Basic paging with CUCM
One of our customer need to configure basic paging in CUCM 9.1
I check with CUCM version 9.0 cisco included basic paging functionlity which is provided by singlewire.
So, that means I do not need any extra hardware or software to implement basic paging(1 group with 50 phones).
Please clarify.
Thanks.
George Sotiropoulos
I believe the following post may be helpful to you
https://community.cisco.com/t5/other-collaboration-subjects/paging-with-cucm/td-p/3228472
George
Hope the above helps,
gsotirop
Thank you so much George for your reply.
@Syed
Level 3
Level 3
For basic paging functionality all you need is paging software from Single. Install it in your VM envinornment and configure, you can create multiple groups but only up to 50 devices can be added in total.
No additional hardware, software or licenses required.
Thank you so much syed for your reply.
