11-30-2007 12:47 AM - edited 03-15-2019 07:30 AM
Is it possible to create a DHCP scope for avaya ip phones with all the required option 176 parameters on a cisco router or switch?
Cisco seems to be very easy with just the option 150
Narayan
11-30-2007 07:03 AM
Yes, you can configure your Cisco Switch/Router as DHCP Server and use option 176. The command would be the same as you would use for option 150. This should work fine without any issue.
The command would be (Under ip dhcp pool
option 176 ip
Hope this helps
11-30-2007 11:55 PM
That is fine but when we use avaya phones, the DHCP option 176 string has a lot of parameters which includes the voice vlan ID, the CLAN etc...
So i was just wondering whether just pointing the IP address of the CLAN would give the phones the Voice ID
I need to test this out
Narayan
04-11-2011 04:50 PM
I assume this has been resolved already, but just incase, here is some info that might help.
Option 176 ascii
"mcipadd=192.168.X.X,tftpsrvr=192.168.X.X,tftpdir=/,mcport=1719,l2qvlan=0,l2qsig=5,l2qaud=5,phndlength=3,vlantest=999"
This is your standard Scope option for Avaya phones that use tftp server IE: 5600 series
If you have 9600 series, you need to replace tftp with HTTP, and use 242 as the option.
03-03-2014 03:05 PM
Thanks, this helped me out today!
06-20-2016 01:32 PM
This is how you should type the command:
option 176 ascii MCIPADD=10.0.100.80,MCPORT=1719,TFTPSRVR=10.0.100.80,VLANTEST=0
option 242 ascii MCIPADD=10.0.100.80,MCPORT=1719,TFTPSRVR=10.0.100.80,VLANTEST=0
Option 176 and 242
Yordan
06-20-2018 06:02 PM - edited 06-20-2018 06:03 PM
so i have to ask the question , when you add this in dhcp options in infoblox for option 150 and you have cisco ip phones for end points. There is no string needed and the type should be array of ip-address??
thanks in advance
