CME ISSUE
MohamedHussen
I have cisco 2811 and few 7961G cisco phones, CME verion 8.6, the phones not registering at all, the phone is getting DHCP Address which means connectivity is fine, I have done the following on the router
- NTP is set
- uploaded the phone config file (SCCP41.9-4-2SR1-1S.loads) <<<< could this be a problem
- TFTP Statement on the router (tftp-server flash:SCCP41.9-4-2SR1-1S.loads)
- Loaded the config files (load 7961 SCCP41.9-4-2SR1-1S.loads)
- created cnf file, ephone and dn.
ephone 1
device-security-mode none
mac-address 001E.7AC5.xxxx
type 7960
button 1:1
I have reset the cisco phones, what am I missing
Post your config and the following debugs
debug tftp event
debug ephone register mac-address xxxx.xxxx.xxxx
HARIS_HUSSAIN
Have you configured Option 150 Ip = CUCME IP address in DHCP Server ?
George Sotiropoulos
Can you try to change the ephone type from 7960 to 7961?
conf t
ephone 1
no type 7960
type 7961
and then create-cnf files and restart the phone
Hope this helps,
George
Hope the above helps,
gsotirop
When you say you added your TFTP statement, did you include tftp-server flash: commands for all of the individual files to be downloaded? (jar, dsp, cvm, etc.)
And, as suggested below, add debug tftp event and debug ephone reg and let us know the results.
Maren
