Automatic Call Forwarding
hutto.txed.net
Is there a way to setup Call Forwarding so that you just hit one button that is all ready configured with a phone number.  I am running Call Manager
System version: 7.1.5.33900-10
Chris Deren
No, you need to press the CallFwdAll softkey and then enter the number, if this is a consistent number you are forwarding to you can setup that up as speed dial and then press the softkey followed by the speed dial.
HTH,
Chris
Chris Deren
HTH,
Chris
Thank you, this seems to be to best way, using the speed dial.
