09-30-2019 05:04 AM
I have Cisco 4431 router having NIM-2MFT-T1/E1 will this support 2 BRI line?
If yes what is the configuration should I have to do on router and Call Manager
09-30-2019 06:37 AM - edited 09-30-2019 06:38 AM
BRI lines are not supported on NIM-2MFT-T1/E1. You need either NIM-2BRI-NT/TE or NIM-4BRI-NT/TE modules.
Once you have correct interface modules, you can use below BRI configuration guide:
09-30-2019 06:59 AM
