Auto-registration not work
msaeedi
i have a cluster  consists of CUCM Publisher and two CUCM Subscribers , auto registration is disabled on Publisher and enabled on Subscriber 1 and subscriber 2, also i have tow CM Groups as below :
CMGROUP1 :
subscriber 1
subscriber 2
Publisher
Auto registration Enabled.
CMGROUP2:
subscriber 2
subscriber 1
Publisher
Auto registration Disabled.
now for Auto-registration if i put subscriber 1 and subscriber 2 on NONE partition phones get extension and working fine, if i put subscriber 1 and subscriber 2 in PT-INTERNAL it is not able to get extension , please advise any got this problem before?
Senior Network Engineer
3 Accepted Solutions
Ayodeji Okanlawon
Are you sure that those extensions are not already present in your cucm database..
Use route plan report to check that these extensions range don't already exist
Please rate all useful posts
Rob Huffman
Hi there,
Just a note to add to the good ideas from my friend Deji (+5 Deji!)
Any time Auto-Registration is disabled the Partition setting for Auto-Registration DN's gets reset to "None" so I would have a look at the Partition setting on the Auto-Registration config page and change to the one you desire to use ie; PT-Internal in your case.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/7_1_2/ccmcfg/bccm-712-cm/b02autor.html
Cheers!
Rob
Hi Rob (+5)..Great to catch you hear again..Long time ( I have been mostly out..). Hope you are keeping well..
5 Replies 5
Ayodeji Okanlawon
thanks all persons , i deleted the numbers from Call routing ----> Directory Numbers , the numbers descibed as Auto, around 100 numbers Deleted , it works well.
Glad to know its working..Please mark the answer as correct to help others in the future
Rob Huffman
Hi there,
Cheers!
Rob
