Bulk Administration Tool Error
I have tried to insert phone using above BAT file. But CUCM 10.5 says
MAC Address/Device Name Error Code Error Description
38ED1855F9D6 DEVICE :: Error : 407 The Model type for the specified Product type was not found
38ED1855FA83 DEVICE :: Error : 407 The Model type for the specified Product type was not found
38ED1855FC20 DEVICE :: Error : 407 The Model type for the specified Product type was not found
38ED1855F9FC DEVICE :: Error : 407 The Model type for the specified Product type was not found
38ED1855FA7F DEVICE :: Error : 407 The Model type for the specified Product type was not found
38ED1855FA21 DEVICE :: Error : 407 The Model type for the specified Product type was not found
38ED1855FA36 DEVICE :: Error : 407 The Model type for the specified Product type was not found
38ED1855FA16 DEVICE :: Error : 407 The Model type for the specified Product type was not found
38ED1855FC0C DEVICE :: Error : 407 The Model type for the specified Product type was not found
38ED1855FA0B DEVICE :: Error : 407 The Model type for the specified Product type was not found
Result Summary :
INSERT for 0 PHONES passed.
INSERT for 10 PHONES failed.
End Time : 12/28/2015 19:11:05
Please find the attached txt file.
Rajitha
Manish Gogna
Hi Rajitha,
If you are trying to add 7821 ip phones to cucm 10.5.2 please ensure that the latest device pack for cucm 10.5.2 is installed on all cucm servers followed by a cluster reboot.
Manish
- Do rate helpful posts -
Dear Manish,
Thanks for the reply. I have added "Device Type" field and uploaded the bat file. Aslo I have added "SEP" before MAC address and it worked.
Rajitha Hettiarachchi
Good to know that, thanks for updating the post.
Manish
