blocking a number from being dialled outbound on H323 gateway and CUCM
carl_townshend
Hi all
I need to block a numberfrom being dialled from our cucm to the outside, for example the number is
112233445566
How would I do this on the cucm and h323 pstn gateway?
we use 9@ on cucm for outside calls
on the gateway we have some translation rules as below
voice translation-rule 101
 rule 1 /^4\(...\)$/ /594\1/
 rule 2 /^3\(...\)$/ /593\1/
 rule 3 /^6\(...\)$/ /506\1/
voice translation-profile PSTN-OUT-1-0
 translate calling 101
voice-port 0/0/0:15
 translation-profile outgoing PSTN-OUT-1-0
jonathan.salter
Level 3
Level 3
Just put a specific route pattern in CUCM for the numbers and block there.
9112233445566
Under Route Option chose Block this Pattern
Please remember to rate useful posts, click on the stars below.
R0g22
On CUCM, either a TP or a RP can be used for a call block. On the IOS, you can create a translation as follows -
rule 1 reject /112233445566/
voice translation-profile CALL-BLOCK
translated called 1
dial-peer voice X voip
call-block incoming translation-profile CALL-BLOCK
You will always have to apply the call block on an incoming dial-peer. You might need to do a "debug voip cc inout" to see the incoming dial-peer for these calls. Alternatively you can use a "show voice call status" to get the dial-peers.
