BE6000 CUCM setup
kpintens
Hi all
I was wondering if we can do the following on 2 BE6000's
1 BE6000 will host a PUB and SUB, the other one a second SUB and UnityConnection.
The FAQ, states max 2 nodes but further down it says the cluster can hold more then 3.....
Thanks in advance
Koen
This is perfectly fine and supported to have multiple BE6K servers.
6 Replies 6
Aman Soi
Hi Koen,
BE 6000 consists of the following foundational elements:
  • Cisco Unified Communications Manager
  • IM & Presence
  • Cisco Unity® Connection
  • Cisco Prime Provisioning
  • Cisco UC Virtualization Hypervisor
  • Cisco Unified Computing System C200 M2/C220 M3 Rack-mount server.
Following applications can be optionally added to Cisco Business Edition 6000 solution.
  • Cisco Unified Contact Center Express
  • Cisco Unified Attendant Consoles
  • Cisco Emergency Responder
  • Cisco Telepresence Video Communication Server (Supported only with UCS C220 M3)
  • Cisco Paging Server
Cisco Business Edition 6000 supports up to 4 UC applications plus 1 Cisco Prime Provisioning (from the list of applications above) running co-resident on single UCS C200 or UCS C220 hardware platform and supports full featured redundancy for all the core applications over a WAN or LAN environment.
you can refer the link
http://docwiki.cisco.com/wiki/Cisco_Unified_Communications_Manager_Business_Edition_6000
regds,
aman
Thanks for that but that does not answer my question
2 nodes, can be PUB and SUB, or 2 BE6000's
our distributor says only PUB/SUB and not PUB/SUB/SUB, even staying below 1000 users
one one UCS chassis , you can install PB/SUB1 while on other UCS chassis, u can install SUB2/UCXN.
regds,
aman
I know going to UCS or even UCS mini, but the BE6000 have been acquired already....
so we need to use those
Thanks Chris
