Basic CUBE Question
kpstross
                   Sorry if this is a dumb question.  Since CUBE is an SBC, should inbound calls arrive on one interface and outbound calls go out on another?  That is to say, shouldn't one interface be in the DMZ facng the PSTN and the other on the corporate LAN?  I've been through all of the configuration documentation and I can't find anything that details this.
13 Replies 13
Mark Turpin
Level 5
Level 5
You do not need multiple interfaces. You will need an inbound voip dial peer and outbound VoIP dial peer.
Take a look at the following for an example config.
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_configuration_example09186a00808ead0f.shtml
Hope this helps!
-Mark Turpin
But an SBC should sit at the edge of the private LAN, seperating and securing it from the public network.  Is that not the function of CUBE?
I would not use a CUBE alone to be the security point if you are trying to stay very tight with security.  I think you would be more interested in this document as it pertains to security for CUBE.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/gatecont/ps5640/white_paper_c11-613550_ps10536_Products_White_Paper.html
Check out the section about Security Recommendations and consider which might apply to your needs.  However, I would advise you to consider using an ASA doing SIP inspection in front of the CUBE instead of using the CUBE's security features alone.
-Mark Turpin
-Mark Turpin
Let me provide a little history and thereby (hopefully) simplify my question.  Our CUBEs are lab systems only, they were bought to emulate a customer environment for test purposes.  The customer uses them as I have described as an edge device (I'm sure they have more for their security, but this is part of it).  What we would like to do is have SIP calls enter the CUBE on one interface, and egress on another, with each interface being in a seperate segment of our network.  Is that possible?  If so, can you offer an example of how that is accomplished?
That is most definitely possible. Just configure the different interfaces and route the appropriate networks out on these. Then setup dial peers to point at a destination IP that egress out on each interface.
There is no magic to setup routing off VOIP traffic, it's just as any other type off IP traffic. The only difference is the dial peer part, but that's just as any other VGW with voice cards, it's very much alike when you configure a CUBE. Remember that a CUBE is only a VGW without voice cards.
There are good examples on how to setup CUBE on Cisco.com. I suggest that you start there and then come back here if you get stuck.
Best of luck!
Please rate useful posts.
Response Signature
I've been through all of the CUBE SIP docs that I can find on Cisco.com, and I have not found any that speak to this specific scenario (ingress on one interface, egress on another).  I have both interfaces configured and up, and inbound and outbound dial-peers, but calls are coming in and going out on the same interface.  What's the magic bit to make them transition to the other interface?
That's just IP routing not CUBE
You simply need to route traffic with ip route statements or with your dynamic routing protocol, out the interface you want it to go.
-Mark Turpin
-Mark Turpin
How do we specify the interface that we want to use?
Paste your config and we can help
But basically we are going to solve this with routing, so if you're using dns for your destinations please include their ip's and if using a dynamic routing protocol, please include a show ip route.
Thanks!
-Mark Turpin
Current configuration : 2346 bytes
! Last configuration change at 15:42:56 UTC Wed Sep 19 2012 by cubea
version 15.1
no platform punt-keepalive disable-kernel-core
hostname cubea
boot-start-marker
boot system flash:/asr1001-universalk9.03.07.00b.S.152-4.S0b.bin
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable password telecom
aaa new-model
aaa authentication login default local
aaa authentication ppp default if-needed local
aaa session-id common
ip domain name genesyslab.com
ip name-server 192.168.20.134
ip name-server 192.168.20.167
voice service voip
address-hiding
allow-connections sip to sip
sip
  header-passing sip-sip
  error-passthru
voice class codec 1
codec preference 1 g711ulaw
codec preference 3 g723r63
codec preference 4 g729r8
codec preference 5 g729br8
username cubea password 0 telecom
redundancy
mode none
ip tftp source-interface GigabitEthernet0
interface GigabitEthernet0/0/0
ip address 192.168.6.243 255.255.255.0
ip route-cache same-interface
negotiation auto
interface GigabitEthernet0/0/1
ip address 135.17.64.11 255.255.255.0
negotiation auto
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/3
no ip address
shutdown
negotiation auto
vrf forwarding Mgmt-intf
ip address 192.168.6.246 255.255.255.0
negotiation auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route profile
ip route 0.0.0.0 0.0.0.0 192.168.6.1
ip route 0.0.0.0 0.0.0.0 135.17.64.1
ip route vrf Mgmt-intf 0.0.0.0 0.0.0.0 192.168.6.1
control-plane
dial-peer voice 1 voip
description Incoming SIP Dial-Peer
incoming called-number ....
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 163 voip
tone ringback alert-no-PI
description Outgoing Test to Ken
destination-pattern 163.
session protocol sipv2
session target ipv4:192.168.18.20
dtmf-relay rtp-nte
codec g711ulaw
no vad
sip-ua
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password telecom
end
Let's say you have these networks and nodes.
Outside
Interface 1 IP: 10.10.10.2
Mask: 255.255.255.252
IPT GW IP: 10.10.10.1
IPT SIP IP: 10.0.0.1
Inside
Interface 2 IP: 192.168.0.20
Mask: 255.255.255.0
GW IP: 192.168.0.254
CUCM IP: 192.168.0.100
Route all internal traffic to 192.168.0.254 and outside traffic to 10.10.10.1.
Setup a dial peer that match internal DNs that point the session target to the CUCM IP.
Setup another dial peer, or more than one if needed, that match all external calls that point the session target to the IPT SIP IP.
Both of these will be considered as outgoing dial peers. You should also have at least one dial peer that is used to match in the incoming direction.
I recommend that you use SIP as the protocol on both ends, to the IPT you have no choice, but to the the CUCM you have the option to use SIP or H.323.
Response Signature
Sorry if I'm being lame here, but what ties the Session Target to a specific interface?
Currently we have interface 0 = 192.168.6.243 and interface 1 = 135.17.64.11.  PSTN calls come from our gateway via SIP to interface 0 and then route to our SIP proxy, but they go back out interface 0.  How can we get them to go out interface 1?
There are some fundamental parts in your config that need to be addressed.
First the routing.
You need to change one of these so that it's not a default route. It need to be a more specific route to the destination network.
The other part you need to address is that you only have 1 VoIP dial peer that point to your ITSP, there aren't any dial peer that point in the direction of your SIP Proxy. Add a dial peer that matches calls in that direction with a session target that has the proxys ip as the destination.
Please rate all useful posts.
Response Signature
