Id=8170,
Wed Mar 20 09:53:43 2013: <191>167247:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:53:43 2013: <191>167248: .Mar 20 09:53:41: //8170/05FF2D55B40F/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:53:43 2013: <191>167249:    Call Disconnect Event Sent
Wed Mar 20 09:53:43 2013: <191>167250: .Mar 20 09:53:41: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:53:43 2013: <191>167251:
Wed Mar 20 09:53:43 2013: <191>167252: .Mar 20 09:53:41: :cc_free_feature_vsa freeing 4BCF5B10
Wed Mar 20 09:53:43 2013: <191>167253: .Mar 20 09:53:41: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:53:43 2013: <191>167254:
Wed Mar 20 09:53:43 2013: <191>167255: .Mar 20 09:53:41:  vsacount in free is 0
Wed Mar 20 09:54:03 2013: <190>167256: .Mar 20 09:54:01: %IPPHONE-6-UNREGISTER_NORMAL: ephone-5:SEP002699441E44 IP:10.229.64.32 Socket:5 DeviceType:Phone has unregistered normally.
Wed Mar 20 09:54:15 2013: <190>167257: .Mar 20 09:54:12: %IPPHONE-6-REGISTER_NEW: ephone-5:SEP002699441E44 IP:10.229.64.32 Socket:5 DeviceType:Phone has registered.
Wed Mar 20 09:55:57 2013: <191>167259:    cc_api_call_setup_ind_common:
Wed Mar 20 09:55:57 2013: <191>167258: .Mar 20 09:55:55: //-1/56C47A74B413/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:55:57 2013: <191>167260:    cisco-username=
Wed Mar 20 09:55:57 2013: <191>167261:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:55:57 2013: <191>167262:    cisco-ani=1811032004
Wed Mar 20 09:55:57 2013: <191>167263:    cisco-anitype=0
Wed Mar 20 09:55:57 2013: <191>167264:    cisco-aniplan=0
Wed Mar 20 09:55:57 2013: <191>167265:    cisco-anipi=0
Wed Mar 20 09:55:57 2013: <191>167266:    cisco-anisi=0
Wed Mar 20 09:55:57 2013: <191>167267:    dest=
Wed Mar 20 09:55:57 2013: <191>167268:    cisco-desttype=0
Wed Mar 20 09:55:57 2013: <191>167269:    cisco-destplan=0
Wed Mar 20 09:55:57 2013: <191>167270:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:55:57 2013: <191>167271:    cisco-rdn=
Wed Mar 20 09:55:57 2013: <191>167272:    cisco-lastrdn=
Wed Mar 20 09:55:57 2013: <191>167273:    cisco-rdntype=0
Wed Mar 20 09:55:57 2013: <191>167274:    cisco-rdnplan=0
Wed Mar 20 09:55:57 2013: <191>167275:    cisco-rdnpi=0
Wed Mar 20 09:55:57 2013: <191>167276:    cisco-rdnsi=0
Wed Mar 20 09:55:57 2013: <191>167277:    cisco-redirectreason=0   fwd_final_type =0
Wed Mar 20 09:55:57 2013: <191>167278:    final_redirectNumber =
Wed Mar 20 09:55:57 2013: <191>167279:    hunt_group_timeout =0
Wed Mar 20 09:55:57 2013: <191>167280:
Wed Mar 20 09:55:57 2013: <191>167281: .Mar 20 09:55:55: //-1/56C47A74B413/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:55:57 2013: <191>167282:
Wed Mar 20 09:55:57 2013: <191>167283: Interface=0x4B806530, Call Info(
Wed Mar 20 09:55:57 2013: <191>167284:    Calling Number=1811032004,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:55:57 2013: <191>167285:    Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:55:57 2013: <191>167286:    Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:55:57 2013: <191>167287:    Incoming Dial-peer=20009, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:55:57 2013: <191>167288:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:55:57 2013: <191>167289: .Mar 20 09:55:55: //-1/56C47A74B413/CCAPI/ccCheckClipClir:
Wed Mar 20 09:55:57 2013: <191>167290:    In: Calling Number=1811032004(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:55:57 2013: <191>167291: .Mar 20 09:55:55: //-1/56C47A74B413/CCAPI/ccCheckClipClir:
Wed Mar 20 09:55:57 2013: <191>167292:    Out: Calling Number=1811032004(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:55:57 2013: <191>167293: .Mar 20 09:55:55: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:55:57 2013: <191>167294:
Wed Mar 20 09:55:57 2013: <191>167295: .Mar 20 09:55:55: :cc_get_feature_vsa malloc success
Wed Mar 20 09:55:57 2013: <191>167296: .Mar 20 09:55:55: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:55:57 2013: <191>167297:
Wed Mar 20 09:55:57 2013: <191>167298: .Mar 20 09:55:55:  cc_get_feature_vsa count is 1
Wed Mar 20 09:55:57 2013: <191>167299: .Mar 20 09:55:55: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:55:57 2013: <191>167300:
Wed Mar 20 09:55:57 2013: <191>167301: .Mar 20 09:55:55: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203336000,feature_id:8171
Wed Mar 20 09:55:57 2013: <191>167302: .Mar 20 09:55:55: //8171/56C47A74B413/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:55:57 2013: <191>167304: Set Up Event Sent;
Wed Mar 20 09:55:57 2013: <191>167306:    Called Number=(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:55:57 2013: <191>167309: .Mar 20 09:55:55: //8171/56C47A74B413/CCAPI/ccCallSetContext:
Wed Mar 20 09:55:57 2013: <191>167310:    Context=0x4BA67528
Wed Mar 20 09:55:57 2013: <191>167313: .Mar 20 09:55:55: //8171/56C47A74B413/CCAPI/ccCallSetupAck:
Wed Mar 20 09:55:57 2013: <191>167314:    Call Id=8171
Wed Mar 20 09:55:57 2013: <191>167318: .Mar 20 09:55:55: //8171/56C47A74B413/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:55:57 2013: <191>167327: .Mar 20 09:55:55: //8171/56C47A74B413/CCAPI/ccCallReportDigits:
Wed Mar 20 09:55:57 2013: <191>167328:
Wed Mar 20 09:55:58 2013: <191>167329: Enabled=TRUE, Call Id=8171
Wed Mar 20 09:55:58 2013: <191>167330: .Mar 20 09:55:55: //8171/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:55:58 2013: <191>167331:    (vdbPtr=0x4B806530, callID=0x1FEB, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:55:58 2013: <191>167332: .Mar 20 09:55:55: //8171/56C47A74B413/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:55:58 2013: <191>167333:    Enabled=TRUE, Disposition=0x0, Interface=0x4B806530, Call Id=8171
Wed Mar 20 09:55:58 2013: <191>167334: .Mar 20 09:55:55: //8171/56C47A74B413/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:55:58 2013: <191>167335:    Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:55:59 2013: <191>167336: .Mar 20 09:55:57: //8171/56C47A74B413/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:55:59 2013: <191>167337:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:55:59 2013: <191>167338:    Source Call Id=8171, Digit=0, DigitBeginFlags=0x0,
Wed Mar 20 09:55:59 2013: <191>167339:    Rtp Timestamp=0x3D18A0, Rtp Expiration=0x0
Wed Mar 20 09:55:59 2013: <191>167340: .Mar 20 09:55:57: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:55:59 2013: <191>167341:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:55:59 2013: <191>167342:    Source Call Id=8171, Digit=0, Duration=100,
Wed Mar 20 09:55:59 2013: <191>167343:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:55:59 2013: <191>167344: .Mar 20 09:55:57: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:55:59 2013: <191>167345:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:56:00 2013: <191>167346: .Mar 20 09:55:58: //8171/56C47A74B413/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:56:00 2013: <191>167347:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:00 2013: <191>167348:    Source Call Id=8171, Digit=9, DigitBeginFlags=0x0,
Wed Mar 20 09:56:00 2013: <191>167349:    Rtp Timestamp=0x3D95A0, Rtp Expiration=0x0
Wed Mar 20 09:56:00 2013: <191>167350: .Mar 20 09:55:58: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:00 2013: <191>167351:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:00 2013: <191>167352:    Source Call Id=8171, Digit=9, Duration=100,
Wed Mar 20 09:56:00 2013: <191>167353:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:56:00 2013: <191>167354: .Mar 20 09:55:58: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:00 2013: <191>167355:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:56:00 2013: <191>167356: .Mar 20 09:55:59: //8171/56C47A74B413/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:56:00 2013: <191>167357:
Wed Mar 20 09:56:01 2013: <191>167358: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:01 2013: <191>167359:    Source Call Id=8171, Digit=7, DigitBeginFlags=0x0,
Wed Mar 20 09:56:01 2013: <191>167360:    Rtp Timestamp=0x3E12A0, Rtp Expiration=0x0
Wed Mar 20 09:56:01 2013: <191>167361: .Mar 20 09:55:59: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:01 2013: <191>167362:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:01 2013: <191>167363:    Source Call Id=8171, Digit=7, Duration=100,
Wed Mar 20 09:56:01 2013: <191>167364:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:56:01 2013: <191>167365: .Mar 20 09:55:59: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:01 2013: <191>167366:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:56:01 2013: <191>167367: .Mar 20 09:56:00: //8171/56C47A74B413/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:56:01 2013: <191>167368:
Wed Mar 20 09:56:01 2013: <191>167369: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:01 2013: <191>167370:    Source Call Id=8171, Digit=1, DigitBeginFlags=0x0,
Wed Mar 20 09:56:01 2013: <191>167371:    Rtp Timestamp=0x3E8FA0, Rtp Expiration=0x0
Wed Mar 20 09:56:01 2013: <191>167372: .Mar 20 09:56:00: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:01 2013: <191>167373:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:01 2013: <191>167374:    Source Call Id=8171, Digit=1, Duration=100,
Wed Mar 20 09:56:01 2013: <191>167375:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:56:01 2013: <191>167376: .Mar 20 09:56:00: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:01 2013: <191>167377:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:56:01 2013: <191>167378: .Mar 20 09:56:00: //8171/56C47A74B413/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:56:01 2013: <191>167379:
Wed Mar 20 09:56:02 2013: <191>167380: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:02 2013: <191>167381:    Source Call Id=8171, Digit=4, DigitBeginFlags=0x0,
Wed Mar 20 09:56:02 2013: <191>167382:    Rtp Timestamp=0x3F0CA0, Rtp Expiration=0x0
Wed Mar 20 09:56:02 2013: <191>167383: .Mar 20 09:56:00: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:02 2013: <191>167384:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:02 2013: <191>167385:    Source Call Id=8171, Digit=4, Duration=100,
Wed Mar 20 09:56:02 2013: <191>167386:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:56:02 2013: <191>167387: .Mar 20 09:56:00: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:02 2013: <191>167388:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:56:02 2013: <191>167389: .Mar 20 09:56:00: //8171/56C47A74B413/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:56:02 2013: <191>167390:
Wed Mar 20 09:56:02 2013: <191>167391: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:02 2013: <191>167392:    Source Call Id=8171, Digit=4, DigitBeginFlags=0x0,
Wed Mar 20 09:56:02 2013: <191>167393:    Rtp Timestamp=0x3F89A0, Rtp Expiration=0x0
Wed Mar 20 09:56:02 2013: <191>167394: .Mar 20 09:56:00: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:02 2013: <191>167395:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:02 2013: <191>167396:    Source Call Id=8171, Digit=4, Duration=100,
Wed Mar 20 09:56:02 2013: <191>167397:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:56:02 2013: <191>167398: .Mar 20 09:56:00: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:02 2013: <191>167399:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:56:02 2013: <191>167400: .Mar 20 09:56:01: //8171/56C47A74B413/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:56:02 2013: <191>167401:
Wed Mar 20 09:56:02 2013: <191>167402: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:02 2013: <191>167403:    Source Call Id=8171, Digit=8, DigitBeginFlags=0x0,
Wed Mar 20 09:56:02 2013: <191>167404:    Rtp Timestamp=0x4006A0, Rtp Expiration=0x0
Wed Mar 20 09:56:02 2013: <191>167405: .Mar 20 09:56:01: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:02 2013: <191>167406:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:02 2013: <191>167407:    Source Call Id=8171, Digit=8, Duration=100,
Wed Mar 20 09:56:02 2013: <191>167408:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:56:02 2013: <191>167409: .Mar 20 09:56:01: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:02 2013: <191>167410:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:56:02 2013: <191>167411: .Mar 20 09:56:01: //8171/56C47A74B413/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:56:02 2013: <191>167412:
Wed Mar 20 09:56:02 2013: <191>167413: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:02 2013: <191>167414:    Source Call Id=8171, Digit=6, DigitBeginFlags=0x0,
Wed Mar 20 09:56:02 2013: <191>167415:    Rtp Timestamp=0x4083A0, Rtp Expiration=0x0
Wed Mar 20 09:56:02 2013: <191>167416: .Mar 20 09:56:01: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:03 2013: <191>167417:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:03 2013: <191>167418:    Source Call Id=8171, Digit=6, Duration=100,
Wed Mar 20 09:56:03 2013: <191>167419:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:56:03 2013: <191>167420: .Mar 20 09:56:01: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:03 2013: <191>167421:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:56:03 2013: <191>167422: .Mar 20 09:56:01: //8171/56C47A74B413/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:56:03 2013: <191>167423:
Wed Mar 20 09:56:03 2013: <191>167424: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:03 2013: <191>167425:    Source Call Id=8171, Digit=8, DigitBeginFlags=0x0,
Wed Mar 20 09:56:03 2013: <191>167426:    Rtp Timestamp=0x4100A0, Rtp Expiration=0x0
Wed Mar 20 09:56:03 2013: <191>167427: .Mar 20 09:56:01: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:03 2013: <191>167428:    Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:04 2013: <191>167429:    Source Call Id=8171, Digit=8, Duration=100,
Wed Mar 20 09:56:04 2013: <191>167430:    Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:56:04 2013: <191>167431: .Mar 20 09:56:01: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:04 2013: <191>167432:    Call Entry(Handoff Depth=0)
Wed Mar 20 09:56:11 2013: <191>167433: .Mar 20 09:56:09: //8171/56C47A74B413/CCAPI/cc_handle_inter_digit_timer:
Wed Mar 20 09:56:11 2013: <191>167434:    Generate inter-digit timeout CC_EV_CALL_DIGIT_END event
Wed Mar 20 09:56:11 2013: <191>167435: .Mar 20 09:56:09: //8171/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
Wed Mar 20 09:56:11 2013: <191>167436:    (callID=0x1FEB, digit_event=0x0, enable=FALSE, consume=FALSE)
Wed Mar 20 09:56:11 2013: <191>167437: .Mar 20 09:56:09: //8171/56C47A74B413/CCAPI/ccCallReportDigits:
Wed Mar 20 09:56:11 2013: <191>167438:    Enabled=TRUE, Call Id=8171
Wed Mar 20 09:56:11 2013: <191>167439: .Mar 20 09:56:09: //8171/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:56:11 2013: <191>167440:    (vdbPtr=0x4B806530, callID=0x1FEB, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Wed Mar 20 09:56:11 2013: <191>167441: .Mar 20 09:56:09: //8171/56C47A74B413/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:56:11 2013: <191>167442:    Enabled=TRUE, Disposition=0x0, Interface=0x4B806530, Call Id=8171
Wed Mar 20 09:56:11 2013: <191>167443: .Mar 20 09:56:09: //8171/56C47A74B413/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:56:11 2013: <191>167444:    Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:56:11 2013: <191>167445: .Mar 20 09:56:09: //8171/56C47A74B413/CCAPI/ccCallProceeding:
Wed Mar 20 09:56:11 2013: <191>167446:    Progress Indication=NULL(0)
Wed Mar 20 09:56:11 2013: <191>167447: .Mar 20 09:56:09: //8171/56C47A74B413/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:56:11 2013: <191>167448:    Destination=, Calling IE Present=TRUE, Mode=0,
Wed Mar 20 09:56:11 2013: <191>167449:    Outgoing Dial-peer=20, Params=0x4BA6D4A0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Wed Mar 20 09:56:11 2013: <191>167450: .Mar 20 09:56:09: //8171/56C47A74B413/CCAPI/ccCheckClipClir:
Wed Mar 20 09:56:11 2013: <191>167451:    In: Calling Number=1811032004(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:56:11 2013: <191>167452: .Mar 20 09:56:09: //8171/56C47A74B413/CCAPI/ccCheckClipClir:
Wed Mar 20 09:56:11 2013: <191>167453:    Out: Calling Number=1811032004(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:56:11 2013: <191>167454: .Mar 20 09:56:09: //8171/56C47A74B413/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:56:11 2013: <191>167455:    Destination Pattern=09......T, Called Number=097144868, Digit Strip=TRUE
Wed Mar 20 09:56:11 2013: <191>167456: .Mar 20 09:56:09: //8171/56C47A74B413/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:56:11 2013: <191>167457:    Calling Number=1811032004(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:56:11 2013: <191>167458:    Called Number=097144868(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:56:11 2013: <191>167459:    Redirect Number=, Display Info=1811032004
Wed Mar 20 09:56:11 2013: <191>167460:
Wed Mar 20 09:56:11 2013: <191>167461: Account Number=, Final Destination Flag=FALSE,
Wed Mar 20 09:56:11 2013: <191>167462:    Guid=56C47A74-9094-11E2-B413-DE08FC69A21F, Outgoing Dial-peer=20
Wed Mar 20 09:56:11 2013: <191>167463: .Mar 20 09:56:09: //8171/56C47A74B413/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:56:11 2013: <191>167464:    ccCallSetupRequest:
Wed Mar 20 09:56:11 2013: <191>167465:    cisco-username=
Wed Mar 20 09:56:11 2013: <191>167466:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:56:11 2013: <191>167467:    cisco-ani=1811032004
Wed Mar 20 09:56:11 2013: <191>167468:    cisco-anitype=0
Wed Mar 20 09:56:11 2013: <191>167469:    cisco-aniplan=0
Wed Mar 20 09:56:11 2013: <191>167470:    cisco-anipi=0
Wed Mar 20 09:56:11 2013: <191>167472:    dest=097144868
Wed Mar 20 09:56:11 2013: <191>167473:    cisco-desttype=0
Wed Mar 20 09:56:11 2013: <191>167477:    cisco-lastrdn=
Wed Mar 20 09:56:11 2013: <191>167479:    cisco-rdnplan=0
Wed Mar 20 09:56:11 2013: <191>167480:    cisco-rdnpi=0
Wed Mar 20 09:56:11 2013: <191>167490:    Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=20, Call Count On=FALSE,
Wed Mar 20 09:56:11 2013: <191>167493:
Wed Mar 20 09:56:11 2013: <191>167504:    Context=0x4BA6D450
Wed Mar 20 09:56:11 2013: <191>167505: .Mar 20 09:56:09: //8171/56C47A74B413/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:56:12 2013: <191>167507: .Mar 20 09:56:09: //8172/56C47A74B413/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:56:12 2013: <191>167508:    Interface=0x4987FF98, Progress Indication=NULL(0)
Wed Mar 20 09:56:13 2013: <191>167509: .Mar 20 09:56:12: //8172/56C47A74B413/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:56:13 2013: <191>167510:    Interface=0x4987FF98, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
Wed Mar 20 09:56:13 2013: <191>167511:    Cause Value=0
Wed Mar 20 09:56:13 2013: <191>167512: .Mar 20 09:56:12: //8172/56C47A74B413/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:56:13 2013: <191>167513:    Call Entry(Responsed=TRUE)
Wed Mar 20 09:56:13 2013: <191>167514: .Mar 20 09:56:12: //8171/56C47A74B413/CCAPI/ccCallCutProgress:
Wed Mar 20 09:56:13 2013: <191>167515:    Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
Wed Mar 20 09:56:13 2013: <191>167516:    Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Wed Mar 20 09:56:13 2013: <191>167517: .Mar 20 09:56:12: //8171/56C47A74B413/CCAPI/ccCallCutProgress:
Wed Mar 20 09:56:13 2013: <191>167518:    Call Entry(Responsed=TRUE)
Wed Mar 20 09:56:13 2013: <191>167519: .Mar 20 09:56:12: //8171/56C47A74B413/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:56:13 2013: <191>167520:
Wed Mar 20 09:56:14 2013: <191>167521: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:56:14 2013: <191>167522:    Tone Direction=Network, Params=0x0, Call Id=8171
Wed Mar 20 09:56:14 2013: <191>167523: .Mar 20 09:56:12: //8171/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:56:14 2013: <191>167524:    (confID=0x4BB02038, callID1=0x1FEB, callID2=0x1FEC, tag=0x0)
Wed Mar 20 09:56:14 2013: <191>167525: .Mar 20 09:56:12: //8171/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:56:14 2013: <191>167526:    (confID=0x4BB02038, callID1=0x1FEB, gcid=56C47A74-909411E2-B413DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:56:14 2013: <191>167527: .Mar 20 09:56:12: //8172/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:56:14 2013: <191>167528:    (confID=0x4BB02038, callID2=0x1FEC, gcid=56C47A74-909411E2-B413DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:56:14 2013: <191>167529: .Mar 20 09:56:12: //8171/56C47A74B413/CCAPI/ccConferenceCreate:
Wed Mar 20 09:56:14 2013: <191>167530:    Conference Id=0x4BB02038, Call Id1=8171, Call Id2=8172, Tag=0x0
Wed Mar 20 09:56:14 2013: <191>167531: .Mar 20 09:56:12: //8171/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:56:14 2013: <191>167532:    Conference Id=0xE62, Source Interface=0x4B806530, Source Call Id=8171,
Wed Mar 20 09:56:14 2013: <191>167533:    Destination Call Id=8172, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:56:14 2013: <191>167534: .Mar 20 09:56:12: //8172/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:56:14 2013: <191>167535:    Conference Id=0xE62, Source Interface=0x4987FF98, Source Call Id=8172,
Wed Mar 20 09:56:14 2013: <191>167536:    Destination Call Id=8171, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:56:14 2013: <191>167537: .Mar 20 09:56:12: //8171/56C47A74B413/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:56:14 2013: <191>167538:    Conference Id=0xE62, Source Interface=0x4987FF98, Source Call Id=8172,
Wed Mar 20 09:56:14 2013: <191>167539:    Destination Call Id=8171, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:56:14 2013: <191>167540: .Mar 20 09:56:12: //8171/56C47A74B413/CCAPI/ccConferenceCreate:
Wed Mar 20 09:56:14 2013: <191>167541:
Wed Mar 20 09:56:14 2013: <191>167542: Call Entry(Conference Id=0xE62, Destination Call Id=8172)
Wed Mar 20 09:56:14 2013: <191>167543: .Mar 20 09:56:12: //8172/56C47A74B413/CCAPI/ccConferenceCreate:
Wed Mar 20 09:56:14 2013: <191>167544:    Call Entry(Conference Id=0xE62, Destination Call Id=8171)
Wed Mar 20 09:56:14 2013: <191>167545: .Mar 20 09:56:12: //8171/56C47A74B413/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:56:14 2013: <191>167546:    Destination Interface=0x4987FF98, Destination Call Id=8172, Source Call Id=8171,
Wed Mar 20 09:56:14 2013: <191>167549: .Mar 20 09:56:12: //8171/56C47A74B413/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:56:14 2013: <191>167552: .Mar 20 09:56:12: //8172/56C47A74B413/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:56:14 2013: <191>167553:
Wed Mar 20 09:56:14 2013: <191>167554: Destination Interface=0x4B806530, Destination Call Id=8171, Source Call Id=8172,
Wed Mar 20 09:56:14 2013: <191>167558:    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:56:14 2013: <191>167559:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:56:14 2013: <191>167560: .Mar 20 09:56:12: //8172/56C47A74B413/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:56:14 2013: <191>167561:    Destination Interface=0x4B806530, Destination Call Id=8171, Source Call Id=8172,
Wed Mar 20 09:56:14 2013: <191>167569:    Call Id=8171
Wed Mar 20 09:56:14 2013: <191>167571:    Call Entry(Context=0x4BA67528)
Wed Mar 20 09:56:14 2013: <191>167573:    Conference Id=0xE62, Call Id1=8171, Call Id2=8172
Wed Mar 20 09:56:14 2013: <191>167574: .Mar 20 09:56:12: //8171/56C47A74B413/CCAPI/ccCallFeature:
Wed Mar 20 09:56:14 2013: <191>167575:
Wed Mar 20 09:56:14 2013: <191>167576: Feature Type=25, Call Id=8171
Wed Mar 20 09:56:14 2013: <191>167584: .Mar 20 09:56:12: //8172/56C47A74B413/CCAPI/cc_api_call_connected:
Wed Mar 20 09:56:14 2013: <191>167585:    Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:56:14 2013: <191>167586: .Mar 20 09:56:12: //8171/56C47A74B413/CCAPI/ccCallConnect:
Wed Mar 20 09:56:14 2013: <191>167587:    Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
Wed Mar 20 09:56:14 2013: <191>167588: .Mar 20 09:56:12: //8171/56C47A74B413/CCAPI/ccCallConnect:
Wed Mar 20 09:56:14 2013: <191>167589:    Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:56:14 2013: <191>167590: .Mar 20 09:56:12: //8171/56C47A74B413/CCAPI/ccCallFeature:
Wed Mar 20 09:56:14 2013: <191>167591:    Feature Type=25, Call Id=8171
Wed Mar 20 09:57:27 2013: <191>167592: .Mar 20 09:57:26: //8171/56C47A74B413/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:57:27 2013: <191>167593:    Cause Value=16, Interface=0x4B806530, Call Id=8171
Wed Mar 20 09:57:27 2013: <191>167594: .Mar 20 09:57:26: //8171/56C47A74B413/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:57:27 2013: <191>167595:    Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:57:27 2013: <191>167596: .Mar 20 09:57:26: //8171/56C47A74B413/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:57:27 2013: <191>167597:    Conference Id=0xE62, Tag=0x0
Wed Mar 20 09:57:27 2013: <191>167598: .Mar 20 09:57:26: //8171/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:57:27 2013: <191>167599:    Conference Id=0xE62, Source Interface=0x4B806530, Source Call Id=8171,
Wed Mar 20 09:57:27 2013: <191>167600:    Destination Call Id=8172, Disposition=0x0, Tag=0x0
Wed Mar 20 09:57:27 2013: <191>167601: .Mar 20 09:57:26: //8172/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:57:27 2013: <191>167602:
Wed Mar 20 09:57:27 2013: <191>167603: Conference Id=0xE62, Source Interface=0x4987FF98, Source Call Id=8172,
Wed Mar 20 09:57:27 2013: <191>167604:    Destination Call Id=8171, Disposition=0x0, Tag=0x0
Wed Mar 20 09:57:27 2013: <191>167605: .Mar 20 09:57:26: //8171/56C47A74B413/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:57:27 2013: <191>167606:    Conference Id=0xE62, Source Interface=0x4987FF98, Source Call Id=8172,
Wed Mar 20 09:57:27 2013: <191>167607:    Destination Call Id=8171, Disposition=0x0, Tag=0x0
Wed Mar 20 09:57:27 2013: <191>167608: .Mar 20 09:57:26: //8171/56C47A74B413/CCAPI/ccCallDisconnect:
Wed Mar 20 09:57:27 2013: <191>167609:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:57:27 2013: <191>167610: .Mar 20 09:57:26: //8171/56C47A74B413/CCAPI/ccCallDisconnect:
Wed Mar 20 09:57:27 2013: <191>167611:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:57:27 2013: <191>167612: .Mar 20 09:57:26: //8171/56C47A74B413/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:57:27 2013: <191>167613:
Wed Mar 20 09:57:27 2013: <191>167614: Transfer Number Is Null
Wed Mar 20 09:57:27 2013: <191>167615: .Mar 20 09:57:26: //8172/56C47A74B413/CCAPI/ccCallDisconnect:
Wed Mar 20 09:57:27 2013: <191>167616:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:57:27 2013: <191>167617: .Mar 20 09:57:26: //8172/56C47A74B413/CCAPI/ccCallDisconnect:
Wed Mar 20 09:57:27 2013: <191>167618:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:57:27 2013: <191>167619: .Mar 20 09:57:26: //8172/56C47A74B413/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:57:27 2013: <191>167620:    Transfer Number Is Null
Wed Mar 20 09:57:27 2013: <191>167621: .Mar 20 09:57:26: //8171/56C47A74B413/CCAPI/cc_api_call_feature:
Wed Mar 20 09:57:27 2013: <191>167622:    Feature Type=6, Interface=0x4B806530, Call Id=8171
Wed Mar 20 09:57:27 2013: <191>167623: .Mar 20 09:57:26: //8171/56C47A74B413/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:57:27 2013: <191>167624:
Wed Mar 20 09:57:27 2013: <191>167625: Disposition=0, Interface=0x4B806530, Tag=0x0, Call Id=8171,
Wed Mar 20 09:57:27 2013: <191>167626:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:57:27 2013: <191>167627: .Mar 20 09:57:26: //8171/56C47A74B413/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:57:27 2013: <191>167628:    Call Disconnect Event Sent
Wed Mar 20 09:57:27 2013: <191>167629: .Mar 20 09:57:26: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:57:27 2013: <191>167630:
Wed Mar 20 09:57:27 2013: <191>167631: .Mar 20 09:57:26: :cc_free_feature_vsa freeing 47B97338
Wed Mar 20 09:57:27 2013: <191>167632: .Mar 20 09:57:26: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:57:27 2013: <191>167633:
Wed Mar 20 09:57:27 2013: <191>167634: .Mar 20 09:57:26:  vsacount in free is 1
Wed Mar 20 09:57:27 2013: <191>167635: .Mar 20 09:57:26: //8172/56C47A74B413/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:57:27 2013: <191>167636:    Disposition=0, Interface=0x4987FF98, Tag=0x0, Call Id=8172,
Wed Mar 20 09:57:27 2013: <191>167637:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:57:28 2013: <191>167638: .Mar 20 09:57:26: //8172/56C47A74B413/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:57:28 2013: <191>167639:    Call Disconnect Event Sent
Wed Mar 20 09:57:28 2013: <191>167640: .Mar 20 09:57:26: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:57:28 2013: <191>167641:
Wed Mar 20 09:57:28 2013: <191>167642: .Mar 20 09:57:26: :cc_free_feature_vsa freeing 47B97258
Wed Mar 20 09:57:28 2013: <191>167643: .Mar 20 09:57:26: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:57:28 2013: <191>167644:
Wed Mar 20 09:57:28 2013: <191>167645: .Mar 20 09:57:26:  vsacount in free is 0
Wed Mar 20 09:57:37 2013: <190>167646: .Mar 20 09:57:34: %IPPHONE-6-UNREGISTER_NORMAL: ephone-5:SEP002699441E44 IP:10.229.64.32 Socket:5 DeviceType:Phone has unregistered normally.
Wed Mar 20 09:58:32 2013: <191>167647: .Mar 20 09:58:31: //-1/80D1F4DC4306/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:58:32 2013: <191>167648:    cc_api_call_setup_ind_common:
Wed Mar 20 09:58:32 2013: <191>167649:    cisco-username=PF-Assis
Wed Mar 20 09:58:32 2013: <191>167650:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:58:32 2013: <191>167651:    cisco-ani=1811032004
Wed Mar 20 09:58:32 2013: <191>167652:    cisco-anitype=0
Wed Mar 20 09:58:32 2013: <191>167653:    cisco-aniplan=0
Wed Mar 20 09:58:32 2013: <191>167654:    cisco-anipi=0
Wed Mar 20 09:58:32 2013: <191>167655:    cisco-anisi=1
Wed Mar 20 09:58:32 2013: <191>167656:    dest=097144868
Wed Mar 20 09:58:32 2013: <191>167657:    cisco-desttype=0
Wed Mar 20 09:58:32 2013: <191>167658:    cisco-destplan=0
Wed Mar 20 09:58:32 2013: <191>167659:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:58:32 2013: <191>167660:    cisco-rdn=
Wed Mar 20 09:58:32 2013: <191>167661:    cisco-lastrdn=
Wed Mar 20 09:58:32 2013: <191>167662:    cisco-rdntype=-1
Wed Mar 20 09:58:32 2013: <191>167663:    cisco-rdnplan=-1
Wed Mar 20 09:58:32 2013: <191>167664:    cisco-rdnpi=-1
Wed Mar 20 09:58:32 2013: <191>167665:    cisco-rdnsi=-1
Wed Mar 20 09:58:32 2013: <191>167666:    cisco-redirectreason=-1   fwd_final_type =0
Wed Mar 20 09:58:32 2013: <191>167667:    final_redirectNumber =
Wed Mar 20 09:58:32 2013: <191>167668:    hunt_group_timeout =0
Wed Mar 20 09:58:32 2013: <191>167669:
Wed Mar 20 09:58:32 2013: <191>167670: .Mar 20 09:58:31: //-1/80D1F4DC4306/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:58:32 2013: <191>167671:
Wed Mar 20 09:58:32 2013: <191>167672: Interface=0x48A4F728, Call Info(
Wed Mar 20 09:58:32 2013: <191>167673:    Calling Number=1811032004,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Wed Mar 20 09:58:32 2013: <191>167674:    Called Number=097144868(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:58:32 2013: <191>167675:    Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Wed Mar 20 09:58:32 2013: <191>167676:    Incoming Dial-peer=200, Progress Indication=NULL(0), Calling IE Present=TRUE,
Wed Mar 20 09:58:32 2013: <191>167677:    Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=8173
Wed Mar 20 09:58:32 2013: <191>167678: .Mar 20 09:58:31: //-1/80D1F4DC4306/CCAPI/ccCheckClipClir:
Wed Mar 20 09:58:32 2013: <191>167679:    In: Calling Number=1811032004(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Wed Mar 20 09:58:32 2013: <191>167680: .Mar 20 09:58:31: //-1/80D1F4DC4306/CCAPI/ccCheckClipClir:
Wed Mar 20 09:58:32 2013: <191>167681:    Out: Calling Number=1811032004(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Wed Mar 20 09:58:32 2013: <191>167682: .Mar 20 09:58:31: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:58:32 2013: <191>167683:
Wed Mar 20 09:58:32 2013: <191>167684: .Mar 20 09:58:31: :cc_get_feature_vsa malloc success
Wed Mar 20 09:58:32 2013: <191>167685: .Mar 20 09:58:31: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:58:32 2013: <191>167686:
Wed Mar 20 09:58:32 2013: <191>167687: .Mar 20 09:58:31:  cc_get_feature_vsa count is 1
Wed Mar 20 09:58:32 2013: <191>167688: .Mar 20 09:58:31: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:58:32 2013: <191>167689:
Wed Mar 20 09:58:32 2013: <191>167690: .Mar 20 09:58:31: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248360,feature_id:8173
Wed Mar 20 09:58:32 2013: <191>167691: .Mar 20 09:58:31: //8173/80D1F4DC4306/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:58:32 2013: <191>167692:
Wed Mar 20 09:58:32 2013: <191>167693: Set Up Event Sent;
Wed Mar 20 09:58:32 2013: <191>167695:    Called Number=097144868(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:58:32 2013: <191>167696: .Mar 20 09:58:31: //8173/80D1F4DC4306/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:58:32 2013: <191>167699:    Try with the demoted called number 097144868
Wed Mar 20 09:58:32 2013: <191>167700: .Mar 20 09:58:31: //8173/80D1F4DC4306/CCAPI/ccCallSetContext:
Wed Mar 20 09:58:32 2013: <191>167707:    Destination=, Calling IE Present=TRUE, Mode=0,
Wed Mar 20 09:58:32 2013: <191>167708:    Outgoing Dial-peer=20, Params=0x4BA733C8, Progress Indication=NULL(0)
Wed Mar 20 09:58:32 2013: <191>167725:    ----- ccCallInfo IE subfields -----
Wed Mar 20 09:58:32 2013: <191>167726:    cisco-ani=1811032004
Wed Mar 20 09:58:32 2013: <191>167730:    cisco-anipi=0
Wed Mar 20 09:58:32 2013: <191>167732:    dest=097144868
Wed Mar 20 09:58:32 2013: <191>167735:    cisco-rdie=FFFFFFFF
Wed Mar 20 09:58:32 2013: <191>167745:
Wed Mar 20 09:58:32 2013: <191>167746: .Mar 20 09:58:31: //8173/80D1F4DC4306/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:58:33 2013: <191>167758: .Mar 20 09:58:31:  cc_get_feature_vsa count is 2
Wed Mar 20 09:58:33 2013: <191>167759: .Mar 20 09:58:31: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:58:33 2013: <191>167760:
Wed Mar 20 09:58:33 2013: <191>167761: .Mar 20 09:58:31: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248136,feature_id:8174
Wed Mar 20 09:58:33 2013: <191>167762: .Mar 20 09:58:31: //8174/80D1F4DC4306/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:58:33 2013: <191>167763:    SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Wed Mar 20 09:58:33 2013: <191>167764: .Mar 20 09:58:31: //8174/80D1F4DC4306/CCAPI/ccCallSetContext:
Wed Mar 20 09:58:33 2013: <191>167765:    Context=0x4BA73378
Wed Mar 20 09:58:33 2013: <191>167766: .Mar 20 09:58:31: //8173/80D1F4DC4306/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:58:33 2013: <191>167767:    Outgoing Dial-peer=20
Wed Mar 20 09:58:33 2013: <191>167768: .Mar 20 09:58:31: //8174/80D1F4DC4306/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:58:33 2013: <191>167769:    Interface=0x4987FF98, Progress Indication=NULL(0)
Wed Mar 20 09:58:35 2013: <191>167770: .Mar 20 09:58:34: //8174/80D1F4DC4306/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:58:35 2013: <191>167771:    Interface=0x4987FF98, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
Wed Mar 20 09:58:35 2013: <191>167772:    Cause Value=0
Wed Mar 20 09:58:35 2013: <191>167773: .Mar 20 09:58:34: //8174/80D1F4DC4306/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:58:35 2013: <191>167774:    Call Entry(Responsed=TRUE)
Wed Mar 20 09:58:35 2013: <191>167775: .Mar 20 09:58:34: //8173/80D1F4DC4306/CCAPI/ccCallCutProgress:
Wed Mar 20 09:58:35 2013: <191>167776:    Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
Wed Mar 20 09:58:35 2013: <191>167777:    Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Wed Mar 20 09:58:35 2013: <191>167778: .Mar 20 09:58:34: //8173/80D1F4DC4306/CCAPI/ccCallCutProgress:
Wed Mar 20 09:58:35 2013: <191>167779:    Call Entry(Responsed=TRUE)
Wed Mar 20 09:58:35 2013: <191>167780: .Mar 20 09:58:34: //8174/80D1F4DC4306/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:58:35 2013: <191>167781:    CallInfo(ccm detected=0)
Wed Mar 20 09:58:35 2013: <191>167782: .Mar 20 09:58:34: //8173/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:58:35 2013: <191>167783:    (confID=0x4BB01C90, callID1=0x1FED, callID2=0x1FEE, tag=0x0)
Wed Mar 20 09:58:35 2013: <191>167784: .Mar 20 09:58:34: //8173/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:58:35 2013: <191>167785:    (confID=0x4BB01C90, callID1=0x1FED, gcid=0-0-0-0, tag=0x0)
Wed Mar 20 09:58:35 2013: <191>167786: .Mar 20 09:58:34: //8174/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:58:35 2013: <191>167787:    (confID=0x4BB01C90, callID2=0x1FEE, gcid=0-0-0-0, tag=0x0)
Wed Mar 20 09:58:35 2013: <191>167788: .Mar 20 09:58:34: //8173/80D1F4DC4306/CCAPI/ccConferenceCreate:
Wed Mar 20 09:58:35 2013: <191>167789:    Conference Id=0x4BB01C90, Call Id1=8173, Call Id2=8174, Tag=0x0
Wed Mar 20 09:58:35 2013: <191>167790: .Mar 20 09:58:34: //8173/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:58:35 2013: <191>167791:
Wed Mar 20 09:58:35 2013: <191>167792: .Mar 20 09:58:34: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:58:35 2013: <191>167793: .Mar 20 09:58:34: //8173/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:58:35 2013: <191>167794:    Conference Id=0xE63, Source Interface=0x48A4F728, Source Call Id=8173,
Wed Mar 20 09:58:35 2013: <191>167795:    Destination Call Id=8174, Disposition=0x0, Tag=0x0
Wed Mar 20 09:58:35 2013: <191>167796: .Mar 20 09:58:34: //8174/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:58:35 2013: <191>167797:    Conference Id=0xE63, Source Interface=0x4987FF98, Source Call Id=8174,
Wed Mar 20 09:58:35 2013: <191>167798:    Destination Call Id=8173, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:58:35 2013: <191>167799: .Mar 20 09:58:34: //8173/80D1F4DC4306/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:58:35 2013: <191>167800:    Conference Id=0xE63, Source Interface=0x4987FF98, Source Call Id=8174,
Wed Mar 20 09:58:35 2013: <191>167801:    Destination Call Id=8173, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:58:35 2013: <191>167802: .Mar 20 09:58:34: //8173/80D1F4DC4306/CCAPI/ccConferenceCreate:
Wed Mar 20 09:58:35 2013: <191>167803:
Wed Mar 20 09:58:35 2013: <191>167804: Call Entry(Conference Id=0xE63, Destination Call Id=8174)
Wed Mar 20 09:58:35 2013: <191>167805: .Mar 20 09:58:34: //8174/80D1F4DC4306/CCAPI/ccConferenceCreate:
Wed Mar 20 09:58:35 2013: <191>167816: Conference Id=0xE63, Call Id1=8173, Call Id2=8174
Wed Mar 20 09:58:35 2013: <191>167817: .Mar 20 09:58:34: //8173/80D1F4DC4306/CCAPI/ccCallNotify:
Wed Mar 20 09:58:35 2013: <191>167818:    Data Bitmask=0x7, Call Id=8173
Wed Mar 20 09:58:35 2013: <191>167819: .Mar 20 09:58:34: //8174/80D1F4DC4306/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:58:35 2013: <191>167820:    CallInfo(ccm detected=0)
Wed Mar 20 09:58:35 2013: <191>167821: .Mar 20 09:58:34: //8173/80D1F4DC4306/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:58:35 2013: <191>167822:    Destination Interface=0x4987FF98, Destination Call Id=8174, Source Call Id=8173,
Wed Mar 20 09:58:35 2013: <191>167823:    Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:58:35 2013: <191>167824:    Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:58:35 2013: <191>167825: .Mar 20 09:58:34: //8173/80D1F4DC4306/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:58:35 2013: <191>167826:    Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:58:35 2013: <191>167827:    Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:58:35 2013: <191>167828: .Mar 20 09:58:34: //8173/80D1F4DC4306/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:58:35 2013: <191>167829:    Destination Interface=0x4987FF98, Destination Call Id=8174, Source Call Id=8173,
Wed Mar 20 09:58:35 2013: <191>167830:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:58:35 2013: <191>167831:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1860)
Wed Mar 20 09:58:35 2013: <191>167832: .Mar 20 09:58:34: //8174/80D1F4DC4306/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:58:35 2013: <191>167833:    Destination Interface=0x48A4F728, Destination Call Id=8173, Source Call Id=8174,
Wed Mar 20 09:58:35 2013: <191>167834:    Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:58:35 2013: <191>167835:    Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1860)
Wed Mar 20 09:58:35 2013: <191>167836: .Mar 20 09:58:34: //8174/80D1F4DC4306/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:58:35 2013: <191>167837:    Call Id=8174
Wed Mar 20 09:58:35 2013: <191>167838: .Mar 20 09:58:34: //8174/80D1F4DC4306/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:58:35 2013: <191>167839:    Call Entry(Context=0x4BA73378)
Wed Mar 20 09:58:35 2013: <191>167840: .Mar 20 09:58:34: //8174/80D1F4DC4306/CCAPI/cc_api_call_connected:
Wed Mar 20 09:58:35 2013: <191>167841:    Interface=0x4987FF98, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
Wed Mar 20 09:58:35 2013: <191>167842:    Connection Handle=0
Wed Mar 20 09:58:35 2013: <191>167843: .Mar 20 09:58:34: //8174/80D1F4DC4306/CCAPI/cc_api_call_connected:
Wed Mar 20 09:58:35 2013: <191>167844:    Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:58:35 2013: <191>167845: .Mar 20 09:58:34: //8173/80D1F4DC4306/CCAPI/ccCallConnect:
Wed Mar 20 09:58:35 2013: <191>167846:    Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
Wed Mar 20 09:58:35 2013: <191>167847: .Mar 20 09:58:34: //8174/80D1F4DC4306/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:58:35 2013: <191>167848:    CallInfo(ccm detected=0)
Wed Mar 20 09:58:36 2013: <191>167849: .Mar 20 09:58:34: //8173/80D1F4DC4306/CCAPI/ccCallConnect:
Wed Mar 20 09:58:36 2013: <191>167850:    Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:58:36 2013: <191>167851: .Mar 20 09:58:34: //8173/80D1F4DC4306/CCAPI/ccCallNotify:
Wed Mar 20 09:58:36 2013: <191>167852:    Data Bitmask=0x7, Call Id=8173
Wed Mar 20 09:58:36 2013: <191>167853: .Mar 20 09:58:34: //8174/80D1F4DC4306/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:58:36 2013: <191>167854:    CallInfo(ccm detected=0)
Wed Mar 20 09:59:10 2013: <191>167855: .Mar 20 09:59:09: //8173/80D1F4DC4306/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:59:10 2013: <191>167856:    Cause Value=16, Interface=0x48A4F728, Call Id=8173
Wed Mar 20 09:59:10 2013: <191>167857: .Mar 20 09:59:09: //8173/80D1F4DC4306/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:59:10 2013: <191>167858:    Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:59:10 2013: <191>167859: .Mar 20 09:59:09: //8173/80D1F4DC4306/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:59:10 2013: <191>167860:    Conference Id=0xE63, Tag=0x0
Wed Mar 20 09:59:10 2013: <191>167861: .Mar 20 09:59:09: //8173/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:59:10 2013: <191>167862:    Conference Id=0xE63, Source Interface=0x48A4F728, Source Call Id=8173,
Wed Mar 20 09:59:10 2013: <191>167863:    Destination Call Id=8174, Disposition=0x0, Tag=0x0
Wed Mar 20 09:59:10 2013: <191>167864: .Mar 20 09:59:09: //8174/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:59:10 2013: <191>167865:
Wed Mar 20 09:59:10 2013: <191>167866: Conference Id=0xE63, Source Interface=0x4987FF98, Source Call Id=8174,
Wed Mar 20 09:59:10 2013: <191>167867:    Destination Call Id=8173, Disposition=0x0, Tag=0x0
Wed Mar 20 09:59:10 2013: <191>167868: .Mar 20 09:59:09: //8173/80D1F4DC4306/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:59:10 2013: <191>167869:    Conference Id=0xE63, Source Interface=0x4987FF98, Source Call Id=8174,
Wed Mar 20 09:59:10 2013: <191>167870:    Destination Call Id=8173, Disposition=0x0, Tag=0x0
Wed Mar 20 09:59:10 2013: <191>167871: .Mar 20 09:59:09: //8173/80D1F4DC4306/CCAPI/ccCallDisconnect:
Wed Mar 20 09:59:10 2013: <191>167872:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:59:10 2013: <191>167873: .Mar 20 09:59:09: //8173/80D1F4DC4306/CCAPI/ccCallDisconnect:
Wed Mar 20 09:59:10 2013: <191>167874:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:59:10 2013: <191>167875: .Mar 20 09:59:09: //8173/80D1F4DC4306/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:59:10 2013: <191>167876:
Wed Mar 20 09:59:10 2013: <191>167877: Transfer Number Is Null
Wed Mar 20 09:59:10 2013: <191>167878: .Mar 20 09:59:09: //8174/80D1F4DC4306/CCAPI/ccCallDisconnect:
Wed Mar 20 09:59:10 2013: <191>167879:    Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:59:10 2013: <191>167880: .Mar 20 09:59:09: //8174/80D1F4DC4306/CCAPI/ccCallDisconnect:
Wed Mar 20 09:59:10 2013: <191>167881:    Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:59:10 2013: <191>167882: .Mar 20 09:59:09: //8174/80D1F4DC4306/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:59:10 2013: <191>167883:    Transfer Number Is Null
Wed Mar 20 09:59:10 2013: <191>167884: .Mar 20 09:59:09: //8173/80D1F4DC4306/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:59:10 2013: <191>167885:    Transfer Number Is Null
Wed Mar 20 09:59:10 2013: <191>167886: .Mar 20 09:59:09: //8173/80D1F4DC4306/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:59:10 2013: <191>167887:
Wed Mar 20 09:59:10 2013: <191>167888: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8173,
Wed Mar 20 09:59:10 2013: <191>167889:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:59:10 2013: <191>167890: .Mar 20 09:59:09: //8173/80D1F4DC4306/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:59:10 2013: <191>167891:    Call Disconnect Event Sent
Wed Mar 20 09:59:10 2013: <191>167892: .Mar 20 09:59:09: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:59:10 2013: <191>167893:
Wed Mar 20 09:59:10 2013: <191>167894: .Mar 20 09:59:09: :cc_free_feature_vsa freeing 47B81CE0
Wed Mar 20 09:59:10 2013: <191>167895: .Mar 20 09:59:09: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:59:10 2013: <191>167896:
Wed Mar 20 09:59:10 2013: <191>167897: .Mar 20 09:59:09:  vsacount in free is 1
Wed Mar 20 09:59:10 2013: <191>167898: .Mar 20 09:59:09: //8174/80D1F4DC4306/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:59:10 2013: <191>167899:    Disposition=0, Interface=0x4987FF98, Tag=0x0, Call Id=8174,
Wed Mar 20 09:59:10 2013: <191>167900:    Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:59:11 2013: <191>167901: .Mar 20 09:59:09: //8174/80D1F4DC4306/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:59:11 2013: <191>167902:    Call Disconnect Event Sent
Wed Mar 20 09:59:11 2013: <191>167903: .Mar 20 09:59:09: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:59:11 2013: <191>167904:
Wed Mar 20 09:59:11 2013: <191>167905: .Mar 20 09:59:09: :cc_free_feature_vsa freeing 47B81C00
Wed Mar 20 09:59:11 2013: <191>167906: .Mar 20 09:59:09: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:59:11 2013: <191>167907:
Wed Mar 20 09:59:11 2013: <191>167908: .Mar 20 09:59:09:  vsacount in free is 0
Wed Mar 20 10:02:11 2013: <191>167909: .Mar 20 10:02:09: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
Wed Mar 20 10:02:11 2013: <191>167910:    ccAppShutdownMode: remove it from the queue
Wilson
Anas Abueideh
Level 9
Level 9
try to create voice class code 1 and assign it to dial-peer voip pointing to the call manager.
kindly find the below thread
https://supportforums.cisco.com/thread/2098768
also i find the below link for H323 troubleshooting
http://docwiki.cisco.com/wiki/Cisco_IOS_Voice_Troubleshooting_and_Monitoring_--_H.323_Gateway_Troubleshooting
Anas
don't forget to rate the helpful posts
