03-14-2012 11:57 AM - edited 03-16-2019 10:07 AM
We are currently running CUCM, CUCCX (premium), and Unity 7.0. Our servers are going EOL in the next couple of months and we are looking to move our systems to a virtual environment and upgrade everything to 8.6. I realize we will have to switch to Unity Connection.
I was wondering if anyone could suggest the best route to go on how to get to our end result. The servers that we have now won't support any software later than 7.0. They are Cisco MCS 7825 I2's
Thanks for the advice.
03-14-2012 12:06 PM
Hi Greyson,
Do you will install the 8.6 into the VMWARE environment?
03-14-2012 12:07 PM
That is correct. We will be installing in VMWARE environment.
03-14-2012 07:17 PM
HI
1) Tahe COBRAS back of UNity
2) Install CUC in Vmware
3) Import COBRAS
Detailed steps are in below link.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/upgrade/guide/8xcucrug022.html
Ronak Patel
Please rate helpfull posts.
03-14-2012 07:47 PM
Even though version 7 is not supported in ESXi, i have been successful installing 7.X in ESXi and then upgrading to 8.X as you really have no other options with unsupported server.
As to UCON upgrade as recommaded by Ronak use COBRAS tool.
HTH,
Chris
03-15-2012 05:26 AM
Chris, When you say you have been successful in installing 7.X in ESXi are you talking about CUCM or CUCCX or both?
Thanks for help.
03-15-2012 06:37 AM
Both.
HTH,
Chris
03-15-2012 06:47 AM
Thanks for this info! I hope this works!
