Blocking incoming calls - Unknown caller id
Need help in blocking calls that come with an unknown caller id. we would ideally like to have calls coming to a particular DID to be able to be routed to Unity to a call handler, then have an option for ex press 1 to reach user directly. I hope this would help solve the issue. Can some one suggest how I should go about it?
Dennis Mink
Not 100% sure what you are trying to achieve, do you want all inbound calls without called ID to go to a call handler and all calls that do have a caller ID to get routed to a DID number?
if you want all call to go to a call handler, just translate the whole DID number range into the extension of the call handler.
Please rate if useful.
Please remember to rate useful posts, by clicking on the stars below.
