04-04-2013 09:49 AM - edited 03-16-2019 04:37 PM
Hi Everyone,
I need to upload the PNG and Thumb files for 7075 phones into the TFTP servers. We have 20 TFTP and Master TFTP Servers. Do I need to upload the files into each and every TFTP server or just Master TFTPs would be enough?
MK
04-04-2013 09:53 AM
Sorry the phones are 7975
04-04-2013 12:49 PM
you need to upload it to the other servers that the phone may contact to take the background.
kindly find the below link page (6-5)
Anas
please don't forget to rate the helpful posts
04-04-2013 12:58 PM
Thanks Anas,
So, we have 20 TFTP servers and 2 Master TFTP servers. Do I need to upload the files into all 22 servers?
MK
04-04-2013 01:03 PM
upload to the 2 Masters servers, and test your phones if they get background. if not you need to complete your trip based on the guide
Anas
04-04-2013 01:07 PM
Whatever TFTP server addresses the 7975 phones have will need to have the images. Also don't forget to update the List.xml.
Yosh
04-04-2013 01:30 PM
Thanks guys,
The problem is that I don't have access to a lab to test the options. I am making the detailed document and some other people are going to implement the solution. I kind of need to know the way it's going to work. I personally think we have to upload the files into each and every TFTP server. I believe the Master TFTP only forwards the request to the local TFTPs. It does nothing by itself. Am I mistaken?
MK
04-04-2013 01:34 PM
the guide is clear to upload the back ground for all servers may the phone connect to.
start with the master TFTP then continue to the rest.
Anas
04-04-2013 01:45 PM
Thanks guys,
MK
04-04-2013 02:43 PM
Just to let you guys know that by uploading the file only on the Proxy servers, the phones were able to download the new background images. So, we don't need to upload in all TFTP servers.
MK
04-04-2013 07:53 PM
Is this normal that the Phones are pointed to the Proxy TFTP servers. I thought the phones should be pointed to the local TFTPs and the local TFTPs should be pointed to the proxy TFTP.
MK
04-05-2013 07:09 AM
Anybody has an answer for me?
