Broadcast paging through Cisco phones
hamsterfish
Hi all,
We're currently running cucm 6.1.4, and will be upgrading to 8.0 soon.
Anyways, we are interested in setting up paging through the phones.   Apparenlty tt's available for CME, but not for CUCM.
Is this supported in 8.0?
And if not, are there any other solutions?  I heard a rumor you can use a 3rd party software product for this?  I'm all ears.
Thanks so much.
Adrian Saavedra
Level 7
Level 7
No.
Need third-party application. Search Netpro for "paging cucm". You'll find a lot of posts and good suggestions.
Hope it helps, please rate if it does.
Kind regards,
- Adrian.
You can check out the Broadcasting/Paging Cisco IP Phone 3rd party application at http://www.parsec-tech.com/index.html
We are Cisco developer partner and we have a paging application that integrate with CUCM
Let me know if you are interested
Kind Regards
Mohamed Abdallah
