Avaya K175 as 3rd party SIP issues
shaabneh33
Dears.
I Have Avaya K175 configured as SIP on Cisco Call Manager.
the phone keeps disconnecting every 2- 3 minutes.
I can make calls from Avaya phone to Cisco phones. but Avaya is not receiving from Cisco " gives busy tone".
I checked Cisco & Avaya logs (attached).
found that Avaya phone sends 2 register requests, on Avaya logs showed that Avaya trying to register many times and it got different responses from Cisco Call Manager.
I also attached 46xxsettings for Avaya if I missed to add something, or do I need to add some configuration in SIP profile.
thanks
It appears that the phone is not registered with CUCM, which could be the reason for the busy tone. Additionally, I noticed 503 and 401 unauthorized errors in the Avaya logs. Have you completed the necessary configurations for the third-party phone on CUCM? Here are the mandatory configurations you need to complete for third-party phones.
https://www.youtube.com/watch?v=8amr4rZNvjg
Also, could you specify the type of third-party phone you tried? Was it standard or advanced? It should be advanced, as I understand this is a video phone."
Response Signature
Hi Nithin;
thanks for your reply.
I added all the necessary configuration ON CUCM.
SIP profile type: SIP Profile advanced.
note: phone status on CUCM is "registered", but problem that the device keeps disconnecting every 2 -3 minutes with message on Avaya "SIP login failure", then back normal, + I can't receive calls from Cisco Phones (busy tone).
