11-01-2013 11:36 AM - edited 03-16-2019 08:11 PM
My boss has come to me and wants better voice quality when making calls within our group. He indicated that we should sound like we are in the same room when calling each other.
For a little more info - We have 10 phones up that are on the same switch. I have the phones on the latest available code.I have looked in CM and the phones look to be on G711ulaw. Since that option is greyed out for changing to anything else, I will assume that this option cant be changed.
I have looked and dont see another codec that can give us even better sound quality. Maybe there is a setting in Call Manager 9.1.1 that can be used to help with this but I havent been able to find anything.
Wanted to check with the community before opening a case with TAC.
Ron
11-01-2013 11:42 AM
Have you enabled G722??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
11-01-2013 12:22 PM
that is my next step. Looking in Call Manager now on how to do that.
Ron
11-01-2013 01:04 PM
Hi Ronald,
On CUCM 9.1 by default G.722/G.711 should be negotiated between phones.
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
11-01-2013 01:14 PM
According to what I can find in Call Manager, it is advertising G711 and G722. i see the phone running at G711 from what I can see in the Admin settings. Trying to find a way to enable it in the phones. Not seeing anything in the Device->Phone menu so far.
11-02-2013 08:41 AM
You also need the wideband handwet for G.722.
11-01-2013 01:36 PM
Hi Ron,
Just an FYI...some users love G.722 and some hate it so if the Boss has it enabled
try disabling it and vise-versa
Two parameters in Cisco Unified Communications Manager Administration affect whether wideband is supported for this Cisco Unified Communications Manager server and/or a specific phone:
•Advertise G.722 Codec—From Cisco Unified Communications Manager Administration, choose System > Enterprise Parameters. The default value of this enterprise parameter is True, which means that all Cisco Unified IP Phone Models 9971 that are registered to this Cisco Unified Communications Manager will advertise G.722 to Cisco Unified Communications Manager. If each endpoint in the attempted call supports G.722 in its capabilities set, Cisco Unified Communications Manager will choose that codec for the call when possible.
•Advertise G.722 Codec—From Cisco Unified Communications Manager Administration, choose Device > Phone. The default value of this product-specific parameter is to use the value specified in the enterprise parameter. If you want to override this on a per-phone basis, choose Enabled or Disabled in the Advertise G.722 Codec parameter on the Product Specific Configuration area of the Phone Configuration window.
Cheers!
Rob
"Why do the best things always disappear "
- The Band
