10-25-2013 11:33 PM - edited 03-16-2019 08:05 PM
I am new to this scripting and tcl world. I just want to know the actual use of this BACD and AA. Since we have CUE then why and where do we use?
Lets say my incoming calls listen to musci from CUE where i have configured AA and VoiceMail then still i should use this ?
Solved! Go to Solution.
10-26-2013 01:23 AM
HI
No , if you have AA on your CUE this will be eniugh for you.Please find the below:-
1-Automatic answering of outside calls with greetings and menus that allow callers to select the appropriate department or to dial known extension numbers.Managed call queues for hunt groups that route calls for different menu options.
2-I can use TCL scripts or AA or B-ACD , by uploading flash of the router.But these applications are so limited , you cannt change a the script which you have for AA.This solution most of people used it when there is no CUE module to enable AA.For B-ACD drop-through , this a good solution if need to do something as small call center , will have a pilot number and agents.If you have CUE , you need only B-ACD.
3-CUE has its own script editor which can give you more features and more benefits for change and edit the menu for AA which created on CUE.
Thank you
Please rate all useful information
10-26-2013 01:23 AM
HI
Thank you
10-26-2013 01:25 AM
HI
Cisco Unified CME B-ACD provides automatic answering and call distribution for calls through the use of interactive menus and local hunt groups. Each Cisco Unified CME B-ACD application consists of one or more auto-attendant (AA) services and one call-queue service. An incoming call dials the B-ACD AA pilot number and hears a prompt that provides a greeting and instructions to help the caller automatically route the call.
For example, callers to a newspaper might hear: "Thank you for calling the Times. To place an advertisement or to subscribe to the Dispatch, press 1; for the editorial department, press 2; for the operator, press 0; if you know your party's extension, press 4." Callers who do not select an option will hear the greeting and menu options repeated.
The Cisco Unified CME B-ACD application is specified by two Tool Command Language (Tcl) scripts: an AA script that handles the welcome prompt and menu choices, and a call-queue script that manages call routing and queuing behavior.
Cisco Unified CME B-ACD Components
As mentioned, the Cisco Unified CME B-ACD application consists of a call-queue service and one or more AA services. The configurable components of these services are outlined as follows. Keep in mind that each one of these topics could be it's own blog entry.. hmm.. that's not a bad idea!
Pilot Number : This is the number that callers dial to reach the AA.
Welcome Prompt and Other Audio Files
Menu Options
Hunt Group Option and Ephone Hunt Groups : These define how calls are distributed to groups that share the same function.
Dial-by-Extension Option : Allows the caller to go straight to a known agent.
Drop-Through Mode : "Drops" the caller directly into a hunt group following an optional greeting.
Multiple Auto-Attendant Services : Multiple AA Services can be created that feed into a common single call-queue.
Call Queues
Call Queue Exit Options
Alternate Destination for Unavailable Hunt Groups : Where do I go if nobody is logged in?
Voice Mail : Optionally refer callers to voice mail to leave a message.
Thank you
10-26-2013 01:28 AM
Please find the below links:-
https://supportforums.cisco.com/docs/DOC-16934
Thank you
10-26-2013 03:53 AM
In my case, i have cue where i have configured AA and Mailboxes.
I just want to use B-ACD in live environment so if you have working configuration of B-ACD. Thanks
I have downloaded some files from www.cisco.com
cme-b-acd-2.1.2.3.zip which contains many files
10-26-2013 04:14 AM
This very ok , if you need that . I will tell you about scinario you have Sales department ( 4101 ,4102 ,4103 ,etc..).you need to group these people on a group , when call hits the pilot number the caller will hear welcome message then call will transfer to the your sales emplyees one by one , as a small idea of call-canter:- Please find the below:-
application
service app-b-acd-aa
param voice-mail 4220 /Voicemail when there is no answer/
paramspace english index 1
param max-time-call-retry 700
param service-name app-b-acd
param number-of-hunt-grps 1
param drop-through-option 1
paramspace english language en
param handoff-string app-b-acd-aa
param max-time-vm-retry 2
paramspace english location flash:
param aa-pilot 4000 /400 the number which will be dialed/
param second-greeting-time 60
param drop-through-prompt _bacd_welcome.au /welcome message/
param call-retry-timer 15
service app-b-acd
param queue-len 2
param aa-hunt1 4500 /this pilot number/
param queue-manager-debugs 1
ephone-hunt 10 longest-idle
pilot 4500
list 4101, 4102 /ext of sales department/
timeout 10, 10
Thank you
10-26-2013 04:16 AM
1- You have to make sure that all B-ACD files on your flash:-
2-You have to use the below dial-peers
dial-peer voice 40 pots
incoming called-number 4000
direct-inward-dial
dial-peer voice 4000 voip
destination-pattern 4000
dtmf-relay h245-alphanumeric
codec g711ulaw
Thank you
10-26-2013 05:58 AM
Hi Islam,
Can you please explain call flow. I have FXO ports connted with analogue lines. All lines are plared with 5000 number.
5000 is AA defined on Cisco CUE. Where perator extension is 3900 (Receptionist number).
For testing purpose, lets say i spare 2 FXO lines for B-ACD purpose. Then i can change the connection plar.
Acc. to your configuration, just explain the Call flow
application
param aa-pilot 5050....connection plar on FXO ?
param drop-through-prompt en_bacd_welcome.au
service app-b-acd
param queue-len 2
param aa-hunt1 4500...??
pilot 4500...??
list 4102, 4103
timeout 10, 10
10-26-2013 06:28 AM
1- param aa-pilot 5050....connection plar on FXO ? yes .
2- param aa-hunt1 4500...??. 4500 acts as number of your hunt group which will contains your reception numbers .
so call come to -5050 -then call go to queue 4500 which will includes numbers of your receptionaists for example (4101 , 4102 , 4103 ,etc..). This is advantage of ACD automatic call distribuotar as IPCC .
Thank you
10-26-2013 06:32 AM
voice-port 0/0/0
connection plar opx 5050
description inbound FXO direct to Auto-Attendant
caller-id enable
dial-peer voice 500 voip
description inboumd FXO-test to auto-attendant
destination-pattern 5050
session target ipv4:10.107.146.1
dtmf-relay dtmf-relay
codec g711ulaw
no vad
Thank you
please rate all useful information
