IP Telephony and Phones
Labels
Resolved! CUCM OVF template
Dears,Please find the attached snapshot for the OVF template,i am using cucm_8.6_vmv8_v1.5.ova when i choose 1000 node it uses 2 vCPU and when i use 2500 user nodes it uses only 1 cpu why that's so when the no's of users are increasing the cpu should...
adamgibs7 by Level 6
  • 1003 Views
  • 1 replies
Good AfternoonQuick Question - have a user in CUCM 7.1.5 who wanted a 7915.changed the phone button template to individual template and changed all the buttons to "Speed Dial BLF". The user is now reporting that they cannot interrupt calls or pick th...
Hello,I am looking to setup a CUCM cluster running version 9.x. As this is for a lab I only need a small amount of user licenses. So, in version 9, I understand that ELM will be installed by default which is what I must use to upload and control lice...
Hello, I tryed migrate for TFTP Server from CME to CUCM 8.6(2). IP-Phone 7970 Regist Success when I try to register the IP-Phone that has been registered in the old CME to the CUCM. IP-Phone's Firmware is Migrate to Firmware Release 9.2(3). But, Regi...
Hi, We have 4 overseas Location including HO. Lets Name is HO Location – A & rest of branch location is B, C & D B, C & D are connected with A via Site to site VPN (IPSec Tunnel) over internet as a star topology. If B wants to reach C then its conne...
Hello: I have a CUBE enterprise, and I need add a carried-id field in incomming dial-peer but I don't know. I had configured the following dial-peer:   dial-peer voice 51 voip  description ### LLAMADA ORIGEN INTEROUTE MEXICO ###  translation-profil...
Normal an agent only has  DN on line 1 which is their ACD line however there may be a need to have the following Scenario ALine 1 ACDLine 2 Non ACD Scenario BLine 1 Non ACDLine 2 ACD How does UCCX react If the agent is on an active Line 2 call with S...
iptuser55 by Level 6
  • 1390 Views
  • 7 replies
