09-03-2012 05:17 AM - edited 03-16-2019 12:59 PM
Can i run any OS admin commands to provide me with the same output as BAT would give? For Example
BAT Export:
Device
Device Profiles
Line Groups
Hunt Pilots
Can i also run an OS query to give me a list of actively logged in profiles?
Is it possible to log a device profile into a phone from OS Admin. I need to log several device profiles in at once, can it be scripted?
Cheers
Dave
09-03-2012 05:57 AM
Hello Dave,
You can export this CUCM config depending on your CUCM Version.
To see who is logged, go to Device -> Phone, on related links select the option "Active logged in device report", there you can find the active logged device profiles.
Leonardo Santana
09-03-2012 06:00 AM
Hi Leonardo,
I'm well aware of how to display actively logged in device report in CUCM i need to export that data, which isn't possible from CUCM. Do you know of a way of extracting it?
Dave
