Avaya Sip Phones on CUCM
ArthurFranks
Has anybody figured out if the Avaya 1200E sip phone can operate behind a CUCM as a regular desk phone??
Anas Abueideh
Level 9
Level 9
as a concept you can add it as third party sip phone (basic or advanced)
it is better to test it before purchasing.
Anas
don't forget to rate the helpful posts
Mark VandeVere
Right now I have a 1608 I'm testing with, but I can't get it to register. It hangs at "Discover x.x.x.x" where x.x.x.x is the CUCM ip address.
It seems like I should have to set some information in the device related to sip domains, etc. but I don't see documentation for that. The other possibility is it may need a file on the CUCM tftp that it can pull for more settings, but I'm not sure what format that file would be in.
